root/radiance/ray/src/common/image.c
Revision: 1.16
Committed: Thu Nov 7 11:04:00 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.15: +10 -9 lines
added badarg() routine for argument checking
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * image.c - routines for image generation.
9 *
10 * 10/17/85
11 */
12
13 #include "standard.h"
14
15 #include "view.h"
16
17 VIEW stdview = STDVIEW; /* default view parameters */
18
19
20 char *
21 setview(v) /* set hvec and vvec, return message on error */
22 register VIEW *v;
23 {
24 static char ill_horiz[] = "illegal horizontal view size";
25 static char ill_vert[] = "illegal vertical view size";
26
27 if (normalize(v->vdir) == 0.0) /* normalize direction */
28 return("zero view direction");
29
30 if (normalize(v->vup) == 0.0) /* normalize view up */
31 return("zero view up vector");
32
33 fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */
34
35 if (normalize(v->hvec) == 0.0)
36 return("view up parallel to view direction");
37
38 fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */
39
40 if (v->horiz <= FTINY)
41 return(ill_horiz);
42 if (v->vert <= FTINY)
43 return(ill_vert);
44
45 switch (v->type) {
46 case VT_PAR: /* parallel view */
47 v->hn2 = v->horiz;
48 v->vn2 = v->vert;
49 break;
50 case VT_PER: /* perspective view */
51 if (v->horiz >= 180.0-FTINY)
52 return(ill_horiz);
53 if (v->vert >= 180.0-FTINY)
54 return(ill_vert);
55 v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0));
56 v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0));
57 break;
58 case VT_ANG: /* angular fisheye */
59 if (v->horiz > 360.0+FTINY)
60 return(ill_horiz);
61 if (v->vert > 360.0+FTINY)
62 return(ill_vert);
63 v->hn2 = v->horiz / 90.0;
64 v->vn2 = v->vert / 90.0;
65 break;
66 case VT_HEM: /* hemispherical fisheye */
67 if (v->horiz > 180.0+FTINY)
68 return(ill_horiz);
69 if (v->vert > 180.0+FTINY)
70 return(ill_vert);
71 v->hn2 = 2.0 * sin(v->horiz*(PI/180.0/2.0));
72 v->vn2 = 2.0 * sin(v->vert*(PI/180.0/2.0));
73 break;
74 default:
75 return("unknown view type");
76 }
77 if (v->type != VT_ANG) {
78 v->hvec[0] *= v->hn2;
79 v->hvec[1] *= v->hn2;
80 v->hvec[2] *= v->hn2;
81 v->vvec[0] *= v->vn2;
82 v->vvec[1] *= v->vn2;
83 v->vvec[2] *= v->vn2;
84 }
85 v->hn2 *= v->hn2;
86 v->vn2 *= v->vn2;
87
88 return(NULL);
89 }
90
91
92 normaspect(va, ap, xp, yp) /* fix pixel aspect or resolution */
93 double va; /* view aspect ratio */
94 double *ap; /* pixel aspect in (or out if 0) */
95 int *xp, *yp; /* x and y resolution in (or out if *ap!=0) */
96 {
97 if (*ap <= FTINY)
98 *ap = va * *xp / *yp; /* compute pixel aspect */
99 else if (va * *xp > *ap * *yp)
100 *xp = *yp / va * *ap + .5; /* reduce x resolution */
101 else
102 *yp = *xp * va / *ap + .5; /* reduce y resolution */
103 }
104
105
106 viewray(orig, direc, v, x, y) /* compute ray origin and direction */
107 FVECT orig, direc;
108 register VIEW *v;
109 double x, y;
110 {
111 double d, z;
112
113 x += v->hoff - 0.5;
114 y += v->voff - 0.5;
115
116 switch(v->type) {
117 case VT_PAR: /* parallel view */
118 orig[0] = v->vp[0] + x*v->hvec[0] + y*v->vvec[0];
119 orig[1] = v->vp[1] + x*v->hvec[1] + y*v->vvec[1];
120 orig[2] = v->vp[2] + x*v->hvec[2] + y*v->vvec[2];
121 VCOPY(direc, v->vdir);
122 return(0);
123 case VT_PER: /* perspective view */
124 VCOPY(orig, v->vp);
125 direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
126 direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
127 direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
128 normalize(direc);
129 return(0);
130 case VT_HEM: /* hemispherical fisheye */
131 z = 1.0 - x*x*v->hn2 - y*y*v->vn2;
132 if (z < 0.0)
133 return(-1);
134 z = sqrt(z);
135 VCOPY(orig, v->vp);
136 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
137 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
138 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
139 return(0);
140 case VT_ANG: /* angular fisheye */
141 x *= v->horiz/180.0;
142 y *= v->vert/180.0;
143 d = x*x + y*y;
144 if (d > 1.0)
145 return(-1);
146 VCOPY(orig, v->vp);
147 if (d <= FTINY) {
148 VCOPY(direc, v->vdir);
149 return(0);
150 }
151 d = sqrt(d);
152 z = cos(PI*d);
153 d = sqrt(1 - z*z)/d;
154 x *= d;
155 y *= d;
156 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
157 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
158 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
159 return(0);
160 }
161 return(-1);
162 }
163
164
165 viewpixel(xp, yp, zp, v, p) /* find image location for point */
166 double *xp, *yp, *zp;
167 register VIEW *v;
168 FVECT p;
169 {
170 double d;
171 FVECT disp;
172
173 disp[0] = p[0] - v->vp[0];
174 disp[1] = p[1] - v->vp[1];
175 disp[2] = p[2] - v->vp[2];
176
177 switch (v->type) {
178 case VT_PAR: /* parallel view */
179 if (zp != NULL)
180 *zp = DOT(disp,v->vdir);
181 break;
182 case VT_PER: /* perspective view */
183 d = DOT(disp,v->vdir);
184 if (zp != NULL) {
185 *zp = sqrt(DOT(disp,disp));
186 if (d < 0.0)
187 *zp = -*zp;
188 }
189 if (d < 0.0) /* fold pyramid */
190 d = -d;
191 if (d > FTINY) {
192 d = 1.0/d;
193 disp[0] *= d;
194 disp[1] *= d;
195 disp[2] *= d;
196 }
197 break;
198 case VT_HEM: /* hemispherical fisheye */
199 d = normalize(disp);
200 if (zp != NULL) {
201 if (DOT(disp,v->vdir) < 0.0)
202 *zp = -d;
203 else
204 *zp = d;
205 }
206 break;
207 case VT_ANG: /* angular fisheye */
208 d = normalize(disp);
209 if (zp != NULL)
210 *zp = d;
211 *xp = 0.5 - v->hoff;
212 *yp = 0.5 - v->voff;
213 d = DOT(disp,v->vdir);
214 if (d >= 1.0-FTINY)
215 return;
216 if (d <= -(1.0-FTINY)) {
217 *xp += 180.0/v->horiz;
218 *yp += 180.0/v->vert;
219 return;
220 }
221 d = acos(d)/PI / sqrt(1.0 - d*d);
222 *xp += DOT(disp,v->hvec)*d*180.0/v->horiz;
223 *yp += DOT(disp,v->vvec)*d*180.0/v->vert;
224 return;
225 }
226 *xp = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff;
227 *yp = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff;
228 }
229
230
231 int
232 getviewopt(v, ac, av) /* process view argument */
233 register VIEW *v;
234 int ac;
235 register char *av[];
236 {
237 #define check(c,l) if ((av[0][c]&&av[0][c]!=' ') || \
238 badarg(ac-1,av+1,l)) return(-1)
239 extern double atof();
240
241 if (ac <= 0 || av[0][0] != '-' || av[0][1] != 'v')
242 return(-1);
243 switch (av[0][2]) {
244 case 't': /* type */
245 if (!av[0][3] || av[0][3]==' ')
246 return(-1);
247 check(4,"");
248 v->type = av[0][3];
249 return(0);
250 case 'p': /* point */
251 check(3,"fff");
252 v->vp[0] = atof(av[1]);
253 v->vp[1] = atof(av[2]);
254 v->vp[2] = atof(av[3]);
255 return(3);
256 case 'd': /* direction */
257 check(3,"fff");
258 v->vdir[0] = atof(av[1]);
259 v->vdir[1] = atof(av[2]);
260 v->vdir[2] = atof(av[3]);
261 return(3);
262 case 'u': /* up */
263 check(3,"fff");
264 v->vup[0] = atof(av[1]);
265 v->vup[1] = atof(av[2]);
266 v->vup[2] = atof(av[3]);
267 return(3);
268 case 'h': /* horizontal size */
269 check(3,"f");
270 v->horiz = atof(av[1]);
271 return(1);
272 case 'v': /* vertical size */
273 check(3,"f");
274 v->vert = atof(av[1]);
275 return(1);
276 case 's': /* shift */
277 check(3,"f");
278 v->hoff = atof(av[1]);
279 return(1);
280 case 'l': /* lift */
281 check(3,"f");
282 v->voff = atof(av[1]);
283 return(1);
284 default:
285 return(-1);
286 }
287 #undef check
288 }
289
290
291 int
292 sscanview(vp, s) /* get view parameters from string */
293 VIEW *vp;
294 register char *s;
295 {
296 int ac;
297 char *av[4];
298 int na;
299 int nvopts = 0;
300
301 while (*s == ' ')
302 s++;
303 while (*s) {
304 ac = 0;
305 do {
306 av[ac++] = s;
307 while (*s && *s != ' ')
308 s++;
309 while (*s == ' ')
310 s++;
311 } while (*s && ac < 4);
312 if ((na = getviewopt(vp, ac, av)) >= 0) {
313 if (na+1 < ac)
314 s = av[na+1];
315 nvopts++;
316 } else if (ac > 1)
317 s = av[1];
318 }
319 return(nvopts);
320 }
321
322
323 fprintview(vp, fp) /* write out view parameters */
324 register VIEW *vp;
325 FILE *fp;
326 {
327 fprintf(fp, " -vt%c", vp->type);
328 fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]);
329 fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]);
330 fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]);
331 fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert);
332 fprintf(fp, " -vs %.6g -vl %.6g", vp->hoff, vp->voff);
333 }
334
335
336 static char *altname[] = {NULL,"rpict","rview","pinterp",VIEWSTR,NULL};
337
338 struct myview {
339 VIEW *hv;
340 int ok;
341 };
342
343
344 static
345 gethview(s, v) /* get view from header */
346 char *s;
347 register struct myview *v;
348 {
349 register char **an;
350
351 for (an = altname; *an != NULL; an++)
352 if (!strncmp(*an, s, strlen(*an))) {
353 if (sscanview(v->hv, s+strlen(*an)) > 0)
354 v->ok++;
355 return;
356 }
357 }
358
359
360 int
361 viewfile(fname, vp, xp, yp) /* get view from file */
362 char *fname;
363 VIEW *vp;
364 int *xp, *yp;
365 {
366 extern char *progname;
367 struct myview mvs;
368 FILE *fp;
369
370 if ((fp = fopen(fname, "r")) == NULL)
371 return(-1);
372
373 altname[0] = progname;
374 mvs.hv = vp;
375 mvs.ok = 0;
376
377 getheader(fp, gethview, &mvs);
378
379 if (xp != NULL && yp != NULL
380 && fgetresolu(xp, yp, fp) == -1)
381 mvs.ok = 0;
382
383 fclose(fp);
384
385 return(mvs.ok);
386 }
