--- ray/src/common/interp2d.c 2013/02/09 17:39:21 2.2 +++ ray/src/common/interp2d.c 2013/02/11 20:01:15 2.3 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: interp2d.c,v 2.2 2013/02/09 17:39:21 greg Exp $"; +static const char RCSid[] = "$Id: interp2d.c,v 2.3 2013/02/11 20:01:15 greg Exp $"; #endif /* * General interpolation method for unstructured values on 2-D plane. @@ -18,11 +18,12 @@ static const char RCSid[] = "$Id: interp2d.c,v 2.2 201 * calculation, we sort the data into 3 half-planes and * perform simple tests to see which neighbor is closest in * a each direction. Once we have our approximate neighborhood - * for a sample, we can use it in a Gaussian weighting scheme - * with anisotropic surround. This gives us a fairly smooth - * interpolation however the sample points may be initially - * distributed. Evaluation is accelerated by use of a fast - * approximation to the atan2(y,x) function. + * for a sample, we can use it in a modified Gaussian weighting + * scheme with anisotropic surround. Harmonic weighting is added + * to reduce the influence of distant neighbors. This yields a + * smooth interpolation regardless of how the sample points are + * initiallydistributed. Evaluation is accelerated by use of a + * fast approximation to the atan2(y,x) function. **************************************************************/ #include @@ -182,23 +183,22 @@ interp2_analyze(INTERP2 *ip) sort_samples(sortord, ip, ang); /* find nearest neighbors each side */ for (i = ip->ns; i--; ) { - const int rpos = rightrndx[sortord[i].si]; - const int lpos = leftrndx[sortord[i].si]; + const int ii = sortord[i].si; int j; - /* preload with large radius */ - ip->ra[i][bd] = ip->ra[i][bd+NI2DIR/2] = encode_radius(ip, + /* preload with large radii */ + ip->ra[ii][bd] = ip->ra[ii][bd+NI2DIR/2] = encode_radius(ip, .25*(sortord[ip->ns-1].dm - sortord[0].dm)); for (j = i; ++j < ip->ns; ) /* nearest above */ - if (rightrndx[sortord[j].si] > rpos && - leftrndx[sortord[j].si] < lpos) { - ip->ra[i][bd] = encode_radius(ip, + if (rightrndx[sortord[j].si] > rightrndx[ii] && + leftrndx[sortord[j].si] < leftrndx[ii]) { + ip->ra[ii][bd] = encode_radius(ip, .5*(sortord[j].dm - sortord[i].dm)); break; } for (j = i; j-- > 0; ) /* nearest below */ - if (rightrndx[sortord[j].si] < rpos && - leftrndx[sortord[j].si] > lpos) { - ip->ra[i][bd+NI2DIR/2] = encode_radius(ip, + if (rightrndx[sortord[j].si] < rightrndx[ii] && + leftrndx[sortord[j].si] > leftrndx[ii]) { + ip->ra[ii][bd+NI2DIR/2] = encode_radius(ip, .5*(sortord[i].dm - sortord[j].dm)); break; } @@ -211,11 +211,11 @@ interp2_analyze(INTERP2 *ip) return(1); } -/* private call returns log of raw weight for a particular sample */ +/* private call returns raw weight for a particular sample */ static double -get_ln_wt(const INTERP2 *ip, const int i, double x, double y) +get_wt(const INTERP2 *ip, const int i, double x, double y) { - double dir, rd; + double dir, rd, d2; int ri; /* get relative direction */ x -= ip->spt[i][0]; @@ -228,8 +228,9 @@ get_ln_wt(const INTERP2 *ip, const int i, double x, do rd -= (double)ri; rd = (1.-rd)*ip->ra[i][ri] + rd*ip->ra[i][(ri+1)%NI2DIR]; rd = ip->smf * DECODE_RAD(ip, rd); - /* return log of Gaussian weight */ - return( (x*x + y*y) / (-2.*rd*rd) ); + d2 = x*x + y*y; + /* Gaussian times harmonic weighting */ + return( exp(d2/(-2.*rd*rd)) * ip->rmin/(ip->rmin + sqrt(d2)) ); } /* Assign full set of normalized weights to interpolate the given position */ @@ -247,12 +248,7 @@ interp2_weights(float wtv[], INTERP2 *ip, double x, do wnorm = 0; /* compute raw weights */ for (i = ip->ns; i--; ) { - double wt = get_ln_wt(ip, i, x, y); - if (wt < -21.) { - wtv[i] = 0; /* ignore weights < 1e-9 */ - continue; - } - wt = exp(wt); /* Gaussian weight */ + double wt = get_wt(ip, i, x, y); wtv[i] = wt; wnorm += wt; } @@ -280,9 +276,9 @@ interp2_topsamp(float wt[], int si[], const int n, INT return(0); /* identify top n weights */ for (i = ip->ns; i--; ) { - const double lnwt = get_ln_wt(ip, i, x, y); + const double wti = get_wt(ip, i, x, y); for (j = nn; j > 0; j--) { - if (wt[j-1] >= lnwt) + if (wt[j-1] >= wti) break; if (j < n) { wt[j] = wt[j-1]; @@ -290,17 +286,14 @@ interp2_topsamp(float wt[], int si[], const int n, INT } } if (j < n) { /* add/insert sample */ - wt[j] = lnwt; + wt[j] = wti; si[j] = i; nn += (nn < n); } } - wnorm = 0; /* exponentiate and normalize */ - for (j = nn; j--; ) { - double dwt = exp(wt[j]); - wt[j] = dwt; - wnorm += dwt; - } + wnorm = 0; /* normalize sample weights */ + for (j = nn; j--; ) + wnorm += wt[j]; if (wnorm <= 0) return(0); wnorm = 1./wnorm;
