root/radiance/ray/src/common/image.c
Fri Dec 12 22:05:38 2008 UTC (16 years, 5 months ago) by greg
Changes since 2.34: +58 -41 lines
Diff to previous 2.34
ANSI C definition updates
Tue Mar 11 02:21:46 2008 UTC (17 years, 2 months ago) by greg
Changes since 2.33: +47 -11 lines
Diff to previous 2.33
Sun Nov 19 01:14:31 2006 UTC (18 years, 6 months ago) by greg
Diff to previous 2.32
Minor bug fix
Wed Jul 12 01:37:40 2006 UTC (18 years, 10 months ago) by greg
Changes since 2.31: +7 -7 lines
Diff to previous 2.31
Fixed bug where tabs in view files were not being interpreted as spaces
Fri Feb 18 17:42:14 2005 UTC (20 years, 3 months ago) by greg
Diff to previous 2.30
Added check for illegal view distance
Mon Feb 7 20:13:55 2005 UTC (20 years, 3 months ago) by greg
Changes since 2.29: +2 -1 lines
Diff to previous 2.29
Robustness improvements in depth-of-field blurring
Tue Jan 18 00:33:16 2005 UTC (20 years, 4 months ago) by greg
Changes since 2.28: +10 -5 lines
Diff to previous 2.28
Tue Jun 8 19:48:29 2004 UTC (20 years, 11 months ago) by greg
Changes since 2.27: +2 -1 lines
Diff to previous 2.27
Thu Feb 12 18:55:50 2004 UTC (21 years, 3 months ago) by greg
Changes since 2.26: +2 -1 lines
Diff to previous 2.26
Fri Jan 2 11:36:26 2004 UTC (21 years, 5 months ago) by schorsch
Changes since 2.25: +10 -7 lines
Diff to previous 2.25
Thu Jan 1 19:47:05 2004 UTC (21 years, 5 months ago) by greg
Diff to previous 2.24
Other updates affected by command renaming
Thu Jan 1 19:31:45 2004 UTC (21 years, 5 months ago) by greg
Diff to previous 2.23
Wed Nov 26 19:16:23 2003 UTC (21 years, 6 months ago) by greg
Diff to previous 2.22
Minor code improvements
Fri Nov 14 17:22:06 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 2.21: +2 -4 lines
Diff to previous 2.21
Sun Sep 7 05:32:02 2003 UTC (21 years, 8 months ago) by greg
Diff to previous 2.20
Prototype fix
Fri Aug 29 23:03:13 2003 UTC (21 years, 9 months ago) by greg
Changes since 2.19: +4 -2 lines
Diff to previous 2.19
Fixed bug in last "improvement"
Tue Aug 26 04:24:26 2003 UTC (21 years, 9 months ago) by greg
Diff to previous 2.18
Minor improvements
Thu Jun 26 00:58:09 2003 UTC (21 years, 11 months ago) by schorsch
Diff to previous 2.17
Tue Feb 25 02:47:21 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.16: +1 -56 lines
Diff to previous 2.16
Changes since 2.15: +75 -14 lines
Diff to previous 2.15
Fri Feb 26 12:24:07 1999 UTC (26 years, 3 months ago) by gwlarson
Diff to previous 2.14
allowed negative fore clipping plane for holographic rendering
Tue Oct 27 08:44:29 1998 UTC (26 years, 7 months ago) by gwlarson
Diff to previous 2.13
Tue Dec 9 16:41:03 1997 UTC (27 years, 5 months ago) by gregl
Changes since 2.12: +8 -9 lines
Diff to previous 2.12
fixed computation for VT_CYL in viewloc() -- at last!
Wed Jan 17 10:55:40 1996 UTC (29 years, 4 months ago) by greg
replaced sskip() behavior and added new sskip2() function
Wed Jan 10 19:25:57 1996 UTC (29 years, 4 months ago) by greg
Changes since 2.10: +59 -3 lines
added viewopt() routine to get minimal view specification
Thu Aug 24 11:55:03 1995 UTC (29 years, 9 months ago) by greg
fixed bug in viewloc() for cylindrical sources
Fri Aug 18 10:20:10 1995 UTC (29 years, 9 months ago) by greg
Changes since 2.8: +38 -6 lines
added cylindrical view type
Wed Dec 21 09:07:19 1994 UTC (30 years, 5 months ago) by greg
bug fix from last change
Tue Dec 20 20:15:04 1994 UTC (30 years, 5 months ago) by greg
Changes since 2.6: +46 -20 lines
added -vo and -va (fore and aft clipping plane) parameters
Sat Dec 5 16:23:37 1992 UTC (32 years, 6 months ago) by greg
Changes since 2.5: +1 -5 lines
fixed bug in -vta type with -DSMLFLT option in viewray()
Tue Sep 8 10:04:30 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.4: +10 -8 lines
Tue Sep 8 09:09:20 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.3: +5 -3 lines
Tue Apr 28 09:36:42 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.2: +30 -13 lines
added isview() call
Thu Dec 19 14:45:50 1991 UTC (33 years, 5 months ago) by greg
Tue Nov 12 16:55:38 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.17
Mon Nov 11 14:00:14 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.16: +72 -33 lines
Diff to previous 1.16
Thu Nov 7 11:04:00 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.15: +10 -9 lines
Diff to previous 1.15
added badarg() routine for argument checking
Thu Apr 18 14:52:55 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.14: +15 -10 lines
Diff to previous 1.14
changed interface to header routines
Mon Mar 18 13:48:05 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.13: +4 -1 lines
Diff to previous 1.13
normalize view up vector (bug in routines expecting nomralized)
Mon Oct 15 14:17:05 1990 UTC (34 years, 7 months ago) by greg
Changes since 1.12: +7 -13 lines
Diff to previous 1.12
fixed bug in hemispherical view calculation
Sat Oct 13 20:56:01 1990 UTC (34 years, 7 months ago) by greg
Changes since 1.11: +123 -31 lines
Diff to previous 1.11
added fisheye view types
Fri Sep 21 17:06:31 1990 UTC (34 years, 8 months ago) by greg
Changes since 1.10: +9 -4 lines
Diff to previous 1.10
added folding of pyramid to viewpixel()
Thu Sep 13 08:34:15 1990 UTC (34 years, 8 months ago) by greg
Diff to previous 1.9
added roundoff to computation of resolutions in normaspect()
Tue Jan 16 16:21:07 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.8: +6 -5 lines
Diff to previous 1.8
fixed bugs in sscanview() and fprintview()
Tue Jan 16 11:29:43 1990 UTC (35 years, 4 months ago) by greg
Diff to previous 1.7
added ability to recover dimensions from picture files
Tue Jan 9 11:37:50 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.6: +5 -7 lines
Diff to previous 1.6
fixed routine for computing pixel ratio
Tue Jan 9 09:08:09 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.5: +16 -0 lines
Diff to previous 1.5
added routine for computing image size and pixel aspect ratios
Mon Jan 8 14:45:52 1990 UTC (35 years, 5 months ago) by greg
Changes since 1.4: +122 -127 lines
Diff to previous 1.4
got rid of resolution and added shift and lift options
Fri Dec 22 08:21:53 1989 UTC (35 years, 5 months ago) by greg
Diff to previous 1.3
changed vhs2 and vvs2 to vhn2 and vvn2
Sun Dec 10 16:19:54 1989 UTC (35 years, 5 months ago) by greg
Changes since 1.2: +54 -7 lines
Diff to previous 1.2
added routines pixelview() and sskip()
Fri Oct 20 16:53:03 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.1: +0 -16 lines
moved bigdiff() from image.c to color.c (more logical)
Thu Feb 2 10:34:34 1989 UTC (36 years, 4 months ago) by greg
