root/radiance/ray/src/common/image.c
Revision: 1.5
Committed: Mon Jan 8 14:45:52 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.4: +122 -127 lines
got rid of resolution and added shift and lift options
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * image.c - routines for image generation.
9 *
10 * 10/17/85
11 */
12
13 #include "standard.h"
14
15 #include "view.h"
16
17 VIEW stdview = STDVIEW; /* default view parameters */
18
19
20 char *
21 setview(v) /* set hvec and vvec, return message on error */
22 register VIEW *v;
23 {
24 extern double tan(), normalize();
25
26 if (normalize(v->vdir) == 0.0) /* normalize direction */
27 return("zero view direction");
28
29 fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */
30
31 if (normalize(v->hvec) == 0.0)
32 return("illegal view up vector");
33
34 fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */
35
36 if (v->type == VT_PAR)
37 v->hn2 = v->horiz;
38 else if (v->type == VT_PER)
39 v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0));
40 else
41 return("unknown view type");
42
43 if (v->hn2 <= FTINY || v->hn2 >= FHUGE)
44 return("illegal horizontal view size");
45
46 v->hvec[0] *= v->hn2;
47 v->hvec[1] *= v->hn2;
48 v->hvec[2] *= v->hn2;
49 v->hn2 *= v->hn2;
50
51 if (v->type == VT_PAR)
52 v->vn2 = v->vert;
53 else
54 v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0));
55
56 if (v->vn2 <= FTINY || v->vn2 >= FHUGE)
57 return("illegal vertical view size");
58
59 v->vvec[0] *= v->vn2;
60 v->vvec[1] *= v->vn2;
61 v->vvec[2] *= v->vn2;
62 v->vn2 *= v->vn2;
63
64 return(NULL);
65 }
66
67
68 viewray(orig, direc, v, x, y) /* compute ray origin and direction */
69 FVECT orig, direc;
70 register VIEW *v;
71 double x, y;
72 {
73 x += v->hoff - 0.5;
74 y += v->voff - 0.5;
75
76 if (v->type == VT_PAR) { /* parallel view */
77 orig[0] = v->vp[0] + x*v->hvec[0] + y*v->vvec[0];
78 orig[1] = v->vp[1] + x*v->hvec[1] + y*v->vvec[1];
79 orig[2] = v->vp[2] + x*v->hvec[2] + y*v->vvec[2];
80 VCOPY(direc, v->vdir);
81 } else { /* perspective view */
82 VCOPY(orig, v->vp);
83 direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
84 direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
85 direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
86 normalize(direc);
87 }
88 }
89
90
91 viewpixel(xp, yp, zp, v, p) /* find image location for point */
92 double *xp, *yp, *zp;
93 register VIEW *v;
94 FVECT p;
95 {
96 extern double sqrt();
97 double d;
98 FVECT disp;
99
100 disp[0] = p[0] - v->vp[0];
101 disp[1] = p[1] - v->vp[1];
102 disp[2] = p[2] - v->vp[2];
103
104 if (v->type == VT_PAR) { /* parallel view */
105 if (zp != NULL)
106 *zp = DOT(disp,v->vdir);
107 } else { /* perspective view */
108 d = 1.0/DOT(disp,v->vdir);
109 if (zp != NULL) {
110 *zp = sqrt(DOT(disp,disp));
111 if (d < 0.0)
112 *zp = -*zp;
113 }
114 disp[0] *= d;
115 disp[1] *= d;
116 disp[2] *= d;
117 }
118 *xp = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff;
119 *yp = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff;
120 }
121
122
123 int
124 getviewopt(v, ac, av) /* process view argument */
125 register VIEW *v;
126 int ac;
127 register char *av[];
128 {
129 #define check(c,n) if ((av[0][c]&&av[0][c]!=' ') || n>=ac) return(-1)
130 extern double atof();
131
132 if (av[0][0] != '-' || av[0][1] != 'v')
133 return(-1);
134 switch (av[0][2]) {
135 case 't': /* type */
136 if (!av[0][3] || av[0][3]==' ')
137 return(-1);
138 check(4,0);
139 v->type = av[0][3];
140 return(0);
141 case 'p': /* point */
142 check(3,3);
143 v->vp[0] = atof(av[1]);
144 v->vp[1] = atof(av[2]);
145 v->vp[2] = atof(av[3]);
146 return(3);
147 case 'd': /* direction */
148 check(3,3);
149 v->vdir[0] = atof(av[1]);
150 v->vdir[1] = atof(av[2]);
151 v->vdir[2] = atof(av[3]);
152 return(3);
153 case 'u': /* up */
154 check(3,3);
155 v->vup[0] = atof(av[1]);
156 v->vup[1] = atof(av[2]);
157 v->vup[2] = atof(av[3]);
158 return(3);
159 case 'h': /* horizontal size */
160 check(3,1);
161 v->horiz = atof(av[1]);
162 return(1);
163 case 'v': /* vertical size */
164 check(3,1);
165 v->vert = atof(av[1]);
166 return(1);
167 case 's': /* shift */
168 check(3,1);
169 v->hoff = atof(av[1]);
170 return(1);
171 case 'l': /* lift */
172 check(3,1);
173 v->voff = atof(av[1]);
174 return(1);
175 default:
176 return(-1);
177 }
178 #undef check
179 }
180
181
182 int
183 sscanview(vp, s) /* get view parameters from string */
184 VIEW *vp;
185 register char *s;
186 {
187 int ac;
188 char *av[4];
189 int na;
190 int nvopts = 0;
191
192 while (*s == ' ')
193 s++;
194 do {
195 ac = 0;
196 do {
197 av[ac++] = s;
198 while (*s && *s != ' ')
199 s++;
200 while (*s == ' ')
201 s++;
202 } while (*s && ac < 4);
203 if ((na = getviewopt(vp, ac, av)) >= 0) {
204 if (na+1 < ac)
205 s = av[na+1];
206 nvopts++;
207 }
208 } while (*s);
209 return(nvopts);
210 }
211
212
213 fprintview(vp, fp) /* write out view parameters */
214 register VIEW *vp;
215 FILE *fp;
216 {
217 fprintf(fp, " -vt%c", vp->type);
218 fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]);
219 fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]);
220 fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]);
221 fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert);
222 fprintf(fp, " -vs %d -vl %d", vp->hoff, vp->voff);
223 }
224
225
226 static VIEW *hview; /* view from header */
227 static int gothview; /* success indicator */
228 static char *altname[] = {NULL,"rpict","rview","pinterp",VIEWSTR,NULL};
229
230
231 static
232 gethview(s) /* get view from header */
233 char *s;
234 {
235 register char **an;
236
237 for (an = altname; *an != NULL; an++)
238 if (!strncmp(*an, s, strlen(*an))) {
239 if (sscanview(hview, s+strlen(*an)) > 0)
240 gothview++;
241 return;
242 }
243 }
244
245
246 int
247 viewfile(fname, vp) /* get view from file */
248 char *fname;
249 VIEW *vp;
250 {
251 extern char *progname;
252 FILE *fp;
253
254 if ((fp = fopen(fname, "r")) == NULL)
255 return(-1);
256
257 altname[0] = progname;
258 hview = vp;
259 gothview = 0;
260
261 getheader(fp, gethview);
262
263 fclose(fp);
264
265 return(gothview);
266 }
