root/Development/ray/src/common/instance.c
Thu Dec 12 20:04:46 2024 UTC (12 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.13: +6 -11 lines
Diff to previous 2.13 , to selected 1.3
perf: Eliminated unnecessary call to getpath() for loaded octree
Tue Nov 5 00:03:10 2024 UTC (13 months, 3 weeks ago) by greg
Changes since 2.12: +23 -20 lines
Diff to previous 2.12 , to selected 1.3
style: ANSIfication
Tue Mar 22 03:56:17 2016 UTC (9 years, 9 months ago) by greg
CVS Tags: rad5R1, rad5R2, rad5R3, rad5R4
Diff to previous 2.11 , to selected 1.3
Made error messages more consistent when library file not found
Thu Feb 12 18:55:50 2004 UTC (21 years, 10 months ago) by greg
Diff to previous 2.10 , to selected 1.3
Fri Nov 14 17:22:06 2003 UTC (22 years, 1 month ago) by schorsch
Diff to previous 2.9 , to selected 1.3
Thu Jul 10 03:30:11 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.8: +19 -12 lines
Diff to previous 2.8 , to selected 1.3
Fixed potential bug in reference counting of mesh'es and instance's
Tue May 13 17:58:32 2003 UTC (22 years, 7 months ago) by greg
Diff to previous 2.7 , to selected 1.3
Tue Mar 4 05:49:21 2003 UTC (22 years, 10 months ago) by greg
Diff to previous 2.6 , to selected 1.3
Tue Feb 25 02:47:21 2003 UTC (22 years, 10 months ago) by greg
Diff to previous 2.5 , to selected 1.3
Sat Feb 22 02:07:22 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.4: +111 -22 lines
Diff to previous 2.4 , to selected 1.3
Thu Apr 14 04:44:47 1994 UTC (31 years, 8 months ago) by greg
Diff to previous 2.3 , to selected 1.3
Tue Feb 2 13:24:50 1993 UTC (32 years, 11 months ago) by greg
Changes since 2.2: +8 -4 lines
Diff to previous 2.2 , to selected 1.3
eliminated unnecessary searching due to IO_ALL
Thu Aug 6 16:46:47 1992 UTC (33 years, 5 months ago) by greg
Changes since 2.1: +9 -0 lines
Diff to previous 2.1 , to selected 1.3
added firstobj and nobjs to SCENE structure
Tue Nov 12 16:54:54 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.8 , to selected 1.3
Wed Jul 17 14:10:14 1991 UTC (34 years, 5 months ago) by greg
Diff to previous 1.7 , to selected 1.3
made call to free structures more robust
Wed May 29 17:11:32 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.6: +7 -0 lines
Diff to previous 1.6 , to selected 1.3
added freeinstance() call
Sat Dec 15 15:01:37 1990 UTC (35 years ago) by greg
Changes since 1.5: +6 -7 lines
Diff to previous 1.5 , to selected 1.3
Fri Oct 13 19:45:50 1989 UTC (36 years, 2 months ago) by greg
Diff to previous 1.4 , to selected 1.3
Prevent loading of octree header in get_instance().
Thu Oct 5 07:54:06 1989 UTC (36 years, 3 months ago) by greg
Changes since 1.3: +0 -4 lines
Diff to previous 1.3
Preinitialization of matrix for xf() and invxf() no longer necessary.
Revision 1.3 - (view) (download) (annotate) - [selected]
Thu Jul 27 22:25:56 1989 UTC (36 years, 5 months ago) by greg
Diff to previous 1.2
Changed getpath() to check access modes
Tue Feb 21 14:39:53 1989 UTC (36 years, 10 months ago) by greg
Diff to previous 1.1 , to selected 1.3
portability fixes for SGI
Thu Feb 2 10:34:35 1989 UTC (36 years, 11 months ago) by greg
Diff to selected 1.3
