root/radiance/ray/src/common/image.c
Revision: 1.11
Committed: Fri Sep 21 17:06:31 1990 UTC (33 years, 9 months ago) by greg
Changes since 1.10: +9 -4 lines
added folding of pyramid to viewpixel()
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * image.c - routines for image generation.
9 *
10 * 10/17/85
11 */
12
13 #include "standard.h"
14
15 #include "view.h"
16
17 VIEW stdview = STDVIEW; /* default view parameters */
18
19
20 char *
21 setview(v) /* set hvec and vvec, return message on error */
22 register VIEW *v;
23 {
24 extern double tan(), normalize();
25
26 if (normalize(v->vdir) == 0.0) /* normalize direction */
27 return("zero view direction");
28
29 fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */
30
31 if (normalize(v->hvec) == 0.0)
32 return("illegal view up vector");
33
34 fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */
35
36 if (v->type == VT_PAR)
37 v->hn2 = v->horiz;
38 else if (v->type == VT_PER)
39 v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0));
40 else
41 return("unknown view type");
42
43 if (v->hn2 <= FTINY || v->hn2 >= FHUGE)
44 return("illegal horizontal view size");
45
46 v->hvec[0] *= v->hn2;
47 v->hvec[1] *= v->hn2;
48 v->hvec[2] *= v->hn2;
49 v->hn2 *= v->hn2;
50
51 if (v->type == VT_PAR)
52 v->vn2 = v->vert;
53 else
54 v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0));
55
56 if (v->vn2 <= FTINY || v->vn2 >= FHUGE)
57 return("illegal vertical view size");
58
59 v->vvec[0] *= v->vn2;
60 v->vvec[1] *= v->vn2;
61 v->vvec[2] *= v->vn2;
62 v->vn2 *= v->vn2;
63
64 return(NULL);
65 }
66
67
68 normaspect(va, ap, xp, yp) /* fix pixel aspect or resolution */
69 double va; /* view aspect ratio */
70 double *ap; /* pixel aspect in (or out if 0) */
71 int *xp, *yp; /* x and y resolution in (or out if *ap!=0) */
72 {
73 if (*ap <= FTINY)
74 *ap = va * *xp / *yp; /* compute pixel aspect */
75 else if (va * *xp > *ap * *yp)
76 *xp = *yp / va * *ap + .5; /* reduce x resolution */
77 else
78 *yp = *xp * va / *ap + .5; /* reduce y resolution */
79 }
80
81
82 viewray(orig, direc, v, x, y) /* compute ray origin and direction */
83 FVECT orig, direc;
84 register VIEW *v;
85 double x, y;
86 {
87 x += v->hoff - 0.5;
88 y += v->voff - 0.5;
89
90 if (v->type == VT_PAR) { /* parallel view */
91 orig[0] = v->vp[0] + x*v->hvec[0] + y*v->vvec[0];
92 orig[1] = v->vp[1] + x*v->hvec[1] + y*v->vvec[1];
93 orig[2] = v->vp[2] + x*v->hvec[2] + y*v->vvec[2];
94 VCOPY(direc, v->vdir);
95 } else { /* perspective view */
96 VCOPY(orig, v->vp);
97 direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
98 direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
99 direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
100 normalize(direc);
101 }
102 }
103
104
105 viewpixel(xp, yp, zp, v, p) /* find image location for point */
106 double *xp, *yp, *zp;
107 register VIEW *v;
108 FVECT p;
109 {
110 extern double sqrt();
111 double d;
112 FVECT disp;
113
114 disp[0] = p[0] - v->vp[0];
115 disp[1] = p[1] - v->vp[1];
116 disp[2] = p[2] - v->vp[2];
117
118 if (v->type == VT_PAR) { /* parallel view */
119 if (zp != NULL)
120 *zp = DOT(disp,v->vdir);
121 } else { /* perspective view */
122 d = DOT(disp,v->vdir);
123 if (zp != NULL) {
124 *zp = sqrt(DOT(disp,disp));
125 if (d < 0.0)
126 *zp = -*zp;
127 }
128 if (d < 0.0) /* fold pyramid */
129 d = -d;
130 if (d > FTINY) {
131 d = 1.0/d;
132 disp[0] *= d;
133 disp[1] *= d;
134 disp[2] *= d;
135 }
136 }
137 *xp = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff;
138 *yp = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff;
139 }
140
141
142 int
143 getviewopt(v, ac, av) /* process view argument */
144 register VIEW *v;
145 int ac;
146 register char *av[];
147 {
148 #define check(c,n) if ((av[0][c]&&av[0][c]!=' ') || n>=ac) return(-1)
149 extern double atof();
150
151 if (ac <= 0 || av[0][0] != '-' || av[0][1] != 'v')
152 return(-1);
153 switch (av[0][2]) {
154 case 't': /* type */
155 if (!av[0][3] || av[0][3]==' ')
156 return(-1);
157 check(4,0);
158 v->type = av[0][3];
159 return(0);
160 case 'p': /* point */
161 check(3,3);
162 v->vp[0] = atof(av[1]);
163 v->vp[1] = atof(av[2]);
164 v->vp[2] = atof(av[3]);
165 return(3);
166 case 'd': /* direction */
167 check(3,3);
168 v->vdir[0] = atof(av[1]);
169 v->vdir[1] = atof(av[2]);
170 v->vdir[2] = atof(av[3]);
171 return(3);
172 case 'u': /* up */
173 check(3,3);
174 v->vup[0] = atof(av[1]);
175 v->vup[1] = atof(av[2]);
176 v->vup[2] = atof(av[3]);
177 return(3);
178 case 'h': /* horizontal size */
179 check(3,1);
180 v->horiz = atof(av[1]);
181 return(1);
182 case 'v': /* vertical size */
183 check(3,1);
184 v->vert = atof(av[1]);
185 return(1);
186 case 's': /* shift */
187 check(3,1);
188 v->hoff = atof(av[1]);
189 return(1);
190 case 'l': /* lift */
191 check(3,1);
192 v->voff = atof(av[1]);
193 return(1);
194 default:
195 return(-1);
196 }
197 #undef check
198 }
199
200
201 int
202 sscanview(vp, s) /* get view parameters from string */
203 VIEW *vp;
204 register char *s;
205 {
206 int ac;
207 char *av[4];
208 int na;
209 int nvopts = 0;
210
211 while (*s == ' ')
212 s++;
213 while (*s) {
214 ac = 0;
215 do {
216 av[ac++] = s;
217 while (*s && *s != ' ')
218 s++;
219 while (*s == ' ')
220 s++;
221 } while (*s && ac < 4);
222 if ((na = getviewopt(vp, ac, av)) >= 0) {
223 if (na+1 < ac)
224 s = av[na+1];
225 nvopts++;
226 } else if (ac > 1)
227 s = av[1];
228 }
229 return(nvopts);
230 }
231
232
233 fprintview(vp, fp) /* write out view parameters */
234 register VIEW *vp;
235 FILE *fp;
236 {
237 fprintf(fp, " -vt%c", vp->type);
238 fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]);
239 fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]);
240 fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]);
241 fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert);
242 fprintf(fp, " -vs %.6g -vl %.6g", vp->hoff, vp->voff);
243 }
244
245
246 static VIEW *hview; /* view from header */
247 static int gothview; /* success indicator */
248 static char *altname[] = {NULL,"rpict","rview","pinterp",VIEWSTR,NULL};
249
250
251 static
252 gethview(s) /* get view from header */
253 char *s;
254 {
255 register char **an;
256
257 for (an = altname; *an != NULL; an++)
258 if (!strncmp(*an, s, strlen(*an))) {
259 if (sscanview(hview, s+strlen(*an)) > 0)
260 gothview++;
261 return;
262 }
263 }
264
265
266 int
267 viewfile(fname, vp, xp, yp) /* get view from file */
268 char *fname;
269 VIEW *vp;
270 int *xp, *yp;
271 {
272 extern char *progname;
273 FILE *fp;
274
275 if ((fp = fopen(fname, "r")) == NULL)
276 return(-1);
277
278 altname[0] = progname;
279 hview = vp;
280 gothview = 0;
281
282 getheader(fp, gethview);
283
284 if (xp != NULL && yp != NULL
285 && fgetresolu(xp, yp, fp) == -1)
286 gothview = 0;
287
288 fclose(fp);
289
290 return(gothview);
291 }
