root/radiance/ray/src/common/instance.c
Thu Feb 12 18:55:50 2004 UTC (20 years, 2 months ago) by greg
Thu Jul 10 03:30:11 2003 UTC (20 years, 10 months ago) by greg
Changes since 2.8: +19 -12 lines
Fixed potential bug in reference counting of mesh'es and instance's
Tue May 13 17:58:32 2003 UTC (20 years, 11 months ago) by greg
Tue Mar 4 05:49:21 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.4: +111 -22 lines
Thu Apr 14 04:44:47 1994 UTC (30 years, 1 month ago) by greg
Tue Feb 2 13:24:50 1993 UTC (31 years, 3 months ago) by greg
Changes since 2.2: +8 -4 lines
eliminated unnecessary searching due to IO_ALL
Thu Aug 6 16:46:47 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.1: +9 -0 lines
added firstobj and nobjs to SCENE structure
Tue Nov 12 16:54:54 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.8
Wed Jul 17 14:10:14 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.7 , to selected 2.1
made call to free structures more robust
Wed May 29 17:11:32 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.6: +7 -0 lines
added freeinstance() call
Sat Dec 15 15:01:37 1990 UTC (33 years, 4 months ago) by greg
Changes since 1.5: +6 -7 lines
Fri Oct 13 19:45:50 1989 UTC (34 years, 7 months ago) by greg
Prevent loading of octree header in get_instance().
Thu Oct 5 07:54:06 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.3: +0 -4 lines
Preinitialization of matrix for xf() and invxf() no longer necessary.
Thu Jul 27 22:25:56 1989 UTC (34 years, 9 months ago) by greg
Changed getpath() to check access modes
Tue Feb 21 14:39:53 1989 UTC (35 years, 2 months ago) by greg
portability fixes for SGI
Thu Feb 2 10:34:35 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.1
