| 1 |
/* Copyright (c) 1991 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* image.c - routines for image generation.
| 9 |
| 10 |
* 10/17/85
| 11 |
| 12 |
| 13 |
#include "standard.h"
| 14 |
| 15 |
#include "view.h"
| 16 |
| 17 |
#include "resolu.h"
| 18 |
| 19 |
VIEW stdview = STDVIEW; /* default view parameters */
| 20 |
| 21 |
| 22 |
char *
| 23 |
setview(v) /* set hvec and vvec, return message on error */
| 24 |
register VIEW *v;
| 25 |
| 26 |
static char ill_horiz[] = "illegal horizontal view size";
| 27 |
static char ill_vert[] = "illegal vertical view size";
| 28 |
| 29 |
if (normalize(v->vdir) == 0.0) /* normalize direction */
| 30 |
return("zero view direction");
| 31 |
| 32 |
if (normalize(v->vup) == 0.0) /* normalize view up */
| 33 |
return("zero view up vector");
| 34 |
| 35 |
fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */
| 36 |
| 37 |
if (normalize(v->hvec) == 0.0)
| 38 |
return("view up parallel to view direction");
| 39 |
| 40 |
fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */
| 41 |
| 42 |
if (v->horiz <= FTINY)
| 43 |
return(ill_horiz);
| 44 |
if (v->vert <= FTINY)
| 45 |
return(ill_vert);
| 46 |
| 47 |
switch (v->type) {
| 48 |
case VT_PAR: /* parallel view */
| 49 |
v->hn2 = v->horiz;
| 50 |
v->vn2 = v->vert;
| 51 |
break;
| 52 |
case VT_PER: /* perspective view */
| 53 |
if (v->horiz >= 180.0-FTINY)
| 54 |
return(ill_horiz);
| 55 |
if (v->vert >= 180.0-FTINY)
| 56 |
return(ill_vert);
| 57 |
v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0));
| 58 |
v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0));
| 59 |
break;
| 60 |
case VT_ANG: /* angular fisheye */
| 61 |
if (v->horiz > 360.0+FTINY)
| 62 |
return(ill_horiz);
| 63 |
if (v->vert > 360.0+FTINY)
| 64 |
return(ill_vert);
| 65 |
v->hn2 = v->horiz / 90.0;
| 66 |
v->vn2 = v->vert / 90.0;
| 67 |
break;
| 68 |
case VT_HEM: /* hemispherical fisheye */
| 69 |
if (v->horiz > 180.0+FTINY)
| 70 |
return(ill_horiz);
| 71 |
if (v->vert > 180.0+FTINY)
| 72 |
return(ill_vert);
| 73 |
v->hn2 = 2.0 * sin(v->horiz*(PI/180.0/2.0));
| 74 |
v->vn2 = 2.0 * sin(v->vert*(PI/180.0/2.0));
| 75 |
break;
| 76 |
default:
| 77 |
return("unknown view type");
| 78 |
| 79 |
if (v->type != VT_ANG) {
| 80 |
v->hvec[0] *= v->hn2;
| 81 |
v->hvec[1] *= v->hn2;
| 82 |
v->hvec[2] *= v->hn2;
| 83 |
v->vvec[0] *= v->vn2;
| 84 |
v->vvec[1] *= v->vn2;
| 85 |
v->vvec[2] *= v->vn2;
| 86 |
| 87 |
v->hn2 *= v->hn2;
| 88 |
v->vn2 *= v->vn2;
| 89 |
| 90 |
return(NULL);
| 91 |
| 92 |
| 93 |
| 94 |
normaspect(va, ap, xp, yp) /* fix pixel aspect or resolution */
| 95 |
double va; /* view aspect ratio */
| 96 |
double *ap; /* pixel aspect in (or out if 0) */
| 97 |
int *xp, *yp; /* x and y resolution in (or out if *ap!=0) */
| 98 |
| 99 |
if (*ap <= FTINY)
| 100 |
*ap = va * *xp / *yp; /* compute pixel aspect */
| 101 |
else if (va * *xp > *ap * *yp)
| 102 |
*xp = *yp / va * *ap + .5; /* reduce x resolution */
| 103 |
else
| 104 |
*yp = *xp * va / *ap + .5; /* reduce y resolution */
| 105 |
| 106 |
| 107 |
| 108 |
viewray(orig, direc, v, x, y) /* compute ray origin and direction */
| 109 |
FVECT orig, direc;
| 110 |
register VIEW *v;
| 111 |
double x, y;
| 112 |
| 113 |
double d, z;
| 114 |
| 115 |
x += v->hoff - 0.5;
| 116 |
y += v->voff - 0.5;
| 117 |
| 118 |
switch(v->type) {
| 119 |
| 120 |
orig[0] = v->vp[0] + x*v->hvec[0] + y*v->vvec[0];
| 121 |
orig[1] = v->vp[1] + x*v->hvec[1] + y*v->vvec[1];
| 122 |
orig[2] = v->vp[2] + x*v->hvec[2] + y*v->vvec[2];
| 123 |
VCOPY(direc, v->vdir);
| 124 |
return(0);
| 125 |
| 126 |
VCOPY(orig, v->vp);
| 127 |
direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
| 128 |
direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
| 129 |
direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
| 130 |
normalize(direc);
| 131 |
return(0);
| 132 |
| 133 |
z = 1.0 - x*x*v->hn2 - y*y*v->vn2;
| 134 |
if (z < 0.0)
| 135 |
return(-1);
| 136 |
z = sqrt(z);
| 137 |
VCOPY(orig, v->vp);
| 138 |
direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
| 139 |
direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
| 140 |
direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
| 141 |
return(0);
| 142 |
| 143 |
x *= v->horiz/180.0;
| 144 |
y *= v->vert/180.0;
| 145 |
d = x*x + y*y;
| 146 |
if (d > 1.0)
| 147 |
return(-1);
| 148 |
VCOPY(orig, v->vp);
| 149 |
if (d <= FTINY) {
| 150 |
| 151 |
return(0);
| 152 |
| 153 |
d = sqrt(d);
| 154 |
z = cos(PI*d);
| 155 |
d = sqrt(1 - z*z)/d;
| 156 |
x *= d;
| 157 |
y *= d;
| 158 |
| 159 |
| 160 |
| 161 |
return(0);
| 162 |
| 163 |
return(-1);
| 164 |
| 165 |
| 166 |
| 167 |
viewloc(ip, v, p) /* find image location for point */
| 168 |
FVECT ip;
| 169 |
register VIEW *v;
| 170 |
FVECT p;
| 171 |
| 172 |
double d;
| 173 |
FVECT disp;
| 174 |
| 175 |
disp[0] = p[0] - v->vp[0];
| 176 |
disp[1] = p[1] - v->vp[1];
| 177 |
disp[2] = p[2] - v->vp[2];
| 178 |
| 179 |
switch (v->type) {
| 180 |
| 181 |
ip[2] = DOT(disp,v->vdir);
| 182 |
break;
| 183 |
| 184 |
d = DOT(disp,v->vdir);
| 185 |
ip[2] = sqrt(DOT(disp,disp));
| 186 |
if (d < 0.0) { /* fold pyramid */
| 187 |
ip[2] = -ip[2];
| 188 |
d = -d;
| 189 |
} else if (d > FTINY) {
| 190 |
d = 1.0/d;
| 191 |
disp[0] *= d;
| 192 |
disp[1] *= d;
| 193 |
disp[2] *= d;
| 194 |
| 195 |
break;
| 196 |
| 197 |
d = normalize(disp);
| 198 |
if (DOT(disp,v->vdir) < 0.0)
| 199 |
ip[2] = -d;
| 200 |
else
| 201 |
ip[2] = d;
| 202 |
break;
| 203 |
| 204 |
ip[0] = 0.5 - v->hoff;
| 205 |
ip[1] = 0.5 - v->voff;
| 206 |
ip[2] = normalize(disp);
| 207 |
| 208 |
if (d >= 1.0-FTINY)
| 209 |
return;
| 210 |
if (d <= -(1.0-FTINY)) {
| 211 |
ip[1] += 180.0/v->horiz;
| 212 |
ip[2] += 180.0/v->vert;
| 213 |
return;
| 214 |
| 215 |
d = acos(d)/PI / sqrt(1.0 - d*d);
| 216 |
ip[0] += DOT(disp,v->hvec)*d*180.0/v->horiz;
| 217 |
ip[1] += DOT(disp,v->vvec)*d*180.0/v->vert;
| 218 |
return;
| 219 |
| 220 |
ip[0] = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff;
| 221 |
ip[1] = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff;
| 222 |
| 223 |
| 224 |
| 225 |
pix2loc(loc, rp, px, py) /* compute image location from pixel pos. */
| 226 |
FLOAT loc[2];
| 227 |
register RESOLU *rp;
| 228 |
int px, py;
| 229 |
| 230 |
register int x, y;
| 231 |
| 232 |
if (rp->or & YMAJOR) {
| 233 |
x = px;
| 234 |
y = py;
| 235 |
} else {
| 236 |
x = py;
| 237 |
y = px;
| 238 |
| 239 |
if (rp->or & XDECR)
| 240 |
x = rp->xr-1 - x;
| 241 |
if (rp->or & YDECR)
| 242 |
y = rp->yr-1 - y;
| 243 |
loc[0] = (x+.5)/rp->xr;
| 244 |
loc[1] = (y+.5)/rp->yr;
| 245 |
| 246 |
| 247 |
| 248 |
loc2pix(pp, rp, lx, ly) /* compute pixel pos. from image location */
| 249 |
int pp[2];
| 250 |
| 251 |
double lx, ly;
| 252 |
| 253 |
register int x, y;
| 254 |
| 255 |
x = lx * rp->xr;
| 256 |
y = ly * rp->yr;
| 257 |
if (rp->or & XDECR)
| 258 |
x = rp->xr-1 - x;
| 259 |
if (rp->or & YDECR)
| 260 |
y = rp->yr-1 - y;
| 261 |
| 262 |
pp[0] = x;
| 263 |
pp[1] = y;
| 264 |
} else {
| 265 |
pp[0] = y;
| 266 |
pp[1] = x;
| 267 |
| 268 |
| 269 |
| 270 |
| 271 |
int
| 272 |
getviewopt(v, ac, av) /* process view argument */
| 273 |
register VIEW *v;
| 274 |
int ac;
| 275 |
register char *av[];
| 276 |
| 277 |
#define check(c,l) if ((av[0][c]&&av[0][c]!=' ') || \
| 278 |
badarg(ac-1,av+1,l)) return(-1)
| 279 |
extern double atof();
| 280 |
| 281 |
if (ac <= 0 || av[0][0] != '-' || av[0][1] != 'v')
| 282 |
return(-1);
| 283 |
switch (av[0][2]) {
| 284 |
case 't': /* type */
| 285 |
if (!av[0][3] || av[0][3]==' ')
| 286 |
return(-1);
| 287 |
check(4,"");
| 288 |
v->type = av[0][3];
| 289 |
return(0);
| 290 |
case 'p': /* point */
| 291 |
check(3,"fff");
| 292 |
v->vp[0] = atof(av[1]);
| 293 |
v->vp[1] = atof(av[2]);
| 294 |
v->vp[2] = atof(av[3]);
| 295 |
return(3);
| 296 |
case 'd': /* direction */
| 297 |
check(3,"fff");
| 298 |
v->vdir[0] = atof(av[1]);
| 299 |
v->vdir[1] = atof(av[2]);
| 300 |
v->vdir[2] = atof(av[3]);
| 301 |
return(3);
| 302 |
case 'u': /* up */
| 303 |
check(3,"fff");
| 304 |
v->vup[0] = atof(av[1]);
| 305 |
v->vup[1] = atof(av[2]);
| 306 |
v->vup[2] = atof(av[3]);
| 307 |
return(3);
| 308 |
case 'h': /* horizontal size */
| 309 |
check(3,"f");
| 310 |
v->horiz = atof(av[1]);
| 311 |
return(1);
| 312 |
case 'v': /* vertical size */
| 313 |
check(3,"f");
| 314 |
v->vert = atof(av[1]);
| 315 |
return(1);
| 316 |
case 's': /* shift */
| 317 |
check(3,"f");
| 318 |
v->hoff = atof(av[1]);
| 319 |
return(1);
| 320 |
case 'l': /* lift */
| 321 |
check(3,"f");
| 322 |
v->voff = atof(av[1]);
| 323 |
return(1);
| 324 |
default:
| 325 |
return(-1);
| 326 |
| 327 |
#undef check
| 328 |
| 329 |
| 330 |
| 331 |
int
| 332 |
sscanview(vp, s) /* get view parameters from string */
| 333 |
VIEW *vp;
| 334 |
register char *s;
| 335 |
| 336 |
int ac;
| 337 |
char *av[4];
| 338 |
int na;
| 339 |
int nvopts = 0;
| 340 |
| 341 |
while (*s == ' ')
| 342 |
s++;
| 343 |
while (*s) {
| 344 |
ac = 0;
| 345 |
do {
| 346 |
av[ac++] = s;
| 347 |
while (*s && *s != ' ')
| 348 |
s++;
| 349 |
while (*s == ' ')
| 350 |
s++;
| 351 |
} while (*s && ac < 4);
| 352 |
if ((na = getviewopt(vp, ac, av)) >= 0) {
| 353 |
if (na+1 < ac)
| 354 |
s = av[na+1];
| 355 |
nvopts++;
| 356 |
} else if (ac > 1)
| 357 |
s = av[1];
| 358 |
| 359 |
return(nvopts);
| 360 |
| 361 |
| 362 |
| 363 |
fprintview(vp, fp) /* write out view parameters */
| 364 |
register VIEW *vp;
| 365 |
FILE *fp;
| 366 |
| 367 |
fprintf(fp, " -vt%c", vp->type);
| 368 |
fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]);
| 369 |
fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]);
| 370 |
fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]);
| 371 |
fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert);
| 372 |
fprintf(fp, " -vs %.6g -vl %.6g", vp->hoff, vp->voff);
| 373 |
| 374 |
| 375 |
| 376 |
static char *altname[] = {NULL,"rpict","rview","pinterp",VIEWSTR,NULL};
| 377 |
| 378 |
struct myview {
| 379 |
VIEW *hv;
| 380 |
int ok;
| 381 |
| 382 |
| 383 |
| 384 |
static
| 385 |
gethview(s, v) /* get view from header */
| 386 |
char *s;
| 387 |
register struct myview *v;
| 388 |
| 389 |
register char **an;
| 390 |
| 391 |
for (an = altname; *an != NULL; an++)
| 392 |
if (!strncmp(*an, s, strlen(*an))) {
| 393 |
if (sscanview(v->hv, s+strlen(*an)) > 0)
| 394 |
v->ok++;
| 395 |
return;
| 396 |
| 397 |
| 398 |
| 399 |
| 400 |
int
| 401 |
viewfile(fname, vp, rp) /* get view from file */
| 402 |
char *fname;
| 403 |
VIEW *vp;
| 404 |
RESOLU *rp;
| 405 |
| 406 |
extern char *progname;
| 407 |
struct myview mvs;
| 408 |
FILE *fp;
| 409 |
| 410 |
if ((fp = fopen(fname, "r")) == NULL)
| 411 |
return(-1);
| 412 |
| 413 |
altname[0] = progname;
| 414 |
mvs.hv = vp;
| 415 |
mvs.ok = 0;
| 416 |
| 417 |
getheader(fp, gethview, &mvs);
| 418 |
| 419 |
if (rp != NULL && !fgetsresolu(rp, fp))
| 420 |
mvs.ok = 0;
| 421 |
| 422 |
fclose(fp);
| 423 |
| 424 |
return(mvs.ok);
| 425 |
