root/radiance/ray/src/common/image.c
Revision: 2.34
Committed: Tue Mar 11 02:21:46 2008 UTC (16 years, 3 months ago) by greg
Changes since 2.33: +47 -11 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.34 static const char RCSid[] = "$Id: image.c,v 2.33 2006/11/19 01:14:31 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * image.c - routines for image generation.
6 greg 2.16 *
7     * External symbols declared in view.h
8     */
9
10 greg 2.17 #include "copyright.h"
11 greg 1.1
12 greg 2.32 #include <ctype.h>
13 schorsch 2.22 #include "rtio.h"
14 greg 2.28 #include "rtmath.h"
15 greg 2.27 #include "paths.h"
16 greg 1.1 #include "view.h"
17
18 greg 2.4
19 greg 2.11 #define FEQ(x,y) (fabs((x)-(y)) <= FTINY)
20     #define VEQ(v,w) (FEQ((v)[0],(w)[0]) && FEQ((v)[1],(w)[1]) \
21     && FEQ((v)[2],(w)[2]))
22
23 greg 1.5 VIEW stdview = STDVIEW; /* default view parameters */
24 greg 1.1
25 schorsch 2.26 static gethfunc gethview;
26
27 greg 1.1
28     char *
29 greg 1.5 setview(v) /* set hvec and vvec, return message on error */
30     register VIEW *v;
31 greg 1.3 {
32 greg 1.12 static char ill_horiz[] = "illegal horizontal view size";
33     static char ill_vert[] = "illegal vertical view size";
34
35 gwlarson 2.15 if (v->vaft < -FTINY || (v->vaft > FTINY && v->vaft <= v->vfore))
36 greg 2.7 return("illegal fore/aft clipping plane");
37
38 greg 2.31 if (v->vdist <= FTINY)
39     return("illegal view distance");
40 greg 2.29 v->vdist *= normalize(v->vdir); /* normalize direction */
41     if (v->vdist == 0.0)
42 greg 1.1 return("zero view direction");
43
44 greg 1.14 if (normalize(v->vup) == 0.0) /* normalize view up */
45     return("zero view up vector");
46
47 greg 1.5 fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */
48
49     if (normalize(v->hvec) == 0.0)
50 greg 1.14 return("view up parallel to view direction");
51 greg 1.1
52 greg 1.5 fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */
53
54 greg 1.12 if (v->horiz <= FTINY)
55     return(ill_horiz);
56     if (v->vert <= FTINY)
57     return(ill_vert);
58
59     switch (v->type) {
60     case VT_PAR: /* parallel view */
61 greg 1.5 v->hn2 = v->horiz;
62 greg 1.12 v->vn2 = v->vert;
63     break;
64     case VT_PER: /* perspective view */
65     if (v->horiz >= 180.0-FTINY)
66     return(ill_horiz);
67     if (v->vert >= 180.0-FTINY)
68     return(ill_vert);
69 greg 1.5 v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0));
70 greg 1.12 v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0));
71     break;
72 greg 2.9 case VT_CYL: /* cylindrical panorama */
73     if (v->horiz > 360.0+FTINY)
74     return(ill_horiz);
75     if (v->vert >= 180.0-FTINY)
76     return(ill_vert);
77     v->hn2 = v->horiz * (PI/180.0);
78     v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0));
79     break;
80 greg 1.12 case VT_ANG: /* angular fisheye */
81     if (v->horiz > 360.0+FTINY)
82     return(ill_horiz);
83     if (v->vert > 360.0+FTINY)
84     return(ill_vert);
85 greg 2.9 v->hn2 = v->horiz * (PI/180.0);
86     v->vn2 = v->vert * (PI/180.0);
87 greg 1.12 break;
88     case VT_HEM: /* hemispherical fisheye */
89     if (v->horiz > 180.0+FTINY)
90     return(ill_horiz);
91     if (v->vert > 180.0+FTINY)
92     return(ill_vert);
93     v->hn2 = 2.0 * sin(v->horiz*(PI/180.0/2.0));
94     v->vn2 = 2.0 * sin(v->vert*(PI/180.0/2.0));
95     break;
96 greg 2.34 case VT_PLS: /* planispheric fisheye */
97     if (v->horiz >= 360.0-FTINY)
98     return(ill_horiz);
99     if (v->vert >= 360.0-FTINY)
100     return(ill_vert);
101     v->hn2 = 2.*sin(v->horiz*(PI/180.0/2.0)) /
102     (1.0 + cos(v->horiz*(PI/180.0/2.0)));
103     v->vn2 = 2.*sin(v->vert*(PI/180.0/2.0)) /
104     (1.0 + cos(v->vert*(PI/180.0/2.0)));
105     break;
106 greg 1.12 default:
107 greg 1.1 return("unknown view type");
108 greg 1.12 }
109 greg 2.34 if (v->type != VT_ANG && v->type != VT_PLS) {
110 greg 2.9 if (v->type != VT_CYL) {
111     v->hvec[0] *= v->hn2;
112     v->hvec[1] *= v->hn2;
113     v->hvec[2] *= v->hn2;
114     }
115 greg 1.12 v->vvec[0] *= v->vn2;
116     v->vvec[1] *= v->vn2;
117     v->vvec[2] *= v->vn2;
118     }
119 greg 1.5 v->hn2 *= v->hn2;
120     v->vn2 *= v->vn2;
121 greg 1.1
122     return(NULL);
123     }
124
125
126 greg 2.16 void
127 greg 1.7 normaspect(va, ap, xp, yp) /* fix pixel aspect or resolution */
128     double va; /* view aspect ratio */
129     double *ap; /* pixel aspect in (or out if 0) */
130     int *xp, *yp; /* x and y resolution in (or out if *ap!=0) */
131 greg 1.6 {
132     if (*ap <= FTINY)
133 greg 1.7 *ap = va * *xp / *yp; /* compute pixel aspect */
134 greg 1.6 else if (va * *xp > *ap * *yp)
135 greg 1.10 *xp = *yp / va * *ap + .5; /* reduce x resolution */
136 greg 1.6 else
137 greg 1.10 *yp = *xp * va / *ap + .5; /* reduce y resolution */
138 greg 1.6 }
139
140
141 greg 2.7 double
142 greg 1.5 viewray(orig, direc, v, x, y) /* compute ray origin and direction */
143 greg 1.1 FVECT orig, direc;
144     register VIEW *v;
145     double x, y;
146     {
147 greg 1.12 double d, z;
148
149 greg 1.5 x += v->hoff - 0.5;
150     y += v->voff - 0.5;
151 greg 1.1
152 greg 1.12 switch(v->type) {
153     case VT_PAR: /* parallel view */
154 greg 2.7 orig[0] = v->vp[0] + v->vfore*v->vdir[0]
155     + x*v->hvec[0] + y*v->vvec[0];
156     orig[1] = v->vp[1] + v->vfore*v->vdir[1]
157     + x*v->hvec[1] + y*v->vvec[1];
158     orig[2] = v->vp[2] + v->vfore*v->vdir[2]
159     + x*v->hvec[2] + y*v->vvec[2];
160 greg 1.1 VCOPY(direc, v->vdir);
161 greg 2.8 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
162 greg 1.12 case VT_PER: /* perspective view */
163 greg 1.5 direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
164     direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
165     direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
166 greg 2.7 orig[0] = v->vp[0] + v->vfore*direc[0];
167     orig[1] = v->vp[1] + v->vfore*direc[1];
168     orig[2] = v->vp[2] + v->vfore*direc[2];
169     d = normalize(direc);
170 greg 2.8 return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0);
171 greg 1.12 case VT_HEM: /* hemispherical fisheye */
172 greg 1.13 z = 1.0 - x*x*v->hn2 - y*y*v->vn2;
173 greg 1.12 if (z < 0.0)
174 greg 2.7 return(-1.0);
175 greg 1.12 z = sqrt(z);
176     direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
177     direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
178     direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
179 greg 2.7 orig[0] = v->vp[0] + v->vfore*direc[0];
180     orig[1] = v->vp[1] + v->vfore*direc[1];
181     orig[2] = v->vp[2] + v->vfore*direc[2];
182 greg 2.8 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
183 greg 2.9 case VT_CYL: /* cylindrical panorama */
184     d = x * v->horiz * (PI/180.0);
185     z = cos(d);
186     x = sin(d);
187     direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
188     direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
189     direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
190     orig[0] = v->vp[0] + v->vfore*direc[0];
191     orig[1] = v->vp[1] + v->vfore*direc[1];
192     orig[2] = v->vp[2] + v->vfore*direc[2];
193     d = normalize(direc);
194     return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0);
195 greg 1.12 case VT_ANG: /* angular fisheye */
196 greg 2.34 x *= (1.0/180.0)*v->horiz;
197     y *= (1.0/180.0)*v->vert;
198 greg 1.12 d = x*x + y*y;
199     if (d > 1.0)
200 greg 2.7 return(-1.0);
201 greg 1.12 d = sqrt(d);
202     z = cos(PI*d);
203 greg 2.34 d = d <= FTINY ? PI : sqrt(1.0 - z*z)/d;
204     x *= d;
205     y *= d;
206     direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
207     direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
208     direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
209     orig[0] = v->vp[0] + v->vfore*direc[0];
210     orig[1] = v->vp[1] + v->vfore*direc[1];
211     orig[2] = v->vp[2] + v->vfore*direc[2];
212     return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
213     case VT_PLS: /* planispheric fisheye */
214     x *= sqrt(v->hn2);
215     y *= sqrt(v->vn2);
216     d = x*x + y*y;
217     z = (1. - d)/(1. + d);
218     d = d <= FTINY*FTINY ? PI : sqrt((1.0 - z*z)/d);
219 greg 1.12 x *= d;
220     y *= d;
221     direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
222     direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
223     direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
224 greg 2.7 orig[0] = v->vp[0] + v->vfore*direc[0];
225     orig[1] = v->vp[1] + v->vfore*direc[1];
226     orig[2] = v->vp[2] + v->vfore*direc[2];
227 greg 2.8 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
228 greg 1.1 }
229 greg 2.7 return(-1.0);
230 greg 1.1 }
231
232
233 greg 2.16 void
234 greg 1.17 viewloc(ip, v, p) /* find image location for point */
235     FVECT ip;
236 greg 1.3 register VIEW *v;
237     FVECT p;
238     {
239 gregl 2.13 double d, d2;
240 greg 1.3 FVECT disp;
241 greg 1.5
242 greg 2.34 VSUB(disp, p, v->vp);
243 greg 1.3
244 greg 1.12 switch (v->type) {
245     case VT_PAR: /* parallel view */
246 greg 2.7 ip[2] = DOT(disp,v->vdir) - v->vfore;
247 greg 1.13 break;
248 greg 1.12 case VT_PER: /* perspective view */
249 greg 1.11 d = DOT(disp,v->vdir);
250 gregl 2.13 ip[2] = VLEN(disp);
251 greg 1.17 if (d < 0.0) { /* fold pyramid */
252     ip[2] = -ip[2];
253 greg 1.11 d = -d;
254 greg 2.7 }
255     if (d > FTINY) {
256 greg 1.11 d = 1.0/d;
257     disp[0] *= d;
258     disp[1] *= d;
259     disp[2] *= d;
260     }
261 greg 2.7 ip[2] *= (1.0 - v->vfore*d);
262 greg 1.13 break;
263 greg 1.12 case VT_HEM: /* hemispherical fisheye */
264     d = normalize(disp);
265 greg 1.17 if (DOT(disp,v->vdir) < 0.0)
266     ip[2] = -d;
267     else
268     ip[2] = d;
269 greg 2.7 ip[2] -= v->vfore;
270 greg 1.13 break;
271 greg 2.9 case VT_CYL: /* cylindrical panorama */
272     d = DOT(disp,v->hvec);
273 gregl 2.13 d2 = DOT(disp,v->vdir);
274     ip[0] = 180.0/PI * atan2(d,d2) / v->horiz + 0.5 - v->hoff;
275     d = 1.0/sqrt(d*d + d2*d2);
276     ip[1] = DOT(disp,v->vvec)*d/v->vn2 + 0.5 - v->voff;
277     ip[2] = VLEN(disp);
278 gwlarson 2.15 ip[2] *= (1.0 - v->vfore*d);
279 greg 2.9 return;
280 greg 1.12 case VT_ANG: /* angular fisheye */
281 greg 1.17 ip[0] = 0.5 - v->hoff;
282     ip[1] = 0.5 - v->voff;
283 greg 2.7 ip[2] = normalize(disp) - v->vfore;
284 greg 1.12 d = DOT(disp,v->vdir);
285     if (d >= 1.0-FTINY)
286     return;
287     if (d <= -(1.0-FTINY)) {
288 greg 2.7 ip[0] += 180.0/v->horiz;
289 greg 1.12 return;
290     }
291 greg 2.34 d = (180.0/PI)*acos(d) / sqrt(1.0 - d*d);
292     ip[0] += DOT(disp,v->hvec)*d/v->horiz;
293     ip[1] += DOT(disp,v->vvec)*d/v->vert;
294     return;
295     case VT_PLS: /* planispheric fisheye */
296     ip[0] = 0.5 - v->hoff;
297     ip[1] = 0.5 - v->voff;
298     ip[2] = normalize(disp) - v->vfore;
299     d = DOT(disp,v->vdir);
300     if (d >= 1.0-FTINY)
301     return;
302     if (d <= -(1.0-FTINY))
303     return; /* really an error */
304     d = sqrt(1.0 - d*d) / (1.0 + d);
305     ip[0] += DOT(disp,v->hvec)*d/sqrt(v->hn2);
306     ip[1] += DOT(disp,v->vvec)*d/sqrt(v->vn2);
307 greg 1.12 return;
308 greg 1.3 }
309 greg 1.17 ip[0] = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff;
310     ip[1] = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff;
311 greg 1.3 }
312
313
314 greg 2.16 void
315 greg 1.17 pix2loc(loc, rp, px, py) /* compute image location from pixel pos. */
316 schorsch 2.18 RREAL loc[2];
317 greg 1.17 register RESOLU *rp;
318     int px, py;
319     {
320     register int x, y;
321
322 greg 2.16 if (rp->rt & YMAJOR) {
323 greg 1.17 x = px;
324     y = py;
325     } else {
326     x = py;
327     y = px;
328     }
329 greg 2.16 if (rp->rt & XDECR)
330 greg 1.17 x = rp->xr-1 - x;
331 greg 2.16 if (rp->rt & YDECR)
332 greg 1.17 y = rp->yr-1 - y;
333     loc[0] = (x+.5)/rp->xr;
334     loc[1] = (y+.5)/rp->yr;
335     }
336
337
338 greg 2.16 void
339 greg 1.17 loc2pix(pp, rp, lx, ly) /* compute pixel pos. from image location */
340     int pp[2];
341     register RESOLU *rp;
342     double lx, ly;
343     {
344     register int x, y;
345
346     x = lx * rp->xr;
347     y = ly * rp->yr;
348 greg 2.16 if (rp->rt & XDECR)
349 greg 1.17 x = rp->xr-1 - x;
350 greg 2.16 if (rp->rt & YDECR)
351 greg 1.17 y = rp->yr-1 - y;
352 greg 2.16 if (rp->rt & YMAJOR) {
353 greg 1.17 pp[0] = x;
354     pp[1] = y;
355     } else {
356     pp[0] = y;
357     pp[1] = x;
358     }
359     }
360
361
362 greg 1.5 int
363     getviewopt(v, ac, av) /* process view argument */
364     register VIEW *v;
365     int ac;
366     register char *av[];
367     {
368 greg 1.16 #define check(c,l) if ((av[0][c]&&av[0][c]!=' ') || \
369     badarg(ac-1,av+1,l)) return(-1)
370 greg 1.5
371 greg 1.9 if (ac <= 0 || av[0][0] != '-' || av[0][1] != 'v')
372 greg 1.5 return(-1);
373     switch (av[0][2]) {
374     case 't': /* type */
375     if (!av[0][3] || av[0][3]==' ')
376     return(-1);
377 greg 1.16 check(4,"");
378 greg 1.5 v->type = av[0][3];
379     return(0);
380     case 'p': /* point */
381 greg 1.16 check(3,"fff");
382 greg 1.5 v->vp[0] = atof(av[1]);
383     v->vp[1] = atof(av[2]);
384     v->vp[2] = atof(av[3]);
385     return(3);
386     case 'd': /* direction */
387 greg 1.16 check(3,"fff");
388 greg 1.5 v->vdir[0] = atof(av[1]);
389     v->vdir[1] = atof(av[2]);
390     v->vdir[2] = atof(av[3]);
391 greg 2.30 v->vdist = 1.;
392 greg 1.5 return(3);
393     case 'u': /* up */
394 greg 1.16 check(3,"fff");
395 greg 1.5 v->vup[0] = atof(av[1]);
396     v->vup[1] = atof(av[2]);
397     v->vup[2] = atof(av[3]);
398     return(3);
399     case 'h': /* horizontal size */
400 greg 1.16 check(3,"f");
401 greg 1.5 v->horiz = atof(av[1]);
402     return(1);
403     case 'v': /* vertical size */
404 greg 1.16 check(3,"f");
405 greg 1.5 v->vert = atof(av[1]);
406     return(1);
407 greg 2.7 case 'o': /* fore clipping plane */
408     check(3,"f");
409     v->vfore = atof(av[1]);
410     return(1);
411     case 'a': /* aft clipping plane */
412     check(3,"f");
413     v->vaft = atof(av[1]);
414     return(1);
415 greg 1.5 case 's': /* shift */
416 greg 1.16 check(3,"f");
417 greg 1.5 v->hoff = atof(av[1]);
418     return(1);
419     case 'l': /* lift */
420 greg 1.16 check(3,"f");
421 greg 1.5 v->voff = atof(av[1]);
422     return(1);
423     default:
424     return(-1);
425     }
426     #undef check
427     }
428
429
430     int
431     sscanview(vp, s) /* get view parameters from string */
432     VIEW *vp;
433 greg 1.1 register char *s;
434     {
435 greg 1.5 int ac;
436     char *av[4];
437     int na;
438     int nvopts = 0;
439
440 greg 2.32 while (isspace(*s))
441     if (!*s++)
442     return(0);
443 greg 1.9 while (*s) {
444 greg 1.5 ac = 0;
445     do {
446 greg 2.21 if (ac || *s == '-')
447     av[ac++] = s;
448 greg 2.32 while (*s && !isspace(*s))
449 greg 1.5 s++;
450 greg 2.32 while (isspace(*s))
451 greg 1.5 s++;
452     } while (*s && ac < 4);
453     if ((na = getviewopt(vp, ac, av)) >= 0) {
454     if (na+1 < ac)
455     s = av[na+1];
456     nvopts++;
457 greg 1.9 } else if (ac > 1)
458     s = av[1];
459     }
460 greg 1.5 return(nvopts);
461 greg 1.1 }
462
463
464 greg 2.16 void
465 greg 1.1 fprintview(vp, fp) /* write out view parameters */
466     register VIEW *vp;
467     FILE *fp;
468     {
469     fprintf(fp, " -vt%c", vp->type);
470     fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]);
471 greg 2.29 fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0]*vp->vdist,
472     vp->vdir[1]*vp->vdist,
473     vp->vdir[2]*vp->vdist);
474 greg 1.1 fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]);
475     fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert);
476 greg 2.7 fprintf(fp, " -vo %.6g -va %.6g", vp->vfore, vp->vaft);
477 greg 1.9 fprintf(fp, " -vs %.6g -vl %.6g", vp->hoff, vp->voff);
478 greg 2.11 }
479
480
481     char *
482     viewopt(vp) /* translate to minimal view string */
483     register VIEW *vp;
484     {
485     static char vwstr[128];
486     register char *cp = vwstr;
487
488 greg 2.33 *cp = '\0';
489 greg 2.11 if (vp->type != stdview.type) {
490     sprintf(cp, " -vt%c", vp->type);
491     cp += strlen(cp);
492     }
493     if (!VEQ(vp->vp,stdview.vp)) {
494     sprintf(cp, " -vp %.6g %.6g %.6g",
495     vp->vp[0], vp->vp[1], vp->vp[2]);
496     cp += strlen(cp);
497     }
498 greg 2.29 if (!FEQ(vp->vdist,stdview.vdist) || !VEQ(vp->vdir,stdview.vdir)) {
499 greg 2.11 sprintf(cp, " -vd %.6g %.6g %.6g",
500 greg 2.29 vp->vdir[0]*vp->vdist,
501     vp->vdir[1]*vp->vdist,
502     vp->vdir[2]*vp->vdist);
503 greg 2.11 cp += strlen(cp);
504     }
505     if (!VEQ(vp->vup,stdview.vup)) {
506     sprintf(cp, " -vu %.6g %.6g %.6g",
507     vp->vup[0], vp->vup[1], vp->vup[2]);
508     cp += strlen(cp);
509     }
510     if (!FEQ(vp->horiz,stdview.horiz)) {
511     sprintf(cp, " -vh %.6g", vp->horiz);
512     cp += strlen(cp);
513     }
514     if (!FEQ(vp->vert,stdview.vert)) {
515     sprintf(cp, " -vv %.6g", vp->vert);
516     cp += strlen(cp);
517     }
518     if (!FEQ(vp->vfore,stdview.vfore)) {
519     sprintf(cp, " -vo %.6g", vp->vfore);
520     cp += strlen(cp);
521     }
522     if (!FEQ(vp->vaft,stdview.vaft)) {
523     sprintf(cp, " -va %.6g", vp->vaft);
524     cp += strlen(cp);
525     }
526     if (!FEQ(vp->hoff,stdview.hoff)) {
527     sprintf(cp, " -vs %.6g", vp->hoff);
528     cp += strlen(cp);
529     }
530     if (!FEQ(vp->voff,stdview.voff)) {
531     sprintf(cp, " -vl %.6g", vp->voff);
532     cp += strlen(cp);
533     }
534     return(vwstr);
535 greg 1.1 }
536
537
538 greg 2.3 int
539     isview(s) /* is this a view string? */
540     char *s;
541     {
542 greg 2.25 static char *altname[]={NULL,VIEWSTR,"rpict","rview","rvu","rpiece","pinterp",NULL};
543 greg 2.5 extern char *progname;
544 greg 2.3 register char *cp;
545     register char **an;
546     /* add program name to list */
547 greg 2.5 if (altname[0] == NULL) {
548     for (cp = progname; *cp; cp++)
549     ;
550     while (cp > progname && !ISDIRSEP(cp[-1]))
551     cp--;
552     altname[0] = cp;
553     }
554 greg 2.3 /* skip leading path */
555     cp = s;
556     while (*cp && *cp != ' ')
557     cp++;
558 greg 2.5 while (cp > s && !ISDIRSEP(cp[-1]))
559 greg 2.3 cp--;
560     for (an = altname; *an != NULL; an++)
561     if (!strncmp(*an, cp, strlen(*an)))
562     return(1);
563     return(0);
564     }
565 greg 1.1
566 greg 2.3
567 greg 1.15 struct myview {
568     VIEW *hv;
569     int ok;
570     };
571 greg 1.1
572 greg 1.15
573 gwlarson 2.14 static int
574 schorsch 2.26 gethview( /* get view from header */
575     char *s,
576     void *v
577     )
578 greg 1.1 {
579 schorsch 2.26 if (isview(s) && sscanview(((struct myview*)v)->hv, s) > 0)
580     ((struct myview*)v)->ok++;
581 gwlarson 2.14 return(0);
582 greg 1.1 }
583
584
585     int
586 greg 1.17 viewfile(fname, vp, rp) /* get view from file */
587 greg 1.1 char *fname;
588     VIEW *vp;
589 greg 1.17 RESOLU *rp;
590 greg 1.1 {
591 greg 1.15 struct myview mvs;
592 greg 1.1 FILE *fp;
593
594 greg 2.16 if (fname == NULL || !strcmp(fname, "-"))
595     fp = stdin;
596     else if ((fp = fopen(fname, "r")) == NULL)
597 greg 1.1 return(-1);
598
599 greg 1.15 mvs.hv = vp;
600     mvs.ok = 0;
601 greg 1.1
602 schorsch 2.26 getheader(fp, gethview, &mvs);
603 greg 1.8
604 greg 1.17 if (rp != NULL && !fgetsresolu(rp, fp))
605 greg 1.15 mvs.ok = 0;
606 greg 1.1
607     fclose(fp);
608
609 greg 1.15 return(mvs.ok);
610 greg 1.1 }
