root/radiance/ray/src/common/image.c
Fri Dec 12 22:05:38 2008 UTC (16 years, 7 months ago) by greg
Changes since 2.34: +58 -41 lines
Diff to previous 2.34 , to selected 2.17
ANSI C definition updates
Tue Mar 11 02:21:46 2008 UTC (17 years, 4 months ago) by greg
Changes since 2.33: +47 -11 lines
Diff to previous 2.33 , to selected 2.17
Sun Nov 19 01:14:31 2006 UTC (18 years, 8 months ago) by greg
Diff to previous 2.32 , to selected 2.17
Minor bug fix
Wed Jul 12 01:37:40 2006 UTC (19 years ago) by greg
Changes since 2.31: +7 -7 lines
Diff to previous 2.31 , to selected 2.17
Fixed bug where tabs in view files were not being interpreted as spaces
Fri Feb 18 17:42:14 2005 UTC (20 years, 5 months ago) by greg
Diff to previous 2.30 , to selected 2.17
Added check for illegal view distance
Mon Feb 7 20:13:55 2005 UTC (20 years, 5 months ago) by greg
Changes since 2.29: +2 -1 lines
Diff to previous 2.29 , to selected 2.17
Robustness improvements in depth-of-field blurring
Tue Jan 18 00:33:16 2005 UTC (20 years, 6 months ago) by greg
Changes since 2.28: +10 -5 lines
Diff to previous 2.28 , to selected 2.17
Tue Jun 8 19:48:29 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.27: +2 -1 lines
Diff to previous 2.27 , to selected 2.17
Thu Feb 12 18:55:50 2004 UTC (21 years, 5 months ago) by greg
Changes since 2.26: +2 -1 lines
Diff to previous 2.26 , to selected 2.17
Fri Jan 2 11:36:26 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 2.25: +10 -7 lines
Diff to previous 2.25 , to selected 2.17
Thu Jan 1 19:47:05 2004 UTC (21 years, 7 months ago) by greg
Diff to previous 2.24 , to selected 2.17
Other updates affected by command renaming
Thu Jan 1 19:31:45 2004 UTC (21 years, 7 months ago) by greg
Diff to previous 2.23 , to selected 2.17
Wed Nov 26 19:16:23 2003 UTC (21 years, 8 months ago) by greg
Diff to previous 2.22 , to selected 2.17
Minor code improvements
Fri Nov 14 17:22:06 2003 UTC (21 years, 8 months ago) by schorsch
Changes since 2.21: +2 -4 lines
Diff to previous 2.21 , to selected 2.17
Sun Sep 7 05:32:02 2003 UTC (21 years, 10 months ago) by greg
Diff to previous 2.20 , to selected 2.17
Prototype fix
Fri Aug 29 23:03:13 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.19: +4 -2 lines
Diff to previous 2.19 , to selected 2.17
Fixed bug in last "improvement"
Tue Aug 26 04:24:26 2003 UTC (21 years, 11 months ago) by greg
Diff to previous 2.18 , to selected 2.17
Minor improvements
Thu Jun 26 00:58:09 2003 UTC (22 years, 1 month ago) by schorsch
Diff to previous 2.17
Revision 2.17 - (view) (download) (annotate) - [selected]
Tue Feb 25 02:47:21 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.16: +1 -56 lines
Diff to previous 2.16
Sat Feb 22 02:07:22 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.15: +75 -14 lines
Diff to previous 2.15 , to selected 2.17
Fri Feb 26 12:24:07 1999 UTC (26 years, 5 months ago) by gwlarson
Diff to previous 2.14 , to selected 2.17
allowed negative fore clipping plane for holographic rendering
Tue Oct 27 08:44:29 1998 UTC (26 years, 9 months ago) by gwlarson
Diff to previous 2.13 , to selected 2.17
Tue Dec 9 16:41:03 1997 UTC (27 years, 7 months ago) by gregl
Changes since 2.12: +8 -9 lines
Diff to previous 2.12 , to selected 2.17
fixed computation for VT_CYL in viewloc() -- at last!
Wed Jan 17 10:55:40 1996 UTC (29 years, 6 months ago) by greg
Diff to previous 2.11 , to selected 2.17
replaced sskip() behavior and added new sskip2() function
Wed Jan 10 19:25:57 1996 UTC (29 years, 6 months ago) by greg
Changes since 2.10: +59 -3 lines
Diff to previous 2.10 , to selected 2.17
added viewopt() routine to get minimal view specification
Thu Aug 24 11:55:03 1995 UTC (29 years, 11 months ago) by greg
Diff to previous 2.9 , to selected 2.17
fixed bug in viewloc() for cylindrical sources
Fri Aug 18 10:20:10 1995 UTC (29 years, 11 months ago) by greg
Changes since 2.8: +38 -6 lines
Diff to previous 2.8 , to selected 2.17
added cylindrical view type
Wed Dec 21 09:07:19 1994 UTC (30 years, 7 months ago) by greg
Diff to previous 2.7 , to selected 2.17
bug fix from last change
Tue Dec 20 20:15:04 1994 UTC (30 years, 7 months ago) by greg
Changes since 2.6: +46 -20 lines
Diff to previous 2.6 , to selected 2.17
added -vo and -va (fore and aft clipping plane) parameters
Sat Dec 5 16:23:37 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.5: +1 -5 lines
Diff to previous 2.5 , to selected 2.17
fixed bug in -vta type with -DSMLFLT option in viewray()
Tue Sep 8 10:04:30 1992 UTC (32 years, 10 months ago) by greg
Changes since 2.4: +10 -8 lines
Diff to previous 2.4 , to selected 2.17
Tue Sep 8 09:09:20 1992 UTC (32 years, 10 months ago) by greg
Changes since 2.3: +5 -3 lines
Diff to previous 2.3 , to selected 2.17
Tue Apr 28 09:36:42 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.2: +30 -13 lines
Diff to previous 2.2 , to selected 2.17
added isview() call
Thu Dec 19 14:45:50 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 2.1 , to selected 2.17
Tue Nov 12 16:55:38 1991 UTC (33 years, 8 months ago) by greg
Diff to previous 1.17 , to selected 2.17
Mon Nov 11 14:00:14 1991 UTC (33 years, 8 months ago) by greg
Changes since 1.16: +72 -33 lines
Diff to previous 1.16 , to selected 2.17
Thu Nov 7 11:04:00 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.15: +10 -9 lines
Diff to previous 1.15 , to selected 2.17
added badarg() routine for argument checking
Thu Apr 18 14:52:55 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.14: +15 -10 lines
Diff to previous 1.14 , to selected 2.17
changed interface to header routines
Mon Mar 18 13:48:05 1991 UTC (34 years, 4 months ago) by greg
Changes since 1.13: +4 -1 lines
Diff to previous 1.13 , to selected 2.17
normalize view up vector (bug in routines expecting nomralized)
Mon Oct 15 14:17:05 1990 UTC (34 years, 9 months ago) by greg
Changes since 1.12: +7 -13 lines
Diff to previous 1.12 , to selected 2.17
fixed bug in hemispherical view calculation
Sat Oct 13 20:56:01 1990 UTC (34 years, 9 months ago) by greg
Changes since 1.11: +123 -31 lines
Diff to previous 1.11 , to selected 2.17
added fisheye view types
Fri Sep 21 17:06:31 1990 UTC (34 years, 10 months ago) by greg
Changes since 1.10: +9 -4 lines
Diff to previous 1.10 , to selected 2.17
added folding of pyramid to viewpixel()
Thu Sep 13 08:34:15 1990 UTC (34 years, 10 months ago) by greg
Diff to previous 1.9 , to selected 2.17
added roundoff to computation of resolutions in normaspect()
Tue Jan 16 16:21:07 1990 UTC (35 years, 6 months ago) by greg
Changes since 1.8: +6 -5 lines
Diff to previous 1.8 , to selected 2.17
fixed bugs in sscanview() and fprintview()
Tue Jan 16 11:29:43 1990 UTC (35 years, 6 months ago) by greg
Diff to previous 1.7 , to selected 2.17
added ability to recover dimensions from picture files
Tue Jan 9 11:37:50 1990 UTC (35 years, 6 months ago) by greg
Changes since 1.6: +5 -7 lines
Diff to previous 1.6 , to selected 2.17
fixed routine for computing pixel ratio
Tue Jan 9 09:08:09 1990 UTC (35 years, 6 months ago) by greg
Changes since 1.5: +16 -0 lines
Diff to previous 1.5 , to selected 2.17
added routine for computing image size and pixel aspect ratios
Mon Jan 8 14:45:52 1990 UTC (35 years, 6 months ago) by greg
Changes since 1.4: +122 -127 lines
Diff to previous 1.4 , to selected 2.17
got rid of resolution and added shift and lift options
Fri Dec 22 08:21:53 1989 UTC (35 years, 7 months ago) by greg
Diff to previous 1.3 , to selected 2.17
changed vhs2 and vvs2 to vhn2 and vvn2
Sun Dec 10 16:19:54 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.2: +54 -7 lines
Diff to previous 1.2 , to selected 2.17
added routines pixelview() and sskip()
Fri Oct 20 16:53:03 1989 UTC (35 years, 9 months ago) by greg
Changes since 1.1: +0 -16 lines
Diff to previous 1.1 , to selected 2.17
moved bigdiff() from image.c to color.c (more logical)
Thu Feb 2 10:34:34 1989 UTC (36 years, 6 months ago) by greg
Diff to selected 2.17
