1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: interp2d.c,v 2.6 2013/02/12 02:56:05 greg Exp $"; |
3 |
#endif |
4 |
5 |
* General interpolation method for unstructured values on 2-D plane. |
6 |
7 |
* G.Ward Feb 2013 |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
13 |
* This is a general method for 2-D interpolation similar to |
14 |
* radial basis functions but allowing for a good deal of local |
15 |
* anisotropy in the point distribution. Each sample point |
16 |
* is examined to determine the closest neighboring samples in |
17 |
* each of NI2DIR surrounding directions. To speed this |
18 |
* calculation, we sort the data into half-planes and apply |
19 |
* simple tests to see which neighbor is closest in each |
20 |
* angular slice. Once we have our approximate neighborhood |
21 |
* for a sample, we can use it in a modified Gaussian weighting |
22 |
* with allowing local anisotropy. Harmonic weighting is added |
23 |
* to reduce the influence of distant neighbors. This yields a |
24 |
* smooth interpolation regardless of how the sample points are |
25 |
* initially distributed. Evaluation is accelerated by use of |
26 |
* a fast approximation to the atan2(y,x) function. |
27 |
28 |
29 |
#include <stdio.h> |
30 |
#include <stdlib.h> |
31 |
#include "rtmath.h" |
32 |
#include "interp2d.h" |
33 |
34 |
#define DECODE_DIA(ip,ed) ((ip)->dmin*(1. + .5*(ed))) |
35 |
#define ENCODE_DIA(ip,d) ((int)(2.*(d)/(ip)->dmin) - 2) |
36 |
37 |
/* Sample order (private) */ |
38 |
typedef struct { |
39 |
int si; /* sample index */ |
40 |
float dm; /* distance measure in this direction */ |
41 |
} SAMPORD; |
42 |
43 |
/* Allocate a new set of interpolation samples (caller assigns spt[] array) */ |
44 |
INTERP2 * |
45 |
interp2_alloc(int nsamps) |
46 |
47 |
INTERP2 *nip; |
48 |
49 |
if (nsamps <= 1) |
50 |
return(NULL); |
51 |
52 |
nip = (INTERP2 *)malloc(sizeof(INTERP2) + sizeof(float)*2*(nsamps-1)); |
53 |
if (nip == NULL) |
54 |
return(NULL); |
55 |
56 |
nip->ns = nsamps; |
57 |
nip->dmin = 1; /* default minimum diameter */ |
58 |
nip->smf = NI2DSMF; /* default smoothing factor */ |
59 |
nip->da = NULL; |
60 |
/* caller must assign spt[] array */ |
61 |
return(nip); |
62 |
63 |
64 |
/* Resize interpolation array (caller must assign any new values) */ |
65 |
INTERP2 * |
66 |
interp2_realloc(INTERP2 *ip, int nsamps) |
67 |
68 |
if (ip == NULL) |
69 |
return(interp2_alloc(nsamps)); |
70 |
if (nsamps <= 1) { |
71 |
interp2_free(ip); |
72 |
return(NULL); |
73 |
74 |
if (nsamps == ip->ns); |
75 |
return(ip); |
76 |
if (ip->da != NULL) { /* will need to recompute distribution */ |
77 |
free(ip->da); |
78 |
ip->da = NULL; |
79 |
80 |
ip = (INTERP2 *)realloc(ip, sizeof(INTERP2)+sizeof(float)*2*(nsamps-1)); |
81 |
if (ip == NULL) |
82 |
return(NULL); |
83 |
ip->ns = nsamps; |
84 |
return(ip); |
85 |
86 |
87 |
/* Set minimum distance under which samples will start to merge */ |
88 |
void |
89 |
interp2_spacing(INTERP2 *ip, double mind) |
90 |
91 |
if (mind <= 0) |
92 |
return; |
93 |
if ((.998*ip->dmin <= mind) & (mind <= 1.002*ip->dmin)) |
94 |
return; |
95 |
96 |
free(ip->da); |
97 |
ip->da = NULL; |
98 |
99 |
ip->dmin = mind; |
100 |
101 |
102 |
/* Modify smoothing parameter by the given factor */ |
103 |
void |
104 |
interp2_smooth(INTERP2 *ip, double sf) |
105 |
106 |
if ((ip->smf *= sf) < NI2DSMF) |
107 |
ip->smf = NI2DSMF; |
108 |
109 |
110 |
/* private call-back to sort position index */ |
111 |
static int |
112 |
cmp_spos(const void *p1, const void *p2) |
113 |
114 |
const SAMPORD *so1 = (const SAMPORD *)p1; |
115 |
const SAMPORD *so2 = (const SAMPORD *)p2; |
116 |
117 |
if (so1->dm > so2->dm) |
118 |
return 1; |
119 |
if (so1->dm < so2->dm) |
120 |
return -1; |
121 |
return 0; |
122 |
123 |
124 |
/* private routine to order samples in a particular direction */ |
125 |
static void |
126 |
sort_samples(SAMPORD *sord, const INTERP2 *ip, double ang) |
127 |
128 |
const double cosd = cos(ang); |
129 |
const double sind = sin(ang); |
130 |
int i; |
131 |
132 |
for (i = ip->ns; i--; ) { |
133 |
sord[i].si = i; |
134 |
sord[i].dm = cosd*ip->spt[i][0] + sind*ip->spt[i][1]; |
135 |
136 |
qsort(sord, ip->ns, sizeof(SAMPORD), &cmp_spos); |
137 |
138 |
139 |
/* private routine to encode sample diameter with range checks */ |
140 |
static int |
141 |
encode_diameter(const INTERP2 *ip, double d) |
142 |
143 |
const int ed = ENCODE_DIA(ip, d); |
144 |
145 |
if (ed <= 0) |
146 |
return(0); |
147 |
if (ed >= 0xffff) |
148 |
return(0xffff); |
149 |
return(ed); |
150 |
151 |
152 |
/* (Re)compute anisotropic basis function interpolant (normally automatic) */ |
153 |
int |
154 |
interp2_analyze(INTERP2 *ip) |
155 |
156 |
SAMPORD *sortord; |
157 |
int *rightrndx, *leftrndx, *endrndx; |
158 |
int bd; |
159 |
/* sanity checks */ |
160 |
if (ip == NULL || (ip->ns <= 1) | (ip->dmin <= 0)) |
161 |
return(0); |
162 |
/* need to allocate? */ |
163 |
if (ip->da == NULL) { |
164 |
ip->da = (unsigned short (*)[NI2DIR])malloc( |
165 |
sizeof(unsigned short)*NI2DIR*ip->ns); |
166 |
if (ip->da == NULL) |
167 |
return(0); |
168 |
169 |
/* get temporary arrays */ |
170 |
sortord = (SAMPORD *)malloc(sizeof(SAMPORD)*ip->ns); |
171 |
rightrndx = (int *)malloc(sizeof(int)*ip->ns); |
172 |
leftrndx = (int *)malloc(sizeof(int)*ip->ns); |
173 |
endrndx = (int *)malloc(sizeof(int)*ip->ns); |
174 |
if ((sortord == NULL) | (rightrndx == NULL) | |
175 |
(leftrndx == NULL) | (endrndx == NULL)) |
176 |
return(0); |
177 |
/* run through bidirections */ |
178 |
for (bd = 0; bd < NI2DIR/2; bd++) { |
179 |
const double ang = 2.*PI/NI2DIR*bd; |
180 |
int *sptr; |
181 |
int i; |
182 |
/* create right reverse index */ |
183 |
if (bd) { /* re-use from previous iteration? */ |
184 |
sptr = rightrndx; |
185 |
rightrndx = leftrndx; |
186 |
leftrndx = sptr; |
187 |
} else { /* else sort first half-plane */ |
188 |
sort_samples(sortord, ip, PI/2. - PI/NI2DIR); |
189 |
for (i = ip->ns; i--; ) |
190 |
rightrndx[sortord[i].si] = i; |
191 |
/* & store reverse order for later */ |
192 |
193 |
endrndx[sortord[i].si] = ip->ns-1 - i; |
194 |
195 |
/* create new left reverse index */ |
196 |
if (bd == NI2DIR/2 - 1) { /* use order from first iteration? */ |
197 |
sptr = leftrndx; |
198 |
leftrndx = endrndx; |
199 |
endrndx = sptr; |
200 |
} else { /* else compute new half-plane */ |
201 |
sort_samples(sortord, ip, ang + (PI/2. + PI/NI2DIR)); |
202 |
203 |
leftrndx[sortord[i].si] = i; |
204 |
205 |
/* sort grid values in this direction */ |
206 |
sort_samples(sortord, ip, ang); |
207 |
/* find nearest neighbors each side */ |
208 |
209 |
const int ii = sortord[i].si; |
210 |
int j; |
211 |
/* preload with large radii */ |
212 |
ip->da[ii][bd] = ip->da[ii][bd+NI2DIR/2] = encode_diameter(ip, |
213 |
.5*(sortord[ip->ns-1].dm - sortord[0].dm)); |
214 |
for (j = i; ++j < ip->ns; ) /* nearest above */ |
215 |
if (rightrndx[sortord[j].si] > rightrndx[ii] && |
216 |
leftrndx[sortord[j].si] < leftrndx[ii]) { |
217 |
ip->da[ii][bd] = encode_diameter(ip, |
218 |
sortord[j].dm - sortord[i].dm); |
219 |
break; |
220 |
221 |
for (j = i; j-- > 0; ) /* nearest below */ |
222 |
if (rightrndx[sortord[j].si] < rightrndx[ii] && |
223 |
leftrndx[sortord[j].si] > leftrndx[ii]) { |
224 |
225 |
sortord[i].dm - sortord[j].dm); |
226 |
break; |
227 |
228 |
229 |
230 |
free(sortord); /* clean up */ |
231 |
free(rightrndx); |
232 |
free(leftrndx); |
233 |
free(endrndx); |
234 |
return(1); |
235 |
236 |
237 |
/* private call returns raw weight for a particular sample */ |
238 |
static double |
239 |
get_wt(const INTERP2 *ip, const int i, double x, double y) |
240 |
241 |
double dir, rd, r2, d2; |
242 |
int ri; |
243 |
/* get relative direction */ |
244 |
x -= ip->spt[i][0]; |
245 |
y -= ip->spt[i][1]; |
246 |
dir = atan2a(y, x); |
247 |
dir += 2.*PI*(dir < 0); |
248 |
/* linear radius interpolation */ |
249 |
rd = dir * (NI2DIR/2./PI); |
250 |
ri = (int)rd; |
251 |
rd -= (double)ri; |
252 |
rd = (1.-rd)*ip->da[i][ri] + rd*ip->da[i][(ri+1)%NI2DIR]; |
253 |
rd = ip->smf * DECODE_DIA(ip, rd); |
254 |
r2 = 2.*rd*rd; |
255 |
d2 = x*x + y*y; |
256 |
if (d2 > 21.*r2) /* result would be < 1e-9 */ |
257 |
return(.0); |
258 |
/* Gaussian times harmonic weighting */ |
259 |
return( exp(-d2/r2) * ip->dmin/(ip->dmin + sqrt(d2)) ); |
260 |
261 |
262 |
/* Assign full set of normalized weights to interpolate the given position */ |
263 |
int |
264 |
interp2_weights(float wtv[], INTERP2 *ip, double x, double y) |
265 |
266 |
double wnorm; |
267 |
int i; |
268 |
269 |
if ((wtv == NULL) | (ip == NULL)) |
270 |
return(0); |
271 |
/* need to compute interpolant? */ |
272 |
if (ip->da == NULL && !interp2_analyze(ip)) |
273 |
return(0); |
274 |
275 |
wnorm = 0; /* compute raw weights */ |
276 |
277 |
double wt = get_wt(ip, i, x, y); |
278 |
wtv[i] = wt; |
279 |
wnorm += wt; |
280 |
281 |
if (wnorm <= 0) /* too far from all our samples! */ |
282 |
return(0); |
283 |
wnorm = 1./wnorm; /* normalize weights */ |
284 |
285 |
wtv[i] *= wnorm; |
286 |
return(ip->ns); /* all done */ |
287 |
288 |
289 |
290 |
/* Get normalized weights and indexes for n best samples in descending order */ |
291 |
int |
292 |
interp2_topsamp(float wt[], int si[], const int n, INTERP2 *ip, double x, double y) |
293 |
294 |
int nn = 0; |
295 |
double wnorm; |
296 |
int i, j; |
297 |
298 |
if ((n <= 0) | (wt == NULL) | (si == NULL) | (ip == NULL)) |
299 |
return(0); |
300 |
301 |
302 |
return(0); |
303 |
/* identify top n weights */ |
304 |
305 |
const double wti = get_wt(ip, i, x, y); |
306 |
for (j = nn; j > 0; j--) { |
307 |
if (wt[j-1] >= wti) |
308 |
break; |
309 |
if (j < n) { |
310 |
wt[j] = wt[j-1]; |
311 |
si[j] = si[j-1]; |
312 |
313 |
314 |
if (j < n) { /* add/insert sample */ |
315 |
wt[j] = wti; |
316 |
si[j] = i; |
317 |
nn += (nn < n); |
318 |
319 |
320 |
wnorm = 0; /* normalize sample weights */ |
321 |
for (j = nn; j--; ) |
322 |
wnorm += wt[j]; |
323 |
if (wnorm <= 0) |
324 |
return(0); |
325 |
wnorm = 1./wnorm; |
326 |
327 |
wt[j] *= wnorm; |
328 |
return(nn); /* return actual # samples */ |
329 |
330 |
331 |
/* Free interpolant */ |
332 |
void |
333 |
interp2_free(INTERP2 *ip) |
334 |
335 |
if (ip == NULL) |
336 |
return; |
337 |
if (ip->da != NULL) |
338 |
free(ip->da); |
339 |
free(ip); |
340 |
