--- ray/src/common/image.c 1992/12/05 16:23:37 2.6 +++ ray/src/common/image.c 2003/08/29 23:03:13 2.20 @@ -1,23 +1,24 @@ -/* Copyright (c) 1992 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: image.c,v 2.20 2003/08/29 23:03:13 greg Exp $"; #endif - /* * image.c - routines for image generation. * - * 10/17/85 + * External symbols declared in view.h */ +#include "copyright.h" + #include "standard.h" #include "view.h" -#include "resolu.h" - #include "paths.h" +#define FEQ(x,y) (fabs((x)-(y)) <= FTINY) +#define VEQ(v,w) (FEQ((v)[0],(w)[0]) && FEQ((v)[1],(w)[1]) \ + && FEQ((v)[2],(w)[2])) + VIEW stdview = STDVIEW; /* default view parameters */ @@ -28,6 +29,9 @@ register VIEW *v; static char ill_horiz[] = "illegal horizontal view size"; static char ill_vert[] = "illegal vertical view size"; + if (v->vaft < -FTINY || (v->vaft > FTINY && v->vaft <= v->vfore)) + return("illegal fore/aft clipping plane"); + if (normalize(v->vdir) == 0.0) /* normalize direction */ return("zero view direction"); @@ -59,13 +63,21 @@ register VIEW *v; v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0)); v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0)); break; + case VT_CYL: /* cylindrical panorama */ + if (v->horiz > 360.0+FTINY) + return(ill_horiz); + if (v->vert >= 180.0-FTINY) + return(ill_vert); + v->hn2 = v->horiz * (PI/180.0); + v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0)); + break; case VT_ANG: /* angular fisheye */ if (v->horiz > 360.0+FTINY) return(ill_horiz); if (v->vert > 360.0+FTINY) return(ill_vert); - v->hn2 = v->horiz / 90.0; - v->vn2 = v->vert / 90.0; + v->hn2 = v->horiz * (PI/180.0); + v->vn2 = v->vert * (PI/180.0); break; case VT_HEM: /* hemispherical fisheye */ if (v->horiz > 180.0+FTINY) @@ -79,9 +91,11 @@ register VIEW *v; return("unknown view type"); } if (v->type != VT_ANG) { - v->hvec[0] *= v->hn2; - v->hvec[1] *= v->hn2; - v->hvec[2] *= v->hn2; + if (v->type != VT_CYL) { + v->hvec[0] *= v->hn2; + v->hvec[1] *= v->hn2; + v->hvec[2] *= v->hn2; + } v->vvec[0] *= v->vn2; v->vvec[1] *= v->vn2; v->vvec[2] *= v->vn2; @@ -93,6 +107,7 @@ register VIEW *v; } +void normaspect(va, ap, xp, yp) /* fix pixel aspect or resolution */ double va; /* view aspect ratio */ double *ap; /* pixel aspect in (or out if 0) */ @@ -107,6 +122,7 @@ int *xp, *yp; /* x and y resolution in (or out if * } +double viewray(orig, direc, v, x, y) /* compute ray origin and direction */ FVECT orig, direc; register VIEW *v; @@ -119,35 +135,53 @@ double x, y; switch(v->type) { case VT_PAR: /* parallel view */ - orig[0] = v->vp[0] + x*v->hvec[0] + y*v->vvec[0]; - orig[1] = v->vp[1] + x*v->hvec[1] + y*v->vvec[1]; - orig[2] = v->vp[2] + x*v->hvec[2] + y*v->vvec[2]; + orig[0] = v->vp[0] + v->vfore*v->vdir[0] + + x*v->hvec[0] + y*v->vvec[0]; + orig[1] = v->vp[1] + v->vfore*v->vdir[1] + + x*v->hvec[1] + y*v->vvec[1]; + orig[2] = v->vp[2] + v->vfore*v->vdir[2] + + x*v->hvec[2] + y*v->vvec[2]; VCOPY(direc, v->vdir); - return(0); + return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0); case VT_PER: /* perspective view */ - VCOPY(orig, v->vp); direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; - normalize(direc); - return(0); + orig[0] = v->vp[0] + v->vfore*direc[0]; + orig[1] = v->vp[1] + v->vfore*direc[1]; + orig[2] = v->vp[2] + v->vfore*direc[2]; + d = normalize(direc); + return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0); case VT_HEM: /* hemispherical fisheye */ z = 1.0 - x*x*v->hn2 - y*y*v->vn2; if (z < 0.0) - return(-1); + return(-1.0); z = sqrt(z); - VCOPY(orig, v->vp); direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; - return(0); + orig[0] = v->vp[0] + v->vfore*direc[0]; + orig[1] = v->vp[1] + v->vfore*direc[1]; + orig[2] = v->vp[2] + v->vfore*direc[2]; + return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0); + case VT_CYL: /* cylindrical panorama */ + d = x * v->horiz * (PI/180.0); + z = cos(d); + x = sin(d); + direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; + direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; + direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; + orig[0] = v->vp[0] + v->vfore*direc[0]; + orig[1] = v->vp[1] + v->vfore*direc[1]; + orig[2] = v->vp[2] + v->vfore*direc[2]; + d = normalize(direc); + return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0); case VT_ANG: /* angular fisheye */ x *= v->horiz/180.0; y *= v->vert/180.0; d = x*x + y*y; if (d > 1.0) - return(-1); - VCOPY(orig, v->vp); + return(-1.0); d = sqrt(d); z = cos(PI*d); d = d <= FTINY ? PI : sqrt(1 - z*z)/d; @@ -156,18 +190,22 @@ double x, y; direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; - return(0); + orig[0] = v->vp[0] + v->vfore*direc[0]; + orig[1] = v->vp[1] + v->vfore*direc[1]; + orig[2] = v->vp[2] + v->vfore*direc[2]; + return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0); } - return(-1); + return(-1.0); } +void viewloc(ip, v, p) /* find image location for point */ FVECT ip; register VIEW *v; FVECT p; { - double d; + double d, d2; FVECT disp; disp[0] = p[0] - v->vp[0]; @@ -176,20 +214,22 @@ FVECT p; switch (v->type) { case VT_PAR: /* parallel view */ - ip[2] = DOT(disp,v->vdir); + ip[2] = DOT(disp,v->vdir) - v->vfore; break; case VT_PER: /* perspective view */ d = DOT(disp,v->vdir); - ip[2] = sqrt(DOT(disp,disp)); + ip[2] = VLEN(disp); if (d < 0.0) { /* fold pyramid */ ip[2] = -ip[2]; d = -d; - } else if (d > FTINY) { + } + if (d > FTINY) { d = 1.0/d; disp[0] *= d; disp[1] *= d; disp[2] *= d; } + ip[2] *= (1.0 - v->vfore*d); break; case VT_HEM: /* hemispherical fisheye */ d = normalize(disp); @@ -197,17 +237,26 @@ FVECT p; ip[2] = -d; else ip[2] = d; + ip[2] -= v->vfore; break; + case VT_CYL: /* cylindrical panorama */ + d = DOT(disp,v->hvec); + d2 = DOT(disp,v->vdir); + ip[0] = 180.0/PI * atan2(d,d2) / v->horiz + 0.5 - v->hoff; + d = 1.0/sqrt(d*d + d2*d2); + ip[1] = DOT(disp,v->vvec)*d/v->vn2 + 0.5 - v->voff; + ip[2] = VLEN(disp); + ip[2] *= (1.0 - v->vfore*d); + return; case VT_ANG: /* angular fisheye */ ip[0] = 0.5 - v->hoff; ip[1] = 0.5 - v->voff; - ip[2] = normalize(disp); + ip[2] = normalize(disp) - v->vfore; d = DOT(disp,v->vdir); if (d >= 1.0-FTINY) return; if (d <= -(1.0-FTINY)) { - ip[1] += 180.0/v->horiz; - ip[2] += 180.0/v->vert; + ip[0] += 180.0/v->horiz; return; } d = acos(d)/PI / sqrt(1.0 - d*d); @@ -220,29 +269,31 @@ FVECT p; } +void pix2loc(loc, rp, px, py) /* compute image location from pixel pos. */ -FLOAT loc[2]; +RREAL loc[2]; register RESOLU *rp; int px, py; { register int x, y; - if (rp->or & YMAJOR) { + if (rp->rt & YMAJOR) { x = px; y = py; } else { x = py; y = px; } - if (rp->or & XDECR) + if (rp->rt & XDECR) x = rp->xr-1 - x; - if (rp->or & YDECR) + if (rp->rt & YDECR) y = rp->yr-1 - y; loc[0] = (x+.5)/rp->xr; loc[1] = (y+.5)/rp->yr; } +void loc2pix(pp, rp, lx, ly) /* compute pixel pos. from image location */ int pp[2]; register RESOLU *rp; @@ -252,11 +303,11 @@ double lx, ly; x = lx * rp->xr; y = ly * rp->yr; - if (rp->or & XDECR) + if (rp->rt & XDECR) x = rp->xr-1 - x; - if (rp->or & YDECR) + if (rp->rt & YDECR) y = rp->yr-1 - y; - if (rp->or & YMAJOR) { + if (rp->rt & YMAJOR) { pp[0] = x; pp[1] = y; } else { @@ -310,6 +361,14 @@ register char *av[]; check(3,"f"); v->vert = atof(av[1]); return(1); + case 'o': /* fore clipping plane */ + check(3,"f"); + v->vfore = atof(av[1]); + return(1); + case 'a': /* aft clipping plane */ + check(3,"f"); + v->vaft = atof(av[1]); + return(1); case 's': /* shift */ check(3,"f"); v->hoff = atof(av[1]); @@ -335,8 +394,10 @@ register char *s; int na; int nvopts = 0; + while (*s == ' ') + s++; if (*s != '-') - s = sskip(s); + s = sskip2(s,1); while (*s) { ac = 0; do { @@ -357,6 +418,7 @@ register char *s; } +void fprintview(vp, fp) /* write out view parameters */ register VIEW *vp; FILE *fp; @@ -366,10 +428,65 @@ FILE *fp; fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]); fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]); fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert); + fprintf(fp, " -vo %.6g -va %.6g", vp->vfore, vp->vaft); fprintf(fp, " -vs %.6g -vl %.6g", vp->hoff, vp->voff); } +char * +viewopt(vp) /* translate to minimal view string */ +register VIEW *vp; +{ + static char vwstr[128]; + register char *cp = vwstr; + + if (vp->type != stdview.type) { + sprintf(cp, " -vt%c", vp->type); + cp += strlen(cp); + } + if (!VEQ(vp->vp,stdview.vp)) { + sprintf(cp, " -vp %.6g %.6g %.6g", + vp->vp[0], vp->vp[1], vp->vp[2]); + cp += strlen(cp); + } + if (!VEQ(vp->vdir,stdview.vdir)) { + sprintf(cp, " -vd %.6g %.6g %.6g", + vp->vdir[0], vp->vdir[1], vp->vdir[2]); + cp += strlen(cp); + } + if (!VEQ(vp->vup,stdview.vup)) { + sprintf(cp, " -vu %.6g %.6g %.6g", + vp->vup[0], vp->vup[1], vp->vup[2]); + cp += strlen(cp); + } + if (!FEQ(vp->horiz,stdview.horiz)) { + sprintf(cp, " -vh %.6g", vp->horiz); + cp += strlen(cp); + } + if (!FEQ(vp->vert,stdview.vert)) { + sprintf(cp, " -vv %.6g", vp->vert); + cp += strlen(cp); + } + if (!FEQ(vp->vfore,stdview.vfore)) { + sprintf(cp, " -vo %.6g", vp->vfore); + cp += strlen(cp); + } + if (!FEQ(vp->vaft,stdview.vaft)) { + sprintf(cp, " -va %.6g", vp->vaft); + cp += strlen(cp); + } + if (!FEQ(vp->hoff,stdview.hoff)) { + sprintf(cp, " -vs %.6g", vp->hoff); + cp += strlen(cp); + } + if (!FEQ(vp->voff,stdview.voff)) { + sprintf(cp, " -vl %.6g", vp->voff); + cp += strlen(cp); + } + return(vwstr); +} + + int isview(s) /* is this a view string? */ char *s; @@ -405,13 +522,14 @@ struct myview { }; -static +static int gethview(s, v) /* get view from header */ char *s; register struct myview *v; { if (isview(s) && sscanview(v->hv, s) > 0) v->ok++; + return(0); } @@ -424,13 +542,15 @@ RESOLU *rp; struct myview mvs; FILE *fp; - if ((fp = fopen(fname, "r")) == NULL) + if (fname == NULL || !strcmp(fname, "-")) + fp = stdin; + else if ((fp = fopen(fname, "r")) == NULL) return(-1); mvs.hv = vp; mvs.ok = 0; - getheader(fp, gethview, &mvs); + getheader(fp, (int (*)(char *, char *))&gethview, (char *)&mvs); if (rp != NULL && !fgetsresolu(rp, fp)) mvs.ok = 0;
