root/radiance/ray/src/common/image.c
Revision: 1.2
Committed: Fri Oct 20 16:53:03 1989 UTC (35 years, 8 months ago) by greg
Changes since 1.1: +0 -16 lines
moved bigdiff() from image.c to color.c (more logical)
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * image.c - routines for image generation.
9 *
10 * 10/17/85
11 */
12
13 #include "standard.h"
14
15 #include "view.h"
16
17 VIEW stdview = STDVIEW(512); /* default view parameters */
18
19
20 char *
21 setview(v) /* set vhinc and vvinc, return message on error */
22 register VIEW *v;
23 {
24 double tan(), dt;
25
26 if (normalize(v->vdir) == 0.0) /* normalize direction */
27 return("zero view direction");
28
29 fcross(v->vhinc, v->vdir, v->vup); /* compute horiz dir */
30
31 if (normalize(v->vhinc) == 0.0)
32 return("illegal view up vector");
33
34 fcross(v->vvinc, v->vhinc, v->vdir); /* compute vert dir */
35
36 if (v->type == VT_PAR)
37 dt = v->horiz;
38 else if (v->type == VT_PER)
39 dt = 2.0 * tan(v->horiz*(PI/180.0/2.0));
40 else
41 return("unknown view type");
42
43 if (dt <= FTINY || dt >= FHUGE)
44 return("illegal horizontal view size");
45
46 if (v->hresolu <= 0)
47 return("illegal horizontal resolution");
48
49 dt /= (double)v->hresolu;
50 v->vhinc[0] *= dt;
51 v->vhinc[1] *= dt;
52 v->vhinc[2] *= dt;
53
54 if (v->type == VT_PAR)
55 dt = v->vert;
56 else
57 dt = 2.0 * tan(v->vert*(PI/180.0/2.0));
58
59 if (dt <= FTINY || dt >= FHUGE)
60 return("illegal vertical view size");
61
62 if (v->vresolu <= 0)
63 return("illegal vertical resolution");
64
65 dt /= (double)v->vresolu;
66 v->vvinc[0] *= dt;
67 v->vvinc[1] *= dt;
68 v->vvinc[2] *= dt;
69
70 return(NULL);
71 }
72
73
74 rayview(orig, direc, v, x, y) /* compute ray origin and direction */
75 FVECT orig, direc;
76 register VIEW *v;
77 double x, y;
78 {
79 register int i;
80
81 x -= 0.5 * v->hresolu;
82 y -= 0.5 * v->vresolu;
83
84 if (v->type == VT_PAR) { /* parallel view */
85 for (i = 0; i < 3; i++)
86 orig[i] = v->vp[i] + x*v->vhinc[i] + y*v->vvinc[i];
87 VCOPY(direc, v->vdir);
88 } else { /* perspective view */
89 VCOPY(orig, v->vp);
90 for (i = 0; i < 3; i++)
91 direc[i] = v->vdir[i] + x*v->vhinc[i] + y*v->vvinc[i];
92 normalize(direc);
93 }
94 }
95
96
97 sscanview(vp, s) /* get view parameters */
98 register VIEW *vp;
99 register char *s;
100 {
101 for ( ; ; )
102 switch (*s++) {
103 case '\0':
104 case '\n':
105 return(0);
106 case '-':
107 switch (*s++) {
108 case '\0':
109 return(-1);
110 case 'x':
111 if (sscanf(s, "%d", &vp->hresolu) != 1)
112 return(-1);
113 s = sskip(s);
114 continue;
115 case 'y':
116 if (sscanf(s, "%d", &vp->vresolu) != 1)
117 return(-1);
118 s = sskip(s);
119 continue;
120 case 'v':
121 switch (*s++) {
122 case '\0':
123 return(-1);
124 case 't':
125 vp->type = *s++;
126 continue;
127 case 'p':
128 if (sscanf(s, "%lf %lf %lf",
129 &vp->vp[0],
130 &vp->vp[1],
131 &vp->vp[2]) != 3)
132 return(-1);
133 s = sskip(sskip(sskip(s)));
134 continue;
135 case 'd':
136 if (sscanf(s, "%lf %lf %lf",
137 &vp->vdir[0],
138 &vp->vdir[1],
139 &vp->vdir[2]) != 3)
140 return(-1);
141 s = sskip(sskip(sskip(s)));
142 continue;
143 case 'u':
144 if (sscanf(s, "%lf %lf %lf",
145 &vp->vup[0],
146 &vp->vup[1],
147 &vp->vup[2]) != 3)
148 return(-1);
149 s = sskip(sskip(sskip(s)));
150 continue;
151 case 'h':
152 if (sscanf(s, "%lf",
153 &vp->horiz) != 1)
154 return(-1);
155 s = sskip(s);
156 continue;
157 case 'v':
158 if (sscanf(s, "%lf",
159 &vp->vert) != 1)
160 return(-1);
161 s = sskip(s);
162 continue;
163 }
164 continue;
165 }
166 continue;
167 }
168 }
169
170
171 fprintview(vp, fp) /* write out view parameters */
172 register VIEW *vp;
173 FILE *fp;
174 {
175 fprintf(fp, " -vt%c", vp->type);
176 fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]);
177 fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]);
178 fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]);
179 fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert);
180 fprintf(fp, " -x %d -y %d", vp->hresolu, vp->vresolu);
181 }
182
183
184 static VIEW *hview; /* view from header */
185 static int gothview; /* success indicator */
186 static char *altname[] = {NULL,"rpict","rview",VIEWSTR,NULL};
187
188
189 static
190 gethview(s) /* get view from header */
191 char *s;
192 {
193 register char **an;
194
195 for (an = altname; *an != NULL; an++)
196 if (!strncmp(*an, s, strlen(*an))) {
197 if (sscanview(hview, s+strlen(*an)) == 0)
198 gothview++;
199 return;
200 }
201 }
202
203
204 int
205 viewfile(fname, vp) /* get view from file */
206 char *fname;
207 VIEW *vp;
208 {
209 extern char *progname;
210 FILE *fp;
211
212 if ((fp = fopen(fname, "r")) == NULL)
213 return(-1);
214
215 altname[0] = progname;
216 hview = vp;
217 gothview = 0;
218
219 getheader(fp, gethview);
220
221 fclose(fp);
222
223 return(gothview);
224 }
