root/radiance/ray/src/common/instance.h
Revision: 2.6
Committed: Fri Jun 27 06:53:21 2003 UTC (20 years, 11 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD
Changes since 2.5: +1 -3 lines
# User Rev Content
1 greg 2.6 /* RCSid $Id: instance.h,v 2.5 2003/06/06 16:38:47 schorsch Exp $ */
2 greg 1.1 /*
3     * instance.h - header file for routines using octree objects.
4     *
5 greg 2.3 * Include after object.h and octree.h
6 greg 1.1 */
7 schorsch 2.5 #ifndef _RAD_INSTANCE_H_
8     #define _RAD_INSTANCE_H_
9     #ifdef __cplusplus
10     extern "C" {
11     #endif
12 greg 1.1
13     typedef struct scene {
14     char *name; /* octree name */
15 greg 2.3 int nref; /* number of references */
16 greg 1.1 int ldflags; /* what was loaded */
17     CUBE scube; /* scene cube */
18 greg 2.2 OBJECT firstobj, nobjs; /* first object and count */
19 greg 1.1 struct scene *next; /* next in list */
20     } SCENE; /* loaded octree */
21
22     typedef struct {
23 greg 1.3 FULLXF x; /* forward and backward transforms */
24 greg 1.1 SCENE *obj; /* loaded object */
25     } INSTANCE; /* instance of octree */
26
27
28 greg 2.3 extern SCENE *getscene(char *sname, int flags);
29     extern INSTANCE *getinstance(OBJREC *o, int flags);
30     extern void freescene(SCENE *sc);
31     extern void freeinstance(OBJREC *o);
32
33 schorsch 2.5
34     #ifdef __cplusplus
35     }
36 greg 2.3 #endif
37 schorsch 2.5 #endif /* _RAD_INSTANCE_H_ */
38
