| 1 |
greg |
2.1 |
#ifndef lint
| 2 |
greg |
2.14 |
static const char RCSid[] = "$Id: interp2d.c,v 2.13 2013/02/16 00:41:12 greg Exp $";
| 3 |
greg |
2.1 |
#endif
| 4 |
| 5 |
* General interpolation method for unstructured values on 2-D plane.
| 6 |
| 7 |
* G.Ward Feb 2013
| 8 |
| 9 |
| 10 |
#include "copyright.h"
| 11 |
| 12 |
greg |
2.4 |
| 13 |
greg |
2.1 |
* This is a general method for 2-D interpolation similar to
| 14 |
* radial basis functions but allowing for a good deal of local
| 15 |
* anisotropy in the point distribution. Each sample point
| 16 |
* is examined to determine the closest neighboring samples in
| 17 |
* each of NI2DIR surrounding directions. To speed this
| 18 |
greg |
2.4 |
* calculation, we sort the data into half-planes and apply
| 19 |
* simple tests to see which neighbor is closest in each
| 20 |
greg |
2.7 |
* angular slice. Once we have our approximate neighborhood
| 21 |
greg |
2.3 |
* for a sample, we can use it in a modified Gaussian weighting
| 22 |
greg |
2.4 |
* with allowing local anisotropy. Harmonic weighting is added
| 23 |
greg |
2.3 |
* to reduce the influence of distant neighbors. This yields a
| 24 |
* smooth interpolation regardless of how the sample points are
| 25 |
greg |
2.4 |
* initially distributed. Evaluation is accelerated by use of
| 26 |
greg |
2.13 |
* a fast approximation to the atan2(y,x) function and a low-res
| 27 |
* map indicating where sample weights are significant.
| 28 |
greg |
2.4 |
| 29 |
greg |
2.1 |
| 30 |
#include <stdio.h>
| 31 |
#include <stdlib.h>
| 32 |
#include "rtmath.h"
| 33 |
#include "interp2d.h"
| 34 |
| 35 |
greg |
2.4 |
#define DECODE_DIA(ip,ed) ((ip)->dmin*(1. + .5*(ed)))
| 36 |
#define ENCODE_DIA(ip,d) ((int)(2.*(d)/(ip)->dmin) - 2)
| 37 |
greg |
2.1 |
| 38 |
/* Sample order (private) */
| 39 |
typedef struct {
| 40 |
int si; /* sample index */
| 41 |
float dm; /* distance measure in this direction */
| 42 |
} SAMPORD;
| 43 |
| 44 |
greg |
2.13 |
/* private routine to encode sample diameter with range checks */
| 45 |
static int
| 46 |
encode_diameter(const INTERP2 *ip, double d)
| 47 |
| 48 |
const int ed = ENCODE_DIA(ip, d);
| 49 |
| 50 |
if (ed <= 0)
| 51 |
return(0);
| 52 |
if (ed >= 0xffff)
| 53 |
return(0xffff);
| 54 |
return(ed);
| 55 |
| 56 |
| 57 |
greg |
2.2 |
/* Allocate a new set of interpolation samples (caller assigns spt[] array) */
| 58 |
greg |
2.1 |
INTERP2 *
| 59 |
interp2_alloc(int nsamps)
| 60 |
| 61 |
INTERP2 *nip;
| 62 |
| 63 |
if (nsamps <= 1)
| 64 |
return(NULL);
| 65 |
| 66 |
nip = (INTERP2 *)malloc(sizeof(INTERP2) + sizeof(float)*2*(nsamps-1));
| 67 |
if (nip == NULL)
| 68 |
return(NULL);
| 69 |
| 70 |
nip->ns = nsamps;
| 71 |
greg |
2.4 |
nip->dmin = 1; /* default minimum diameter */
| 72 |
greg |
2.1 |
nip->smf = NI2DSMF; /* default smoothing factor */
| 73 |
greg |
2.4 |
nip->da = NULL;
| 74 |
greg |
2.1 |
/* caller must assign spt[] array */
| 75 |
return(nip);
| 76 |
| 77 |
| 78 |
greg |
2.2 |
/* Resize interpolation array (caller must assign any new values) */
| 79 |
INTERP2 *
| 80 |
interp2_realloc(INTERP2 *ip, int nsamps)
| 81 |
| 82 |
if (ip == NULL)
| 83 |
return(interp2_alloc(nsamps));
| 84 |
if (nsamps <= 1) {
| 85 |
interp2_free(ip);
| 86 |
return(NULL);
| 87 |
| 88 |
greg |
2.8 |
if (nsamps == ip->ns)
| 89 |
greg |
2.2 |
return(ip);
| 90 |
greg |
2.4 |
if (ip->da != NULL) { /* will need to recompute distribution */
| 91 |
free(ip->da);
| 92 |
ip->da = NULL;
| 93 |
greg |
2.2 |
| 94 |
ip = (INTERP2 *)realloc(ip, sizeof(INTERP2)+sizeof(float)*2*(nsamps-1));
| 95 |
if (ip == NULL)
| 96 |
return(NULL);
| 97 |
ip->ns = nsamps;
| 98 |
return(ip);
| 99 |
| 100 |
| 101 |
greg |
2.5 |
/* Set minimum distance under which samples will start to merge */
| 102 |
void
| 103 |
interp2_spacing(INTERP2 *ip, double mind)
| 104 |
| 105 |
if (mind <= 0)
| 106 |
return;
| 107 |
greg |
2.7 |
if ((.998*ip->dmin <= mind) & (mind <= 1.002*ip->dmin))
| 108 |
greg |
2.5 |
return;
| 109 |
| 110 |
free(ip->da);
| 111 |
ip->da = NULL;
| 112 |
| 113 |
ip->dmin = mind;
| 114 |
| 115 |
| 116 |
greg |
2.12 |
/* Compute unnormalized weight for a position relative to a sample */
| 117 |
double
| 118 |
interp2_wti(INTERP2 *ip, const int i, double x, double y)
| 119 |
| 120 |
double dir, rd, r2, d2;
| 121 |
int ri;
| 122 |
/* get relative direction */
| 123 |
x -= ip->spt[i][0];
| 124 |
y -= ip->spt[i][1];
| 125 |
dir = atan2a(y, x);
| 126 |
dir += 2.*PI*(dir < 0);
| 127 |
/* linear radius interpolation */
| 128 |
rd = dir * (NI2DIR/2./PI);
| 129 |
ri = (int)rd;
| 130 |
rd -= (double)ri;
| 131 |
rd = (1.-rd)*ip->da[i].dia[ri] + rd*ip->da[i].dia[(ri+1)%NI2DIR];
| 132 |
rd = ip->smf * DECODE_DIA(ip, rd);
| 133 |
r2 = 2.*rd*rd;
| 134 |
d2 = x*x + y*y;
| 135 |
if (d2 > 21.*r2) /* result would be < 1e-9 */
| 136 |
return(.0);
| 137 |
/* Gaussian times harmonic weighting */
| 138 |
return( exp(-d2/r2) * ip->dmin/(ip->dmin + sqrt(d2)) );
| 139 |
| 140 |
| 141 |
/* private call to get grid flag index */
| 142 |
static int
| 143 |
interp2_flagpos(int fgi[2], INTERP2 *ip, double x, double y)
| 144 |
| 145 |
int inbounds = 0;
| 146 |
| 147 |
if (ip == NULL) /* paranoia */
| 148 |
return(-1);
| 149 |
/* need to compute interpolant? */
| 150 |
if (ip->da == NULL && !interp2_analyze(ip))
| 151 |
return(-1);
| 152 |
/* get x & y grid positions */
| 153 |
fgi[0] = (x - ip->smin[0]) * NI2DIM / (ip->smax[0] - ip->smin[0]);
| 154 |
| 155 |
if (fgi[0] >= NI2DIM)
| 156 |
fgi[0] = NI2DIM-1;
| 157 |
else if (fgi[0] < 0)
| 158 |
fgi[0] = 0;
| 159 |
else
| 160 |
++inbounds;
| 161 |
| 162 |
fgi[1] = (y - ip->smin[1]) * NI2DIM / (ip->smax[1] - ip->smin[1]);
| 163 |
| 164 |
if (fgi[1] >= NI2DIM)
| 165 |
fgi[1] = NI2DIM-1;
| 166 |
else if (fgi[1] < 0)
| 167 |
fgi[1] = 0;
| 168 |
else
| 169 |
++inbounds;
| 170 |
| 171 |
return(inbounds == 2);
| 172 |
| 173 |
| 174 |
#define setflg(fl,xi,yi) ((fl)[yi] |= 1<<(xi))
| 175 |
| 176 |
#define chkflg(fl,xi,yi) ((fl)[yi]>>(xi) & 1)
| 177 |
| 178 |
/* private flood function to determine sample influence */
| 179 |
static void
| 180 |
influence_flood(INTERP2 *ip, const int i, unsigned short visited[NI2DIM],
| 181 |
int xfi, int yfi)
| 182 |
| 183 |
double gx = (xfi+.5)*(1./NI2DIM)*(ip->smax[0] - ip->smin[0]) +
| 184 |
ip->smin[0];
| 185 |
double gy = (yfi+.5)*(1./NI2DIM)*(ip->smax[1] - ip->smin[1]) +
| 186 |
ip->smin[1];
| 187 |
double dx = gx - ip->spt[i][0];
| 188 |
double dy = gy - ip->spt[i][1];
| 189 |
| 190 |
setflg(visited, xfi, yfi);
| 191 |
| 192 |
if (dx*dx + dy*dy > 2.*ip->grid2 && interp2_wti(ip, i, gx, gy) <= 1e-7)
| 193 |
return;
| 194 |
| 195 |
setflg(ip->da[i].infl, xfi, yfi);
| 196 |
| 197 |
if (xfi > 0 && !chkflg(visited, xfi-1, yfi))
| 198 |
influence_flood(ip, i, visited, xfi-1, yfi);
| 199 |
| 200 |
if (yfi > 0 && !chkflg(visited, xfi, yfi-1))
| 201 |
influence_flood(ip, i, visited, xfi, yfi-1);
| 202 |
| 203 |
if (xfi < NI2DIM-1 && !chkflg(visited, xfi+1, yfi))
| 204 |
influence_flood(ip, i, visited, xfi+1, yfi);
| 205 |
| 206 |
if (yfi < NI2DIM-1 && !chkflg(visited, xfi, yfi+1))
| 207 |
influence_flood(ip, i, visited, xfi, yfi+1);
| 208 |
| 209 |
| 210 |
greg |
2.13 |
/* private call to compute sample influence maps */
| 211 |
static void
| 212 |
map_influence(INTERP2 *ip)
| 213 |
| 214 |
unsigned short visited[NI2DIM];
| 215 |
int fgi[2];
| 216 |
int i, j;
| 217 |
| 218 |
for (i = ip->ns; i--; ) {
| 219 |
for (j = NI2DIM; j--; ) {
| 220 |
ip->da[i].infl[j] = 0;
| 221 |
visited[j] = 0;
| 222 |
| 223 |
interp2_flagpos(fgi, ip, ip->spt[i][0], ip->spt[i][1]);
| 224 |
| 225 |
influence_flood(ip, i, visited, fgi[0], fgi[1]);
| 226 |
| 227 |
| 228 |
| 229 |
/* Modify smoothing parameter by the given factor */
| 230 |
void
| 231 |
interp2_smooth(INTERP2 *ip, double sf)
| 232 |
| 233 |
float old_smf = ip->smf;
| 234 |
| 235 |
if ((ip->smf *= sf) < NI2DSMF)
| 236 |
ip->smf = NI2DSMF;
| 237 |
/* need to recompute influence maps? */
| 238 |
if (ip->da != NULL && (old_smf*.85 > ip->smf) |
| 239 |
(ip->smf > old_smf*1.15))
| 240 |
map_influence(ip);
| 241 |
| 242 |
| 243 |
/* private call-back to sort position index */
| 244 |
static int
| 245 |
cmp_spos(const void *p1, const void *p2)
| 246 |
| 247 |
const SAMPORD *so1 = (const SAMPORD *)p1;
| 248 |
const SAMPORD *so2 = (const SAMPORD *)p2;
| 249 |
| 250 |
if (so1->dm > so2->dm)
| 251 |
return 1;
| 252 |
if (so1->dm < so2->dm)
| 253 |
return -1;
| 254 |
return 0;
| 255 |
| 256 |
| 257 |
/* private routine to order samples in a particular direction */
| 258 |
static void
| 259 |
sort_samples(SAMPORD *sord, const INTERP2 *ip, double ang)
| 260 |
| 261 |
const double cosd = cos(ang);
| 262 |
const double sind = sin(ang);
| 263 |
int i;
| 264 |
| 265 |
| 266 |
sord[i].si = i;
| 267 |
sord[i].dm = cosd*ip->spt[i][0] + sind*ip->spt[i][1];
| 268 |
| 269 |
greg |
2.14 |
qsort(sord, ip->ns, sizeof(SAMPORD), cmp_spos);
| 270 |
greg |
2.13 |
| 271 |
| 272 |
greg |
2.2 |
/* (Re)compute anisotropic basis function interpolant (normally automatic) */
| 273 |
int
| 274 |
interp2_analyze(INTERP2 *ip)
| 275 |
greg |
2.1 |
| 276 |
SAMPORD *sortord;
| 277 |
greg |
2.2 |
int *rightrndx, *leftrndx, *endrndx;
| 278 |
greg |
2.13 |
int i, bd;
| 279 |
greg |
2.1 |
/* sanity checks */
| 280 |
greg |
2.10 |
if (ip == NULL)
| 281 |
return(0);
| 282 |
if (ip->da != NULL) { /* free previous data if any */
| 283 |
free(ip->da);
| 284 |
ip->da = NULL;
| 285 |
| 286 |
if ((ip->ns <= 1) | (ip->dmin <= 0))
| 287 |
greg |
2.1 |
return(0);
| 288 |
greg |
2.10 |
/* compute sample domain */
| 289 |
ip->smin[0] = ip->smin[1] = FHUGE;
| 290 |
greg |
2.11 |
ip->smax[0] = ip->smax[1] = -FHUGE;
| 291 |
greg |
2.10 |
| 292 |
greg |
2.12 |
if (ip->spt[i][0] < ip->smin[0]) ip->smin[0] = ip->spt[i][0];
| 293 |
if (ip->spt[i][0] > ip->smax[0]) ip->smax[0] = ip->spt[i][0];
| 294 |
if (ip->spt[i][1] < ip->smin[1]) ip->smin[1] = ip->spt[i][1];
| 295 |
if (ip->spt[i][1] > ip->smax[1]) ip->smax[1] = ip->spt[i][1];
| 296 |
greg |
2.1 |
| 297 |
greg |
2.11 |
ip->grid2 = ((ip->smax[0]-ip->smin[0])*(ip->smax[0]-ip->smin[0]) +
| 298 |
(ip->smax[1]-ip->smin[1])*(ip->smax[1]-ip->smin[1])) *
| 299 |
(1./NI2DIM/NI2DIM);
| 300 |
greg |
2.10 |
if (ip->grid2 <= FTINY*ip->dmin*ip->dmin)
| 301 |
return(0);
| 302 |
/* allocate analysis data */
| 303 |
greg |
2.13 |
ip->da = (struct interp2_samp *)malloc(
| 304 |
sizeof(struct interp2_samp)*ip->ns );
| 305 |
greg |
2.10 |
if (ip->da == NULL)
| 306 |
return(0);
| 307 |
greg |
2.12 |
/* allocate temporary arrays */
| 308 |
greg |
2.1 |
sortord = (SAMPORD *)malloc(sizeof(SAMPORD)*ip->ns);
| 309 |
rightrndx = (int *)malloc(sizeof(int)*ip->ns);
| 310 |
leftrndx = (int *)malloc(sizeof(int)*ip->ns);
| 311 |
greg |
2.2 |
endrndx = (int *)malloc(sizeof(int)*ip->ns);
| 312 |
if ((sortord == NULL) | (rightrndx == NULL) |
| 313 |
(leftrndx == NULL) | (endrndx == NULL))
| 314 |
greg |
2.1 |
return(0);
| 315 |
/* run through bidirections */
| 316 |
for (bd = 0; bd < NI2DIR/2; bd++) {
| 317 |
const double ang = 2.*PI/NI2DIR*bd;
| 318 |
greg |
2.2 |
int *sptr;
| 319 |
greg |
2.1 |
/* create right reverse index */
| 320 |
greg |
2.2 |
if (bd) { /* re-use from previous iteration? */
| 321 |
sptr = rightrndx;
| 322 |
greg |
2.1 |
rightrndx = leftrndx;
| 323 |
leftrndx = sptr;
| 324 |
greg |
2.2 |
} else { /* else sort first half-plane */
| 325 |
sort_samples(sortord, ip, PI/2. - PI/NI2DIR);
| 326 |
| 327 |
greg |
2.1 |
rightrndx[sortord[i].si] = i;
| 328 |
greg |
2.2 |
/* & store reverse order for later */
| 329 |
| 330 |
endrndx[sortord[i].si] = ip->ns-1 - i;
| 331 |
greg |
2.1 |
| 332 |
/* create new left reverse index */
| 333 |
greg |
2.2 |
if (bd == NI2DIR/2 - 1) { /* use order from first iteration? */
| 334 |
sptr = leftrndx;
| 335 |
leftrndx = endrndx;
| 336 |
endrndx = sptr;
| 337 |
} else { /* else compute new half-plane */
| 338 |
sort_samples(sortord, ip, ang + (PI/2. + PI/NI2DIR));
| 339 |
| 340 |
leftrndx[sortord[i].si] = i;
| 341 |
greg |
2.1 |
| 342 |
/* sort grid values in this direction */
| 343 |
greg |
2.2 |
sort_samples(sortord, ip, ang);
| 344 |
greg |
2.1 |
/* find nearest neighbors each side */
| 345 |
greg |
2.2 |
| 346 |
greg |
2.3 |
const int ii = sortord[i].si;
| 347 |
greg |
2.13 |
int j;
| 348 |
greg |
2.3 |
/* preload with large radii */
| 349 |
greg |
2.10 |
ip->da[ii].dia[bd] =
| 350 |
ip->da[ii].dia[bd+NI2DIR/2] = encode_diameter(ip,
| 351 |
.5*(sortord[ip->ns-1].dm - sortord[0].dm));
| 352 |
greg |
2.1 |
for (j = i; ++j < ip->ns; ) /* nearest above */
| 353 |
greg |
2.3 |
if (rightrndx[sortord[j].si] > rightrndx[ii] &&
| 354 |
leftrndx[sortord[j].si] < leftrndx[ii]) {
| 355 |
greg |
2.10 |
ip->da[ii].dia[bd] = encode_diameter(ip,
| 356 |
greg |
2.4 |
sortord[j].dm - sortord[i].dm);
| 357 |
greg |
2.1 |
break;
| 358 |
| 359 |
for (j = i; j-- > 0; ) /* nearest below */
| 360 |
greg |
2.3 |
if (rightrndx[sortord[j].si] < rightrndx[ii] &&
| 361 |
leftrndx[sortord[j].si] > leftrndx[ii]) {
| 362 |
greg |
2.10 |
| 363 |
greg |
2.4 |
sortord[i].dm - sortord[j].dm);
| 364 |
greg |
2.1 |
break;
| 365 |
| 366 |
| 367 |
| 368 |
greg |
2.12 |
free(sortord); /* release temp arrays */
| 369 |
greg |
2.1 |
free(rightrndx);
| 370 |
free(leftrndx);
| 371 |
greg |
2.2 |
free(endrndx);
| 372 |
greg |
2.13 |
/* map sample influence areas */
| 373 |
map_influence(ip);
| 374 |
greg |
2.12 |
return(1); /* all done */
| 375 |
greg |
2.11 |
| 376 |
| 377 |
greg |
2.1 |
/* Assign full set of normalized weights to interpolate the given position */
| 378 |
int
| 379 |
interp2_weights(float wtv[], INTERP2 *ip, double x, double y)
| 380 |
| 381 |
double wnorm;
| 382 |
greg |
2.11 |
int fgi[2];
| 383 |
greg |
2.1 |
int i;
| 384 |
| 385 |
greg |
2.11 |
if (wtv == NULL)
| 386 |
return(0);
| 387 |
/* get flag position */
| 388 |
greg |
2.12 |
if (interp2_flagpos(fgi, ip, x, y) < 0)
| 389 |
greg |
2.1 |
return(0);
| 390 |
| 391 |
wnorm = 0; /* compute raw weights */
| 392 |
greg |
2.11 |
| 393 |
greg |
2.12 |
if (chkflg(ip->da[i].infl, fgi[0], fgi[1])) {
| 394 |
greg |
2.10 |
double wt = interp2_wti(ip, i, x, y);
| 395 |
greg |
2.1 |
wtv[i] = wt;
| 396 |
wnorm += wt;
| 397 |
greg |
2.12 |
} else
| 398 |
wtv[i] = 0;
| 399 |
greg |
2.1 |
if (wnorm <= 0) /* too far from all our samples! */
| 400 |
return(0);
| 401 |
wnorm = 1./wnorm; /* normalize weights */
| 402 |
| 403 |
wtv[i] *= wnorm;
| 404 |
return(ip->ns); /* all done */
| 405 |
| 406 |
| 407 |
| 408 |
/* Get normalized weights and indexes for n best samples in descending order */
| 409 |
int
| 410 |
interp2_topsamp(float wt[], int si[], const int n, INTERP2 *ip, double x, double y)
| 411 |
| 412 |
int nn = 0;
| 413 |
greg |
2.11 |
int fgi[2];
| 414 |
greg |
2.1 |
double wnorm;
| 415 |
int i, j;
| 416 |
| 417 |
greg |
2.11 |
if ((n <= 0) | (wt == NULL) | (si == NULL))
| 418 |
return(0);
| 419 |
| 420 |
greg |
2.12 |
| 421 |
greg |
2.1 |
return(0);
| 422 |
/* identify top n weights */
| 423 |
greg |
2.11 |
| 424 |
greg |
2.12 |
| 425 |
greg |
2.10 |
const double wti = interp2_wti(ip, i, x, y);
| 426 |
greg |
2.1 |
for (j = nn; j > 0; j--) {
| 427 |
greg |
2.3 |
if (wt[j-1] >= wti)
| 428 |
greg |
2.1 |
break;
| 429 |
if (j < n) {
| 430 |
wt[j] = wt[j-1];
| 431 |
si[j] = si[j-1];
| 432 |
| 433 |
| 434 |
if (j < n) { /* add/insert sample */
| 435 |
greg |
2.3 |
wt[j] = wti;
| 436 |
greg |
2.1 |
si[j] = i;
| 437 |
nn += (nn < n);
| 438 |
| 439 |
greg |
2.11 |
| 440 |
greg |
2.3 |
wnorm = 0; /* normalize sample weights */
| 441 |
for (j = nn; j--; )
| 442 |
wnorm += wt[j];
| 443 |
greg |
2.1 |
if (wnorm <= 0)
| 444 |
return(0);
| 445 |
wnorm = 1./wnorm;
| 446 |
for (j = nn; j--; )
| 447 |
wt[j] *= wnorm;
| 448 |
return(nn); /* return actual # samples */
| 449 |
| 450 |
| 451 |
/* Free interpolant */
| 452 |
void
| 453 |
interp2_free(INTERP2 *ip)
| 454 |
| 455 |
if (ip == NULL)
| 456 |
return;
| 457 |
greg |
2.4 |
if (ip->da != NULL)
| 458 |
free(ip->da);
| 459 |
greg |
2.1 |
free(ip);
| 460 |
