--- ray/src/common/image.c 1996/01/17 10:55:40 2.12 +++ ray/src/common/image.c 1999/02/26 12:24:07 2.15 @@ -30,8 +30,7 @@ register VIEW *v; static char ill_horiz[] = "illegal horizontal view size"; static char ill_vert[] = "illegal vertical view size"; - if (v->vfore < -FTINY || v->vaft < -FTINY || - (v->vaft > FTINY && v->vaft <= v->vfore)) + if (v->vaft < -FTINY || (v->vaft > FTINY && v->vaft <= v->vfore)) return("illegal fore/aft clipping plane"); if (normalize(v->vdir) == 0.0) /* normalize direction */ @@ -205,7 +204,7 @@ FVECT ip; register VIEW *v; FVECT p; { - double d; + double d, d2; FVECT disp; disp[0] = p[0] - v->vp[0]; @@ -218,7 +217,7 @@ FVECT p; break; case VT_PER: /* perspective view */ d = DOT(disp,v->vdir); - ip[2] = sqrt(DOT(disp,disp)); + ip[2] = VLEN(disp); if (d < 0.0) { /* fold pyramid */ ip[2] = -ip[2]; d = -d; @@ -240,15 +239,13 @@ FVECT p; ip[2] -= v->vfore; break; case VT_CYL: /* cylindrical panorama */ - ip[2] = DOT(disp,v->vdir); d = DOT(disp,v->hvec); - ip[0] = 180.0/PI * atan2(d,ip[2]) / v->horiz + 0.5 - v->hoff; - ip[1] = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff; - if (v->vfore > FTINY) - ip[2] = sqrt(DOT(disp,disp)) * - (1.0 - v->vfore/sqrt(d*d + ip[2]*ip[2])); - else - ip[2] = sqrt(DOT(disp,disp)); + d2 = DOT(disp,v->vdir); + ip[0] = 180.0/PI * atan2(d,d2) / v->horiz + 0.5 - v->hoff; + d = 1.0/sqrt(d*d + d2*d2); + ip[1] = DOT(disp,v->vvec)*d/v->vn2 + 0.5 - v->voff; + ip[2] = VLEN(disp); + ip[2] *= (1.0 - v->vfore*d); return; case VT_ANG: /* angular fisheye */ ip[0] = 0.5 - v->hoff; @@ -519,13 +516,14 @@ struct myview { }; -static +static int gethview(s, v) /* get view from header */ char *s; register struct myview *v; { if (isview(s) && sscanview(v->hv, s) > 0) v->ok++; + return(0); }
