--- ray/src/common/interp2d.c 2013/02/15 19:15:16 2.12 +++ ray/src/common/interp2d.c 2013/02/16 00:41:12 2.13 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: interp2d.c,v 2.12 2013/02/15 19:15:16 greg Exp $"; +static const char RCSid[] = "$Id: interp2d.c,v 2.13 2013/02/16 00:41:12 greg Exp $"; #endif /* * General interpolation method for unstructured values on 2-D plane. @@ -23,8 +23,8 @@ static const char RCSid[] = "$Id: interp2d.c,v 2.12 20 * to reduce the influence of distant neighbors. This yields a * smooth interpolation regardless of how the sample points are * initially distributed. Evaluation is accelerated by use of - * a fast approximation to the atan2(y,x) function and an array - * of flags indicating where weights are (nearly) zero. + * a fast approximation to the atan2(y,x) function and a low-res + * map indicating where sample weights are significant. ****************************************************************/ #include @@ -41,6 +41,19 @@ typedef struct { float dm; /* distance measure in this direction */ } SAMPORD; +/* private routine to encode sample diameter with range checks */ +static int +encode_diameter(const INTERP2 *ip, double d) +{ + const int ed = ENCODE_DIA(ip, d); + + if (ed <= 0) + return(0); + if (ed >= 0xffff) + return(0xffff); + return(ed); +} + /* Allocate a new set of interpolation samples (caller assigns spt[] array) */ INTERP2 * interp2_alloc(int nsamps) @@ -100,56 +113,6 @@ interp2_spacing(INTERP2 *ip, double mind) ip->dmin = mind; } -/* Modify smoothing parameter by the given factor */ -void -interp2_smooth(INTERP2 *ip, double sf) -{ - if ((ip->smf *= sf) < NI2DSMF) - ip->smf = NI2DSMF; -} - -/* private call-back to sort position index */ -static int -cmp_spos(const void *p1, const void *p2) -{ - const SAMPORD *so1 = (const SAMPORD *)p1; - const SAMPORD *so2 = (const SAMPORD *)p2; - - if (so1->dm > so2->dm) - return 1; - if (so1->dm < so2->dm) - return -1; - return 0; -} - -/* private routine to order samples in a particular direction */ -static void -sort_samples(SAMPORD *sord, const INTERP2 *ip, double ang) -{ - const double cosd = cos(ang); - const double sind = sin(ang); - int i; - - for (i = ip->ns; i--; ) { - sord[i].si = i; - sord[i].dm = cosd*ip->spt[i][0] + sind*ip->spt[i][1]; - } - qsort(sord, ip->ns, sizeof(SAMPORD), &cmp_spos); -} - -/* private routine to encode sample diameter with range checks */ -static int -encode_diameter(const INTERP2 *ip, double d) -{ - const int ed = ENCODE_DIA(ip, d); - - if (ed <= 0) - return(0); - if (ed >= 0xffff) - return(0xffff); - return(ed); -} - /* Compute unnormalized weight for a position relative to a sample */ double interp2_wti(INTERP2 *ip, const int i, double x, double y) @@ -244,13 +207,75 @@ influence_flood(INTERP2 *ip, const int i, unsigned sho influence_flood(ip, i, visited, xfi, yfi+1); } +/* private call to compute sample influence maps */ +static void +map_influence(INTERP2 *ip) +{ + unsigned short visited[NI2DIM]; + int fgi[2]; + int i, j; + + for (i = ip->ns; i--; ) { + for (j = NI2DIM; j--; ) { + ip->da[i].infl[j] = 0; + visited[j] = 0; + } + interp2_flagpos(fgi, ip, ip->spt[i][0], ip->spt[i][1]); + + influence_flood(ip, i, visited, fgi[0], fgi[1]); + } +} + +/* Modify smoothing parameter by the given factor */ +void +interp2_smooth(INTERP2 *ip, double sf) +{ + float old_smf = ip->smf; + + if ((ip->smf *= sf) < NI2DSMF) + ip->smf = NI2DSMF; + /* need to recompute influence maps? */ + if (ip->da != NULL && (old_smf*.85 > ip->smf) | + (ip->smf > old_smf*1.15)) + map_influence(ip); +} + +/* private call-back to sort position index */ +static int +cmp_spos(const void *p1, const void *p2) +{ + const SAMPORD *so1 = (const SAMPORD *)p1; + const SAMPORD *so2 = (const SAMPORD *)p2; + + if (so1->dm > so2->dm) + return 1; + if (so1->dm < so2->dm) + return -1; + return 0; +} + +/* private routine to order samples in a particular direction */ +static void +sort_samples(SAMPORD *sord, const INTERP2 *ip, double ang) +{ + const double cosd = cos(ang); + const double sind = sin(ang); + int i; + + for (i = ip->ns; i--; ) { + sord[i].si = i; + sord[i].dm = cosd*ip->spt[i][0] + sind*ip->spt[i][1]; + } + qsort(sord, ip->ns, sizeof(SAMPORD), &cmp_spos); +} + /* (Re)compute anisotropic basis function interpolant (normally automatic) */ int interp2_analyze(INTERP2 *ip) { SAMPORD *sortord; int *rightrndx, *leftrndx, *endrndx; - int i, j, bd; + int i, bd; /* sanity checks */ if (ip == NULL) return(0); @@ -275,8 +300,8 @@ interp2_analyze(INTERP2 *ip) if (ip->grid2 <= FTINY*ip->dmin*ip->dmin) return(0); /* allocate analysis data */ - ip->da = (struct interp2_samp *)calloc( ip->ns, - sizeof(struct interp2_samp) ); + ip->da = (struct interp2_samp *)malloc( + sizeof(struct interp2_samp)*ip->ns ); if (ip->da == NULL) return(0); /* allocate temporary arrays */ @@ -319,6 +344,7 @@ interp2_analyze(INTERP2 *ip) /* find nearest neighbors each side */ for (i = ip->ns; i--; ) { const int ii = sortord[i].si; + int j; /* preload with large radii */ ip->da[ii].dia[bd] = ip->da[ii].dia[bd+NI2DIR/2] = encode_diameter(ip, @@ -343,15 +369,8 @@ interp2_analyze(INTERP2 *ip) free(rightrndx); free(leftrndx); free(endrndx); - /* fill influence maps */ - for (i = ip->ns; i--; ) { - unsigned short visited[NI2DIM]; - int fgi[2]; - - for (j = NI2DIM; j--; ) visited[j] = 0; - interp2_flagpos(fgi, ip, ip->spt[i][0], ip->spt[i][1]); - influence_flood(ip, i, visited, fgi[0], fgi[1]); - } + /* map sample influence areas */ + map_influence(ip); return(1); /* all done */ }
