--- ray/src/common/interp2d.c 2013/02/11 23:33:35 2.5 +++ ray/src/common/interp2d.c 2013/02/12 17:47:58 2.7 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: interp2d.c,v 2.5 2013/02/11 23:33:35 greg Exp $"; +static const char RCSid[] = "$Id: interp2d.c,v 2.7 2013/02/12 17:47:58 greg Exp $"; #endif /* * General interpolation method for unstructured values on 2-D plane. @@ -17,7 +17,7 @@ static const char RCSid[] = "$Id: interp2d.c,v 2.5 201 * each of NI2DIR surrounding directions. To speed this * calculation, we sort the data into half-planes and apply * simple tests to see which neighbor is closest in each - * direction. Once we have our approximate neighborhood + * angular slice. Once we have our approximate neighborhood * for a sample, we can use it in a modified Gaussian weighting * with allowing local anisotropy. Harmonic weighting is added * to reduce the influence of distant neighbors. This yields a @@ -90,7 +90,7 @@ interp2_spacing(INTERP2 *ip, double mind) { if (mind <= 0) return; - if ((.998*ip->dmin <= mind) && (mind <= 1.002*ip->dmin)) + if ((.998*ip->dmin <= mind) & (mind <= 1.002*ip->dmin)) return; if (ip->da != NULL) { /* will need to recompute distribution */ free(ip->da); @@ -238,7 +238,7 @@ interp2_analyze(INTERP2 *ip) static double get_wt(const INTERP2 *ip, const int i, double x, double y) { - double dir, rd, d2; + double dir, rd, r2, d2; int ri; /* get relative direction */ x -= ip->spt[i][0]; @@ -251,9 +251,12 @@ get_wt(const INTERP2 *ip, const int i, double x, doubl rd -= (double)ri; rd = (1.-rd)*ip->da[i][ri] + rd*ip->da[i][(ri+1)%NI2DIR]; rd = ip->smf * DECODE_DIA(ip, rd); + r2 = 2.*rd*rd; d2 = x*x + y*y; + if (d2 > 21.*r2) /* result would be < 1e-9 */ + return(.0); /* Gaussian times harmonic weighting */ - return( exp(d2/(-2.*rd*rd)) * ip->dmin/(ip->dmin + sqrt(d2)) ); + return( exp(-d2/r2) * ip->dmin/(ip->dmin + sqrt(d2)) ); } /* Assign full set of normalized weights to interpolate the given position */
