--- ray/src/common/image.c 1989/12/22 08:21:53 1.4 +++ ray/src/common/image.c 2006/11/19 01:14:31 2.33 @@ -1,271 +1,574 @@ -/* Copyright (c) 1986 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: image.c,v 2.33 2006/11/19 01:14:31 greg Exp $"; #endif - /* * image.c - routines for image generation. * - * 10/17/85 + * External symbols declared in view.h */ -#include +#include "copyright.h" -#include "standard.h" - +#include +#include "rtio.h" +#include "rtmath.h" +#include "paths.h" #include "view.h" -VIEW stdview = STDVIEW(512); /* default view parameters */ +#define FEQ(x,y) (fabs((x)-(y)) <= FTINY) +#define VEQ(v,w) (FEQ((v)[0],(w)[0]) && FEQ((v)[1],(w)[1]) \ + && FEQ((v)[2],(w)[2])) -char * -sskip(s) /* skip a word */ -register char *s; -{ - while (isspace(*s)) s++; - while (*s && !isspace(*s)) s++; - return(s); -} +VIEW stdview = STDVIEW; /* default view parameters */ +static gethfunc gethview; + char * -setview(v) /* set vhinc and vvinc, return message on error */ +setview(v) /* set hvec and vvec, return message on error */ register VIEW *v; { - double tan(), dt; + static char ill_horiz[] = "illegal horizontal view size"; + static char ill_vert[] = "illegal vertical view size"; - if (normalize(v->vdir) == 0.0) /* normalize direction */ + if (v->vaft < -FTINY || (v->vaft > FTINY && v->vaft <= v->vfore)) + return("illegal fore/aft clipping plane"); + + if (v->vdist <= FTINY) + return("illegal view distance"); + v->vdist *= normalize(v->vdir); /* normalize direction */ + if (v->vdist == 0.0) return("zero view direction"); - - fcross(v->vhinc, v->vdir, v->vup); /* compute horiz dir */ - if (normalize(v->vhinc) == 0.0) - return("illegal view up vector"); - - fcross(v->vvinc, v->vhinc, v->vdir); /* compute vert dir */ + if (normalize(v->vup) == 0.0) /* normalize view up */ + return("zero view up vector"); - if (v->type == VT_PAR) - dt = v->horiz; - else if (v->type == VT_PER) - dt = 2.0 * tan(v->horiz*(PI/180.0/2.0)); - else - return("unknown view type"); + fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */ - if (dt <= FTINY || dt >= FHUGE) - return("illegal horizontal view size"); + if (normalize(v->hvec) == 0.0) + return("view up parallel to view direction"); - if (v->hresolu <= 0) - return("illegal horizontal resolution"); + fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */ - dt /= (double)v->hresolu; - v->vhinc[0] *= dt; - v->vhinc[1] *= dt; - v->vhinc[2] *= dt; + if (v->horiz <= FTINY) + return(ill_horiz); + if (v->vert <= FTINY) + return(ill_vert); - if (v->type == VT_PAR) - dt = v->vert; - else - dt = 2.0 * tan(v->vert*(PI/180.0/2.0)); + switch (v->type) { + case VT_PAR: /* parallel view */ + v->hn2 = v->horiz; + v->vn2 = v->vert; + break; + case VT_PER: /* perspective view */ + if (v->horiz >= 180.0-FTINY) + return(ill_horiz); + if (v->vert >= 180.0-FTINY) + return(ill_vert); + v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0)); + v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0)); + break; + case VT_CYL: /* cylindrical panorama */ + if (v->horiz > 360.0+FTINY) + return(ill_horiz); + if (v->vert >= 180.0-FTINY) + return(ill_vert); + v->hn2 = v->horiz * (PI/180.0); + v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0)); + break; + case VT_ANG: /* angular fisheye */ + if (v->horiz > 360.0+FTINY) + return(ill_horiz); + if (v->vert > 360.0+FTINY) + return(ill_vert); + v->hn2 = v->horiz * (PI/180.0); + v->vn2 = v->vert * (PI/180.0); + break; + case VT_HEM: /* hemispherical fisheye */ + if (v->horiz > 180.0+FTINY) + return(ill_horiz); + if (v->vert > 180.0+FTINY) + return(ill_vert); + v->hn2 = 2.0 * sin(v->horiz*(PI/180.0/2.0)); + v->vn2 = 2.0 * sin(v->vert*(PI/180.0/2.0)); + break; + default: + return("unknown view type"); + } + if (v->type != VT_ANG) { + if (v->type != VT_CYL) { + v->hvec[0] *= v->hn2; + v->hvec[1] *= v->hn2; + v->hvec[2] *= v->hn2; + } + v->vvec[0] *= v->vn2; + v->vvec[1] *= v->vn2; + v->vvec[2] *= v->vn2; + } + v->hn2 *= v->hn2; + v->vn2 *= v->vn2; - if (dt <= FTINY || dt >= FHUGE) - return("illegal vertical view size"); + return(NULL); +} - if (v->vresolu <= 0) - return("illegal vertical resolution"); - - dt /= (double)v->vresolu; - v->vvinc[0] *= dt; - v->vvinc[1] *= dt; - v->vvinc[2] *= dt; - v->vhn2 = DOT(v->vhinc,v->vhinc); - v->vvn2 = DOT(v->vvinc,v->vvinc); - - return(NULL); +void +normaspect(va, ap, xp, yp) /* fix pixel aspect or resolution */ +double va; /* view aspect ratio */ +double *ap; /* pixel aspect in (or out if 0) */ +int *xp, *yp; /* x and y resolution in (or out if *ap!=0) */ +{ + if (*ap <= FTINY) + *ap = va * *xp / *yp; /* compute pixel aspect */ + else if (va * *xp > *ap * *yp) + *xp = *yp / va * *ap + .5; /* reduce x resolution */ + else + *yp = *xp * va / *ap + .5; /* reduce y resolution */ } -rayview(orig, direc, v, x, y) /* compute ray origin and direction */ +double +viewray(orig, direc, v, x, y) /* compute ray origin and direction */ FVECT orig, direc; register VIEW *v; double x, y; { - x -= 0.5 * v->hresolu; - y -= 0.5 * v->vresolu; + double d, z; + + x += v->hoff - 0.5; + y += v->voff - 0.5; - if (v->type == VT_PAR) { /* parallel view */ - orig[0] = v->vp[0] + x*v->vhinc[0] + y*v->vvinc[0]; - orig[1] = v->vp[1] + x*v->vhinc[1] + y*v->vvinc[1]; - orig[2] = v->vp[2] + x*v->vhinc[2] + y*v->vvinc[2]; + switch(v->type) { + case VT_PAR: /* parallel view */ + orig[0] = v->vp[0] + v->vfore*v->vdir[0] + + x*v->hvec[0] + y*v->vvec[0]; + orig[1] = v->vp[1] + v->vfore*v->vdir[1] + + x*v->hvec[1] + y*v->vvec[1]; + orig[2] = v->vp[2] + v->vfore*v->vdir[2] + + x*v->hvec[2] + y*v->vvec[2]; VCOPY(direc, v->vdir); - } else { /* perspective view */ - VCOPY(orig, v->vp); - direc[0] = v->vdir[0] + x*v->vhinc[0] + y*v->vvinc[0]; - direc[1] = v->vdir[1] + x*v->vhinc[1] + y*v->vvinc[1]; - direc[2] = v->vdir[2] + x*v->vhinc[2] + y*v->vvinc[2]; - normalize(direc); + return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0); + case VT_PER: /* perspective view */ + direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; + direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; + direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; + orig[0] = v->vp[0] + v->vfore*direc[0]; + orig[1] = v->vp[1] + v->vfore*direc[1]; + orig[2] = v->vp[2] + v->vfore*direc[2]; + d = normalize(direc); + return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0); + case VT_HEM: /* hemispherical fisheye */ + z = 1.0 - x*x*v->hn2 - y*y*v->vn2; + if (z < 0.0) + return(-1.0); + z = sqrt(z); + direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; + direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; + direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; + orig[0] = v->vp[0] + v->vfore*direc[0]; + orig[1] = v->vp[1] + v->vfore*direc[1]; + orig[2] = v->vp[2] + v->vfore*direc[2]; + return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0); + case VT_CYL: /* cylindrical panorama */ + d = x * v->horiz * (PI/180.0); + z = cos(d); + x = sin(d); + direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; + direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; + direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; + orig[0] = v->vp[0] + v->vfore*direc[0]; + orig[1] = v->vp[1] + v->vfore*direc[1]; + orig[2] = v->vp[2] + v->vfore*direc[2]; + d = normalize(direc); + return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0); + case VT_ANG: /* angular fisheye */ + x *= v->horiz/180.0; + y *= v->vert/180.0; + d = x*x + y*y; + if (d > 1.0) + return(-1.0); + d = sqrt(d); + z = cos(PI*d); + d = d <= FTINY ? PI : sqrt(1 - z*z)/d; + x *= d; + y *= d; + direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; + direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; + direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; + orig[0] = v->vp[0] + v->vfore*direc[0]; + orig[1] = v->vp[1] + v->vfore*direc[1]; + orig[2] = v->vp[2] + v->vfore*direc[2]; + return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0); } + return(-1.0); } -pixelview(xp, yp, zp, v, p) /* find image location for point */ -double *xp, *yp, *zp; +void +viewloc(ip, v, p) /* find image location for point */ +FVECT ip; register VIEW *v; FVECT p; { - extern double sqrt(); - double d; + double d, d2; FVECT disp; - + disp[0] = p[0] - v->vp[0]; disp[1] = p[1] - v->vp[1]; disp[2] = p[2] - v->vp[2]; - if (v->type == VT_PAR) { /* parallel view */ - if (zp != NULL) - *zp = DOT(disp,v->vdir); - } else { /* perspective view */ - d = 1.0/DOT(disp,v->vdir); - if (zp != NULL) { - *zp = sqrt(DOT(disp,disp)); - if (d < 0.0) - *zp = -*zp; + switch (v->type) { + case VT_PAR: /* parallel view */ + ip[2] = DOT(disp,v->vdir) - v->vfore; + break; + case VT_PER: /* perspective view */ + d = DOT(disp,v->vdir); + ip[2] = VLEN(disp); + if (d < 0.0) { /* fold pyramid */ + ip[2] = -ip[2]; + d = -d; } - disp[0] *= d; - disp[1] *= d; - disp[2] *= d; + if (d > FTINY) { + d = 1.0/d; + disp[0] *= d; + disp[1] *= d; + disp[2] *= d; + } + ip[2] *= (1.0 - v->vfore*d); + break; + case VT_HEM: /* hemispherical fisheye */ + d = normalize(disp); + if (DOT(disp,v->vdir) < 0.0) + ip[2] = -d; + else + ip[2] = d; + ip[2] -= v->vfore; + break; + case VT_CYL: /* cylindrical panorama */ + d = DOT(disp,v->hvec); + d2 = DOT(disp,v->vdir); + ip[0] = 180.0/PI * atan2(d,d2) / v->horiz + 0.5 - v->hoff; + d = 1.0/sqrt(d*d + d2*d2); + ip[1] = DOT(disp,v->vvec)*d/v->vn2 + 0.5 - v->voff; + ip[2] = VLEN(disp); + ip[2] *= (1.0 - v->vfore*d); + return; + case VT_ANG: /* angular fisheye */ + ip[0] = 0.5 - v->hoff; + ip[1] = 0.5 - v->voff; + ip[2] = normalize(disp) - v->vfore; + d = DOT(disp,v->vdir); + if (d >= 1.0-FTINY) + return; + if (d <= -(1.0-FTINY)) { + ip[0] += 180.0/v->horiz; + return; + } + d = acos(d)/PI / sqrt(1.0 - d*d); + ip[0] += DOT(disp,v->hvec)*d*180.0/v->horiz; + ip[1] += DOT(disp,v->vvec)*d*180.0/v->vert; + return; } - *xp = DOT(disp,v->vhinc)/v->vhn2 + 0.5*v->hresolu; - *yp = DOT(disp,v->vvinc)/v->vvn2 + 0.5*v->vresolu; + ip[0] = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff; + ip[1] = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff; } -sscanview(vp, s) /* get view parameters */ -register VIEW *vp; +void +pix2loc(loc, rp, px, py) /* compute image location from pixel pos. */ +RREAL loc[2]; +register RESOLU *rp; +int px, py; +{ + register int x, y; + + if (rp->rt & YMAJOR) { + x = px; + y = py; + } else { + x = py; + y = px; + } + if (rp->rt & XDECR) + x = rp->xr-1 - x; + if (rp->rt & YDECR) + y = rp->yr-1 - y; + loc[0] = (x+.5)/rp->xr; + loc[1] = (y+.5)/rp->yr; +} + + +void +loc2pix(pp, rp, lx, ly) /* compute pixel pos. from image location */ +int pp[2]; +register RESOLU *rp; +double lx, ly; +{ + register int x, y; + + x = lx * rp->xr; + y = ly * rp->yr; + if (rp->rt & XDECR) + x = rp->xr-1 - x; + if (rp->rt & YDECR) + y = rp->yr-1 - y; + if (rp->rt & YMAJOR) { + pp[0] = x; + pp[1] = y; + } else { + pp[0] = y; + pp[1] = x; + } +} + + +int +getviewopt(v, ac, av) /* process view argument */ +register VIEW *v; +int ac; +register char *av[]; +{ +#define check(c,l) if ((av[0][c]&&av[0][c]!=' ') || \ + badarg(ac-1,av+1,l)) return(-1) + + if (ac <= 0 || av[0][0] != '-' || av[0][1] != 'v') + return(-1); + switch (av[0][2]) { + case 't': /* type */ + if (!av[0][3] || av[0][3]==' ') + return(-1); + check(4,""); + v->type = av[0][3]; + return(0); + case 'p': /* point */ + check(3,"fff"); + v->vp[0] = atof(av[1]); + v->vp[1] = atof(av[2]); + v->vp[2] = atof(av[3]); + return(3); + case 'd': /* direction */ + check(3,"fff"); + v->vdir[0] = atof(av[1]); + v->vdir[1] = atof(av[2]); + v->vdir[2] = atof(av[3]); + v->vdist = 1.; + return(3); + case 'u': /* up */ + check(3,"fff"); + v->vup[0] = atof(av[1]); + v->vup[1] = atof(av[2]); + v->vup[2] = atof(av[3]); + return(3); + case 'h': /* horizontal size */ + check(3,"f"); + v->horiz = atof(av[1]); + return(1); + case 'v': /* vertical size */ + check(3,"f"); + v->vert = atof(av[1]); + return(1); + case 'o': /* fore clipping plane */ + check(3,"f"); + v->vfore = atof(av[1]); + return(1); + case 'a': /* aft clipping plane */ + check(3,"f"); + v->vaft = atof(av[1]); + return(1); + case 's': /* shift */ + check(3,"f"); + v->hoff = atof(av[1]); + return(1); + case 'l': /* lift */ + check(3,"f"); + v->voff = atof(av[1]); + return(1); + default: + return(-1); + } +#undef check +} + + +int +sscanview(vp, s) /* get view parameters from string */ +VIEW *vp; register char *s; { - for ( ; ; ) - switch (*s++) { - case '\0': - case '\n': + int ac; + char *av[4]; + int na; + int nvopts = 0; + + while (isspace(*s)) + if (!*s++) return(0); - case '-': - switch (*s++) { - case '\0': - return(-1); - case 'x': - if (sscanf(s, "%d", &vp->hresolu) != 1) - return(-1); - s = sskip(s); - continue; - case 'y': - if (sscanf(s, "%d", &vp->vresolu) != 1) - return(-1); - s = sskip(s); - continue; - case 'v': - switch (*s++) { - case '\0': - return(-1); - case 't': - vp->type = *s++; - continue; - case 'p': - if (sscanf(s, "%lf %lf %lf", - &vp->vp[0], - &vp->vp[1], - &vp->vp[2]) != 3) - return(-1); - s = sskip(sskip(sskip(s))); - continue; - case 'd': - if (sscanf(s, "%lf %lf %lf", - &vp->vdir[0], - &vp->vdir[1], - &vp->vdir[2]) != 3) - return(-1); - s = sskip(sskip(sskip(s))); - continue; - case 'u': - if (sscanf(s, "%lf %lf %lf", - &vp->vup[0], - &vp->vup[1], - &vp->vup[2]) != 3) - return(-1); - s = sskip(sskip(sskip(s))); - continue; - case 'h': - if (sscanf(s, "%lf", - &vp->horiz) != 1) - return(-1); - s = sskip(s); - continue; - case 'v': - if (sscanf(s, "%lf", - &vp->vert) != 1) - return(-1); - s = sskip(s); - continue; - } - continue; - } - continue; - } + while (*s) { + ac = 0; + do { + if (ac || *s == '-') + av[ac++] = s; + while (*s && !isspace(*s)) + s++; + while (isspace(*s)) + s++; + } while (*s && ac < 4); + if ((na = getviewopt(vp, ac, av)) >= 0) { + if (na+1 < ac) + s = av[na+1]; + nvopts++; + } else if (ac > 1) + s = av[1]; + } + return(nvopts); } +void fprintview(vp, fp) /* write out view parameters */ register VIEW *vp; FILE *fp; { fprintf(fp, " -vt%c", vp->type); fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]); - fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]); + fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0]*vp->vdist, + vp->vdir[1]*vp->vdist, + vp->vdir[2]*vp->vdist); fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]); fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert); - fprintf(fp, " -x %d -y %d", vp->hresolu, vp->vresolu); + fprintf(fp, " -vo %.6g -va %.6g", vp->vfore, vp->vaft); + fprintf(fp, " -vs %.6g -vl %.6g", vp->hoff, vp->voff); } -static VIEW *hview; /* view from header */ -static int gothview; /* success indicator */ -static char *altname[] = {NULL,"rpict","rview","pinterp",VIEWSTR,NULL}; +char * +viewopt(vp) /* translate to minimal view string */ +register VIEW *vp; +{ + static char vwstr[128]; + register char *cp = vwstr; + *cp = '\0'; + if (vp->type != stdview.type) { + sprintf(cp, " -vt%c", vp->type); + cp += strlen(cp); + } + if (!VEQ(vp->vp,stdview.vp)) { + sprintf(cp, " -vp %.6g %.6g %.6g", + vp->vp[0], vp->vp[1], vp->vp[2]); + cp += strlen(cp); + } + if (!FEQ(vp->vdist,stdview.vdist) || !VEQ(vp->vdir,stdview.vdir)) { + sprintf(cp, " -vd %.6g %.6g %.6g", + vp->vdir[0]*vp->vdist, + vp->vdir[1]*vp->vdist, + vp->vdir[2]*vp->vdist); + cp += strlen(cp); + } + if (!VEQ(vp->vup,stdview.vup)) { + sprintf(cp, " -vu %.6g %.6g %.6g", + vp->vup[0], vp->vup[1], vp->vup[2]); + cp += strlen(cp); + } + if (!FEQ(vp->horiz,stdview.horiz)) { + sprintf(cp, " -vh %.6g", vp->horiz); + cp += strlen(cp); + } + if (!FEQ(vp->vert,stdview.vert)) { + sprintf(cp, " -vv %.6g", vp->vert); + cp += strlen(cp); + } + if (!FEQ(vp->vfore,stdview.vfore)) { + sprintf(cp, " -vo %.6g", vp->vfore); + cp += strlen(cp); + } + if (!FEQ(vp->vaft,stdview.vaft)) { + sprintf(cp, " -va %.6g", vp->vaft); + cp += strlen(cp); + } + if (!FEQ(vp->hoff,stdview.hoff)) { + sprintf(cp, " -vs %.6g", vp->hoff); + cp += strlen(cp); + } + if (!FEQ(vp->voff,stdview.voff)) { + sprintf(cp, " -vl %.6g", vp->voff); + cp += strlen(cp); + } + return(vwstr); +} -static -gethview(s) /* get view from header */ + +int +isview(s) /* is this a view string? */ char *s; { + static char *altname[]={NULL,VIEWSTR,"rpict","rview","rvu","rpiece","pinterp",NULL}; + extern char *progname; + register char *cp; register char **an; - + /* add program name to list */ + if (altname[0] == NULL) { + for (cp = progname; *cp; cp++) + ; + while (cp > progname && !ISDIRSEP(cp[-1])) + cp--; + altname[0] = cp; + } + /* skip leading path */ + cp = s; + while (*cp && *cp != ' ') + cp++; + while (cp > s && !ISDIRSEP(cp[-1])) + cp--; for (an = altname; *an != NULL; an++) - if (!strncmp(*an, s, strlen(*an))) { - if (sscanview(hview, s+strlen(*an)) == 0) - gothview++; - return; - } + if (!strncmp(*an, cp, strlen(*an))) + return(1); + return(0); } +struct myview { + VIEW *hv; + int ok; +}; + + +static int +gethview( /* get view from header */ + char *s, + void *v +) +{ + if (isview(s) && sscanview(((struct myview*)v)->hv, s) > 0) + ((struct myview*)v)->ok++; + return(0); +} + + int -viewfile(fname, vp) /* get view from file */ +viewfile(fname, vp, rp) /* get view from file */ char *fname; VIEW *vp; +RESOLU *rp; { - extern char *progname; + struct myview mvs; FILE *fp; - if ((fp = fopen(fname, "r")) == NULL) + if (fname == NULL || !strcmp(fname, "-")) + fp = stdin; + else if ((fp = fopen(fname, "r")) == NULL) return(-1); - altname[0] = progname; - hview = vp; - gothview = 0; + mvs.hv = vp; + mvs.ok = 0; - getheader(fp, gethview); + getheader(fp, gethview, &mvs); + if (rp != NULL && !fgetsresolu(rp, fp)) + mvs.ok = 0; + fclose(fp); - return(gothview); + return(mvs.ok); }
