root/radiance/ray/src/common/image.c
Revision: 1.3
Committed: Sun Dec 10 16:19:54 1989 UTC (34 years, 6 months ago) by greg
Changes since 1.2: +54 -7 lines
added routines pixelview() and sskip()
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * image.c - routines for image generation.
9 *
10 * 10/17/85
11 */
12
13 #include <ctype.h>
14
15 #include "standard.h"
16
17 #include "view.h"
18
19 VIEW stdview = STDVIEW(512); /* default view parameters */
20
21
22 char *
23 sskip(s) /* skip a word */
24 register char *s;
25 {
26 while (isspace(*s)) s++;
27 while (*s && !isspace(*s)) s++;
28 return(s);
29 }
30
31
32 char *
33 setview(v) /* set vhinc and vvinc, return message on error */
34 register VIEW *v;
35 {
36 double tan(), dt;
37
38 if (normalize(v->vdir) == 0.0) /* normalize direction */
39 return("zero view direction");
40
41 fcross(v->vhinc, v->vdir, v->vup); /* compute horiz dir */
42
43 if (normalize(v->vhinc) == 0.0)
44 return("illegal view up vector");
45
46 fcross(v->vvinc, v->vhinc, v->vdir); /* compute vert dir */
47
48 if (v->type == VT_PAR)
49 dt = v->horiz;
50 else if (v->type == VT_PER)
51 dt = 2.0 * tan(v->horiz*(PI/180.0/2.0));
52 else
53 return("unknown view type");
54
55 if (dt <= FTINY || dt >= FHUGE)
56 return("illegal horizontal view size");
57
58 if (v->hresolu <= 0)
59 return("illegal horizontal resolution");
60
61 dt /= (double)v->hresolu;
62 v->vhinc[0] *= dt;
63 v->vhinc[1] *= dt;
64 v->vhinc[2] *= dt;
65
66 if (v->type == VT_PAR)
67 dt = v->vert;
68 else
69 dt = 2.0 * tan(v->vert*(PI/180.0/2.0));
70
71 if (dt <= FTINY || dt >= FHUGE)
72 return("illegal vertical view size");
73
74 if (v->vresolu <= 0)
75 return("illegal vertical resolution");
76
77 dt /= (double)v->vresolu;
78 v->vvinc[0] *= dt;
79 v->vvinc[1] *= dt;
80 v->vvinc[2] *= dt;
81
82 v->vhs2 = 1.0/DOT(v->vhinc,v->vhinc);
83 v->vvs2 = 1.0/DOT(v->vvinc,v->vvinc);
84
85 return(NULL);
86 }
87
88
89 rayview(orig, direc, v, x, y) /* compute ray origin and direction */
90 FVECT orig, direc;
91 register VIEW *v;
92 double x, y;
93 {
94 x -= 0.5 * v->hresolu;
95 y -= 0.5 * v->vresolu;
96
97 if (v->type == VT_PAR) { /* parallel view */
98 orig[0] = v->vp[0] + x*v->vhinc[0] + y*v->vvinc[0];
99 orig[1] = v->vp[1] + x*v->vhinc[1] + y*v->vvinc[1];
100 orig[2] = v->vp[2] + x*v->vhinc[2] + y*v->vvinc[2];
101 VCOPY(direc, v->vdir);
102 } else { /* perspective view */
103 VCOPY(orig, v->vp);
104 direc[0] = v->vdir[0] + x*v->vhinc[0] + y*v->vvinc[0];
105 direc[1] = v->vdir[1] + x*v->vhinc[1] + y*v->vvinc[1];
106 direc[2] = v->vdir[2] + x*v->vhinc[2] + y*v->vvinc[2];
107 normalize(direc);
108 }
109 }
110
111
112 pixelview(xp, yp, zp, v, p) /* find image location for point */
113 double *xp, *yp, *zp;
114 register VIEW *v;
115 FVECT p;
116 {
117 extern double sqrt();
118 double d;
119 FVECT disp;
120
121 disp[0] = p[0] - v->vp[0];
122 disp[1] = p[1] - v->vp[1];
123 disp[2] = p[2] - v->vp[2];
124
125 if (v->type == VT_PAR) { /* parallel view */
126 if (zp != NULL)
127 *zp = DOT(disp,v->vdir);
128 } else { /* perspective view */
129 d = 1.0/DOT(disp,v->vdir);
130 if (zp != NULL) {
131 *zp = sqrt(DOT(disp,disp));
132 if (d < 0.0)
133 *zp = -*zp;
134 }
135 disp[0] *= d;
136 disp[1] *= d;
137 disp[2] *= d;
138 }
139 *xp = DOT(disp,v->vhinc)*v->vhs2 + 0.5*v->hresolu;
140 *yp = DOT(disp,v->vvinc)*v->vvs2 + 0.5*v->vresolu;
141 }
142
143
144 sscanview(vp, s) /* get view parameters */
145 register VIEW *vp;
146 register char *s;
147 {
148 for ( ; ; )
149 switch (*s++) {
150 case '\0':
151 case '\n':
152 return(0);
153 case '-':
154 switch (*s++) {
155 case '\0':
156 return(-1);
157 case 'x':
158 if (sscanf(s, "%d", &vp->hresolu) != 1)
159 return(-1);
160 s = sskip(s);
161 continue;
162 case 'y':
163 if (sscanf(s, "%d", &vp->vresolu) != 1)
164 return(-1);
165 s = sskip(s);
166 continue;
167 case 'v':
168 switch (*s++) {
169 case '\0':
170 return(-1);
171 case 't':
172 vp->type = *s++;
173 continue;
174 case 'p':
175 if (sscanf(s, "%lf %lf %lf",
176 &vp->vp[0],
177 &vp->vp[1],
178 &vp->vp[2]) != 3)
179 return(-1);
180 s = sskip(sskip(sskip(s)));
181 continue;
182 case 'd':
183 if (sscanf(s, "%lf %lf %lf",
184 &vp->vdir[0],
185 &vp->vdir[1],
186 &vp->vdir[2]) != 3)
187 return(-1);
188 s = sskip(sskip(sskip(s)));
189 continue;
190 case 'u':
191 if (sscanf(s, "%lf %lf %lf",
192 &vp->vup[0],
193 &vp->vup[1],
194 &vp->vup[2]) != 3)
195 return(-1);
196 s = sskip(sskip(sskip(s)));
197 continue;
198 case 'h':
199 if (sscanf(s, "%lf",
200 &vp->horiz) != 1)
201 return(-1);
202 s = sskip(s);
203 continue;
204 case 'v':
205 if (sscanf(s, "%lf",
206 &vp->vert) != 1)
207 return(-1);
208 s = sskip(s);
209 continue;
210 }
211 continue;
212 }
213 continue;
214 }
215 }
216
217
218 fprintview(vp, fp) /* write out view parameters */
219 register VIEW *vp;
220 FILE *fp;
221 {
222 fprintf(fp, " -vt%c", vp->type);
223 fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]);
224 fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]);
225 fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]);
226 fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert);
227 fprintf(fp, " -x %d -y %d", vp->hresolu, vp->vresolu);
228 }
229
230
231 static VIEW *hview; /* view from header */
232 static int gothview; /* success indicator */
233 static char *altname[] = {NULL,"rpict","rview","pinterp",VIEWSTR,NULL};
234
235
236 static
237 gethview(s) /* get view from header */
238 char *s;
239 {
240 register char **an;
241
242 for (an = altname; *an != NULL; an++)
243 if (!strncmp(*an, s, strlen(*an))) {
244 if (sscanview(hview, s+strlen(*an)) == 0)
245 gothview++;
246 return;
247 }
248 }
249
250
251 int
252 viewfile(fname, vp) /* get view from file */
253 char *fname;
254 VIEW *vp;
255 {
256 extern char *progname;
257 FILE *fp;
258
259 if ((fp = fopen(fname, "r")) == NULL)
260 return(-1);
261
262 altname[0] = progname;
263 hview = vp;
264 gothview = 0;
265
266 getheader(fp, gethview);
267
268 fclose(fp);
269
270 return(gothview);
271 }
