root/radiance/ray/src/common/interp2d.h
Revision: 2.6
Committed: Tue Feb 12 00:18:28 2013 UTC (11 years, 4 months ago) by greg
Changes since 2.5: +9 -9 lines
Minor comment change
1 /* RCSid $Id: interp2d.h,v 2.5 2013/02/11 23:33:35 greg Exp $ */
2 /*
3 * Header for interpolation of anisotropic samples on 2-D plane.
4 *
5 * G.Ward Feb 2013
6 */
7
8 #ifndef _RAD_INTERP2D_H_
9 #define _RAD_INTERP2D_H_
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 #define NI2DSMF 0.42f /* minimal smoothing factor */
16
17 #define NI2DIR (2*4) /* # interpolation directions */
18
19 /* Data structure for interpolant */
20 typedef struct {
21 int ns; /* number of sample positions */
22 float dmin; /* minimum diameter (default=1) */
23 float smf; /* smoothing factor (def=NI2DSMF) */
24 unsigned short (*da)[NI2DIR]; /* anisotropic distances (private) */
25 float spt[1][2]; /* sample positions (extends struct) */
26 } INTERP2;
27
28 /* Allocate a new set of interpolation samples (caller assigns spt[] array) */
29 extern INTERP2 *interp2_alloc(int nsamps);
30
31 /* Resize interpolation array (caller must assign any new values) */
32 extern INTERP2 *interp2_realloc(INTERP2 *ip, int nsamps);
33
34 /* Set minimum distance under which samples will start to merge */
35 extern void interp2_spacing(INTERP2 *ip, double mind);
36
37 /* Modify smoothing parameter by the given factor */
38 extern void interp2_smooth(INTERP2 *ip, double sf);
39
40 /* Assign full set of normalized weights to interpolate the given location */
41 extern int interp2_weights(float wtv[], INTERP2 *ip, double x, double y);
42
43 /* Get normalized weights and indexes for n best samples in descending order */
44 extern int interp2_topsamp(float wt[], int si[], const int n,
45 INTERP2 *ip, double x, double y);
46 /* Free interpolant */
47 extern void interp2_free(INTERP2 *ip);
48
49 /* (Re)compute anisotropic basis function interpolant (normally automatic) */
50 extern int interp2_analyze(INTERP2 *ip);
51
52 /***************************************************************
53 * Typical use is to allocate an INTERP2 struct and assign the
54 * spt[] array with the ordered sample locations in x & y. (The
55 * actual orientation of the axes is not important so long as
56 * the application is consistent.) During interpolation, either
57 * interp2_weights() is called to obtain a normalized weighting
58 * vector for all the samples, or interp2_topsamp() is called to
59 * get the most important N samples for the specified location.
60 * The weights (and indexes in the case of interp2_topsamp)
61 * are then used as coefficients for corresponding sample
62 * values in a vector sum that interpolates the function at
63 * that location.
64 * The minimum distance between sample positions defaults to 1.0.
65 * Values spaced closer than this will be merged/averaged.
66 * The interp2_spacing() call may be used to alter this distance,
67 * causing the interpolant to be recalculated during the
68 * next call to the sampling functions.
69 * The default smoothing factor NI2DSMF provides near-optimal
70 * interpolation when well-separated values are known
71 * precisely. Increase this setting by a factor > 1
72 * with the interp2_smooth() call if greater mixing is desired.
73 * A call of interp2_smooth(ip,0) resets to the minimum
74 * default. It is not possible to "sharpen" the data.
75 **************************************************************/
76
77 #ifdef __cplusplus
78 }
79 #endif
80 #endif /* !_RAD_INTERP2D_H_ */
