root/radiance/ray/src/common/interp2d.c
Revision: 2.8
Committed: Tue Feb 12 18:13:28 2013 UTC (11 years, 3 months ago) by greg
Removed stray semicolon in interp2_realloc
2 static const char RCSid[] = "$Id: interp2d.c,v 2.7 2013/02/12 17:47:58 greg Exp $";
5 * General interpolation method for unstructured values on 2-D plane.
6 *
7 * G.Ward Feb 2013
8 */
9
10 #include "copyright.h"
11
12 /***************************************************************
13 * This is a general method for 2-D interpolation similar to
14 * radial basis functions but allowing for a good deal of local
15 * anisotropy in the point distribution. Each sample point
16 * is examined to determine the closest neighboring samples in
17 * each of NI2DIR surrounding directions. To speed this
18 * calculation, we sort the data into half-planes and apply
19 * simple tests to see which neighbor is closest in each
20 * angular slice. Once we have our approximate neighborhood
21 * for a sample, we can use it in a modified Gaussian weighting
22 * with allowing local anisotropy. Harmonic weighting is added
23 * to reduce the influence of distant neighbors. This yields a
24 * smooth interpolation regardless of how the sample points are
25 * initially distributed. Evaluation is accelerated by use of
26 * a fast approximation to the atan2(y,x) function.
27 ****************************************************************/
28
29 #include <stdio.h>
30 #include <stdlib.h>
31 #include "rtmath.h"
32 #include "interp2d.h"
33
34 #define DECODE_DIA(ip,ed) ((ip)->dmin*(1. + .5*(ed)))
35 #define ENCODE_DIA(ip,d) ((int)(2.*(d)/(ip)->dmin) - 2)
36
37 /* Sample order (private) */
38 typedef struct {
39 int si; /* sample index */
40 float dm; /* distance measure in this direction */
41 } SAMPORD;
42
43 /* Allocate a new set of interpolation samples (caller assigns spt[] array) */
44 INTERP2 *
45 interp2_alloc(int nsamps)
46 {
47 INTERP2 *nip;
48
49 if (nsamps <= 1)
50 return(NULL);
51
52 nip = (INTERP2 *)malloc(sizeof(INTERP2) + sizeof(float)*2*(nsamps-1));
53 if (nip == NULL)
54 return(NULL);
55
56 nip->ns = nsamps;
57 nip->dmin = 1; /* default minimum diameter */
58 nip->smf = NI2DSMF; /* default smoothing factor */
59 nip->da = NULL;
60 /* caller must assign spt[] array */
61 return(nip);
62 }
63
64 /* Resize interpolation array (caller must assign any new values) */
65 INTERP2 *
66 interp2_realloc(INTERP2 *ip, int nsamps)
67 {
68 if (ip == NULL)
69 return(interp2_alloc(nsamps));
70 if (nsamps <= 1) {
71 interp2_free(ip);
72 return(NULL);
73 }
74 if (nsamps == ip->ns)
75 return(ip);
76 if (ip->da != NULL) { /* will need to recompute distribution */
77 free(ip->da);
78 ip->da = NULL;
79 }
80 ip = (INTERP2 *)realloc(ip, sizeof(INTERP2)+sizeof(float)*2*(nsamps-1));
81 if (ip == NULL)
82 return(NULL);
83 ip->ns = nsamps;
84 return(ip);
85 }
86
87 /* Set minimum distance under which samples will start to merge */
88 void
89 interp2_spacing(INTERP2 *ip, double mind)
90 {
91 if (mind <= 0)
92 return;
93 if ((.998*ip->dmin <= mind) & (mind <= 1.002*ip->dmin))
94 return;
95 if (ip->da != NULL) { /* will need to recompute distribution */
96 free(ip->da);
97 ip->da = NULL;
98 }
99 ip->dmin = mind;
100 }
101
102 /* Modify smoothing parameter by the given factor */
103 void
104 interp2_smooth(INTERP2 *ip, double sf)
105 {
106 if ((ip->smf *= sf) < NI2DSMF)
107 ip->smf = NI2DSMF;
108 }
109
110 /* private call-back to sort position index */
111 static int
112 cmp_spos(const void *p1, const void *p2)
113 {
114 const SAMPORD *so1 = (const SAMPORD *)p1;
115 const SAMPORD *so2 = (const SAMPORD *)p2;
116
117 if (so1->dm > so2->dm)
118 return 1;
119 if (so1->dm < so2->dm)
120 return -1;
121 return 0;
122 }
123
124 /* private routine to order samples in a particular direction */
125 static void
126 sort_samples(SAMPORD *sord, const INTERP2 *ip, double ang)
127 {
128 const double cosd = cos(ang);
129 const double sind = sin(ang);
130 int i;
131
132 for (i = ip->ns; i--; ) {
133 sord[i].si = i;
134 sord[i].dm = cosd*ip->spt[i][0] + sind*ip->spt[i][1];
135 }
136 qsort(sord, ip->ns, sizeof(SAMPORD), &cmp_spos);
137 }
138
139 /* private routine to encode sample diameter with range checks */
140 static int
141 encode_diameter(const INTERP2 *ip, double d)
142 {
143 const int ed = ENCODE_DIA(ip, d);
144
145 if (ed <= 0)
146 return(0);
147 if (ed >= 0xffff)
148 return(0xffff);
149 return(ed);
150 }
151
152 /* (Re)compute anisotropic basis function interpolant (normally automatic) */
153 int
154 interp2_analyze(INTERP2 *ip)
155 {
156 SAMPORD *sortord;
157 int *rightrndx, *leftrndx, *endrndx;
158 int bd;
159 /* sanity checks */
160 if (ip == NULL || (ip->ns <= 1) | (ip->dmin <= 0))
161 return(0);
162 /* need to allocate? */
163 if (ip->da == NULL) {
164 ip->da = (unsigned short (*)[NI2DIR])malloc(
165 sizeof(unsigned short)*NI2DIR*ip->ns);
166 if (ip->da == NULL)
167 return(0);
168 }
169 /* get temporary arrays */
170 sortord = (SAMPORD *)malloc(sizeof(SAMPORD)*ip->ns);
171 rightrndx = (int *)malloc(sizeof(int)*ip->ns);
172 leftrndx = (int *)malloc(sizeof(int)*ip->ns);
173 endrndx = (int *)malloc(sizeof(int)*ip->ns);
174 if ((sortord == NULL) | (rightrndx == NULL) |
175 (leftrndx == NULL) | (endrndx == NULL))
176 return(0);
177 /* run through bidirections */
178 for (bd = 0; bd < NI2DIR/2; bd++) {
179 const double ang = 2.*PI/NI2DIR*bd;
180 int *sptr;
181 int i;
182 /* create right reverse index */
183 if (bd) { /* re-use from previous iteration? */
184 sptr = rightrndx;
185 rightrndx = leftrndx;
186 leftrndx = sptr;
187 } else { /* else sort first half-plane */
188 sort_samples(sortord, ip, PI/2. - PI/NI2DIR);
189 for (i = ip->ns; i--; )
190 rightrndx[sortord[i].si] = i;
191 /* & store reverse order for later */
192 for (i = ip->ns; i--; )
193 endrndx[sortord[i].si] = ip->ns-1 - i;
194 }
195 /* create new left reverse index */
196 if (bd == NI2DIR/2 - 1) { /* use order from first iteration? */
197 sptr = leftrndx;
198 leftrndx = endrndx;
199 endrndx = sptr;
200 } else { /* else compute new half-plane */
201 sort_samples(sortord, ip, ang + (PI/2. + PI/NI2DIR));
202 for (i = ip->ns; i--; )
203 leftrndx[sortord[i].si] = i;
204 }
205 /* sort grid values in this direction */
206 sort_samples(sortord, ip, ang);
207 /* find nearest neighbors each side */
208 for (i = ip->ns; i--; ) {
209 const int ii = sortord[i].si;
210 int j;
211 /* preload with large radii */
212 ip->da[ii][bd] = ip->da[ii][bd+NI2DIR/2] = encode_diameter(ip,
213 .5*(sortord[ip->ns-1].dm - sortord[0].dm));
214 for (j = i; ++j < ip->ns; ) /* nearest above */
215 if (rightrndx[sortord[j].si] > rightrndx[ii] &&
216 leftrndx[sortord[j].si] < leftrndx[ii]) {
217 ip->da[ii][bd] = encode_diameter(ip,
218 sortord[j].dm - sortord[i].dm);
219 break;
220 }
221 for (j = i; j-- > 0; ) /* nearest below */
222 if (rightrndx[sortord[j].si] < rightrndx[ii] &&
223 leftrndx[sortord[j].si] > leftrndx[ii]) {
224 ip->da[ii][bd+NI2DIR/2] = encode_diameter(ip,
225 sortord[i].dm - sortord[j].dm);
226 break;
227 }
228 }
229 }
230 free(sortord); /* clean up */
231 free(rightrndx);
232 free(leftrndx);
233 free(endrndx);
234 return(1);
235 }
236
237 /* private call returns raw weight for a particular sample */
238 static double
239 get_wt(const INTERP2 *ip, const int i, double x, double y)
240 {
241 double dir, rd, r2, d2;
242 int ri;
243 /* get relative direction */
244 x -= ip->spt[i][0];
245 y -= ip->spt[i][1];
246 dir = atan2a(y, x);
247 dir += 2.*PI*(dir < 0);
248 /* linear radius interpolation */
249 rd = dir * (NI2DIR/2./PI);
250 ri = (int)rd;
251 rd -= (double)ri;
252 rd = (1.-rd)*ip->da[i][ri] + rd*ip->da[i][(ri+1)%NI2DIR];
253 rd = ip->smf * DECODE_DIA(ip, rd);
254 r2 = 2.*rd*rd;
255 d2 = x*x + y*y;
256 if (d2 > 21.*r2) /* result would be < 1e-9 */
257 return(.0);
258 /* Gaussian times harmonic weighting */
259 return( exp(-d2/r2) * ip->dmin/(ip->dmin + sqrt(d2)) );
260 }
261
262 /* Assign full set of normalized weights to interpolate the given position */
263 int
264 interp2_weights(float wtv[], INTERP2 *ip, double x, double y)
265 {
266 double wnorm;
267 int i;
268
269 if ((wtv == NULL) | (ip == NULL))
270 return(0);
271 /* need to compute interpolant? */
272 if (ip->da == NULL && !interp2_analyze(ip))
273 return(0);
274
275 wnorm = 0; /* compute raw weights */
276 for (i = ip->ns; i--; ) {
277 double wt = get_wt(ip, i, x, y);
278 wtv[i] = wt;
279 wnorm += wt;
280 }
281 if (wnorm <= 0) /* too far from all our samples! */
282 return(0);
283 wnorm = 1./wnorm; /* normalize weights */
284 for (i = ip->ns; i--; )
285 wtv[i] *= wnorm;
286 return(ip->ns); /* all done */
287 }
288
289
290 /* Get normalized weights and indexes for n best samples in descending order */
291 int
292 interp2_topsamp(float wt[], int si[], const int n, INTERP2 *ip, double x, double y)
293 {
294 int nn = 0;
295 double wnorm;
296 int i, j;
297
298 if ((n <= 0) | (wt == NULL) | (si == NULL) | (ip == NULL))
299 return(0);
300 /* need to compute interpolant? */
301 if (ip->da == NULL && !interp2_analyze(ip))
302 return(0);
303 /* identify top n weights */
304 for (i = ip->ns; i--; ) {
305 const double wti = get_wt(ip, i, x, y);
306 for (j = nn; j > 0; j--) {
307 if (wt[j-1] >= wti)
308 break;
309 if (j < n) {
310 wt[j] = wt[j-1];
311 si[j] = si[j-1];
312 }
313 }
314 if (j < n) { /* add/insert sample */
315 wt[j] = wti;
316 si[j] = i;
317 nn += (nn < n);
318 }
319 }
320 wnorm = 0; /* normalize sample weights */
321 for (j = nn; j--; )
322 wnorm += wt[j];
323 if (wnorm <= 0)
324 return(0);
325 wnorm = 1./wnorm;
326 for (j = nn; j--; )
327 wt[j] *= wnorm;
328 return(nn); /* return actual # samples */
329 }
330
331 /* Free interpolant */
332 void
333 interp2_free(INTERP2 *ip)
334 {
335 if (ip == NULL)
336 return;
337 if (ip->da != NULL)
338 free(ip->da);
339 free(ip);
340 }
