--- ray/src/common/interp2d.c 2013/02/09 00:55:40 2.1 +++ ray/src/common/interp2d.c 2013/02/15 01:26:47 2.11 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: interp2d.c,v 2.1 2013/02/09 00:55:40 greg Exp $"; +static const char RCSid[] = "$Id: interp2d.c,v 2.11 2013/02/15 01:26:47 greg Exp $"; #endif /* * General interpolation method for unstructured values on 2-D plane. @@ -9,29 +9,31 @@ static const char RCSid[] = "$Id: interp2d.c,v 2.1 201 #include "copyright.h" -/************************************************************* +/*************************************************************** * This is a general method for 2-D interpolation similar to * radial basis functions but allowing for a good deal of local * anisotropy in the point distribution. Each sample point * is examined to determine the closest neighboring samples in * each of NI2DIR surrounding directions. To speed this - * calculation, we sort the data into 3 half-planes and - * perform simple tests to see which neighbor is closest in - * a each direction. Once we have our approximate neighborhood - * for a sample, we can use it in a Gaussian weighting scheme - * with anisotropic surround. This gives us a fairly smooth - * interpolation however the sample points may be initially - * distributed. Evaluation is accelerated by use of a fast - * approximation to the atan2(y,x) function. - **************************************************************/ + * calculation, we sort the data into half-planes and apply + * simple tests to see which neighbor is closest in each + * angular slice. Once we have our approximate neighborhood + * for a sample, we can use it in a modified Gaussian weighting + * with allowing local anisotropy. Harmonic weighting is added + * to reduce the influence of distant neighbors. This yields a + * smooth interpolation regardless of how the sample points are + * initially distributed. Evaluation is accelerated by use of + * a fast approximation to the atan2(y,x) function and an array + * of flags indicating where weights are (nearly) zero. + ****************************************************************/ #include #include #include "rtmath.h" #include "interp2d.h" -#define DECODE_RAD(ip,er) ((ip)->rmin*(1. + .5*(er))) -#define ENCODE_RAD(ip,r) ((int)(2.*(r)/(ip)->rmin) - 2) +#define DECODE_DIA(ip,ed) ((ip)->dmin*(1. + .5*(ed))) +#define ENCODE_DIA(ip,d) ((int)(2.*(d)/(ip)->dmin) - 2) /* Sample order (private) */ typedef struct { @@ -39,7 +41,7 @@ typedef struct { float dm; /* distance measure in this direction */ } SAMPORD; -/* Allocate a new set of interpolation samples */ +/* Allocate a new set of interpolation samples (caller assigns spt[] array) */ INTERP2 * interp2_alloc(int nsamps) { @@ -53,13 +55,59 @@ interp2_alloc(int nsamps) return(NULL); nip->ns = nsamps; - nip->rmin = .5; /* default radius minimum */ + nip->dmin = 1; /* default minimum diameter */ nip->smf = NI2DSMF; /* default smoothing factor */ - nip->ra = NULL; + nip->da = NULL; /* caller must assign spt[] array */ return(nip); } +/* Resize interpolation array (caller must assign any new values) */ +INTERP2 * +interp2_realloc(INTERP2 *ip, int nsamps) +{ + if (ip == NULL) + return(interp2_alloc(nsamps)); + if (nsamps <= 1) { + interp2_free(ip); + return(NULL); + } + if (nsamps == ip->ns) + return(ip); + if (ip->da != NULL) { /* will need to recompute distribution */ + free(ip->da); + ip->da = NULL; + } + ip = (INTERP2 *)realloc(ip, sizeof(INTERP2)+sizeof(float)*2*(nsamps-1)); + if (ip == NULL) + return(NULL); + ip->ns = nsamps; + return(ip); +} + +/* Set minimum distance under which samples will start to merge */ +void +interp2_spacing(INTERP2 *ip, double mind) +{ + if (mind <= 0) + return; + if ((.998*ip->dmin <= mind) & (mind <= 1.002*ip->dmin)) + return; + if (ip->da != NULL) { /* will need to recompute distribution */ + free(ip->da); + ip->da = NULL; + } + ip->dmin = mind; +} + +/* Modify smoothing parameter by the given factor */ +void +interp2_smooth(INTERP2 *ip, double sf) +{ + if ((ip->smf *= sf) < NI2DSMF) + ip->smf = NI2DSMF; +} + /* private call-back to sort position index */ static int cmp_spos(const void *p1, const void *p2) @@ -74,101 +122,130 @@ cmp_spos(const void *p1, const void *p2) return 0; } -/* private routine to encode radius with range checks */ +/* private routine to order samples in a particular direction */ +static void +sort_samples(SAMPORD *sord, const INTERP2 *ip, double ang) +{ + const double cosd = cos(ang); + const double sind = sin(ang); + int i; + + for (i = ip->ns; i--; ) { + sord[i].si = i; + sord[i].dm = cosd*ip->spt[i][0] + sind*ip->spt[i][1]; + } + qsort(sord, ip->ns, sizeof(SAMPORD), &cmp_spos); +} + +/* private routine to encode sample diameter with range checks */ static int -encode_radius(const INTERP2 *ip, double r) +encode_diameter(const INTERP2 *ip, double d) { - const int er = ENCODE_RAD(ip, r); + const int ed = ENCODE_DIA(ip, d); - if (er <= 0) + if (ed <= 0) return(0); - if (er >= 0xffff) + if (ed >= 0xffff) return(0xffff); - return(er); + return(ed); } -/* Compute anisotropic Gaussian basis function interpolant */ -static int -interp2_compute(INTERP2 *ip) +/* (Re)compute anisotropic basis function interpolant (normally automatic) */ +int +interp2_analyze(INTERP2 *ip) { SAMPORD *sortord; - int *rightrndx, *leftrndx; - int bd; + int *rightrndx, *leftrndx, *endrndx; + int i, bd; /* sanity checks */ - if (ip == NULL || (ip->ns <= 1) | (ip->rmin <= 0)) + if (ip == NULL) return(0); - /* need to allocate? */ - if (ip->ra == NULL) { - ip->ra = (unsigned short (*)[NI2DIR])malloc( - sizeof(unsigned short)*NI2DIR*ip->ns); - if (ip->ra == NULL) - return(0); + if (ip->da != NULL) { /* free previous data if any */ + free(ip->da); + ip->da = NULL; } + if ((ip->ns <= 1) | (ip->dmin <= 0)) + return(0); + /* compute sample domain */ + ip->smin[0] = ip->smin[1] = FHUGE; + ip->smax[0] = ip->smax[1] = -FHUGE; + for (i = ip->ns; i--; ) { + if (ip->spt[i][0] < ip->smin[0]) + ip->smin[0] = ip->spt[i][0]; + if (ip->spt[i][0] > ip->smax[0]) + ip->smax[0] = ip->spt[i][0]; + if (ip->spt[i][1] < ip->smin[1]) + ip->smin[1] = ip->spt[i][1]; + if (ip->spt[i][1] > ip->smax[1]) + ip->smax[1] = ip->spt[i][1]; + } + ip->grid2 = ((ip->smax[0]-ip->smin[0])*(ip->smax[0]-ip->smin[0]) + + (ip->smax[1]-ip->smin[1])*(ip->smax[1]-ip->smin[1])) * + (1./NI2DIM/NI2DIM); + if (ip->grid2 <= FTINY*ip->dmin*ip->dmin) + return(0); + /* allocate analysis data */ + ip->da = (struct interp2_samp *)calloc( ip->ns, + sizeof(struct interp2_samp) ); + if (ip->da == NULL) + return(0); /* get temporary arrays */ sortord = (SAMPORD *)malloc(sizeof(SAMPORD)*ip->ns); rightrndx = (int *)malloc(sizeof(int)*ip->ns); leftrndx = (int *)malloc(sizeof(int)*ip->ns); - if ((sortord == NULL) | (rightrndx == NULL) | (leftrndx == NULL)) + endrndx = (int *)malloc(sizeof(int)*ip->ns); + if ((sortord == NULL) | (rightrndx == NULL) | + (leftrndx == NULL) | (endrndx == NULL)) return(0); /* run through bidirections */ for (bd = 0; bd < NI2DIR/2; bd++) { const double ang = 2.*PI/NI2DIR*bd; - double cosd, sind; - int i; + int *sptr; /* create right reverse index */ - if (bd) { /* re-use from prev. iteration? */ - int *sptr = rightrndx; + if (bd) { /* re-use from previous iteration? */ + sptr = rightrndx; rightrndx = leftrndx; leftrndx = sptr; - } else { /* else compute it */ - cosd = cos(ang + (PI/2. - PI/NI2DIR)); - sind = sin(ang + (PI/2. - PI/NI2DIR)); - for (i = 0; i < ip->ns; i++) { - sortord[i].si = i; - sortord[i].dm = cosd*ip->spt[i][0] + sind*ip->spt[i][1]; - } - qsort(sortord, ip->ns, sizeof(SAMPORD), &cmp_spos); - for (i = 0; i < ip->ns; i++) + } else { /* else sort first half-plane */ + sort_samples(sortord, ip, PI/2. - PI/NI2DIR); + for (i = ip->ns; i--; ) rightrndx[sortord[i].si] = i; + /* & store reverse order for later */ + for (i = ip->ns; i--; ) + endrndx[sortord[i].si] = ip->ns-1 - i; } /* create new left reverse index */ - cosd = cos(ang + (PI/2. + PI/NI2DIR)); - sind = sin(ang + (PI/2. + PI/NI2DIR)); - for (i = 0; i < ip->ns; i++) { - sortord[i].si = i; - sortord[i].dm = cosd*ip->spt[i][0] + sind*ip->spt[i][1]; - } - qsort(sortord, ip->ns, sizeof(SAMPORD), &cmp_spos); - for (i = 0; i < ip->ns; i++) + if (bd == NI2DIR/2 - 1) { /* use order from first iteration? */ + sptr = leftrndx; + leftrndx = endrndx; + endrndx = sptr; + } else { /* else compute new half-plane */ + sort_samples(sortord, ip, ang + (PI/2. + PI/NI2DIR)); + for (i = ip->ns; i--; ) leftrndx[sortord[i].si] = i; - /* sort grid values in this direction */ - cosd = cos(ang); - sind = sin(ang); - for (i = 0; i < ip->ns; i++) { - sortord[i].si = i; - sortord[i].dm = cosd*ip->spt[i][0] + sind*ip->spt[i][1]; } - qsort(sortord, ip->ns, sizeof(SAMPORD), &cmp_spos); + /* sort grid values in this direction */ + sort_samples(sortord, ip, ang); /* find nearest neighbors each side */ - for (i = 0; i < ip->ns; i++) { - const int rpos = rightrndx[sortord[i].si]; - const int lpos = leftrndx[sortord[i].si]; + for (i = ip->ns; i--; ) { + const int ii = sortord[i].si; int j; - /* preload with large radius */ - ip->ra[i][bd] = ip->ra[i][bd+NI2DIR/2] = encode_radius(ip, - .25*(sortord[ip->ns-1].dm - sortord[0].dm)); + /* preload with large radii */ + ip->da[ii].dia[bd] = + ip->da[ii].dia[bd+NI2DIR/2] = encode_diameter(ip, + .5*(sortord[ip->ns-1].dm - sortord[0].dm)); for (j = i; ++j < ip->ns; ) /* nearest above */ - if (rightrndx[sortord[j].si] > rpos && - leftrndx[sortord[j].si] < lpos) { - ip->ra[i][bd] = encode_radius(ip, - .5*(sortord[j].dm - sortord[i].dm)); + if (rightrndx[sortord[j].si] > rightrndx[ii] && + leftrndx[sortord[j].si] < leftrndx[ii]) { + ip->da[ii].dia[bd] = encode_diameter(ip, + sortord[j].dm - sortord[i].dm); break; } for (j = i; j-- > 0; ) /* nearest below */ - if (rightrndx[sortord[j].si] < rpos && - leftrndx[sortord[j].si] > lpos) { - ip->ra[i][bd+NI2DIR/2] = encode_radius(ip, - .5*(sortord[i].dm - sortord[j].dm)); + if (rightrndx[sortord[j].si] < rightrndx[ii] && + leftrndx[sortord[j].si] > leftrndx[ii]) { + ip->da[ii].dia[bd+NI2DIR/2] = encode_diameter(ip, + sortord[i].dm - sortord[j].dm); break; } } @@ -176,15 +253,16 @@ interp2_compute(INTERP2 *ip) free(sortord); /* clean up */ free(rightrndx); free(leftrndx); + free(endrndx); return(1); } -/* private call returns log of raw weight for a particular sample */ -static double -get_ln_wt(const INTERP2 *ip, const int i, double x, double y) +/* Compute unnormalized weight for a position relative to a sample */ +double +interp2_wti(INTERP2 *ip, const int i, double x, double y) { - double dir, rd; - int ri; + double dir, rd, r2, d2; + int ri; /* get relative direction */ x -= ip->spt[i][0]; y -= ip->spt[i][1]; @@ -194,36 +272,88 @@ get_ln_wt(const INTERP2 *ip, const int i, double x, do rd = dir * (NI2DIR/2./PI); ri = (int)rd; rd -= (double)ri; - rd = (1.-rd)*ip->ra[i][ri] + rd*ip->ra[i][(ri+1)%NI2DIR]; - rd = ip->smf * DECODE_RAD(ip, rd); - /* return log of Gaussian weight */ - return( (x*x + y*y) / (-2.*rd*rd) ); + rd = (1.-rd)*ip->da[i].dia[ri] + rd*ip->da[i].dia[(ri+1)%NI2DIR]; + rd = ip->smf * DECODE_DIA(ip, rd); + r2 = 2.*rd*rd; + d2 = x*x + y*y; + if (d2 > 21.*r2) /* result would be < 1e-9 */ + return(.0); + /* Gaussian times harmonic weighting */ + return( exp(-d2/r2) * ip->dmin/(ip->dmin + sqrt(d2)) ); } +/* private call to get grid flag index */ +static int +interp2_flagpos(int fgi[2], INTERP2 *ip, double x, double y) +{ + int ingrid = 1; + + if (ip == NULL) /* paranoia */ + return(-1); + /* need to compute interpolant? */ + if (ip->da == NULL && !interp2_analyze(ip)) + return(-1); + /* get grid position */ + fgi[0] = (x - ip->smin[0]) * NI2DIM / (ip->smax[0] - ip->smin[0]); + if (fgi[0] >= NI2DIM) { + fgi[0] = NI2DIM-1; + ingrid = 0; + } else if (fgi[0] < 0) { + fgi[0] = 0; + ingrid = 0; + } + fgi[1] = (y - ip->smin[1]) * NI2DIM / (ip->smax[1] - ip->smin[1]); + if (fgi[1] >= NI2DIM) { + fgi[1] = NI2DIM-1; + ingrid = 0; + } else if (fgi[1] < 0) { + fgi[1] = 0; + ingrid = 0; + } + return(ingrid); +} + +/* private call to set black flag if not too close to the given sample */ +static void +setblk(INTERP2 *ip, const int i, const int gi[2]) +{ + double dx = (gi[0]+.5)*(1./NI2DIM)*(ip->smax[0] - ip->smin[0]) + + ip->smin[0] - ip->spt[i][0]; + double dy = (gi[1]+.5)*(1./NI2DIM)*(ip->smax[1] - ip->smin[1]) + + ip->smin[1] - ip->spt[i][1]; + + if (dx*dx + dy*dy > 2.*ip->grid2) + ip->da[i].blkflg[gi[1]] |= 1<da[i].blkflg[(gi)[1]]>>(gi)[0] & 1) + /* Assign full set of normalized weights to interpolate the given position */ int interp2_weights(float wtv[], INTERP2 *ip, double x, double y) { double wnorm; + int fgi[2]; + int ingrid; int i; - if ((wtv == NULL) | (ip == NULL)) + if (wtv == NULL) return(0); - /* need to compute interpolant? */ - if (ip->ra == NULL && !interp2_compute(ip)) + /* get flag position */ + if ((ingrid = interp2_flagpos(fgi, ip, x, y)) < 0) return(0); wnorm = 0; /* compute raw weights */ - for (i = ip->ns; i--; ) { - double wt = get_ln_wt(ip, i, x, y); - if (wt < -21.) { - wtv[i] = 0; /* ignore weights < 1e-9 */ - continue; - } - wt = exp(wt); /* Gaussian weight */ + for (i = ip->ns; i--; ) + if (chkblk(ip, i, fgi)) { + wtv[i] = 0; + } else { + double wt = interp2_wti(ip, i, x, y); wtv[i] = wt; wnorm += wt; - } + if (wt <= 1e-9 && ingrid) + setblk(ip, i, fgi); + } if (wnorm <= 0) /* too far from all our samples! */ return(0); wnorm = 1./wnorm; /* normalize weights */ @@ -238,19 +368,27 @@ int interp2_topsamp(float wt[], int si[], const int n, INTERP2 *ip, double x, double y) { int nn = 0; + int fgi[2]; + int ingrid; double wnorm; int i, j; - if ((n <= 0) | (wt == NULL) | (si == NULL) | (ip == NULL)) + if ((n <= 0) | (wt == NULL) | (si == NULL)) return(0); - /* need to compute interpolant? */ - if (ip->ra == NULL && !interp2_compute(ip)) + /* get flag position */ + if ((ingrid = interp2_flagpos(fgi, ip, x, y)) < 0) return(0); /* identify top n weights */ - for (i = ip->ns; i--; ) { - const double lnwt = get_ln_wt(ip, i, x, y); + for (i = ip->ns; i--; ) + if (!chkblk(ip, i, fgi)) { + const double wti = interp2_wti(ip, i, x, y); + if (wti <= 1e-9) { + if (ingrid) + setblk(ip, i, fgi); + continue; + } for (j = nn; j > 0; j--) { - if (wt[j-1] >= lnwt) + if (wt[j-1] >= wti) break; if (j < n) { wt[j] = wt[j-1]; @@ -258,17 +396,14 @@ interp2_topsamp(float wt[], int si[], const int n, INT } } if (j < n) { /* add/insert sample */ - wt[j] = lnwt; + wt[j] = wti; si[j] = i; nn += (nn < n); } - } - wnorm = 0; /* exponentiate and normalize */ - for (j = nn; j--; ) { - double dwt = exp(wt[j]); - wt[j] = dwt; - wnorm += dwt; - } + } + wnorm = 0; /* normalize sample weights */ + for (j = nn; j--; ) + wnorm += wt[j]; if (wnorm <= 0) return(0); wnorm = 1./wnorm; @@ -283,7 +418,7 @@ interp2_free(INTERP2 *ip) { if (ip == NULL) return; - if (ip->ra != NULL) - free(ip->ra); + if (ip->da != NULL) + free(ip->da); free(ip); }
