1 |
/* Copyright (c) 1986 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* image.c - routines for image generation. |
9 |
10 |
* 10/17/85 |
11 |
12 |
13 |
#include "standard.h" |
14 |
15 |
#include "view.h" |
16 |
17 |
VIEW stdview = STDVIEW; /* default view parameters */ |
18 |
19 |
20 |
char * |
21 |
setview(v) /* set hvec and vvec, return message on error */ |
22 |
register VIEW *v; |
23 |
24 |
static char ill_horiz[] = "illegal horizontal view size"; |
25 |
static char ill_vert[] = "illegal vertical view size"; |
26 |
27 |
if (normalize(v->vdir) == 0.0) /* normalize direction */ |
28 |
return("zero view direction"); |
29 |
30 |
fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */ |
31 |
32 |
if (normalize(v->hvec) == 0.0) |
33 |
return("illegal view up vector"); |
34 |
35 |
fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */ |
36 |
37 |
if (v->horiz <= FTINY) |
38 |
return(ill_horiz); |
39 |
if (v->vert <= FTINY) |
40 |
return(ill_vert); |
41 |
42 |
switch (v->type) { |
43 |
case VT_PAR: /* parallel view */ |
44 |
v->hn2 = v->horiz; |
45 |
v->vn2 = v->vert; |
46 |
break; |
47 |
case VT_PER: /* perspective view */ |
48 |
if (v->horiz >= 180.0-FTINY) |
49 |
50 |
if (v->vert >= 180.0-FTINY) |
51 |
return(ill_vert); |
52 |
v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0)); |
53 |
v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0)); |
54 |
break; |
55 |
case VT_ANG: /* angular fisheye */ |
56 |
if (v->horiz > 360.0+FTINY) |
57 |
58 |
if (v->vert > 360.0+FTINY) |
59 |
return(ill_vert); |
60 |
v->hn2 = v->horiz / 90.0; |
61 |
v->vn2 = v->vert / 90.0; |
62 |
break; |
63 |
case VT_HEM: /* hemispherical fisheye */ |
64 |
if (v->horiz > 180.0+FTINY) |
65 |
66 |
if (v->vert > 180.0+FTINY) |
67 |
return(ill_vert); |
68 |
v->hn2 = 2.0 * sin(v->horiz*(PI/180.0/2.0)); |
69 |
v->vn2 = 2.0 * sin(v->vert*(PI/180.0/2.0)); |
70 |
break; |
71 |
default: |
72 |
return("unknown view type"); |
73 |
74 |
if (v->type != VT_ANG) { |
75 |
v->hvec[0] *= v->hn2; |
76 |
v->hvec[1] *= v->hn2; |
77 |
v->hvec[2] *= v->hn2; |
78 |
v->vvec[0] *= v->vn2; |
79 |
v->vvec[1] *= v->vn2; |
80 |
v->vvec[2] *= v->vn2; |
81 |
82 |
v->hn2 *= v->hn2; |
83 |
v->vn2 *= v->vn2; |
84 |
85 |
return(NULL); |
86 |
87 |
88 |
89 |
normaspect(va, ap, xp, yp) /* fix pixel aspect or resolution */ |
90 |
double va; /* view aspect ratio */ |
91 |
double *ap; /* pixel aspect in (or out if 0) */ |
92 |
int *xp, *yp; /* x and y resolution in (or out if *ap!=0) */ |
93 |
94 |
if (*ap <= FTINY) |
95 |
*ap = va * *xp / *yp; /* compute pixel aspect */ |
96 |
else if (va * *xp > *ap * *yp) |
97 |
*xp = *yp / va * *ap + .5; /* reduce x resolution */ |
98 |
else |
99 |
*yp = *xp * va / *ap + .5; /* reduce y resolution */ |
100 |
101 |
102 |
103 |
viewray(orig, direc, v, x, y) /* compute ray origin and direction */ |
104 |
FVECT orig, direc; |
105 |
register VIEW *v; |
106 |
double x, y; |
107 |
108 |
double d, z; |
109 |
110 |
x += v->hoff - 0.5; |
111 |
y += v->voff - 0.5; |
112 |
113 |
switch(v->type) { |
114 |
115 |
orig[0] = v->vp[0] + x*v->hvec[0] + y*v->vvec[0]; |
116 |
orig[1] = v->vp[1] + x*v->hvec[1] + y*v->vvec[1]; |
117 |
orig[2] = v->vp[2] + x*v->hvec[2] + y*v->vvec[2]; |
118 |
VCOPY(direc, v->vdir); |
119 |
return(0); |
120 |
121 |
VCOPY(orig, v->vp); |
122 |
direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; |
123 |
direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; |
124 |
direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; |
125 |
normalize(direc); |
126 |
return(0); |
127 |
128 |
z = 1.0 - x*x*v->hn2 - y*y*v->vn2; |
129 |
if (z < 0.0) |
130 |
return(-1); |
131 |
z = sqrt(z); |
132 |
133 |
direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; |
134 |
direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; |
135 |
direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; |
136 |
return(0); |
137 |
138 |
x *= v->horiz/180.0; |
139 |
y *= v->vert/180.0; |
140 |
d = x*x + y*y; |
141 |
if (d > 1.0) |
142 |
return(-1); |
143 |
144 |
if (d <= FTINY) { |
145 |
146 |
return(0); |
147 |
148 |
d = sqrt(d); |
149 |
z = cos(PI*d); |
150 |
d = sqrt(1 - z*z)/d; |
151 |
x *= d; |
152 |
y *= d; |
153 |
154 |
155 |
156 |
return(0); |
157 |
158 |
return(-1); |
159 |
160 |
161 |
162 |
viewpixel(xp, yp, zp, v, p) /* find image location for point */ |
163 |
double *xp, *yp, *zp; |
164 |
register VIEW *v; |
165 |
FVECT p; |
166 |
167 |
double d; |
168 |
FVECT disp; |
169 |
170 |
disp[0] = p[0] - v->vp[0]; |
171 |
disp[1] = p[1] - v->vp[1]; |
172 |
disp[2] = p[2] - v->vp[2]; |
173 |
174 |
175 |
176 |
if (zp != NULL) |
177 |
*zp = DOT(disp,v->vdir); |
178 |
break; |
179 |
180 |
d = DOT(disp,v->vdir); |
181 |
if (zp != NULL) { |
182 |
*zp = sqrt(DOT(disp,disp)); |
183 |
if (d < 0.0) |
184 |
*zp = -*zp; |
185 |
186 |
if (d < 0.0) /* fold pyramid */ |
187 |
d = -d; |
188 |
if (d > FTINY) { |
189 |
d = 1.0/d; |
190 |
disp[0] *= d; |
191 |
disp[1] *= d; |
192 |
disp[2] *= d; |
193 |
194 |
break; |
195 |
196 |
d = normalize(disp); |
197 |
if (zp != NULL) { |
198 |
if (DOT(disp,v->vdir) < 0.0) |
199 |
*zp = -d; |
200 |
else |
201 |
*zp = d; |
202 |
203 |
break; |
204 |
205 |
206 |
if (zp != NULL) |
207 |
*zp = d; |
208 |
*xp = 0.5 - v->hoff; |
209 |
*yp = 0.5 - v->voff; |
210 |
211 |
if (d >= 1.0-FTINY) |
212 |
return; |
213 |
if (d <= -(1.0-FTINY)) { |
214 |
*xp += 180.0/v->horiz; |
215 |
*yp += 180.0/v->vert; |
216 |
return; |
217 |
218 |
d = acos(d)/PI / sqrt(1.0 - d*d); |
219 |
*xp += DOT(disp,v->hvec)*d*180.0/v->horiz; |
220 |
*yp += DOT(disp,v->vvec)*d*180.0/v->vert; |
221 |
return; |
222 |
223 |
*xp = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff; |
224 |
*yp = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff; |
225 |
226 |
227 |
228 |
int |
229 |
getviewopt(v, ac, av) /* process view argument */ |
230 |
register VIEW *v; |
231 |
int ac; |
232 |
register char *av[]; |
233 |
234 |
#define check(c,n) if ((av[0][c]&&av[0][c]!=' ') || n>=ac) return(-1) |
235 |
extern double atof(); |
236 |
237 |
if (ac <= 0 || av[0][0] != '-' || av[0][1] != 'v') |
238 |
return(-1); |
239 |
switch (av[0][2]) { |
240 |
case 't': /* type */ |
241 |
if (!av[0][3] || av[0][3]==' ') |
242 |
return(-1); |
243 |
check(4,0); |
244 |
v->type = av[0][3]; |
245 |
return(0); |
246 |
case 'p': /* point */ |
247 |
check(3,3); |
248 |
v->vp[0] = atof(av[1]); |
249 |
v->vp[1] = atof(av[2]); |
250 |
v->vp[2] = atof(av[3]); |
251 |
return(3); |
252 |
case 'd': /* direction */ |
253 |
check(3,3); |
254 |
v->vdir[0] = atof(av[1]); |
255 |
v->vdir[1] = atof(av[2]); |
256 |
v->vdir[2] = atof(av[3]); |
257 |
return(3); |
258 |
case 'u': /* up */ |
259 |
check(3,3); |
260 |
v->vup[0] = atof(av[1]); |
261 |
v->vup[1] = atof(av[2]); |
262 |
v->vup[2] = atof(av[3]); |
263 |
return(3); |
264 |
case 'h': /* horizontal size */ |
265 |
check(3,1); |
266 |
v->horiz = atof(av[1]); |
267 |
return(1); |
268 |
case 'v': /* vertical size */ |
269 |
check(3,1); |
270 |
v->vert = atof(av[1]); |
271 |
return(1); |
272 |
case 's': /* shift */ |
273 |
check(3,1); |
274 |
v->hoff = atof(av[1]); |
275 |
return(1); |
276 |
case 'l': /* lift */ |
277 |
check(3,1); |
278 |
v->voff = atof(av[1]); |
279 |
return(1); |
280 |
default: |
281 |
return(-1); |
282 |
283 |
#undef check |
284 |
285 |
286 |
287 |
int |
288 |
sscanview(vp, s) /* get view parameters from string */ |
289 |
VIEW *vp; |
290 |
register char *s; |
291 |
292 |
int ac; |
293 |
char *av[4]; |
294 |
int na; |
295 |
int nvopts = 0; |
296 |
297 |
while (*s == ' ') |
298 |
s++; |
299 |
while (*s) { |
300 |
ac = 0; |
301 |
do { |
302 |
av[ac++] = s; |
303 |
while (*s && *s != ' ') |
304 |
s++; |
305 |
while (*s == ' ') |
306 |
s++; |
307 |
} while (*s && ac < 4); |
308 |
if ((na = getviewopt(vp, ac, av)) >= 0) { |
309 |
if (na+1 < ac) |
310 |
s = av[na+1]; |
311 |
nvopts++; |
312 |
} else if (ac > 1) |
313 |
s = av[1]; |
314 |
315 |
return(nvopts); |
316 |
317 |
318 |
319 |
fprintview(vp, fp) /* write out view parameters */ |
320 |
register VIEW *vp; |
321 |
FILE *fp; |
322 |
323 |
fprintf(fp, " -vt%c", vp->type); |
324 |
fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]); |
325 |
fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]); |
326 |
fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]); |
327 |
fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert); |
328 |
fprintf(fp, " -vs %.6g -vl %.6g", vp->hoff, vp->voff); |
329 |
330 |
331 |
332 |
static VIEW *hview; /* view from header */ |
333 |
static int gothview; /* success indicator */ |
334 |
static char *altname[] = {NULL,"rpict","rview","pinterp",VIEWSTR,NULL}; |
335 |
336 |
337 |
static |
338 |
gethview(s) /* get view from header */ |
339 |
char *s; |
340 |
341 |
register char **an; |
342 |
343 |
for (an = altname; *an != NULL; an++) |
344 |
if (!strncmp(*an, s, strlen(*an))) { |
345 |
if (sscanview(hview, s+strlen(*an)) > 0) |
346 |
gothview++; |
347 |
return; |
348 |
349 |
350 |
351 |
352 |
int |
353 |
viewfile(fname, vp, xp, yp) /* get view from file */ |
354 |
char *fname; |
355 |
VIEW *vp; |
356 |
int *xp, *yp; |
357 |
358 |
extern char *progname; |
359 |
FILE *fp; |
360 |
361 |
if ((fp = fopen(fname, "r")) == NULL) |
362 |
return(-1); |
363 |
364 |
altname[0] = progname; |
365 |
hview = vp; |
366 |
gothview = 0; |
367 |
368 |
getheader(fp, gethview); |
369 |
370 |
if (xp != NULL && yp != NULL |
371 |
&& fgetresolu(xp, yp, fp) == -1) |
372 |
gothview = 0; |
373 |
374 |
fclose(fp); |
375 |
376 |
return(gothview); |
377 |
