root/radiance/ray/src/common/interp2d.c
Revision: 2.16
Committed: Thu Mar 11 01:58:59 2021 UTC (4 years, 2 months ago) by greg
Changes since 2.15: +9 -3 lines
perf: made it so interp2_realloc() will never fail if reducing array size
2 static const char RCSid[] = "$Id: interp2d.c,v 2.15 2021/02/13 16:49:18 greg Exp $";
5 * General interpolation method for unstructured values on 2-D plane.
6 *
7 * G.Ward Feb 2013
8 */
9
10 #include "copyright.h"
11
12 /***************************************************************
13 * This is a general method for 2-D interpolation similar to
14 * radial basis functions but allowing for a good deal of local
15 * anisotropy in the point distribution. Each sample point
16 * is examined to determine the closest neighboring samples in
17 * each of NI2DIR surrounding directions. To speed this
18 * calculation, we sort the data into half-planes and apply
19 * simple tests to see which neighbor is closest in each
20 * angular slice. Once we have our approximate neighborhood
21 * for a sample, we can use it in a modified Gaussian weighting
22 * with allowing local anisotropy. Harmonic weighting is added
23 * to reduce the influence of distant neighbors. This yields a
24 * smooth interpolation regardless of how the sample points are
25 * initially distributed. Evaluation is accelerated by use of
26 * a fast approximation to the atan2(y,x) function and a low-res
27 * map indicating where sample weights are significant.
28 ****************************************************************/
29
30 #include <stdio.h>
31 #include <stdlib.h>
32 #include "rtmath.h"
33 #include "interp2d.h"
34
35 #define DECODE_DIA(ip,ed) ((ip)->dmin*(1. + .5*(ed)))
36 #define ENCODE_DIA(ip,d) ((int)(2.*(d)/(ip)->dmin) - 2)
37
38 /* Sample order (private) */
39 typedef struct {
40 int si; /* sample index */
41 float dm; /* distance measure in this direction */
42 } SAMPORD;
43
44 /* private routine to encode sample diameter with range checks */
45 static int
46 encode_diameter(const INTERP2 *ip, double d)
47 {
48 const int ed = ENCODE_DIA(ip, d);
49
50 if (ed <= 0)
51 return(0);
52 if (ed >= 0xffff)
53 return(0xffff);
54 return(ed);
55 }
56
57 /* Allocate a new set of interpolation samples (caller assigns spt[] array) */
58 INTERP2 *
59 interp2_alloc(int nsamps)
60 {
61 INTERP2 *nip;
62
63 if (nsamps <= 1)
64 return(NULL);
65
66 nip = (INTERP2 *)malloc(sizeof(INTERP2) + sizeof(float)*2*(nsamps-1));
67 if (nip == NULL)
68 return(NULL);
69
70 nip->ns = nsamps;
71 nip->dmin = 1; /* default minimum diameter */
72 nip->smf = NI2DSMF; /* default smoothing factor */
73 nip->c_data = NULL;
74 nip->da = NULL;
75 /* caller must assign spt[] array */
76 return(nip);
77 }
78
79 /* Resize interpolation array (caller must assign any new values) */
80 INTERP2 *
81 interp2_realloc(INTERP2 *ip, int nsamps)
82 {
83 INTERP2 *old_ip = ip;
84
85 if (ip == NULL)
86 return(interp2_alloc(nsamps));
87 if (nsamps <= 1) {
88 interp2_free(ip);
89 return(NULL);
90 }
91 if (nsamps == ip->ns)
92 return(ip);
93 if (ip->da != NULL) { /* will need to recompute distribution */
94 free(ip->da);
95 ip->da = NULL;
96 }
97 ip = (INTERP2 *)realloc(ip, sizeof(INTERP2)+sizeof(float)*2*(nsamps-1));
98 if (ip == NULL) {
99 if (nsamps <= ip->ns)
100 ip = old_ip;
101 else
102 return(NULL);
103 }
104 ip->ns = nsamps;
105 return(ip);
106 }
107
108 /* Set minimum distance under which samples will start to merge */
109 void
110 interp2_spacing(INTERP2 *ip, double mind)
111 {
112 if (mind <= 0)
113 return;
114 if ((.998*ip->dmin <= mind) & (mind <= 1.002*ip->dmin))
115 return;
116 if (ip->da != NULL) { /* will need to recompute distribution */
117 free(ip->da);
118 ip->da = NULL;
119 }
120 ip->dmin = mind;
121 }
122
123 /* Compute unnormalized weight for a position relative to a sample */
124 double
125 interp2_wti(INTERP2 *ip, const int i, double x, double y)
126 {
127 double dir, rd, r2, d2;
128 int ri;
129 /* get relative direction */
130 x -= ip->spt[i][0];
131 y -= ip->spt[i][1];
132 dir = atan2a(y, x);
133 dir += 2.*PI*(dir < 0);
134 /* linear radius interpolation */
135 rd = dir * (NI2DIR/2./PI);
136 ri = (int)rd;
137 rd -= (double)ri;
138 rd = (1.-rd)*ip->da[i].dia[ri] + rd*ip->da[i].dia[(ri+1)%NI2DIR];
139 rd = ip->smf * DECODE_DIA(ip, rd);
140 r2 = 2.*rd*rd;
141 d2 = x*x + y*y;
142 if (d2 > 21.*r2) /* result would be < 1e-9 */
143 return(.0);
144 /* Gaussian times harmonic weighting */
145 return( exp(-d2/r2) * ip->dmin/(ip->dmin + sqrt(d2)) );
146 }
147
148 /* private call to get grid flag index */
149 static int
150 interp2_flagpos(int fgi[2], INTERP2 *ip, double x, double y)
151 {
152 int inbounds = 0;
153
154 if (ip == NULL) /* paranoia */
155 return(-1);
156 /* need to compute interpolant? */
157 if (ip->da == NULL && !interp2_analyze(ip))
158 return(-1);
159 /* get x & y grid positions */
160 fgi[0] = (x - ip->smin[0]) * NI2DIM / (ip->smax[0] - ip->smin[0]);
161
162 if (fgi[0] >= NI2DIM)
163 fgi[0] = NI2DIM-1;
164 else if (fgi[0] < 0)
165 fgi[0] = 0;
166 else
167 ++inbounds;
168
169 fgi[1] = (y - ip->smin[1]) * NI2DIM / (ip->smax[1] - ip->smin[1]);
170
171 if (fgi[1] >= NI2DIM)
172 fgi[1] = NI2DIM-1;
173 else if (fgi[1] < 0)
174 fgi[1] = 0;
175 else
176 ++inbounds;
177
178 return(inbounds == 2);
179 }
180
181 #define setflg(fl,xi,yi) ((fl)[yi] |= 1<<(xi))
182
183 #define chkflg(fl,xi,yi) ((fl)[yi]>>(xi) & 1)
184
185 /* private flood function to determine sample influence */
186 static void
187 influence_flood(INTERP2 *ip, const int i, unsigned short visited[NI2DIM],
188 int xfi, int yfi)
189 {
190 double gx = (xfi+.5)*(1./NI2DIM)*(ip->smax[0] - ip->smin[0]) +
191 ip->smin[0];
192 double gy = (yfi+.5)*(1./NI2DIM)*(ip->smax[1] - ip->smin[1]) +
193 ip->smin[1];
194 double dx = gx - ip->spt[i][0];
195 double dy = gy - ip->spt[i][1];
196
197 setflg(visited, xfi, yfi);
198
199 if (dx*dx + dy*dy > 2.*ip->grid2 && interp2_wti(ip, i, gx, gy) <= 1e-7)
200 return;
201
202 setflg(ip->da[i].infl, xfi, yfi);
203
204 if (xfi > 0 && !chkflg(visited, xfi-1, yfi))
205 influence_flood(ip, i, visited, xfi-1, yfi);
206
207 if (yfi > 0 && !chkflg(visited, xfi, yfi-1))
208 influence_flood(ip, i, visited, xfi, yfi-1);
209
210 if (xfi < NI2DIM-1 && !chkflg(visited, xfi+1, yfi))
211 influence_flood(ip, i, visited, xfi+1, yfi);
212
213 if (yfi < NI2DIM-1 && !chkflg(visited, xfi, yfi+1))
214 influence_flood(ip, i, visited, xfi, yfi+1);
215 }
216
217 /* private call to compute sample influence maps */
218 static void
219 map_influence(INTERP2 *ip)
220 {
221 unsigned short visited[NI2DIM];
222 int fgi[2];
223 int i, j;
224
225 for (i = ip->ns; i--; ) {
226 for (j = NI2DIM; j--; ) {
227 ip->da[i].infl[j] = 0;
228 visited[j] = 0;
229 }
230 interp2_flagpos(fgi, ip, ip->spt[i][0], ip->spt[i][1]);
231
232 influence_flood(ip, i, visited, fgi[0], fgi[1]);
233 }
234 }
235
236 /* Modify smoothing parameter by the given factor */
237 void
238 interp2_smooth(INTERP2 *ip, double sf)
239 {
240 float old_smf = ip->smf;
241
242 if ((ip->smf *= sf) < NI2DSMF)
243 ip->smf = NI2DSMF;
244 /* need to recompute influence maps? */
245 if (ip->da != NULL && (old_smf*.85 > ip->smf) |
246 (ip->smf > old_smf*1.15))
247 map_influence(ip);
248 }
249
250 /* private call-back to sort position index */
251 static int
252 cmp_spos(const void *p1, const void *p2)
253 {
254 const SAMPORD *so1 = (const SAMPORD *)p1;
255 const SAMPORD *so2 = (const SAMPORD *)p2;
256
257 if (so1->dm > so2->dm)
258 return 1;
259 if (so1->dm < so2->dm)
260 return -1;
261 return 0;
262 }
263
264 /* private routine to order samples in a particular direction */
265 static void
266 sort_samples(SAMPORD *sord, const INTERP2 *ip, double ang)
267 {
268 const double cosd = cos(ang);
269 const double sind = sin(ang);
270 int i;
271
272 for (i = ip->ns; i--; ) {
273 sord[i].si = i;
274 sord[i].dm = cosd*ip->spt[i][0] + sind*ip->spt[i][1];
275 }
276 qsort(sord, ip->ns, sizeof(SAMPORD), cmp_spos);
277 }
278
279 /* (Re)compute anisotropic basis function interpolant (normally automatic) */
280 int
281 interp2_analyze(INTERP2 *ip)
282 {
283 SAMPORD *sortord;
284 int *rightrndx, *leftrndx, *endrndx;
285 int i, bd;
286 /* sanity checks */
287 if (ip == NULL)
288 return(0);
289 if (ip->da != NULL) { /* free previous data if any */
290 free(ip->da);
291 ip->da = NULL;
292 }
293 if ((ip->ns <= 1) | (ip->dmin <= 0))
294 return(0);
295 /* compute sample domain */
296 ip->smin[0] = ip->smin[1] = FHUGE;
297 ip->smax[0] = ip->smax[1] = -FHUGE;
298 for (i = ip->ns; i--; ) {
299 if (ip->spt[i][0] < ip->smin[0]) ip->smin[0] = ip->spt[i][0];
300 if (ip->spt[i][0] > ip->smax[0]) ip->smax[0] = ip->spt[i][0];
301 if (ip->spt[i][1] < ip->smin[1]) ip->smin[1] = ip->spt[i][1];
302 if (ip->spt[i][1] > ip->smax[1]) ip->smax[1] = ip->spt[i][1];
303 }
304 ip->grid2 = ((ip->smax[0]-ip->smin[0])*(ip->smax[0]-ip->smin[0]) +
305 (ip->smax[1]-ip->smin[1])*(ip->smax[1]-ip->smin[1])) *
306 (1./NI2DIM/NI2DIM);
307 if (ip->grid2 <= FTINY*ip->dmin*ip->dmin)
308 return(0);
309 /* allocate analysis data */
310 ip->da = (struct interp2_samp *)malloc(
311 sizeof(struct interp2_samp)*ip->ns );
312 if (ip->da == NULL)
313 return(0);
314 /* allocate temporary arrays */
315 sortord = (SAMPORD *)malloc(sizeof(SAMPORD)*ip->ns);
316 rightrndx = (int *)malloc(sizeof(int)*ip->ns);
317 leftrndx = (int *)malloc(sizeof(int)*ip->ns);
318 endrndx = (int *)malloc(sizeof(int)*ip->ns);
319 if ((sortord == NULL) | (rightrndx == NULL) |
320 (leftrndx == NULL) | (endrndx == NULL))
321 return(0);
322 /* run through bidirections */
323 for (bd = 0; bd < NI2DIR/2; bd++) {
324 const double ang = 2.*PI/NI2DIR*bd;
325 int *sptr;
326 /* create right reverse index */
327 if (bd) { /* re-use from previous iteration? */
328 sptr = rightrndx;
329 rightrndx = leftrndx;
330 leftrndx = sptr;
331 } else { /* else sort first half-plane */
332 sort_samples(sortord, ip, PI/2. - PI/NI2DIR);
333 for (i = ip->ns; i--; )
334 rightrndx[sortord[i].si] = i;
335 /* & store reverse order for later */
336 for (i = ip->ns; i--; )
337 endrndx[sortord[i].si] = ip->ns-1 - i;
338 }
339 /* create new left reverse index */
340 if (bd == NI2DIR/2 - 1) { /* use order from first iteration? */
341 sptr = leftrndx;
342 leftrndx = endrndx;
343 endrndx = sptr;
344 } else { /* else compute new half-plane */
345 sort_samples(sortord, ip, ang + (PI/2. + PI/NI2DIR));
346 for (i = ip->ns; i--; )
347 leftrndx[sortord[i].si] = i;
348 }
349 /* sort grid values in this direction */
350 sort_samples(sortord, ip, ang);
351 /* find nearest neighbors each side */
352 for (i = ip->ns; i--; ) {
353 const int ii = sortord[i].si;
354 int j;
355 /* preload with large radii */
356 ip->da[ii].dia[bd] =
357 ip->da[ii].dia[bd+NI2DIR/2] = encode_diameter(ip,
358 .5*(sortord[ip->ns-1].dm - sortord[0].dm));
359 for (j = i; ++j < ip->ns; ) /* nearest above */
360 if (rightrndx[sortord[j].si] > rightrndx[ii] &&
361 leftrndx[sortord[j].si] < leftrndx[ii]) {
362 ip->da[ii].dia[bd] = encode_diameter(ip,
363 sortord[j].dm - sortord[i].dm);
364 break;
365 }
366 for (j = i; j-- > 0; ) /* nearest below */
367 if (rightrndx[sortord[j].si] < rightrndx[ii] &&
368 leftrndx[sortord[j].si] > leftrndx[ii]) {
369 ip->da[ii].dia[bd+NI2DIR/2] = encode_diameter(ip,
370 sortord[i].dm - sortord[j].dm);
371 break;
372 }
373 }
374 }
375 free(sortord); /* release temp arrays */
376 free(rightrndx);
377 free(leftrndx);
378 free(endrndx);
379 /* map sample influence areas */
380 map_influence(ip);
381 return(1); /* all done */
382 }
383
384 /* Assign full set of normalized weights to interpolate the given position */
385 int
386 interp2_weights(float wtv[], INTERP2 *ip, double x, double y)
387 {
388 double wnorm;
389 int fgi[2];
390 int i;
391
392 if (wtv == NULL)
393 return(0);
394 /* get flag position */
395 if (interp2_flagpos(fgi, ip, x, y) < 0)
396 return(0);
397
398 wnorm = 0; /* compute raw weights */
399 for (i = ip->ns; i--; )
400 if (chkflg(ip->da[i].infl, fgi[0], fgi[1])) {
401 double wt = interp2_wti(ip, i, x, y);
402 wtv[i] = wt;
403 wnorm += wt;
404 } else
405 wtv[i] = 0;
406 if (wnorm <= 0) /* too far from all our samples! */
407 return(0);
408 wnorm = 1./wnorm; /* normalize weights */
409 for (i = ip->ns; i--; )
410 wtv[i] *= wnorm;
411 return(ip->ns); /* all done */
412 }
413
414
415 /* Get normalized weights and indexes for n best samples in descending order */
416 int
417 interp2_topsamp(float wt[], int si[], const int n, INTERP2 *ip, double x, double y)
418 {
419 int nn = 0;
420 int fgi[2];
421 double wnorm;
422 int i, j;
423
424 if ((n <= 0) | (wt == NULL) | (si == NULL))
425 return(0);
426 /* get flag position */
427 if (interp2_flagpos(fgi, ip, x, y) < 0)
428 return(0);
429 /* identify top n weights */
430 for (i = ip->ns; i--; )
431 if (chkflg(ip->da[i].infl, fgi[0], fgi[1])) {
432 const double wti = interp2_wti(ip, i, x, y);
433 for (j = nn; j > 0; j--) {
434 if (wt[j-1] >= wti)
435 break;
436 if (j < n) {
437 wt[j] = wt[j-1];
438 si[j] = si[j-1];
439 }
440 }
441 if (j < n) { /* add/insert sample */
442 wt[j] = wti;
443 si[j] = i;
444 nn += (nn < n);
445 }
446 }
447 wnorm = 0; /* normalize sample weights */
448 for (j = nn; j--; )
449 wnorm += wt[j];
450 if (wnorm <= 0)
451 return(0);
452 wnorm = 1./wnorm;
453 for (j = nn; j--; )
454 wt[j] *= wnorm;
455 return(nn); /* return actual # samples */
456 }
457
458 /* Free interpolant */
459 void
460 interp2_free(INTERP2 *ip)
461 {
462 if (ip == NULL)
463 return;
464 if (ip->da != NULL)
465 free(ip->da);
466 free(ip);
467 }
