root/Development/ray/src/common/image.c
Revision: 1.8
Committed: Tue Jan 16 11:29:43 1990 UTC (35 years, 9 months ago) by greg
added ability to recover dimensions from picture files
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * image.c - routines for image generation.
9 *
10 * 10/17/85
11 */
12
13 #include "standard.h"
14
15 #include "view.h"
16
17 VIEW stdview = STDVIEW; /* default view parameters */
18
19
20 char *
21 setview(v) /* set hvec and vvec, return message on error */
22 register VIEW *v;
23 {
24 extern double tan(), normalize();
25
26 if (normalize(v->vdir) == 0.0) /* normalize direction */
27 return("zero view direction");
28
29 fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */
30
31 if (normalize(v->hvec) == 0.0)
32 return("illegal view up vector");
33
34 fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */
35
36 if (v->type == VT_PAR)
37 v->hn2 = v->horiz;
38 else if (v->type == VT_PER)
39 v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0));
40 else
41 return("unknown view type");
42
43 if (v->hn2 <= FTINY || v->hn2 >= FHUGE)
44 return("illegal horizontal view size");
45
46 v->hvec[0] *= v->hn2;
47 v->hvec[1] *= v->hn2;
48 v->hvec[2] *= v->hn2;
49 v->hn2 *= v->hn2;
50
51 if (v->type == VT_PAR)
52 v->vn2 = v->vert;
53 else
54 v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0));
55
56 if (v->vn2 <= FTINY || v->vn2 >= FHUGE)
57 return("illegal vertical view size");
58
59 v->vvec[0] *= v->vn2;
60 v->vvec[1] *= v->vn2;
61 v->vvec[2] *= v->vn2;
62 v->vn2 *= v->vn2;
63
64 return(NULL);
65 }
66
67
68 normaspect(va, ap, xp, yp) /* fix pixel aspect or resolution */
69 double va; /* view aspect ratio */
70 double *ap; /* pixel aspect in (or out if 0) */
71 int *xp, *yp; /* x and y resolution in (or out if *ap!=0) */
72 {
73 if (*ap <= FTINY)
74 *ap = va * *xp / *yp; /* compute pixel aspect */
75 else if (va * *xp > *ap * *yp)
76 *xp = *yp / va * *ap; /* reduce x resolution */
77 else
78 *yp = *xp * va / *ap; /* reduce y resolution */
79 }
80
81
82 viewray(orig, direc, v, x, y) /* compute ray origin and direction */
83 FVECT orig, direc;
84 register VIEW *v;
85 double x, y;
86 {
87 x += v->hoff - 0.5;
88 y += v->voff - 0.5;
89
90 if (v->type == VT_PAR) { /* parallel view */
91 orig[0] = v->vp[0] + x*v->hvec[0] + y*v->vvec[0];
92 orig[1] = v->vp[1] + x*v->hvec[1] + y*v->vvec[1];
93 orig[2] = v->vp[2] + x*v->hvec[2] + y*v->vvec[2];
94 VCOPY(direc, v->vdir);
95 } else { /* perspective view */
96 VCOPY(orig, v->vp);
97 direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
98 direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
99 direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
100 normalize(direc);
101 }
102 }
103
104
105 viewpixel(xp, yp, zp, v, p) /* find image location for point */
106 double *xp, *yp, *zp;
107 register VIEW *v;
108 FVECT p;
109 {
110 extern double sqrt();
111 double d;
112 FVECT disp;
113
114 disp[0] = p[0] - v->vp[0];
115 disp[1] = p[1] - v->vp[1];
116 disp[2] = p[2] - v->vp[2];
117
118 if (v->type == VT_PAR) { /* parallel view */
119 if (zp != NULL)
120 *zp = DOT(disp,v->vdir);
121 } else { /* perspective view */
122 d = 1.0/DOT(disp,v->vdir);
123 if (zp != NULL) {
124 *zp = sqrt(DOT(disp,disp));
125 if (d < 0.0)
126 *zp = -*zp;
127 }
128 disp[0] *= d;
129 disp[1] *= d;
130 disp[2] *= d;
131 }
132 *xp = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff;
133 *yp = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff;
134 }
135
136
137 int
138 getviewopt(v, ac, av) /* process view argument */
139 register VIEW *v;
140 int ac;
141 register char *av[];
142 {
143 #define check(c,n) if ((av[0][c]&&av[0][c]!=' ') || n>=ac) return(-1)
144 extern double atof();
145
146 if (av[0][0] != '-' || av[0][1] != 'v')
147 return(-1);
148 switch (av[0][2]) {
149 case 't': /* type */
150 if (!av[0][3] || av[0][3]==' ')
151 return(-1);
152 check(4,0);
153 v->type = av[0][3];
154 return(0);
155 case 'p': /* point */
156 check(3,3);
157 v->vp[0] = atof(av[1]);
158 v->vp[1] = atof(av[2]);
159 v->vp[2] = atof(av[3]);
160 return(3);
161 case 'd': /* direction */
162 check(3,3);
163 v->vdir[0] = atof(av[1]);
164 v->vdir[1] = atof(av[2]);
165 v->vdir[2] = atof(av[3]);
166 return(3);
167 case 'u': /* up */
168 check(3,3);
169 v->vup[0] = atof(av[1]);
170 v->vup[1] = atof(av[2]);
171 v->vup[2] = atof(av[3]);
172 return(3);
173 case 'h': /* horizontal size */
174 check(3,1);
175 v->horiz = atof(av[1]);
176 return(1);
177 case 'v': /* vertical size */
178 check(3,1);
179 v->vert = atof(av[1]);
180 return(1);
181 case 's': /* shift */
182 check(3,1);
183 v->hoff = atof(av[1]);
184 return(1);
185 case 'l': /* lift */
186 check(3,1);
187 v->voff = atof(av[1]);
188 return(1);
189 default:
190 return(-1);
191 }
192 #undef check
193 }
194
195
196 int
197 sscanview(vp, s) /* get view parameters from string */
198 VIEW *vp;
199 register char *s;
200 {
201 int ac;
202 char *av[4];
203 int na;
204 int nvopts = 0;
205
206 while (*s == ' ')
207 s++;
208 do {
209 ac = 0;
210 do {
211 av[ac++] = s;
212 while (*s && *s != ' ')
213 s++;
214 while (*s == ' ')
215 s++;
216 } while (*s && ac < 4);
217 if ((na = getviewopt(vp, ac, av)) >= 0) {
218 if (na+1 < ac)
219 s = av[na+1];
220 nvopts++;
221 }
222 } while (*s);
223 return(nvopts);
224 }
225
226
227 fprintview(vp, fp) /* write out view parameters */
228 register VIEW *vp;
229 FILE *fp;
230 {
231 fprintf(fp, " -vt%c", vp->type);
232 fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]);
233 fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]);
234 fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]);
235 fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert);
236 fprintf(fp, " -vs %d -vl %d", vp->hoff, vp->voff);
237 }
238
239
240 static VIEW *hview; /* view from header */
241 static int gothview; /* success indicator */
242 static char *altname[] = {NULL,"rpict","rview","pinterp",VIEWSTR,NULL};
243
244
245 static
246 gethview(s) /* get view from header */
247 char *s;
248 {
249 register char **an;
250
251 for (an = altname; *an != NULL; an++)
252 if (!strncmp(*an, s, strlen(*an))) {
253 if (sscanview(hview, s+strlen(*an)) > 0)
254 gothview++;
255 return;
256 }
257 }
258
259
260 int
261 viewfile(fname, vp, xp, yp) /* get view from file */
262 char *fname;
263 VIEW *vp;
264 int *xp, *yp;
265 {
266 extern char *progname;
267 FILE *fp;
268
269 if ((fp = fopen(fname, "r")) == NULL)
270 return(-1);
271
272 altname[0] = progname;
273 hview = vp;
274 gothview = 0;
275
276 getheader(fp, gethview);
277
278 if (xp != NULL && yp != NULL
279 && fgetresolu(xp, yp, fp) == -1)
280 gothview = 0;
281
282 fclose(fp);
283
284 return(gothview);
285 }
