| 1 |
/* Copyright (c) 1992 Regents of the University of California */ |
| 2 |
| 3 |
#ifndef lint |
| 4 |
static char SCCSid[] = "$SunId$ LBL"; |
| 5 |
#endif |
| 6 |
| 7 |
| 8 |
* image.c - routines for image generation. |
| 9 |
| 10 |
* 10/17/85 |
| 11 |
| 12 |
| 13 |
#include "standard.h" |
| 14 |
| 15 |
#include "view.h" |
| 16 |
| 17 |
#include "resolu.h" |
| 18 |
| 19 |
#include "paths.h" |
| 20 |
| 21 |
VIEW stdview = STDVIEW; /* default view parameters */ |
| 22 |
| 23 |
| 24 |
char * |
| 25 |
setview(v) /* set hvec and vvec, return message on error */ |
| 26 |
register VIEW *v; |
| 27 |
| 28 |
static char ill_horiz[] = "illegal horizontal view size"; |
| 29 |
static char ill_vert[] = "illegal vertical view size"; |
| 30 |
| 31 |
if (normalize(v->vdir) == 0.0) /* normalize direction */ |
| 32 |
return("zero view direction"); |
| 33 |
| 34 |
if (normalize(v->vup) == 0.0) /* normalize view up */ |
| 35 |
return("zero view up vector"); |
| 36 |
| 37 |
fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */ |
| 38 |
| 39 |
if (normalize(v->hvec) == 0.0) |
| 40 |
return("view up parallel to view direction"); |
| 41 |
| 42 |
fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */ |
| 43 |
| 44 |
if (v->horiz <= FTINY) |
| 45 |
return(ill_horiz); |
| 46 |
if (v->vert <= FTINY) |
| 47 |
return(ill_vert); |
| 48 |
| 49 |
switch (v->type) { |
| 50 |
case VT_PAR: /* parallel view */ |
| 51 |
v->hn2 = v->horiz; |
| 52 |
v->vn2 = v->vert; |
| 53 |
break; |
| 54 |
case VT_PER: /* perspective view */ |
| 55 |
if (v->horiz >= 180.0-FTINY) |
| 56 |
| 57 |
if (v->vert >= 180.0-FTINY) |
| 58 |
return(ill_vert); |
| 59 |
v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0)); |
| 60 |
v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0)); |
| 61 |
break; |
| 62 |
case VT_ANG: /* angular fisheye */ |
| 63 |
if (v->horiz > 360.0+FTINY) |
| 64 |
| 65 |
if (v->vert > 360.0+FTINY) |
| 66 |
return(ill_vert); |
| 67 |
v->hn2 = v->horiz / 90.0; |
| 68 |
v->vn2 = v->vert / 90.0; |
| 69 |
break; |
| 70 |
case VT_HEM: /* hemispherical fisheye */ |
| 71 |
if (v->horiz > 180.0+FTINY) |
| 72 |
| 73 |
if (v->vert > 180.0+FTINY) |
| 74 |
return(ill_vert); |
| 75 |
v->hn2 = 2.0 * sin(v->horiz*(PI/180.0/2.0)); |
| 76 |
v->vn2 = 2.0 * sin(v->vert*(PI/180.0/2.0)); |
| 77 |
break; |
| 78 |
default: |
| 79 |
return("unknown view type"); |
| 80 |
| 81 |
if (v->type != VT_ANG) { |
| 82 |
v->hvec[0] *= v->hn2; |
| 83 |
v->hvec[1] *= v->hn2; |
| 84 |
v->hvec[2] *= v->hn2; |
| 85 |
v->vvec[0] *= v->vn2; |
| 86 |
v->vvec[1] *= v->vn2; |
| 87 |
v->vvec[2] *= v->vn2; |
| 88 |
| 89 |
v->hn2 *= v->hn2; |
| 90 |
v->vn2 *= v->vn2; |
| 91 |
| 92 |
return(NULL); |
| 93 |
| 94 |
| 95 |
| 96 |
normaspect(va, ap, xp, yp) /* fix pixel aspect or resolution */ |
| 97 |
double va; /* view aspect ratio */ |
| 98 |
double *ap; /* pixel aspect in (or out if 0) */ |
| 99 |
int *xp, *yp; /* x and y resolution in (or out if *ap!=0) */ |
| 100 |
| 101 |
if (*ap <= FTINY) |
| 102 |
*ap = va * *xp / *yp; /* compute pixel aspect */ |
| 103 |
else if (va * *xp > *ap * *yp) |
| 104 |
*xp = *yp / va * *ap + .5; /* reduce x resolution */ |
| 105 |
else |
| 106 |
*yp = *xp * va / *ap + .5; /* reduce y resolution */ |
| 107 |
| 108 |
| 109 |
| 110 |
viewray(orig, direc, v, x, y) /* compute ray origin and direction */ |
| 111 |
FVECT orig, direc; |
| 112 |
register VIEW *v; |
| 113 |
double x, y; |
| 114 |
| 115 |
double d, z; |
| 116 |
| 117 |
x += v->hoff - 0.5; |
| 118 |
y += v->voff - 0.5; |
| 119 |
| 120 |
switch(v->type) { |
| 121 |
| 122 |
orig[0] = v->vp[0] + x*v->hvec[0] + y*v->vvec[0]; |
| 123 |
orig[1] = v->vp[1] + x*v->hvec[1] + y*v->vvec[1]; |
| 124 |
orig[2] = v->vp[2] + x*v->hvec[2] + y*v->vvec[2]; |
| 125 |
VCOPY(direc, v->vdir); |
| 126 |
return(0); |
| 127 |
| 128 |
VCOPY(orig, v->vp); |
| 129 |
direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; |
| 130 |
direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; |
| 131 |
direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; |
| 132 |
normalize(direc); |
| 133 |
return(0); |
| 134 |
| 135 |
z = 1.0 - x*x*v->hn2 - y*y*v->vn2; |
| 136 |
if (z < 0.0) |
| 137 |
return(-1); |
| 138 |
z = sqrt(z); |
| 139 |
| 140 |
direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; |
| 141 |
direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; |
| 142 |
direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; |
| 143 |
return(0); |
| 144 |
| 145 |
x *= v->horiz/180.0; |
| 146 |
y *= v->vert/180.0; |
| 147 |
d = x*x + y*y; |
| 148 |
if (d > 1.0) |
| 149 |
return(-1); |
| 150 |
| 151 |
if (d <= FTINY) { |
| 152 |
| 153 |
return(0); |
| 154 |
| 155 |
d = sqrt(d); |
| 156 |
z = cos(PI*d); |
| 157 |
d = sqrt(1 - z*z)/d; |
| 158 |
x *= d; |
| 159 |
y *= d; |
| 160 |
| 161 |
| 162 |
| 163 |
return(0); |
| 164 |
| 165 |
return(-1); |
| 166 |
| 167 |
| 168 |
| 169 |
viewloc(ip, v, p) /* find image location for point */ |
| 170 |
FVECT ip; |
| 171 |
register VIEW *v; |
| 172 |
FVECT p; |
| 173 |
| 174 |
double d; |
| 175 |
FVECT disp; |
| 176 |
| 177 |
disp[0] = p[0] - v->vp[0]; |
| 178 |
disp[1] = p[1] - v->vp[1]; |
| 179 |
disp[2] = p[2] - v->vp[2]; |
| 180 |
| 181 |
| 182 |
| 183 |
ip[2] = DOT(disp,v->vdir); |
| 184 |
break; |
| 185 |
| 186 |
d = DOT(disp,v->vdir); |
| 187 |
ip[2] = sqrt(DOT(disp,disp)); |
| 188 |
if (d < 0.0) { /* fold pyramid */ |
| 189 |
ip[2] = -ip[2]; |
| 190 |
d = -d; |
| 191 |
} else if (d > FTINY) { |
| 192 |
d = 1.0/d; |
| 193 |
disp[0] *= d; |
| 194 |
disp[1] *= d; |
| 195 |
disp[2] *= d; |
| 196 |
| 197 |
break; |
| 198 |
| 199 |
d = normalize(disp); |
| 200 |
if (DOT(disp,v->vdir) < 0.0) |
| 201 |
ip[2] = -d; |
| 202 |
else |
| 203 |
ip[2] = d; |
| 204 |
break; |
| 205 |
| 206 |
ip[0] = 0.5 - v->hoff; |
| 207 |
ip[1] = 0.5 - v->voff; |
| 208 |
ip[2] = normalize(disp); |
| 209 |
| 210 |
if (d >= 1.0-FTINY) |
| 211 |
return; |
| 212 |
if (d <= -(1.0-FTINY)) { |
| 213 |
ip[1] += 180.0/v->horiz; |
| 214 |
ip[2] += 180.0/v->vert; |
| 215 |
return; |
| 216 |
| 217 |
d = acos(d)/PI / sqrt(1.0 - d*d); |
| 218 |
ip[0] += DOT(disp,v->hvec)*d*180.0/v->horiz; |
| 219 |
ip[1] += DOT(disp,v->vvec)*d*180.0/v->vert; |
| 220 |
return; |
| 221 |
| 222 |
ip[0] = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff; |
| 223 |
ip[1] = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff; |
| 224 |
| 225 |
| 226 |
| 227 |
pix2loc(loc, rp, px, py) /* compute image location from pixel pos. */ |
| 228 |
FLOAT loc[2]; |
| 229 |
register RESOLU *rp; |
| 230 |
int px, py; |
| 231 |
| 232 |
register int x, y; |
| 233 |
| 234 |
if (rp->or & YMAJOR) { |
| 235 |
x = px; |
| 236 |
y = py; |
| 237 |
} else { |
| 238 |
x = py; |
| 239 |
y = px; |
| 240 |
| 241 |
if (rp->or & XDECR) |
| 242 |
x = rp->xr-1 - x; |
| 243 |
if (rp->or & YDECR) |
| 244 |
y = rp->yr-1 - y; |
| 245 |
loc[0] = (x+.5)/rp->xr; |
| 246 |
loc[1] = (y+.5)/rp->yr; |
| 247 |
| 248 |
| 249 |
| 250 |
loc2pix(pp, rp, lx, ly) /* compute pixel pos. from image location */ |
| 251 |
int pp[2]; |
| 252 |
| 253 |
double lx, ly; |
| 254 |
| 255 |
| 256 |
| 257 |
x = lx * rp->xr; |
| 258 |
y = ly * rp->yr; |
| 259 |
| 260 |
x = rp->xr-1 - x; |
| 261 |
| 262 |
y = rp->yr-1 - y; |
| 263 |
| 264 |
pp[0] = x; |
| 265 |
pp[1] = y; |
| 266 |
} else { |
| 267 |
pp[0] = y; |
| 268 |
pp[1] = x; |
| 269 |
| 270 |
| 271 |
| 272 |
| 273 |
int |
| 274 |
getviewopt(v, ac, av) /* process view argument */ |
| 275 |
register VIEW *v; |
| 276 |
int ac; |
| 277 |
register char *av[]; |
| 278 |
| 279 |
#define check(c,l) if ((av[0][c]&&av[0][c]!=' ') || \ |
| 280 |
badarg(ac-1,av+1,l)) return(-1) |
| 281 |
| 282 |
if (ac <= 0 || av[0][0] != '-' || av[0][1] != 'v') |
| 283 |
return(-1); |
| 284 |
switch (av[0][2]) { |
| 285 |
case 't': /* type */ |
| 286 |
if (!av[0][3] || av[0][3]==' ') |
| 287 |
return(-1); |
| 288 |
check(4,""); |
| 289 |
v->type = av[0][3]; |
| 290 |
return(0); |
| 291 |
case 'p': /* point */ |
| 292 |
check(3,"fff"); |
| 293 |
v->vp[0] = atof(av[1]); |
| 294 |
v->vp[1] = atof(av[2]); |
| 295 |
v->vp[2] = atof(av[3]); |
| 296 |
return(3); |
| 297 |
case 'd': /* direction */ |
| 298 |
check(3,"fff"); |
| 299 |
v->vdir[0] = atof(av[1]); |
| 300 |
v->vdir[1] = atof(av[2]); |
| 301 |
v->vdir[2] = atof(av[3]); |
| 302 |
return(3); |
| 303 |
case 'u': /* up */ |
| 304 |
check(3,"fff"); |
| 305 |
v->vup[0] = atof(av[1]); |
| 306 |
v->vup[1] = atof(av[2]); |
| 307 |
v->vup[2] = atof(av[3]); |
| 308 |
return(3); |
| 309 |
case 'h': /* horizontal size */ |
| 310 |
check(3,"f"); |
| 311 |
v->horiz = atof(av[1]); |
| 312 |
return(1); |
| 313 |
case 'v': /* vertical size */ |
| 314 |
check(3,"f"); |
| 315 |
v->vert = atof(av[1]); |
| 316 |
return(1); |
| 317 |
case 's': /* shift */ |
| 318 |
check(3,"f"); |
| 319 |
v->hoff = atof(av[1]); |
| 320 |
return(1); |
| 321 |
case 'l': /* lift */ |
| 322 |
check(3,"f"); |
| 323 |
v->voff = atof(av[1]); |
| 324 |
return(1); |
| 325 |
default: |
| 326 |
return(-1); |
| 327 |
| 328 |
#undef check |
| 329 |
| 330 |
| 331 |
| 332 |
int |
| 333 |
sscanview(vp, s) /* get view parameters from string */ |
| 334 |
VIEW *vp; |
| 335 |
register char *s; |
| 336 |
| 337 |
int ac; |
| 338 |
char *av[4]; |
| 339 |
int na; |
| 340 |
int nvopts = 0; |
| 341 |
| 342 |
if (*s != '-') |
| 343 |
s = sskip(s); |
| 344 |
while (*s) { |
| 345 |
ac = 0; |
| 346 |
do { |
| 347 |
av[ac++] = s; |
| 348 |
while (*s && *s != ' ') |
| 349 |
s++; |
| 350 |
while (*s == ' ') |
| 351 |
s++; |
| 352 |
} while (*s && ac < 4); |
| 353 |
if ((na = getviewopt(vp, ac, av)) >= 0) { |
| 354 |
if (na+1 < ac) |
| 355 |
s = av[na+1]; |
| 356 |
nvopts++; |
| 357 |
} else if (ac > 1) |
| 358 |
s = av[1]; |
| 359 |
| 360 |
return(nvopts); |
| 361 |
| 362 |
| 363 |
| 364 |
fprintview(vp, fp) /* write out view parameters */ |
| 365 |
register VIEW *vp; |
| 366 |
FILE *fp; |
| 367 |
| 368 |
fprintf(fp, " -vt%c", vp->type); |
| 369 |
fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]); |
| 370 |
fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]); |
| 371 |
fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]); |
| 372 |
fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert); |
| 373 |
fprintf(fp, " -vs %.6g -vl %.6g", vp->hoff, vp->voff); |
| 374 |
| 375 |
| 376 |
| 377 |
int |
| 378 |
isview(s) /* is this a view string? */ |
| 379 |
char *s; |
| 380 |
| 381 |
static char *altname[]={NULL,VIEWSTR,"rpict","rview","pinterp",NULL}; |
| 382 |
extern char *progname; |
| 383 |
register char *cp; |
| 384 |
register char **an; |
| 385 |
/* add program name to list */ |
| 386 |
if (altname[0] == NULL) { |
| 387 |
for (cp = progname; *cp; cp++) |
| 388 |
| 389 |
while (cp > progname && !ISDIRSEP(cp[-1])) |
| 390 |
cp--; |
| 391 |
altname[0] = cp; |
| 392 |
| 393 |
/* skip leading path */ |
| 394 |
cp = s; |
| 395 |
while (*cp && *cp != ' ') |
| 396 |
cp++; |
| 397 |
while (cp > s && !ISDIRSEP(cp[-1])) |
| 398 |
cp--; |
| 399 |
for (an = altname; *an != NULL; an++) |
| 400 |
if (!strncmp(*an, cp, strlen(*an))) |
| 401 |
return(1); |
| 402 |
return(0); |
| 403 |
| 404 |
| 405 |
| 406 |
struct myview { |
| 407 |
VIEW *hv; |
| 408 |
int ok; |
| 409 |
| 410 |
| 411 |
| 412 |
static |
| 413 |
gethview(s, v) /* get view from header */ |
| 414 |
char *s; |
| 415 |
register struct myview *v; |
| 416 |
| 417 |
if (isview(s) && sscanview(v->hv, s) > 0) |
| 418 |
v->ok++; |
| 419 |
| 420 |
| 421 |
| 422 |
int |
| 423 |
viewfile(fname, vp, rp) /* get view from file */ |
| 424 |
char *fname; |
| 425 |
VIEW *vp; |
| 426 |
RESOLU *rp; |
| 427 |
| 428 |
struct myview mvs; |
| 429 |
FILE *fp; |
| 430 |
| 431 |
if ((fp = fopen(fname, "r")) == NULL) |
| 432 |
return(-1); |
| 433 |
| 434 |
mvs.hv = vp; |
| 435 |
mvs.ok = 0; |
| 436 |
| 437 |
getheader(fp, gethview, &mvs); |
| 438 |
| 439 |
if (rp != NULL && !fgetsresolu(rp, fp)) |
| 440 |
mvs.ok = 0; |
| 441 |
| 442 |
fclose(fp); |
| 443 |
| 444 |
return(mvs.ok); |
| 445 |
