root/radiance/ray/src/common/image.c
Revision: 2.40
Committed: Wed Apr 3 00:35:09 2013 UTC (12 years, 3 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R2P1
Changes since 2.39: +6 -16 lines
Added VSUM() macro calls
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.40 static const char RCSid[] = "$Id: image.c,v 2.39 2013/03/24 19:40:26 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * image.c - routines for image generation.
6 greg 2.16 *
7     * External symbols declared in view.h
8     */
9
10 greg 2.17 #include "copyright.h"
11 greg 1.1
12 greg 2.32 #include <ctype.h>
13 schorsch 2.22 #include "rtio.h"
14 greg 2.28 #include "rtmath.h"
15 greg 2.27 #include "paths.h"
16 greg 1.1 #include "view.h"
17
18 greg 2.4
19 greg 2.11 #define FEQ(x,y) (fabs((x)-(y)) <= FTINY)
20     #define VEQ(v,w) (FEQ((v)[0],(w)[0]) && FEQ((v)[1],(w)[1]) \
21     && FEQ((v)[2],(w)[2]))
22
23 greg 1.5 VIEW stdview = STDVIEW; /* default view parameters */
24 greg 1.1
25 schorsch 2.26 static gethfunc gethview;
26
27 greg 1.1
28     char *
29 greg 2.35 setview( /* set hvec and vvec, return message on error */
30     VIEW *v
31     )
32 greg 1.3 {
33 greg 1.12 static char ill_horiz[] = "illegal horizontal view size";
34     static char ill_vert[] = "illegal vertical view size";
35
36 greg 2.39 if ((v->vfore < -FTINY) | (v->vaft < -FTINY) ||
37     (v->vaft > FTINY) & (v->vaft <= v->vfore))
38 greg 2.7 return("illegal fore/aft clipping plane");
39
40 greg 2.31 if (v->vdist <= FTINY)
41     return("illegal view distance");
42 greg 2.29 v->vdist *= normalize(v->vdir); /* normalize direction */
43     if (v->vdist == 0.0)
44 greg 1.1 return("zero view direction");
45
46 greg 1.14 if (normalize(v->vup) == 0.0) /* normalize view up */
47     return("zero view up vector");
48
49 greg 1.5 fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */
50
51     if (normalize(v->hvec) == 0.0)
52 greg 1.14 return("view up parallel to view direction");
53 greg 1.1
54 greg 1.5 fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */
55
56 greg 1.12 if (v->horiz <= FTINY)
57     return(ill_horiz);
58     if (v->vert <= FTINY)
59     return(ill_vert);
60
61     switch (v->type) {
62     case VT_PAR: /* parallel view */
63 greg 1.5 v->hn2 = v->horiz;
64 greg 1.12 v->vn2 = v->vert;
65     break;
66     case VT_PER: /* perspective view */
67     if (v->horiz >= 180.0-FTINY)
68     return(ill_horiz);
69     if (v->vert >= 180.0-FTINY)
70     return(ill_vert);
71 greg 1.5 v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0));
72 greg 1.12 v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0));
73     break;
74 greg 2.9 case VT_CYL: /* cylindrical panorama */
75     if (v->horiz > 360.0+FTINY)
76     return(ill_horiz);
77     if (v->vert >= 180.0-FTINY)
78     return(ill_vert);
79     v->hn2 = v->horiz * (PI/180.0);
80     v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0));
81     break;
82 greg 1.12 case VT_ANG: /* angular fisheye */
83     if (v->horiz > 360.0+FTINY)
84     return(ill_horiz);
85     if (v->vert > 360.0+FTINY)
86     return(ill_vert);
87 greg 2.9 v->hn2 = v->horiz * (PI/180.0);
88     v->vn2 = v->vert * (PI/180.0);
89 greg 1.12 break;
90     case VT_HEM: /* hemispherical fisheye */
91     if (v->horiz > 180.0+FTINY)
92     return(ill_horiz);
93     if (v->vert > 180.0+FTINY)
94     return(ill_vert);
95     v->hn2 = 2.0 * sin(v->horiz*(PI/180.0/2.0));
96     v->vn2 = 2.0 * sin(v->vert*(PI/180.0/2.0));
97     break;
98 greg 2.34 case VT_PLS: /* planispheric fisheye */
99     if (v->horiz >= 360.0-FTINY)
100     return(ill_horiz);
101     if (v->vert >= 360.0-FTINY)
102     return(ill_vert);
103     v->hn2 = 2.*sin(v->horiz*(PI/180.0/2.0)) /
104     (1.0 + cos(v->horiz*(PI/180.0/2.0)));
105     v->vn2 = 2.*sin(v->vert*(PI/180.0/2.0)) /
106     (1.0 + cos(v->vert*(PI/180.0/2.0)));
107     break;
108 greg 1.12 default:
109 greg 1.1 return("unknown view type");
110 greg 1.12 }
111 greg 2.34 if (v->type != VT_ANG && v->type != VT_PLS) {
112 greg 2.9 if (v->type != VT_CYL) {
113     v->hvec[0] *= v->hn2;
114     v->hvec[1] *= v->hn2;
115     v->hvec[2] *= v->hn2;
116     }
117 greg 1.12 v->vvec[0] *= v->vn2;
118     v->vvec[1] *= v->vn2;
119     v->vvec[2] *= v->vn2;
120     }
121 greg 1.5 v->hn2 *= v->hn2;
122     v->vn2 *= v->vn2;
123 greg 1.1
124     return(NULL);
125     }
126
127
128 greg 2.16 void
129 greg 2.35 normaspect( /* fix pixel aspect or resolution */
130     double va, /* view aspect ratio */
131     double *ap, /* pixel aspect in (or out if 0) */
132     int *xp,
133     int *yp /* x and y resolution in (or out if *ap!=0) */
134     )
135 greg 1.6 {
136     if (*ap <= FTINY)
137 greg 1.7 *ap = va * *xp / *yp; /* compute pixel aspect */
138 greg 1.6 else if (va * *xp > *ap * *yp)
139 greg 1.10 *xp = *yp / va * *ap + .5; /* reduce x resolution */
140 greg 1.6 else
141 greg 1.10 *yp = *xp * va / *ap + .5; /* reduce y resolution */
142 greg 1.6 }
143
144
145 greg 2.7 double
146 greg 2.35 viewray( /* compute ray origin and direction */
147     FVECT orig,
148     FVECT direc,
149     VIEW *v,
150     double x,
151     double y
152     )
153 greg 1.1 {
154 greg 1.12 double d, z;
155
156 greg 1.5 x += v->hoff - 0.5;
157     y += v->voff - 0.5;
158 greg 1.1
159 greg 1.12 switch(v->type) {
160     case VT_PAR: /* parallel view */
161 greg 2.7 orig[0] = v->vp[0] + v->vfore*v->vdir[0]
162     + x*v->hvec[0] + y*v->vvec[0];
163     orig[1] = v->vp[1] + v->vfore*v->vdir[1]
164     + x*v->hvec[1] + y*v->vvec[1];
165     orig[2] = v->vp[2] + v->vfore*v->vdir[2]
166     + x*v->hvec[2] + y*v->vvec[2];
167 greg 1.1 VCOPY(direc, v->vdir);
168 greg 2.8 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
169 greg 1.12 case VT_PER: /* perspective view */
170 greg 1.5 direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
171     direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
172     direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
173 greg 2.40 VSUM(orig, v->vp, direc, v->vfore);
174 greg 2.7 d = normalize(direc);
175 greg 2.8 return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0);
176 greg 1.12 case VT_HEM: /* hemispherical fisheye */
177 greg 1.13 z = 1.0 - x*x*v->hn2 - y*y*v->vn2;
178 greg 1.12 if (z < 0.0)
179 greg 2.7 return(-1.0);
180 greg 1.12 z = sqrt(z);
181     direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
182     direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
183     direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
184 greg 2.40 VSUM(orig, v->vp, direc, v->vfore);
185 greg 2.8 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
186 greg 2.9 case VT_CYL: /* cylindrical panorama */
187     d = x * v->horiz * (PI/180.0);
188     z = cos(d);
189     x = sin(d);
190     direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
191     direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
192     direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
193 greg 2.40 VSUM(orig, v->vp, direc, v->vfore);
194 greg 2.9 d = normalize(direc);
195     return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0);
196 greg 1.12 case VT_ANG: /* angular fisheye */
197 greg 2.34 x *= (1.0/180.0)*v->horiz;
198     y *= (1.0/180.0)*v->vert;
199 greg 1.12 d = x*x + y*y;
200     if (d > 1.0)
201 greg 2.7 return(-1.0);
202 greg 1.12 d = sqrt(d);
203     z = cos(PI*d);
204 greg 2.34 d = d <= FTINY ? PI : sqrt(1.0 - z*z)/d;
205     x *= d;
206     y *= d;
207     direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
208     direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
209     direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
210 greg 2.40 VSUM(orig, v->vp, direc, v->vfore);
211 greg 2.34 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
212     case VT_PLS: /* planispheric fisheye */
213     x *= sqrt(v->hn2);
214     y *= sqrt(v->vn2);
215     d = x*x + y*y;
216     z = (1. - d)/(1. + d);
217 greg 2.38 x *= (1. + z);
218     y *= (1. + z);
219 greg 1.12 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
220     direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
221     direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
222 greg 2.40 VSUM(orig, v->vp, direc, v->vfore);
223 greg 2.8 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
224 greg 1.1 }
225 greg 2.7 return(-1.0);
226 greg 1.1 }
227
228
229 greg 2.16 void
230 greg 2.35 viewloc( /* find image location for point */
231     FVECT ip,
232     VIEW *v,
233     FVECT p
234     )
235 greg 1.3 {
236 gregl 2.13 double d, d2;
237 greg 1.3 FVECT disp;
238 greg 1.5
239 greg 2.34 VSUB(disp, p, v->vp);
240 greg 1.3
241 greg 1.12 switch (v->type) {
242     case VT_PAR: /* parallel view */
243 greg 2.7 ip[2] = DOT(disp,v->vdir) - v->vfore;
244 greg 1.13 break;
245 greg 1.12 case VT_PER: /* perspective view */
246 greg 1.11 d = DOT(disp,v->vdir);
247 gregl 2.13 ip[2] = VLEN(disp);
248 greg 1.17 if (d < 0.0) { /* fold pyramid */
249     ip[2] = -ip[2];
250 greg 1.11 d = -d;
251 greg 2.7 }
252     if (d > FTINY) {
253 greg 1.11 d = 1.0/d;
254     disp[0] *= d;
255     disp[1] *= d;
256     disp[2] *= d;
257     }
258 greg 2.7 ip[2] *= (1.0 - v->vfore*d);
259 greg 1.13 break;
260 greg 1.12 case VT_HEM: /* hemispherical fisheye */
261     d = normalize(disp);
262 greg 1.17 if (DOT(disp,v->vdir) < 0.0)
263     ip[2] = -d;
264     else
265     ip[2] = d;
266 greg 2.7 ip[2] -= v->vfore;
267 greg 1.13 break;
268 greg 2.9 case VT_CYL: /* cylindrical panorama */
269     d = DOT(disp,v->hvec);
270 gregl 2.13 d2 = DOT(disp,v->vdir);
271     ip[0] = 180.0/PI * atan2(d,d2) / v->horiz + 0.5 - v->hoff;
272     d = 1.0/sqrt(d*d + d2*d2);
273     ip[1] = DOT(disp,v->vvec)*d/v->vn2 + 0.5 - v->voff;
274     ip[2] = VLEN(disp);
275 gwlarson 2.15 ip[2] *= (1.0 - v->vfore*d);
276 greg 2.9 return;
277 greg 1.12 case VT_ANG: /* angular fisheye */
278 greg 1.17 ip[0] = 0.5 - v->hoff;
279     ip[1] = 0.5 - v->voff;
280 greg 2.7 ip[2] = normalize(disp) - v->vfore;
281 greg 1.12 d = DOT(disp,v->vdir);
282     if (d >= 1.0-FTINY)
283     return;
284     if (d <= -(1.0-FTINY)) {
285 greg 2.7 ip[0] += 180.0/v->horiz;
286 greg 1.12 return;
287     }
288 greg 2.34 d = (180.0/PI)*acos(d) / sqrt(1.0 - d*d);
289     ip[0] += DOT(disp,v->hvec)*d/v->horiz;
290     ip[1] += DOT(disp,v->vvec)*d/v->vert;
291     return;
292     case VT_PLS: /* planispheric fisheye */
293     ip[0] = 0.5 - v->hoff;
294     ip[1] = 0.5 - v->voff;
295     ip[2] = normalize(disp) - v->vfore;
296     d = DOT(disp,v->vdir);
297     if (d >= 1.0-FTINY)
298     return;
299     if (d <= -(1.0-FTINY))
300     return; /* really an error */
301 greg 2.38 ip[0] += DOT(disp,v->hvec)/((1. + d)*sqrt(v->hn2));
302     ip[1] += DOT(disp,v->vvec)/((1. + d)*sqrt(v->vn2));
303 greg 1.12 return;
304 greg 1.3 }
305 greg 1.17 ip[0] = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff;
306     ip[1] = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff;
307 greg 1.3 }
308
309
310 greg 2.16 void
311 greg 2.35 pix2loc( /* compute image location from pixel pos. */
312     RREAL loc[2],
313     RESOLU *rp,
314     int px,
315     int py
316     )
317 greg 1.17 {
318 greg 2.36 int x, y;
319 greg 1.17
320 greg 2.16 if (rp->rt & YMAJOR) {
321 greg 1.17 x = px;
322     y = py;
323     } else {
324     x = py;
325     y = px;
326     }
327 greg 2.16 if (rp->rt & XDECR)
328 greg 1.17 x = rp->xr-1 - x;
329 greg 2.16 if (rp->rt & YDECR)
330 greg 1.17 y = rp->yr-1 - y;
331     loc[0] = (x+.5)/rp->xr;
332     loc[1] = (y+.5)/rp->yr;
333     }
334
335
336 greg 2.16 void
337 greg 2.35 loc2pix( /* compute pixel pos. from image location */
338     int pp[2],
339     RESOLU *rp,
340     double lx,
341     double ly
342     )
343 greg 1.17 {
344 greg 2.36 int x, y;
345 greg 1.17
346 greg 2.37 x = (int)(lx*rp->xr + .5 - (lx < 0.0));
347     y = (int)(ly*rp->yr + .5 - (ly < 0.0));
348
349 greg 2.16 if (rp->rt & XDECR)
350 greg 1.17 x = rp->xr-1 - x;
351 greg 2.16 if (rp->rt & YDECR)
352 greg 1.17 y = rp->yr-1 - y;
353 greg 2.16 if (rp->rt & YMAJOR) {
354 greg 1.17 pp[0] = x;
355     pp[1] = y;
356     } else {
357     pp[0] = y;
358     pp[1] = x;
359     }
360     }
361
362
363 greg 1.5 int
364 greg 2.35 getviewopt( /* process view argument */
365     VIEW *v,
366     int ac,
367     char *av[]
368     )
369 greg 1.5 {
370 greg 1.16 #define check(c,l) if ((av[0][c]&&av[0][c]!=' ') || \
371     badarg(ac-1,av+1,l)) return(-1)
372 greg 1.5
373 greg 1.9 if (ac <= 0 || av[0][0] != '-' || av[0][1] != 'v')
374 greg 1.5 return(-1);
375     switch (av[0][2]) {
376     case 't': /* type */
377     if (!av[0][3] || av[0][3]==' ')
378     return(-1);
379 greg 1.16 check(4,"");
380 greg 1.5 v->type = av[0][3];
381     return(0);
382     case 'p': /* point */
383 greg 1.16 check(3,"fff");
384 greg 1.5 v->vp[0] = atof(av[1]);
385     v->vp[1] = atof(av[2]);
386     v->vp[2] = atof(av[3]);
387     return(3);
388     case 'd': /* direction */
389 greg 1.16 check(3,"fff");
390 greg 1.5 v->vdir[0] = atof(av[1]);
391     v->vdir[1] = atof(av[2]);
392     v->vdir[2] = atof(av[3]);
393 greg 2.30 v->vdist = 1.;
394 greg 1.5 return(3);
395     case 'u': /* up */
396 greg 1.16 check(3,"fff");
397 greg 1.5 v->vup[0] = atof(av[1]);
398     v->vup[1] = atof(av[2]);
399     v->vup[2] = atof(av[3]);
400     return(3);
401     case 'h': /* horizontal size */
402 greg 1.16 check(3,"f");
403 greg 1.5 v->horiz = atof(av[1]);
404     return(1);
405     case 'v': /* vertical size */
406 greg 1.16 check(3,"f");
407 greg 1.5 v->vert = atof(av[1]);
408     return(1);
409 greg 2.7 case 'o': /* fore clipping plane */
410     check(3,"f");
411     v->vfore = atof(av[1]);
412     return(1);
413     case 'a': /* aft clipping plane */
414     check(3,"f");
415     v->vaft = atof(av[1]);
416     return(1);
417 greg 1.5 case 's': /* shift */
418 greg 1.16 check(3,"f");
419 greg 1.5 v->hoff = atof(av[1]);
420     return(1);
421     case 'l': /* lift */
422 greg 1.16 check(3,"f");
423 greg 1.5 v->voff = atof(av[1]);
424     return(1);
425     default:
426     return(-1);
427     }
428     #undef check
429     }
430
431
432     int
433 greg 2.35 sscanview( /* get view parameters from string */
434     VIEW *vp,
435     char *s
436     )
437 greg 1.1 {
438 greg 1.5 int ac;
439     char *av[4];
440     int na;
441     int nvopts = 0;
442
443 greg 2.32 while (isspace(*s))
444     if (!*s++)
445     return(0);
446 greg 1.9 while (*s) {
447 greg 1.5 ac = 0;
448     do {
449 greg 2.21 if (ac || *s == '-')
450     av[ac++] = s;
451 greg 2.32 while (*s && !isspace(*s))
452 greg 1.5 s++;
453 greg 2.32 while (isspace(*s))
454 greg 1.5 s++;
455     } while (*s && ac < 4);
456     if ((na = getviewopt(vp, ac, av)) >= 0) {
457     if (na+1 < ac)
458     s = av[na+1];
459     nvopts++;
460 greg 1.9 } else if (ac > 1)
461     s = av[1];
462     }
463 greg 1.5 return(nvopts);
464 greg 1.1 }
465
466
467 greg 2.16 void
468 greg 2.35 fprintview( /* write out view parameters */
469     VIEW *vp,
470     FILE *fp
471     )
472 greg 1.1 {
473     fprintf(fp, " -vt%c", vp->type);
474     fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]);
475 greg 2.29 fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0]*vp->vdist,
476     vp->vdir[1]*vp->vdist,
477     vp->vdir[2]*vp->vdist);
478 greg 1.1 fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]);
479     fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert);
480 greg 2.7 fprintf(fp, " -vo %.6g -va %.6g", vp->vfore, vp->vaft);
481 greg 1.9 fprintf(fp, " -vs %.6g -vl %.6g", vp->hoff, vp->voff);
482 greg 2.11 }
483
484
485     char *
486 greg 2.35 viewopt( /* translate to minimal view string */
487     VIEW *vp
488     )
489 greg 2.11 {
490     static char vwstr[128];
491 greg 2.36 char *cp = vwstr;
492 greg 2.11
493 greg 2.33 *cp = '\0';
494 greg 2.11 if (vp->type != stdview.type) {
495     sprintf(cp, " -vt%c", vp->type);
496     cp += strlen(cp);
497     }
498     if (!VEQ(vp->vp,stdview.vp)) {
499     sprintf(cp, " -vp %.6g %.6g %.6g",
500     vp->vp[0], vp->vp[1], vp->vp[2]);
501     cp += strlen(cp);
502     }
503 greg 2.29 if (!FEQ(vp->vdist,stdview.vdist) || !VEQ(vp->vdir,stdview.vdir)) {
504 greg 2.11 sprintf(cp, " -vd %.6g %.6g %.6g",
505 greg 2.29 vp->vdir[0]*vp->vdist,
506     vp->vdir[1]*vp->vdist,
507     vp->vdir[2]*vp->vdist);
508 greg 2.11 cp += strlen(cp);
509     }
510     if (!VEQ(vp->vup,stdview.vup)) {
511     sprintf(cp, " -vu %.6g %.6g %.6g",
512     vp->vup[0], vp->vup[1], vp->vup[2]);
513     cp += strlen(cp);
514     }
515     if (!FEQ(vp->horiz,stdview.horiz)) {
516     sprintf(cp, " -vh %.6g", vp->horiz);
517     cp += strlen(cp);
518     }
519     if (!FEQ(vp->vert,stdview.vert)) {
520     sprintf(cp, " -vv %.6g", vp->vert);
521     cp += strlen(cp);
522     }
523     if (!FEQ(vp->vfore,stdview.vfore)) {
524     sprintf(cp, " -vo %.6g", vp->vfore);
525     cp += strlen(cp);
526     }
527     if (!FEQ(vp->vaft,stdview.vaft)) {
528     sprintf(cp, " -va %.6g", vp->vaft);
529     cp += strlen(cp);
530     }
531     if (!FEQ(vp->hoff,stdview.hoff)) {
532     sprintf(cp, " -vs %.6g", vp->hoff);
533     cp += strlen(cp);
534     }
535     if (!FEQ(vp->voff,stdview.voff)) {
536     sprintf(cp, " -vl %.6g", vp->voff);
537     cp += strlen(cp);
538     }
539     return(vwstr);
540 greg 1.1 }
541
542
543 greg 2.3 int
544 greg 2.35 isview( /* is this a view string? */
545     char *s
546     )
547 greg 2.3 {
548 greg 2.25 static char *altname[]={NULL,VIEWSTR,"rpict","rview","rvu","rpiece","pinterp",NULL};
549 greg 2.5 extern char *progname;
550 greg 2.36 char *cp;
551     char **an;
552 greg 2.3 /* add program name to list */
553 greg 2.5 if (altname[0] == NULL) {
554     for (cp = progname; *cp; cp++)
555     ;
556     while (cp > progname && !ISDIRSEP(cp[-1]))
557     cp--;
558     altname[0] = cp;
559     }
560 greg 2.3 /* skip leading path */
561     cp = s;
562     while (*cp && *cp != ' ')
563     cp++;
564 greg 2.5 while (cp > s && !ISDIRSEP(cp[-1]))
565 greg 2.3 cp--;
566     for (an = altname; *an != NULL; an++)
567     if (!strncmp(*an, cp, strlen(*an)))
568     return(1);
569     return(0);
570     }
571 greg 1.1
572 greg 2.3
573 greg 1.15 struct myview {
574     VIEW *hv;
575     int ok;
576     };
577 greg 1.1
578 greg 1.15
579 gwlarson 2.14 static int
580 schorsch 2.26 gethview( /* get view from header */
581     char *s,
582     void *v
583     )
584 greg 1.1 {
585 schorsch 2.26 if (isview(s) && sscanview(((struct myview*)v)->hv, s) > 0)
586     ((struct myview*)v)->ok++;
587 gwlarson 2.14 return(0);
588 greg 1.1 }
589
590
591     int
592 greg 2.35 viewfile( /* get view from file */
593     char *fname,
594     VIEW *vp,
595     RESOLU *rp
596     )
597 greg 1.1 {
598 greg 1.15 struct myview mvs;
599 greg 1.1 FILE *fp;
600
601 greg 2.16 if (fname == NULL || !strcmp(fname, "-"))
602     fp = stdin;
603     else if ((fp = fopen(fname, "r")) == NULL)
604 greg 1.1 return(-1);
605
606 greg 1.15 mvs.hv = vp;
607     mvs.ok = 0;
608 greg 1.1
609 schorsch 2.26 getheader(fp, gethview, &mvs);
610 greg 1.8
611 greg 1.17 if (rp != NULL && !fgetsresolu(rp, fp))
612 greg 1.15 mvs.ok = 0;
613 greg 1.1
614     fclose(fp);
615
616 greg 1.15 return(mvs.ok);
617 greg 1.1 }
