root/radiance/ray/src/common/image.c
Revision: 2.5
Committed: Tue Sep 8 10:04:30 1992 UTC (32 years, 9 months ago) by greg
Changes since 2.4: +10 -8 lines
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * image.c - routines for image generation.
9 *
10 * 10/17/85
11 */
12
13 #include "standard.h"
14
15 #include "view.h"
16
17 #include "resolu.h"
18
19 #include "paths.h"
20
21 VIEW stdview = STDVIEW; /* default view parameters */
22
23
24 char *
25 setview(v) /* set hvec and vvec, return message on error */
26 register VIEW *v;
27 {
28 static char ill_horiz[] = "illegal horizontal view size";
29 static char ill_vert[] = "illegal vertical view size";
30
31 if (normalize(v->vdir) == 0.0) /* normalize direction */
32 return("zero view direction");
33
34 if (normalize(v->vup) == 0.0) /* normalize view up */
35 return("zero view up vector");
36
37 fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */
38
39 if (normalize(v->hvec) == 0.0)
40 return("view up parallel to view direction");
41
42 fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */
43
44 if (v->horiz <= FTINY)
45 return(ill_horiz);
46 if (v->vert <= FTINY)
47 return(ill_vert);
48
49 switch (v->type) {
50 case VT_PAR: /* parallel view */
51 v->hn2 = v->horiz;
52 v->vn2 = v->vert;
53 break;
54 case VT_PER: /* perspective view */
55 if (v->horiz >= 180.0-FTINY)
56 return(ill_horiz);
57 if (v->vert >= 180.0-FTINY)
58 return(ill_vert);
59 v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0));
60 v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0));
61 break;
62 case VT_ANG: /* angular fisheye */
63 if (v->horiz > 360.0+FTINY)
64 return(ill_horiz);
65 if (v->vert > 360.0+FTINY)
66 return(ill_vert);
67 v->hn2 = v->horiz / 90.0;
68 v->vn2 = v->vert / 90.0;
69 break;
70 case VT_HEM: /* hemispherical fisheye */
71 if (v->horiz > 180.0+FTINY)
72 return(ill_horiz);
73 if (v->vert > 180.0+FTINY)
74 return(ill_vert);
75 v->hn2 = 2.0 * sin(v->horiz*(PI/180.0/2.0));
76 v->vn2 = 2.0 * sin(v->vert*(PI/180.0/2.0));
77 break;
78 default:
79 return("unknown view type");
80 }
81 if (v->type != VT_ANG) {
82 v->hvec[0] *= v->hn2;
83 v->hvec[1] *= v->hn2;
84 v->hvec[2] *= v->hn2;
85 v->vvec[0] *= v->vn2;
86 v->vvec[1] *= v->vn2;
87 v->vvec[2] *= v->vn2;
88 }
89 v->hn2 *= v->hn2;
90 v->vn2 *= v->vn2;
91
92 return(NULL);
93 }
94
95
96 normaspect(va, ap, xp, yp) /* fix pixel aspect or resolution */
97 double va; /* view aspect ratio */
98 double *ap; /* pixel aspect in (or out if 0) */
99 int *xp, *yp; /* x and y resolution in (or out if *ap!=0) */
100 {
101 if (*ap <= FTINY)
102 *ap = va * *xp / *yp; /* compute pixel aspect */
103 else if (va * *xp > *ap * *yp)
104 *xp = *yp / va * *ap + .5; /* reduce x resolution */
105 else
106 *yp = *xp * va / *ap + .5; /* reduce y resolution */
107 }
108
109
110 viewray(orig, direc, v, x, y) /* compute ray origin and direction */
111 FVECT orig, direc;
112 register VIEW *v;
113 double x, y;
114 {
115 double d, z;
116
117 x += v->hoff - 0.5;
118 y += v->voff - 0.5;
119
120 switch(v->type) {
121 case VT_PAR: /* parallel view */
122 orig[0] = v->vp[0] + x*v->hvec[0] + y*v->vvec[0];
123 orig[1] = v->vp[1] + x*v->hvec[1] + y*v->vvec[1];
124 orig[2] = v->vp[2] + x*v->hvec[2] + y*v->vvec[2];
125 VCOPY(direc, v->vdir);
126 return(0);
127 case VT_PER: /* perspective view */
128 VCOPY(orig, v->vp);
129 direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
130 direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
131 direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
132 normalize(direc);
133 return(0);
134 case VT_HEM: /* hemispherical fisheye */
135 z = 1.0 - x*x*v->hn2 - y*y*v->vn2;
136 if (z < 0.0)
137 return(-1);
138 z = sqrt(z);
139 VCOPY(orig, v->vp);
140 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
141 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
142 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
143 return(0);
144 case VT_ANG: /* angular fisheye */
145 x *= v->horiz/180.0;
146 y *= v->vert/180.0;
147 d = x*x + y*y;
148 if (d > 1.0)
149 return(-1);
150 VCOPY(orig, v->vp);
151 if (d <= FTINY) {
152 VCOPY(direc, v->vdir);
153 return(0);
154 }
155 d = sqrt(d);
156 z = cos(PI*d);
157 d = sqrt(1 - z*z)/d;
158 x *= d;
159 y *= d;
160 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
161 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
162 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
163 return(0);
164 }
165 return(-1);
166 }
167
168
169 viewloc(ip, v, p) /* find image location for point */
170 FVECT ip;
171 register VIEW *v;
172 FVECT p;
173 {
174 double d;
175 FVECT disp;
176
177 disp[0] = p[0] - v->vp[0];
178 disp[1] = p[1] - v->vp[1];
179 disp[2] = p[2] - v->vp[2];
180
181 switch (v->type) {
182 case VT_PAR: /* parallel view */
183 ip[2] = DOT(disp,v->vdir);
184 break;
185 case VT_PER: /* perspective view */
186 d = DOT(disp,v->vdir);
187 ip[2] = sqrt(DOT(disp,disp));
188 if (d < 0.0) { /* fold pyramid */
189 ip[2] = -ip[2];
190 d = -d;
191 } else if (d > FTINY) {
192 d = 1.0/d;
193 disp[0] *= d;
194 disp[1] *= d;
195 disp[2] *= d;
196 }
197 break;
198 case VT_HEM: /* hemispherical fisheye */
199 d = normalize(disp);
200 if (DOT(disp,v->vdir) < 0.0)
201 ip[2] = -d;
202 else
203 ip[2] = d;
204 break;
205 case VT_ANG: /* angular fisheye */
206 ip[0] = 0.5 - v->hoff;
207 ip[1] = 0.5 - v->voff;
208 ip[2] = normalize(disp);
209 d = DOT(disp,v->vdir);
210 if (d >= 1.0-FTINY)
211 return;
212 if (d <= -(1.0-FTINY)) {
213 ip[1] += 180.0/v->horiz;
214 ip[2] += 180.0/v->vert;
215 return;
216 }
217 d = acos(d)/PI / sqrt(1.0 - d*d);
218 ip[0] += DOT(disp,v->hvec)*d*180.0/v->horiz;
219 ip[1] += DOT(disp,v->vvec)*d*180.0/v->vert;
220 return;
221 }
222 ip[0] = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff;
223 ip[1] = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff;
224 }
225
226
227 pix2loc(loc, rp, px, py) /* compute image location from pixel pos. */
228 FLOAT loc[2];
229 register RESOLU *rp;
230 int px, py;
231 {
232 register int x, y;
233
234 if (rp->or & YMAJOR) {
235 x = px;
236 y = py;
237 } else {
238 x = py;
239 y = px;
240 }
241 if (rp->or & XDECR)
242 x = rp->xr-1 - x;
243 if (rp->or & YDECR)
244 y = rp->yr-1 - y;
245 loc[0] = (x+.5)/rp->xr;
246 loc[1] = (y+.5)/rp->yr;
247 }
248
249
250 loc2pix(pp, rp, lx, ly) /* compute pixel pos. from image location */
251 int pp[2];
252 register RESOLU *rp;
253 double lx, ly;
254 {
255 register int x, y;
256
257 x = lx * rp->xr;
258 y = ly * rp->yr;
259 if (rp->or & XDECR)
260 x = rp->xr-1 - x;
261 if (rp->or & YDECR)
262 y = rp->yr-1 - y;
263 if (rp->or & YMAJOR) {
264 pp[0] = x;
265 pp[1] = y;
266 } else {
267 pp[0] = y;
268 pp[1] = x;
269 }
270 }
271
272
273 int
274 getviewopt(v, ac, av) /* process view argument */
275 register VIEW *v;
276 int ac;
277 register char *av[];
278 {
279 #define check(c,l) if ((av[0][c]&&av[0][c]!=' ') || \
280 badarg(ac-1,av+1,l)) return(-1)
281
282 if (ac <= 0 || av[0][0] != '-' || av[0][1] != 'v')
283 return(-1);
284 switch (av[0][2]) {
285 case 't': /* type */
286 if (!av[0][3] || av[0][3]==' ')
287 return(-1);
288 check(4,"");
289 v->type = av[0][3];
290 return(0);
291 case 'p': /* point */
292 check(3,"fff");
293 v->vp[0] = atof(av[1]);
294 v->vp[1] = atof(av[2]);
295 v->vp[2] = atof(av[3]);
296 return(3);
297 case 'd': /* direction */
298 check(3,"fff");
299 v->vdir[0] = atof(av[1]);
300 v->vdir[1] = atof(av[2]);
301 v->vdir[2] = atof(av[3]);
302 return(3);
303 case 'u': /* up */
304 check(3,"fff");
305 v->vup[0] = atof(av[1]);
306 v->vup[1] = atof(av[2]);
307 v->vup[2] = atof(av[3]);
308 return(3);
309 case 'h': /* horizontal size */
310 check(3,"f");
311 v->horiz = atof(av[1]);
312 return(1);
313 case 'v': /* vertical size */
314 check(3,"f");
315 v->vert = atof(av[1]);
316 return(1);
317 case 's': /* shift */
318 check(3,"f");
319 v->hoff = atof(av[1]);
320 return(1);
321 case 'l': /* lift */
322 check(3,"f");
323 v->voff = atof(av[1]);
324 return(1);
325 default:
326 return(-1);
327 }
328 #undef check
329 }
330
331
332 int
333 sscanview(vp, s) /* get view parameters from string */
334 VIEW *vp;
335 register char *s;
336 {
337 int ac;
338 char *av[4];
339 int na;
340 int nvopts = 0;
341
342 if (*s != '-')
343 s = sskip(s);
344 while (*s) {
345 ac = 0;
346 do {
347 av[ac++] = s;
348 while (*s && *s != ' ')
349 s++;
350 while (*s == ' ')
351 s++;
352 } while (*s && ac < 4);
353 if ((na = getviewopt(vp, ac, av)) >= 0) {
354 if (na+1 < ac)
355 s = av[na+1];
356 nvopts++;
357 } else if (ac > 1)
358 s = av[1];
359 }
360 return(nvopts);
361 }
362
363
364 fprintview(vp, fp) /* write out view parameters */
365 register VIEW *vp;
366 FILE *fp;
367 {
368 fprintf(fp, " -vt%c", vp->type);
369 fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]);
370 fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]);
371 fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]);
372 fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert);
373 fprintf(fp, " -vs %.6g -vl %.6g", vp->hoff, vp->voff);
374 }
375
376
377 int
378 isview(s) /* is this a view string? */
379 char *s;
380 {
381 static char *altname[]={NULL,VIEWSTR,"rpict","rview","pinterp",NULL};
382 extern char *progname;
383 register char *cp;
384 register char **an;
385 /* add program name to list */
386 if (altname[0] == NULL) {
387 for (cp = progname; *cp; cp++)
388 ;
389 while (cp > progname && !ISDIRSEP(cp[-1]))
390 cp--;
391 altname[0] = cp;
392 }
393 /* skip leading path */
394 cp = s;
395 while (*cp && *cp != ' ')
396 cp++;
397 while (cp > s && !ISDIRSEP(cp[-1]))
398 cp--;
399 for (an = altname; *an != NULL; an++)
400 if (!strncmp(*an, cp, strlen(*an)))
401 return(1);
402 return(0);
403 }
404
405
406 struct myview {
407 VIEW *hv;
408 int ok;
409 };
410
411
412 static
413 gethview(s, v) /* get view from header */
414 char *s;
415 register struct myview *v;
416 {
417 if (isview(s) && sscanview(v->hv, s) > 0)
418 v->ok++;
419 }
420
421
422 int
423 viewfile(fname, vp, rp) /* get view from file */
424 char *fname;
425 VIEW *vp;
426 RESOLU *rp;
427 {
428 struct myview mvs;
429 FILE *fp;
430
431 if ((fp = fopen(fname, "r")) == NULL)
432 return(-1);
433
434 mvs.hv = vp;
435 mvs.ok = 0;
436
437 getheader(fp, gethview, &mvs);
438
439 if (rp != NULL && !fgetsresolu(rp, fp))
440 mvs.ok = 0;
441
442 fclose(fp);
443
444 return(mvs.ok);
445 }
