root/radiance/ray/src/common/interp2d.c
Fri Mar 19 21:16:15 2021 UTC (4 years, 2 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.16: +5 -3 lines
Diff to previous 2.16 , to selected 2.5
fix: free memory on failure
Thu Mar 11 01:58:59 2021 UTC (4 years, 2 months ago) by greg
Changes since 2.15: +9 -3 lines
Diff to previous 2.15 , to selected 2.5
perf: made it so interp2_realloc() will never fail if reducing array size
Sat Feb 13 16:49:18 2021 UTC (4 years, 3 months ago) by greg
feat: added client data pointer for caller convenience
Fri Jun 6 00:56:42 2014 UTC (10 years, 11 months ago) by greg
Removed address operator not needed for function pointer
Sat Feb 16 00:41:12 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.12: +84 -65 lines
Need to recompute influence maps after changing smoothing parameter
Fri Feb 15 19:15:16 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.11: +116 -99 lines
Changed from blkflg to influence flag array
Fri Feb 15 01:26:47 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.10: +88 -48 lines
Additional tweaks -- now 11 times faster than original version
Thu Feb 14 19:57:10 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.9: +74 -32 lines
Doubled calculation speed and exposed raw weight computation
Tue Feb 12 18:41:39 2013 UTC (12 years, 3 months ago) by greg
Minor improvement
Tue Feb 12 18:13:28 2013 UTC (12 years, 3 months ago) by greg
Removed stray semicolon in interp2_realloc
Tue Feb 12 17:47:58 2013 UTC (12 years, 3 months ago) by greg
Really minor tweaks
Tue Feb 12 02:56:05 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.5: +6 -3 lines
Significant speed improvement
Mon Feb 11 23:33:35 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.4: +24 -1 lines
Added accessor functions for minimum spacing and smoothing parameters
Mon Feb 11 22:56:22 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.3: +39 -39 lines
Changed radius specification to diameter and added usage comment
Mon Feb 11 20:01:15 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.2: +29 -36 lines
Fixed a number of serious bugs in initial implementation
Sat Feb 9 17:39:21 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.1: +69 -37 lines
Added interp2_realloc() call, exposed interp2_analyze() and code improvements
Sat Feb 9 00:55:40 2013 UTC (12 years, 3 months ago) by greg
Diff to selected 2.5
Created routines for interpolating anisotropic 2-D samples
