1 |
/* Copyright (c) 1986 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* image.c - routines for image generation. |
9 |
10 |
* 10/17/85 |
11 |
12 |
13 |
#include "standard.h" |
14 |
15 |
#include "view.h" |
16 |
17 |
VIEW stdview = STDVIEW; /* default view parameters */ |
18 |
19 |
20 |
char * |
21 |
setview(v) /* set hvec and vvec, return message on error */ |
22 |
register VIEW *v; |
23 |
24 |
extern double tan(), normalize(); |
25 |
26 |
if (normalize(v->vdir) == 0.0) /* normalize direction */ |
27 |
return("zero view direction"); |
28 |
29 |
fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */ |
30 |
31 |
if (normalize(v->hvec) == 0.0) |
32 |
return("illegal view up vector"); |
33 |
34 |
fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */ |
35 |
36 |
if (v->type == VT_PAR) |
37 |
v->hn2 = v->horiz; |
38 |
else if (v->type == VT_PER) |
39 |
v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0)); |
40 |
else |
41 |
return("unknown view type"); |
42 |
43 |
if (v->hn2 <= FTINY || v->hn2 >= FHUGE) |
44 |
return("illegal horizontal view size"); |
45 |
46 |
v->hvec[0] *= v->hn2; |
47 |
v->hvec[1] *= v->hn2; |
48 |
v->hvec[2] *= v->hn2; |
49 |
v->hn2 *= v->hn2; |
50 |
51 |
52 |
v->vn2 = v->vert; |
53 |
else |
54 |
v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0)); |
55 |
56 |
if (v->vn2 <= FTINY || v->vn2 >= FHUGE) |
57 |
return("illegal vertical view size"); |
58 |
59 |
v->vvec[0] *= v->vn2; |
60 |
v->vvec[1] *= v->vn2; |
61 |
v->vvec[2] *= v->vn2; |
62 |
v->vn2 *= v->vn2; |
63 |
64 |
return(NULL); |
65 |
66 |
67 |
68 |
normaspect(vp, ap, xp, yp) /* fix pixel aspect or resolution */ |
69 |
VIEW *vp; |
70 |
double *ap; |
71 |
int *xp, *yp; |
72 |
73 |
double va = viewaspect(vp); |
74 |
75 |
if (*ap <= FTINY) |
76 |
*ap = (double)*yp / *xp / va; /* compute pixel aspect */ |
77 |
else if (va * *xp > *ap * *yp) |
78 |
*xp = *yp / va * *ap; /* reduce x resolution */ |
79 |
else |
80 |
*yp = *xp * va / *ap; /* reduce y resolution */ |
81 |
82 |
83 |
84 |
viewray(orig, direc, v, x, y) /* compute ray origin and direction */ |
85 |
FVECT orig, direc; |
86 |
register VIEW *v; |
87 |
double x, y; |
88 |
89 |
x += v->hoff - 0.5; |
90 |
y += v->voff - 0.5; |
91 |
92 |
if (v->type == VT_PAR) { /* parallel view */ |
93 |
orig[0] = v->vp[0] + x*v->hvec[0] + y*v->vvec[0]; |
94 |
orig[1] = v->vp[1] + x*v->hvec[1] + y*v->vvec[1]; |
95 |
orig[2] = v->vp[2] + x*v->hvec[2] + y*v->vvec[2]; |
96 |
VCOPY(direc, v->vdir); |
97 |
} else { /* perspective view */ |
98 |
VCOPY(orig, v->vp); |
99 |
direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; |
100 |
direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; |
101 |
direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; |
102 |
normalize(direc); |
103 |
104 |
105 |
106 |
107 |
viewpixel(xp, yp, zp, v, p) /* find image location for point */ |
108 |
double *xp, *yp, *zp; |
109 |
register VIEW *v; |
110 |
FVECT p; |
111 |
112 |
extern double sqrt(); |
113 |
double d; |
114 |
FVECT disp; |
115 |
116 |
disp[0] = p[0] - v->vp[0]; |
117 |
disp[1] = p[1] - v->vp[1]; |
118 |
disp[2] = p[2] - v->vp[2]; |
119 |
120 |
121 |
if (zp != NULL) |
122 |
*zp = DOT(disp,v->vdir); |
123 |
124 |
d = 1.0/DOT(disp,v->vdir); |
125 |
if (zp != NULL) { |
126 |
*zp = sqrt(DOT(disp,disp)); |
127 |
if (d < 0.0) |
128 |
*zp = -*zp; |
129 |
130 |
disp[0] *= d; |
131 |
disp[1] *= d; |
132 |
disp[2] *= d; |
133 |
134 |
*xp = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff; |
135 |
*yp = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff; |
136 |
137 |
138 |
139 |
int |
140 |
getviewopt(v, ac, av) /* process view argument */ |
141 |
register VIEW *v; |
142 |
int ac; |
143 |
register char *av[]; |
144 |
145 |
#define check(c,n) if ((av[0][c]&&av[0][c]!=' ') || n>=ac) return(-1) |
146 |
extern double atof(); |
147 |
148 |
if (av[0][0] != '-' || av[0][1] != 'v') |
149 |
return(-1); |
150 |
switch (av[0][2]) { |
151 |
case 't': /* type */ |
152 |
if (!av[0][3] || av[0][3]==' ') |
153 |
return(-1); |
154 |
check(4,0); |
155 |
v->type = av[0][3]; |
156 |
return(0); |
157 |
case 'p': /* point */ |
158 |
check(3,3); |
159 |
v->vp[0] = atof(av[1]); |
160 |
v->vp[1] = atof(av[2]); |
161 |
v->vp[2] = atof(av[3]); |
162 |
return(3); |
163 |
case 'd': /* direction */ |
164 |
check(3,3); |
165 |
v->vdir[0] = atof(av[1]); |
166 |
v->vdir[1] = atof(av[2]); |
167 |
v->vdir[2] = atof(av[3]); |
168 |
return(3); |
169 |
case 'u': /* up */ |
170 |
check(3,3); |
171 |
v->vup[0] = atof(av[1]); |
172 |
v->vup[1] = atof(av[2]); |
173 |
v->vup[2] = atof(av[3]); |
174 |
return(3); |
175 |
case 'h': /* horizontal size */ |
176 |
check(3,1); |
177 |
v->horiz = atof(av[1]); |
178 |
return(1); |
179 |
case 'v': /* vertical size */ |
180 |
check(3,1); |
181 |
v->vert = atof(av[1]); |
182 |
return(1); |
183 |
case 's': /* shift */ |
184 |
check(3,1); |
185 |
v->hoff = atof(av[1]); |
186 |
return(1); |
187 |
case 'l': /* lift */ |
188 |
check(3,1); |
189 |
v->voff = atof(av[1]); |
190 |
return(1); |
191 |
default: |
192 |
return(-1); |
193 |
194 |
#undef check |
195 |
196 |
197 |
198 |
int |
199 |
sscanview(vp, s) /* get view parameters from string */ |
200 |
VIEW *vp; |
201 |
register char *s; |
202 |
203 |
int ac; |
204 |
char *av[4]; |
205 |
int na; |
206 |
int nvopts = 0; |
207 |
208 |
while (*s == ' ') |
209 |
s++; |
210 |
do { |
211 |
ac = 0; |
212 |
do { |
213 |
av[ac++] = s; |
214 |
while (*s && *s != ' ') |
215 |
s++; |
216 |
while (*s == ' ') |
217 |
s++; |
218 |
} while (*s && ac < 4); |
219 |
if ((na = getviewopt(vp, ac, av)) >= 0) { |
220 |
if (na+1 < ac) |
221 |
s = av[na+1]; |
222 |
nvopts++; |
223 |
224 |
} while (*s); |
225 |
return(nvopts); |
226 |
227 |
228 |
229 |
fprintview(vp, fp) /* write out view parameters */ |
230 |
register VIEW *vp; |
231 |
FILE *fp; |
232 |
233 |
fprintf(fp, " -vt%c", vp->type); |
234 |
fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]); |
235 |
fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]); |
236 |
fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]); |
237 |
fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert); |
238 |
fprintf(fp, " -vs %d -vl %d", vp->hoff, vp->voff); |
239 |
240 |
241 |
242 |
static VIEW *hview; /* view from header */ |
243 |
static int gothview; /* success indicator */ |
244 |
static char *altname[] = {NULL,"rpict","rview","pinterp",VIEWSTR,NULL}; |
245 |
246 |
247 |
static |
248 |
gethview(s) /* get view from header */ |
249 |
char *s; |
250 |
251 |
register char **an; |
252 |
253 |
for (an = altname; *an != NULL; an++) |
254 |
if (!strncmp(*an, s, strlen(*an))) { |
255 |
if (sscanview(hview, s+strlen(*an)) > 0) |
256 |
gothview++; |
257 |
return; |
258 |
259 |
260 |
261 |
262 |
int |
263 |
viewfile(fname, vp) /* get view from file */ |
264 |
char *fname; |
265 |
VIEW *vp; |
266 |
267 |
extern char *progname; |
268 |
FILE *fp; |
269 |
270 |
if ((fp = fopen(fname, "r")) == NULL) |
271 |
return(-1); |
272 |
273 |
altname[0] = progname; |
274 |
hview = vp; |
275 |
gothview = 0; |
276 |
277 |
getheader(fp, gethview); |
278 |
279 |
fclose(fp); |
280 |
281 |
return(gothview); |
282 |
