--- ray/src/common/image.c 1997/12/09 16:41:03 2.13 +++ ray/src/common/image.c 2025/06/25 15:28:56 2.58 @@ -1,40 +1,41 @@ -/* Copyright (c) 1996 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: image.c,v 2.58 2025/06/25 15:28:56 greg Exp $"; #endif - /* * image.c - routines for image generation. + * + * External symbols declared in view.h */ -#include "standard.h" +#include "copyright.h" +#include +#include "rtio.h" +#include "rtmath.h" +#include "paths.h" #include "view.h" -#include "resolu.h" - -#include "paths.h" - -#define FEQ(x,y) (fabs((x)-(y)) <= FTINY) -#define VEQ(v,w) (FEQ((v)[0],(w)[0]) && FEQ((v)[1],(w)[1]) \ - && FEQ((v)[2],(w)[2])) - VIEW stdview = STDVIEW; /* default view parameters */ +static gethfunc gethview; + char * -setview(v) /* set hvec and vvec, return message on error */ -register VIEW *v; +setview( /* set hvec and vvec, return message on error */ +VIEW *v +) { static char ill_horiz[] = "illegal horizontal view size"; static char ill_vert[] = "illegal vertical view size"; - if (v->vfore < -FTINY || v->vaft < -FTINY || - (v->vaft > FTINY && v->vaft <= v->vfore)) + if ((v->vfore < -FTINY) | (v->vaft < -FTINY) || + (v->vaft > FTINY) & (v->vaft <= v->vfore)) return("illegal fore/aft clipping plane"); - if (normalize(v->vdir) == 0.0) /* normalize direction */ + if (v->vdist <= FTINY) + return("illegal view distance"); + v->vdist *= normalize(v->vdir); /* normalize direction */ + if (v->vdist == 0.0) return("zero view direction"); if (normalize(v->vup) == 0.0) /* normalize view up */ @@ -62,8 +63,8 @@ register VIEW *v; return(ill_horiz); if (v->vert >= 180.0-FTINY) return(ill_vert); - v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0)); - v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0)); + v->hn2 = 2.0 * tan(v->horiz*(PI/360.)); + v->vn2 = 2.0 * tan(v->vert*(PI/360.)); break; case VT_CYL: /* cylindrical panorama */ if (v->horiz > 360.0+FTINY) @@ -71,7 +72,7 @@ register VIEW *v; if (v->vert >= 180.0-FTINY) return(ill_vert); v->hn2 = v->horiz * (PI/180.0); - v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0)); + v->vn2 = 2.0 * tan(v->vert*(PI/360.)); break; case VT_ANG: /* angular fisheye */ if (v->horiz > 360.0+FTINY) @@ -86,13 +87,23 @@ register VIEW *v; return(ill_horiz); if (v->vert > 180.0+FTINY) return(ill_vert); - v->hn2 = 2.0 * sin(v->horiz*(PI/180.0/2.0)); - v->vn2 = 2.0 * sin(v->vert*(PI/180.0/2.0)); + v->hn2 = 2.0 * sin(v->horiz*(PI/360.)); + v->vn2 = 2.0 * sin(v->vert*(PI/360.)); break; + case VT_PLS: /* planispheric fisheye */ + if (v->horiz >= 360.0-FTINY) + return(ill_horiz); + if (v->vert >= 360.0-FTINY) + return(ill_vert); + v->hn2 = 2.*sin(v->horiz*(PI/360.)) / + (1.0 + cos(v->horiz*(PI/360.))); + v->vn2 = 2.*sin(v->vert*(PI/360.)) / + (1.0 + cos(v->vert*(PI/360.))); + break; default: return("unknown view type"); } - if (v->type != VT_ANG) { + if (v->type != VT_ANG && v->type != VT_PLS) { if (v->type != VT_CYL) { v->hvec[0] *= v->hn2; v->hvec[1] *= v->hn2; @@ -109,11 +120,87 @@ register VIEW *v; } -normaspect(va, ap, xp, yp) /* fix pixel aspect or resolution */ -double va; /* view aspect ratio */ -double *ap; /* pixel aspect in (or out if 0) */ -int *xp, *yp; /* x and y resolution in (or out if *ap!=0) */ +char * +cropview( /* crop a view to the indicated bounds */ +VIEW *v, +double x0, +double y0, +double x1, +double y1 +) { + static char ill_hemi[] = "illegal crop for hemispherical view"; + double d; + /* order crop extrema */ + if (x0 > x1) { d=x0; x0=x1; x1=d; } + if (y0 > y1) { d=y0; y0=y1; y1=d; } + + if ((x1-x0 <= FTINY) | (y1-y0 <= FTINY)) + return("zero crop area"); + + d = x1 - x0; /* adjust horizontal size? */ + if (!FABSEQ(d, 1.)) + switch (v->type) { + case VT_PER: + v->horiz = 360./PI*atan( d*tan(PI/360.*v->horiz) ); + break; + case VT_PAR: + case VT_ANG: + case VT_CYL: + v->horiz *= d; + break; + case VT_HEM: + d *= sin(PI/360.*v->horiz); + if (d > 1.) + return(ill_hemi); + v->horiz = 360./PI*asin( d ); + break; + case VT_PLS: + d *= sin(PI/360.*v->horiz) / + (1. + cos(PI/360.*v->horiz)); + v->horiz = 360./PI*acos( (1. - d*d) / (1. + d*d) ); + break; + } + + d = y1 - y0; /* adjust vertical size? */ + if (!FABSEQ(d, 1.)) + switch (v->type) { + case VT_PER: + case VT_CYL: + v->vert = 360./PI*atan( d*tan(PI/360.*v->vert) ); + break; + case VT_PAR: + case VT_ANG: + v->vert *= d; + break; + case VT_HEM: + d *= sin(PI/360.*v->vert); + if (d > 1.) + return(ill_hemi); + v->vert = 360./PI*asin( d ); + break; + case VT_PLS: + d *= sin(PI/360.*v->vert) / + (1. + cos(PI/360.*v->vert)); + v->vert = 360./PI*acos( (1. - d*d) / (1. + d*d) ); + break; + } + /* adjust offsets */ + v->hoff = ((x0 + x1)*.5 - .5 + v->hoff) / (x1 - x0); + v->voff = ((y0 + y1)*.5 - .5 + v->voff) / (y1 - y0); + + return(setview(v)); /* final error checks & set-up */ +} + + +void +normaspect( /* fix pixel aspect or resolution */ +double va, /* view aspect ratio */ +double *ap, /* pixel aspect in (or out if 0) */ +int *xp, +int *yp /* x and y resolution in (or out if *ap!=0) */ +) +{ if (*ap <= FTINY) *ap = va * *xp / *yp; /* compute pixel aspect */ else if (va * *xp > *ap * *yp) @@ -124,10 +211,13 @@ int *xp, *yp; /* x and y resolution in (or out if * double -viewray(orig, direc, v, x, y) /* compute ray origin and direction */ -FVECT orig, direc; -register VIEW *v; -double x, y; +viewray( /* compute ray origin and direction */ +FVECT orig, +FVECT direc, +VIEW *v, +double x, +double y +) { double d, z; @@ -148,9 +238,7 @@ double x, y; direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; - orig[0] = v->vp[0] + v->vfore*direc[0]; - orig[1] = v->vp[1] + v->vfore*direc[1]; - orig[2] = v->vp[2] + v->vfore*direc[2]; + VSUM(orig, v->vp, direc, v->vfore); d = normalize(direc); return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0); case VT_HEM: /* hemispherical fisheye */ @@ -161,9 +249,7 @@ double x, y; direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; - orig[0] = v->vp[0] + v->vfore*direc[0]; - orig[1] = v->vp[1] + v->vfore*direc[1]; - orig[2] = v->vp[2] + v->vfore*direc[2]; + VSUM(orig, v->vp, direc, v->vfore); return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0); case VT_CYL: /* cylindrical panorama */ d = x * v->horiz * (PI/180.0); @@ -172,45 +258,54 @@ double x, y; direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; - orig[0] = v->vp[0] + v->vfore*direc[0]; - orig[1] = v->vp[1] + v->vfore*direc[1]; - orig[2] = v->vp[2] + v->vfore*direc[2]; + VSUM(orig, v->vp, direc, v->vfore); d = normalize(direc); return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0); case VT_ANG: /* angular fisheye */ - x *= v->horiz/180.0; - y *= v->vert/180.0; + x *= (1.0/180.0)*v->horiz; + y *= (1.0/180.0)*v->vert; d = x*x + y*y; if (d > 1.0) return(-1.0); d = sqrt(d); z = cos(PI*d); - d = d <= FTINY ? PI : sqrt(1 - z*z)/d; + d = d <= FTINY ? PI : sqrt(1.0 - z*z)/d; x *= d; y *= d; direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; - orig[0] = v->vp[0] + v->vfore*direc[0]; - orig[1] = v->vp[1] + v->vfore*direc[1]; - orig[2] = v->vp[2] + v->vfore*direc[2]; + VSUM(orig, v->vp, direc, v->vfore); return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0); + case VT_PLS: /* planispheric fisheye */ + x *= sqrt(v->hn2); + y *= sqrt(v->vn2); + d = x*x + y*y; + z = (1. - d)/(1. + d); + x *= (1. + z); + y *= (1. + z); + direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; + direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; + direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; + VSUM(orig, v->vp, direc, v->vfore); + return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0); } return(-1.0); } -viewloc(ip, v, p) /* find image location for point */ -FVECT ip; -register VIEW *v; -FVECT p; +int +viewloc( /* find image location for point */ +FVECT ip, +VIEW *v, +FVECT p +) /* Use VL_* flags to interpret return value */ { + int rflags = VL_GOOD; double d, d2; FVECT disp; - disp[0] = p[0] - v->vp[0]; - disp[1] = p[1] - v->vp[1]; - disp[2] = p[2] - v->vp[2]; + VSUB(disp, p, v->vp); switch (v->type) { case VT_PAR: /* parallel view */ @@ -218,17 +313,19 @@ FVECT p; break; case VT_PER: /* perspective view */ d = DOT(disp,v->vdir); + rflags |= VL_BEYOND*((v->vaft > FTINY) & + (d >= v->vaft)); ip[2] = VLEN(disp); - if (d < 0.0) { /* fold pyramid */ + if (d < -FTINY) { /* fold pyramid */ ip[2] = -ip[2]; d = -d; - } - if (d > FTINY) { - d = 1.0/d; - disp[0] *= d; - disp[1] *= d; - disp[2] *= d; - } + } else if (d <= FTINY) + return(VL_BAD); /* at infinite edge */ + d = 1.0/d; + disp[0] *= d; + disp[1] *= d; + disp[2] *= d; + if (ip[2] < 0.0) d = -d; ip[2] *= (1.0 - v->vfore*d); break; case VT_HEM: /* hemispherical fisheye */ @@ -243,70 +340,104 @@ FVECT p; d = DOT(disp,v->hvec); d2 = DOT(disp,v->vdir); ip[0] = 180.0/PI * atan2(d,d2) / v->horiz + 0.5 - v->hoff; - d = 1.0/sqrt(d*d + d2*d2); + d2 = d*d + d2*d2; + if (d2 <= FTINY*FTINY) + return(VL_BAD); /* at pole */ + rflags |= VL_BEYOND*((v->vaft > FTINY) & + (d2 >= v->vaft*v->vaft)); + d = 1.0/sqrt(d2); ip[1] = DOT(disp,v->vvec)*d/v->vn2 + 0.5 - v->voff; ip[2] = VLEN(disp); - if (v->vfore > FTINY) - ip[2] *= (1.0 - v->vfore*d); - return; + ip[2] *= (1.0 - v->vfore*d); + goto gotall; case VT_ANG: /* angular fisheye */ ip[0] = 0.5 - v->hoff; ip[1] = 0.5 - v->voff; ip[2] = normalize(disp) - v->vfore; d = DOT(disp,v->vdir); if (d >= 1.0-FTINY) - return; + goto gotall; if (d <= -(1.0-FTINY)) { ip[0] += 180.0/v->horiz; - return; + goto gotall; } - d = acos(d)/PI / sqrt(1.0 - d*d); - ip[0] += DOT(disp,v->hvec)*d*180.0/v->horiz; - ip[1] += DOT(disp,v->vvec)*d*180.0/v->vert; - return; + d = (180.0/PI)*acos(d) / sqrt(1.0 - d*d); + ip[0] += DOT(disp,v->hvec)*d/v->horiz; + ip[1] += DOT(disp,v->vvec)*d/v->vert; + goto gotall; + case VT_PLS: /* planispheric fisheye */ + ip[0] = 0.5 - v->hoff; + ip[1] = 0.5 - v->voff; + ip[2] = normalize(disp) - v->vfore; + d = DOT(disp,v->vdir); + if (d >= 1.0-FTINY) + goto gotall; + if (d <= -(1.0-FTINY)) + return(VL_BAD); + ip[0] += DOT(disp,v->hvec)/((1. + d)*sqrt(v->hn2)); + ip[1] += DOT(disp,v->vvec)/((1. + d)*sqrt(v->vn2)); + goto gotall; + default: + return(VL_BAD); } ip[0] = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff; ip[1] = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff; +gotall: /* add appropriate return flags */ + if (ip[2] <= 0.0) + rflags |= VL_BEHIND; + else if ((v->type != VT_PER) & (v->type != VT_CYL)) + rflags |= VL_BEYOND*((v->vaft > FTINY) & + (ip[2] >= v->vaft - v->vfore)); + rflags |= VL_OUTSIDE*((0.0 >= ip[0]) | (ip[0] >= 1.0) | + (0.0 >= ip[1]) | (ip[1] >= 1.0)); + return(rflags); } -pix2loc(loc, rp, px, py) /* compute image location from pixel pos. */ -FLOAT loc[2]; -register RESOLU *rp; -int px, py; +void +pix2loc( /* compute image location from pixel pos. */ +RREAL loc[2], +RESOLU *rp, +int px, +int py +) { - register int x, y; + int x, y; - if (rp->or & YMAJOR) { + if (rp->rt & YMAJOR) { x = px; y = py; } else { x = py; y = px; } - if (rp->or & XDECR) + if (rp->rt & XDECR) x = rp->xr-1 - x; - if (rp->or & YDECR) + if (rp->rt & YDECR) y = rp->yr-1 - y; loc[0] = (x+.5)/rp->xr; loc[1] = (y+.5)/rp->yr; } -loc2pix(pp, rp, lx, ly) /* compute pixel pos. from image location */ -int pp[2]; -register RESOLU *rp; -double lx, ly; +void +loc2pix( /* compute pixel pos. from image location */ +int pp[2], +RESOLU *rp, +double lx, +double ly +) { - register int x, y; + int x, y; - x = lx * rp->xr; - y = ly * rp->yr; - if (rp->or & XDECR) + x = (int)(lx*rp->xr + .5 - (lx < 0.0)); + y = (int)(ly*rp->yr + .5 - (ly < 0.0)); + + if (rp->rt & XDECR) x = rp->xr-1 - x; - if (rp->or & YDECR) + if (rp->rt & YDECR) y = rp->yr-1 - y; - if (rp->or & YMAJOR) { + if (rp->rt & YMAJOR) { pp[0] = x; pp[1] = y; } else { @@ -317,19 +448,20 @@ double lx, ly; int -getviewopt(v, ac, av) /* process view argument */ -register VIEW *v; -int ac; -register char *av[]; +getviewopt( /* process view argument */ +VIEW *v, +int ac, +char *av[] +) { -#define check(c,l) if ((av[0][c]&&av[0][c]!=' ') || \ +#define check(c,l) if ((av[0][c]&&!isspace(av[0][c])) || \ badarg(ac-1,av+1,l)) return(-1) if (ac <= 0 || av[0][0] != '-' || av[0][1] != 'v') return(-1); switch (av[0][2]) { case 't': /* type */ - if (!av[0][3] || av[0][3]==' ') + if (!av[0][3] || isspace(av[0][3])) return(-1); check(4,""); v->type = av[0][3]; @@ -345,6 +477,7 @@ register char *av[]; v->vdir[0] = atof(av[1]); v->vdir[1] = atof(av[2]); v->vdir[2] = atof(av[3]); + v->vdist = 1.; return(3); case 'u': /* up */ check(3,"fff"); @@ -384,24 +517,27 @@ register char *av[]; int -sscanview(vp, s) /* get view parameters from string */ -VIEW *vp; -register char *s; +sscanview( /* get view parameters from string */ +VIEW *vp, +char *s +) { int ac; char *av[4]; int na; int nvopts = 0; - if (*s != '-') - s = sskip2(s,1); + while (isspace(*s)) + if (!*s++) + return(0); while (*s) { ac = 0; do { - av[ac++] = s; - while (*s && *s != ' ') + if (ac || *s == '-') + av[ac++] = s; + while (*s && !isspace(*s)) s++; - while (*s == ' ') + while (isspace(*s)) s++; } while (*s && ac < 4); if ((na = getviewopt(vp, ac, av)) >= 0) { @@ -415,67 +551,75 @@ register char *s; } -fprintview(vp, fp) /* write out view parameters */ -register VIEW *vp; -FILE *fp; +void +fprintview( /* write out view parameters */ +VIEW *vp, +FILE *fp +) { fprintf(fp, " -vt%c", vp->type); - fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]); - fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]); - fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]); - fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert); - fprintf(fp, " -vo %.6g -va %.6g", vp->vfore, vp->vaft); - fprintf(fp, " -vs %.6g -vl %.6g", vp->hoff, vp->voff); + fprintf(fp, " -vp %.7g %.7g %.7g", vp->vp[0], vp->vp[1], vp->vp[2]); + fprintf(fp, " -vd %.7g %.7g %.7g", vp->vdir[0]*vp->vdist, + vp->vdir[1]*vp->vdist, + vp->vdir[2]*vp->vdist); + fprintf(fp, " -vu %.5g %.5g %.5g", vp->vup[0], vp->vup[1], vp->vup[2]); + fprintf(fp, " -vh %.5g -vv %.5g", vp->horiz, vp->vert); + fprintf(fp, " -vo %.5g -va %.5g", vp->vfore, vp->vaft); + fprintf(fp, " -vs %.5g -vl %.5g", vp->hoff, vp->voff); } char * -viewopt(vp) /* translate to minimal view string */ -register VIEW *vp; +viewopt( /* translate to minimal view string */ +VIEW *vp +) { static char vwstr[128]; - register char *cp = vwstr; + char *cp = vwstr; + *cp = '\0'; if (vp->type != stdview.type) { sprintf(cp, " -vt%c", vp->type); cp += strlen(cp); } - if (!VEQ(vp->vp,stdview.vp)) { + if (!VABSEQ(vp->vp,stdview.vp)) { sprintf(cp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]); cp += strlen(cp); } - if (!VEQ(vp->vdir,stdview.vdir)) { + if (!FABSEQ(vp->vdist,stdview.vdist) || !VABSEQ(vp->vdir,stdview.vdir)) { sprintf(cp, " -vd %.6g %.6g %.6g", - vp->vdir[0], vp->vdir[1], vp->vdir[2]); + vp->vdir[0]*vp->vdist, + vp->vdir[1]*vp->vdist, + vp->vdir[2]*vp->vdist); cp += strlen(cp); } - if (!VEQ(vp->vup,stdview.vup)) { + if (!VABSEQ(vp->vup,stdview.vup)) { sprintf(cp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]); cp += strlen(cp); } - if (!FEQ(vp->horiz,stdview.horiz)) { + if (!FABSEQ(vp->horiz,stdview.horiz)) { sprintf(cp, " -vh %.6g", vp->horiz); cp += strlen(cp); } - if (!FEQ(vp->vert,stdview.vert)) { + if (!FABSEQ(vp->vert,stdview.vert)) { sprintf(cp, " -vv %.6g", vp->vert); cp += strlen(cp); } - if (!FEQ(vp->vfore,stdview.vfore)) { + if (!FABSEQ(vp->vfore,stdview.vfore)) { sprintf(cp, " -vo %.6g", vp->vfore); cp += strlen(cp); } - if (!FEQ(vp->vaft,stdview.vaft)) { + if (!FABSEQ(vp->vaft,stdview.vaft)) { sprintf(cp, " -va %.6g", vp->vaft); cp += strlen(cp); } - if (!FEQ(vp->hoff,stdview.hoff)) { + if (!FABSEQ(vp->hoff,stdview.hoff)) { sprintf(cp, " -vs %.6g", vp->hoff); cp += strlen(cp); } - if (!FEQ(vp->voff,stdview.voff)) { + if (!FABSEQ(vp->voff,stdview.voff)) { sprintf(cp, " -vl %.6g", vp->voff); cp += strlen(cp); } @@ -484,13 +628,13 @@ register VIEW *vp; int -isview(s) /* is this a view string? */ -char *s; +isview( /* is this a view string? */ +char *s +) { - static char *altname[]={NULL,VIEWSTR,"rpict","rview","pinterp",NULL}; - extern char *progname; - register char *cp; - register char **an; + static char *altname[]={NULL,VIEWSTR,"rpict","rvu","rpiece","rxpiece","pinterp","rview",NULL}; + char *cp; + char **an; /* add program name to list */ if (altname[0] == NULL) { for (cp = progname; *cp; cp++) @@ -501,7 +645,7 @@ char *s; } /* skip leading path */ cp = s; - while (*cp && *cp != ' ') + while (*cp && !isspace(*cp)) cp++; while (cp > s && !ISDIRSEP(cp[-1])) cp--; @@ -518,26 +662,31 @@ struct myview { }; -static -gethview(s, v) /* get view from header */ -char *s; -register struct myview *v; +static int +gethview( /* get view from header */ + char *s, + void *v +) { - if (isview(s) && sscanview(v->hv, s) > 0) - v->ok++; + if (isview(s) && sscanview(((struct myview*)v)->hv, s) > 0) + ((struct myview*)v)->ok++; + return(0); } int -viewfile(fname, vp, rp) /* get view from file */ -char *fname; -VIEW *vp; -RESOLU *rp; +viewfile( /* get view from file */ +char *fname, +VIEW *vp, +RESOLU *rp +) { struct myview mvs; FILE *fp; - if ((fp = fopen(fname, "r")) == NULL) + if (fname == NULL || !strcmp(fname, "-")) + fp = stdin; + else if ((fp = fopen(fname, "r")) == NULL) return(-1); mvs.hv = vp; @@ -548,7 +697,8 @@ RESOLU *rp; if (rp != NULL && !fgetsresolu(rp, fp)) mvs.ok = 0; - fclose(fp); + if (fp != stdin) + fclose(fp); return(mvs.ok); }
