--- ray/src/common/image.c 2006/11/19 01:14:31 2.33 +++ ray/src/common/image.c 2008/03/11 02:21:46 2.34 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: image.c,v 2.33 2006/11/19 01:14:31 greg Exp $"; +static const char RCSid[] = "$Id: image.c,v 2.34 2008/03/11 02:21:46 greg Exp $"; #endif /* * image.c - routines for image generation. @@ -93,10 +93,20 @@ register VIEW *v; v->hn2 = 2.0 * sin(v->horiz*(PI/180.0/2.0)); v->vn2 = 2.0 * sin(v->vert*(PI/180.0/2.0)); break; + case VT_PLS: /* planispheric fisheye */ + if (v->horiz >= 360.0-FTINY) + return(ill_horiz); + if (v->vert >= 360.0-FTINY) + return(ill_vert); + v->hn2 = 2.*sin(v->horiz*(PI/180.0/2.0)) / + (1.0 + cos(v->horiz*(PI/180.0/2.0))); + v->vn2 = 2.*sin(v->vert*(PI/180.0/2.0)) / + (1.0 + cos(v->vert*(PI/180.0/2.0))); + break; default: return("unknown view type"); } - if (v->type != VT_ANG) { + if (v->type != VT_ANG && v->type != VT_PLS) { if (v->type != VT_CYL) { v->hvec[0] *= v->hn2; v->hvec[1] *= v->hn2; @@ -183,14 +193,14 @@ double x, y; d = normalize(direc); return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0); case VT_ANG: /* angular fisheye */ - x *= v->horiz/180.0; - y *= v->vert/180.0; + x *= (1.0/180.0)*v->horiz; + y *= (1.0/180.0)*v->vert; d = x*x + y*y; if (d > 1.0) return(-1.0); d = sqrt(d); z = cos(PI*d); - d = d <= FTINY ? PI : sqrt(1 - z*z)/d; + d = d <= FTINY ? PI : sqrt(1.0 - z*z)/d; x *= d; y *= d; direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; @@ -200,6 +210,21 @@ double x, y; orig[1] = v->vp[1] + v->vfore*direc[1]; orig[2] = v->vp[2] + v->vfore*direc[2]; return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0); + case VT_PLS: /* planispheric fisheye */ + x *= sqrt(v->hn2); + y *= sqrt(v->vn2); + d = x*x + y*y; + z = (1. - d)/(1. + d); + d = d <= FTINY*FTINY ? PI : sqrt((1.0 - z*z)/d); + x *= d; + y *= d; + direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; + direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; + direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; + orig[0] = v->vp[0] + v->vfore*direc[0]; + orig[1] = v->vp[1] + v->vfore*direc[1]; + orig[2] = v->vp[2] + v->vfore*direc[2]; + return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0); } return(-1.0); } @@ -214,9 +239,7 @@ FVECT p; double d, d2; FVECT disp; - disp[0] = p[0] - v->vp[0]; - disp[1] = p[1] - v->vp[1]; - disp[2] = p[2] - v->vp[2]; + VSUB(disp, p, v->vp); switch (v->type) { case VT_PAR: /* parallel view */ @@ -265,9 +288,22 @@ FVECT p; ip[0] += 180.0/v->horiz; return; } - d = acos(d)/PI / sqrt(1.0 - d*d); - ip[0] += DOT(disp,v->hvec)*d*180.0/v->horiz; - ip[1] += DOT(disp,v->vvec)*d*180.0/v->vert; + d = (180.0/PI)*acos(d) / sqrt(1.0 - d*d); + ip[0] += DOT(disp,v->hvec)*d/v->horiz; + ip[1] += DOT(disp,v->vvec)*d/v->vert; + return; + case VT_PLS: /* planispheric fisheye */ + ip[0] = 0.5 - v->hoff; + ip[1] = 0.5 - v->voff; + ip[2] = normalize(disp) - v->vfore; + d = DOT(disp,v->vdir); + if (d >= 1.0-FTINY) + return; + if (d <= -(1.0-FTINY)) + return; /* really an error */ + d = sqrt(1.0 - d*d) / (1.0 + d); + ip[0] += DOT(disp,v->hvec)*d/sqrt(v->hn2); + ip[1] += DOT(disp,v->vvec)*d/sqrt(v->vn2); return; } ip[0] = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff;
