--- ray/src/common/instance.h 2003/02/25 02:47:21 2.4 +++ ray/src/common/instance.h 2003/06/27 06:53:21 2.6 @@ -1,12 +1,15 @@ -/* RCSid $Id: instance.h,v 2.4 2003/02/25 02:47:21 greg Exp $ */ +/* RCSid $Id: instance.h,v 2.6 2003/06/27 06:53:21 greg Exp $ */ /* * instance.h - header file for routines using octree objects. * * Include after object.h and octree.h */ +#ifndef _RAD_INSTANCE_H_ +#define _RAD_INSTANCE_H_ +#ifdef __cplusplus +extern "C" { +#endif -#include "copyright.h" - typedef struct scene { char *name; /* octree name */ int nref; /* number of references */ @@ -21,18 +24,15 @@ typedef struct { SCENE *obj; /* loaded object */ } INSTANCE; /* instance of octree */ -#ifdef NOPROTO -extern SCENE *getscene(); -extern INSTANCE *getinstance(); -extern void freescene(); -extern void freeinstance(); - -#else - extern SCENE *getscene(char *sname, int flags); extern INSTANCE *getinstance(OBJREC *o, int flags); extern void freescene(SCENE *sc); extern void freeinstance(OBJREC *o); + +#ifdef __cplusplus +} #endif +#endif /* _RAD_INSTANCE_H_ */ +
