--- ray/src/common/image.c 1998/10/27 08:44:29 2.14 +++ ray/src/common/image.c 2012/10/27 03:01:21 2.37 @@ -1,40 +1,45 @@ -/* Copyright (c) 1996 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: image.c,v 2.37 2012/10/27 03:01:21 greg Exp $"; #endif - /* * image.c - routines for image generation. + * + * External symbols declared in view.h */ -#include "standard.h" +#include "copyright.h" +#include +#include "rtio.h" +#include "rtmath.h" +#include "paths.h" #include "view.h" -#include "resolu.h" -#include "paths.h" - #define FEQ(x,y) (fabs((x)-(y)) <= FTINY) #define VEQ(v,w) (FEQ((v)[0],(w)[0]) && FEQ((v)[1],(w)[1]) \ && FEQ((v)[2],(w)[2])) VIEW stdview = STDVIEW; /* default view parameters */ +static gethfunc gethview; + char * -setview(v) /* set hvec and vvec, return message on error */ -register VIEW *v; +setview( /* set hvec and vvec, return message on error */ +VIEW *v +) { static char ill_horiz[] = "illegal horizontal view size"; static char ill_vert[] = "illegal vertical view size"; - if (v->vfore < -FTINY || v->vaft < -FTINY || - (v->vaft > FTINY && v->vaft <= v->vfore)) + if (v->vaft < -FTINY || (v->vaft > FTINY && v->vaft <= v->vfore)) return("illegal fore/aft clipping plane"); - if (normalize(v->vdir) == 0.0) /* normalize direction */ + if (v->vdist <= FTINY) + return("illegal view distance"); + v->vdist *= normalize(v->vdir); /* normalize direction */ + if (v->vdist == 0.0) return("zero view direction"); if (normalize(v->vup) == 0.0) /* normalize view up */ @@ -89,10 +94,20 @@ register VIEW *v; v->hn2 = 2.0 * sin(v->horiz*(PI/180.0/2.0)); v->vn2 = 2.0 * sin(v->vert*(PI/180.0/2.0)); break; + case VT_PLS: /* planispheric fisheye */ + if (v->horiz >= 360.0-FTINY) + return(ill_horiz); + if (v->vert >= 360.0-FTINY) + return(ill_vert); + v->hn2 = 2.*sin(v->horiz*(PI/180.0/2.0)) / + (1.0 + cos(v->horiz*(PI/180.0/2.0))); + v->vn2 = 2.*sin(v->vert*(PI/180.0/2.0)) / + (1.0 + cos(v->vert*(PI/180.0/2.0))); + break; default: return("unknown view type"); } - if (v->type != VT_ANG) { + if (v->type != VT_ANG && v->type != VT_PLS) { if (v->type != VT_CYL) { v->hvec[0] *= v->hn2; v->hvec[1] *= v->hn2; @@ -109,10 +124,13 @@ register VIEW *v; } -normaspect(va, ap, xp, yp) /* fix pixel aspect or resolution */ -double va; /* view aspect ratio */ -double *ap; /* pixel aspect in (or out if 0) */ -int *xp, *yp; /* x and y resolution in (or out if *ap!=0) */ +void +normaspect( /* fix pixel aspect or resolution */ +double va, /* view aspect ratio */ +double *ap, /* pixel aspect in (or out if 0) */ +int *xp, +int *yp /* x and y resolution in (or out if *ap!=0) */ +) { if (*ap <= FTINY) *ap = va * *xp / *yp; /* compute pixel aspect */ @@ -124,10 +142,13 @@ int *xp, *yp; /* x and y resolution in (or out if * double -viewray(orig, direc, v, x, y) /* compute ray origin and direction */ -FVECT orig, direc; -register VIEW *v; -double x, y; +viewray( /* compute ray origin and direction */ +FVECT orig, +FVECT direc, +VIEW *v, +double x, +double y +) { double d, z; @@ -178,14 +199,14 @@ double x, y; d = normalize(direc); return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0); case VT_ANG: /* angular fisheye */ - x *= v->horiz/180.0; - y *= v->vert/180.0; + x *= (1.0/180.0)*v->horiz; + y *= (1.0/180.0)*v->vert; d = x*x + y*y; if (d > 1.0) return(-1.0); d = sqrt(d); z = cos(PI*d); - d = d <= FTINY ? PI : sqrt(1 - z*z)/d; + d = d <= FTINY ? PI : sqrt(1.0 - z*z)/d; x *= d; y *= d; direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; @@ -195,22 +216,37 @@ double x, y; orig[1] = v->vp[1] + v->vfore*direc[1]; orig[2] = v->vp[2] + v->vfore*direc[2]; return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0); + case VT_PLS: /* planispheric fisheye */ + x *= sqrt(v->hn2); + y *= sqrt(v->vn2); + d = x*x + y*y; + z = (1. - d)/(1. + d); + d = d <= FTINY*FTINY ? PI : sqrt((1.0 - z*z)/d); + x *= d; + y *= d; + direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; + direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; + direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; + orig[0] = v->vp[0] + v->vfore*direc[0]; + orig[1] = v->vp[1] + v->vfore*direc[1]; + orig[2] = v->vp[2] + v->vfore*direc[2]; + return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0); } return(-1.0); } -viewloc(ip, v, p) /* find image location for point */ -FVECT ip; -register VIEW *v; -FVECT p; +void +viewloc( /* find image location for point */ +FVECT ip, +VIEW *v, +FVECT p +) { double d, d2; FVECT disp; - disp[0] = p[0] - v->vp[0]; - disp[1] = p[1] - v->vp[1]; - disp[2] = p[2] - v->vp[2]; + VSUB(disp, p, v->vp); switch (v->type) { case VT_PAR: /* parallel view */ @@ -246,8 +282,7 @@ FVECT p; d = 1.0/sqrt(d*d + d2*d2); ip[1] = DOT(disp,v->vvec)*d/v->vn2 + 0.5 - v->voff; ip[2] = VLEN(disp); - if (v->vfore > FTINY) - ip[2] *= (1.0 - v->vfore*d); + ip[2] *= (1.0 - v->vfore*d); return; case VT_ANG: /* angular fisheye */ ip[0] = 0.5 - v->hoff; @@ -260,53 +295,73 @@ FVECT p; ip[0] += 180.0/v->horiz; return; } - d = acos(d)/PI / sqrt(1.0 - d*d); - ip[0] += DOT(disp,v->hvec)*d*180.0/v->horiz; - ip[1] += DOT(disp,v->vvec)*d*180.0/v->vert; + d = (180.0/PI)*acos(d) / sqrt(1.0 - d*d); + ip[0] += DOT(disp,v->hvec)*d/v->horiz; + ip[1] += DOT(disp,v->vvec)*d/v->vert; return; + case VT_PLS: /* planispheric fisheye */ + ip[0] = 0.5 - v->hoff; + ip[1] = 0.5 - v->voff; + ip[2] = normalize(disp) - v->vfore; + d = DOT(disp,v->vdir); + if (d >= 1.0-FTINY) + return; + if (d <= -(1.0-FTINY)) + return; /* really an error */ + d = sqrt(1.0 - d*d) / (1.0 + d); + ip[0] += DOT(disp,v->hvec)*d/sqrt(v->hn2); + ip[1] += DOT(disp,v->vvec)*d/sqrt(v->vn2); + return; } ip[0] = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff; ip[1] = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff; } -pix2loc(loc, rp, px, py) /* compute image location from pixel pos. */ -FLOAT loc[2]; -register RESOLU *rp; -int px, py; +void +pix2loc( /* compute image location from pixel pos. */ +RREAL loc[2], +RESOLU *rp, +int px, +int py +) { - register int x, y; + int x, y; - if (rp->or & YMAJOR) { + if (rp->rt & YMAJOR) { x = px; y = py; } else { x = py; y = px; } - if (rp->or & XDECR) + if (rp->rt & XDECR) x = rp->xr-1 - x; - if (rp->or & YDECR) + if (rp->rt & YDECR) y = rp->yr-1 - y; loc[0] = (x+.5)/rp->xr; loc[1] = (y+.5)/rp->yr; } -loc2pix(pp, rp, lx, ly) /* compute pixel pos. from image location */ -int pp[2]; -register RESOLU *rp; -double lx, ly; +void +loc2pix( /* compute pixel pos. from image location */ +int pp[2], +RESOLU *rp, +double lx, +double ly +) { - register int x, y; + int x, y; - x = lx * rp->xr; - y = ly * rp->yr; - if (rp->or & XDECR) + x = (int)(lx*rp->xr + .5 - (lx < 0.0)); + y = (int)(ly*rp->yr + .5 - (ly < 0.0)); + + if (rp->rt & XDECR) x = rp->xr-1 - x; - if (rp->or & YDECR) + if (rp->rt & YDECR) y = rp->yr-1 - y; - if (rp->or & YMAJOR) { + if (rp->rt & YMAJOR) { pp[0] = x; pp[1] = y; } else { @@ -317,10 +372,11 @@ double lx, ly; int -getviewopt(v, ac, av) /* process view argument */ -register VIEW *v; -int ac; -register char *av[]; +getviewopt( /* process view argument */ +VIEW *v, +int ac, +char *av[] +) { #define check(c,l) if ((av[0][c]&&av[0][c]!=' ') || \ badarg(ac-1,av+1,l)) return(-1) @@ -345,6 +401,7 @@ register char *av[]; v->vdir[0] = atof(av[1]); v->vdir[1] = atof(av[2]); v->vdir[2] = atof(av[3]); + v->vdist = 1.; return(3); case 'u': /* up */ check(3,"fff"); @@ -384,24 +441,27 @@ register char *av[]; int -sscanview(vp, s) /* get view parameters from string */ -VIEW *vp; -register char *s; +sscanview( /* get view parameters from string */ +VIEW *vp, +char *s +) { int ac; char *av[4]; int na; int nvopts = 0; - if (*s != '-') - s = sskip2(s,1); + while (isspace(*s)) + if (!*s++) + return(0); while (*s) { ac = 0; do { - av[ac++] = s; - while (*s && *s != ' ') + if (ac || *s == '-') + av[ac++] = s; + while (*s && !isspace(*s)) s++; - while (*s == ' ') + while (isspace(*s)) s++; } while (*s && ac < 4); if ((na = getviewopt(vp, ac, av)) >= 0) { @@ -415,13 +475,17 @@ register char *s; } -fprintview(vp, fp) /* write out view parameters */ -register VIEW *vp; -FILE *fp; +void +fprintview( /* write out view parameters */ +VIEW *vp, +FILE *fp +) { fprintf(fp, " -vt%c", vp->type); fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]); - fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]); + fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0]*vp->vdist, + vp->vdir[1]*vp->vdist, + vp->vdir[2]*vp->vdist); fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]); fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert); fprintf(fp, " -vo %.6g -va %.6g", vp->vfore, vp->vaft); @@ -430,12 +494,14 @@ FILE *fp; char * -viewopt(vp) /* translate to minimal view string */ -register VIEW *vp; +viewopt( /* translate to minimal view string */ +VIEW *vp +) { static char vwstr[128]; - register char *cp = vwstr; + char *cp = vwstr; + *cp = '\0'; if (vp->type != stdview.type) { sprintf(cp, " -vt%c", vp->type); cp += strlen(cp); @@ -445,9 +511,11 @@ register VIEW *vp; vp->vp[0], vp->vp[1], vp->vp[2]); cp += strlen(cp); } - if (!VEQ(vp->vdir,stdview.vdir)) { + if (!FEQ(vp->vdist,stdview.vdist) || !VEQ(vp->vdir,stdview.vdir)) { sprintf(cp, " -vd %.6g %.6g %.6g", - vp->vdir[0], vp->vdir[1], vp->vdir[2]); + vp->vdir[0]*vp->vdist, + vp->vdir[1]*vp->vdist, + vp->vdir[2]*vp->vdist); cp += strlen(cp); } if (!VEQ(vp->vup,stdview.vup)) { @@ -484,13 +552,14 @@ register VIEW *vp; int -isview(s) /* is this a view string? */ -char *s; +isview( /* is this a view string? */ +char *s +) { - static char *altname[]={NULL,VIEWSTR,"rpict","rview","pinterp",NULL}; + static char *altname[]={NULL,VIEWSTR,"rpict","rview","rvu","rpiece","pinterp",NULL}; extern char *progname; - register char *cp; - register char **an; + char *cp; + char **an; /* add program name to list */ if (altname[0] == NULL) { for (cp = progname; *cp; cp++) @@ -519,26 +588,30 @@ struct myview { static int -gethview(s, v) /* get view from header */ -char *s; -register struct myview *v; +gethview( /* get view from header */ + char *s, + void *v +) { - if (isview(s) && sscanview(v->hv, s) > 0) - v->ok++; + if (isview(s) && sscanview(((struct myview*)v)->hv, s) > 0) + ((struct myview*)v)->ok++; return(0); } int -viewfile(fname, vp, rp) /* get view from file */ -char *fname; -VIEW *vp; -RESOLU *rp; +viewfile( /* get view from file */ +char *fname, +VIEW *vp, +RESOLU *rp +) { struct myview mvs; FILE *fp; - if ((fp = fopen(fname, "r")) == NULL) + if (fname == NULL || !strcmp(fname, "-")) + fp = stdin; + else if ((fp = fopen(fname, "r")) == NULL) return(-1); mvs.hv = vp;
