--- ray/src/common/image.c 1990/01/16 11:29:43 1.8 +++ ray/src/common/image.c 1991/11/12 16:55:38 2.1 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1991 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -14,6 +14,8 @@ static char SCCSid[] = "$SunId$ LBL"; #include "view.h" +#include "resolu.h" + VIEW stdview = STDVIEW; /* default view parameters */ @@ -21,44 +23,68 @@ char * setview(v) /* set hvec and vvec, return message on error */ register VIEW *v; { - extern double tan(), normalize(); - + static char ill_horiz[] = "illegal horizontal view size"; + static char ill_vert[] = "illegal vertical view size"; + if (normalize(v->vdir) == 0.0) /* normalize direction */ return("zero view direction"); + if (normalize(v->vup) == 0.0) /* normalize view up */ + return("zero view up vector"); + fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */ if (normalize(v->hvec) == 0.0) - return("illegal view up vector"); + return("view up parallel to view direction"); fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */ - if (v->type == VT_PAR) + if (v->horiz <= FTINY) + return(ill_horiz); + if (v->vert <= FTINY) + return(ill_vert); + + switch (v->type) { + case VT_PAR: /* parallel view */ v->hn2 = v->horiz; - else if (v->type == VT_PER) + v->vn2 = v->vert; + break; + case VT_PER: /* perspective view */ + if (v->horiz >= 180.0-FTINY) + return(ill_horiz); + if (v->vert >= 180.0-FTINY) + return(ill_vert); v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0)); - else + v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0)); + break; + case VT_ANG: /* angular fisheye */ + if (v->horiz > 360.0+FTINY) + return(ill_horiz); + if (v->vert > 360.0+FTINY) + return(ill_vert); + v->hn2 = v->horiz / 90.0; + v->vn2 = v->vert / 90.0; + break; + case VT_HEM: /* hemispherical fisheye */ + if (v->horiz > 180.0+FTINY) + return(ill_horiz); + if (v->vert > 180.0+FTINY) + return(ill_vert); + v->hn2 = 2.0 * sin(v->horiz*(PI/180.0/2.0)); + v->vn2 = 2.0 * sin(v->vert*(PI/180.0/2.0)); + break; + default: return("unknown view type"); - - if (v->hn2 <= FTINY || v->hn2 >= FHUGE) - return("illegal horizontal view size"); - - v->hvec[0] *= v->hn2; - v->hvec[1] *= v->hn2; - v->hvec[2] *= v->hn2; + } + if (v->type != VT_ANG) { + v->hvec[0] *= v->hn2; + v->hvec[1] *= v->hn2; + v->hvec[2] *= v->hn2; + v->vvec[0] *= v->vn2; + v->vvec[1] *= v->vn2; + v->vvec[2] *= v->vn2; + } v->hn2 *= v->hn2; - - if (v->type == VT_PAR) - v->vn2 = v->vert; - else - v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0)); - - if (v->vn2 <= FTINY || v->vn2 >= FHUGE) - return("illegal vertical view size"); - - v->vvec[0] *= v->vn2; - v->vvec[1] *= v->vn2; - v->vvec[2] *= v->vn2; v->vn2 *= v->vn2; return(NULL); @@ -73,9 +99,9 @@ int *xp, *yp; /* x and y resolution in (or out if * if (*ap <= FTINY) *ap = va * *xp / *yp; /* compute pixel aspect */ else if (va * *xp > *ap * *yp) - *xp = *yp / va * *ap; /* reduce x resolution */ + *xp = *yp / va * *ap + .5; /* reduce x resolution */ else - *yp = *xp * va / *ap; /* reduce y resolution */ + *yp = *xp * va / *ap + .5; /* reduce y resolution */ } @@ -84,30 +110,65 @@ FVECT orig, direc; register VIEW *v; double x, y; { + double d, z; + x += v->hoff - 0.5; y += v->voff - 0.5; - if (v->type == VT_PAR) { /* parallel view */ + switch(v->type) { + case VT_PAR: /* parallel view */ orig[0] = v->vp[0] + x*v->hvec[0] + y*v->vvec[0]; orig[1] = v->vp[1] + x*v->hvec[1] + y*v->vvec[1]; orig[2] = v->vp[2] + x*v->hvec[2] + y*v->vvec[2]; VCOPY(direc, v->vdir); - } else { /* perspective view */ + return(0); + case VT_PER: /* perspective view */ VCOPY(orig, v->vp); direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; normalize(direc); + return(0); + case VT_HEM: /* hemispherical fisheye */ + z = 1.0 - x*x*v->hn2 - y*y*v->vn2; + if (z < 0.0) + return(-1); + z = sqrt(z); + VCOPY(orig, v->vp); + direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; + direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; + direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; + return(0); + case VT_ANG: /* angular fisheye */ + x *= v->horiz/180.0; + y *= v->vert/180.0; + d = x*x + y*y; + if (d > 1.0) + return(-1); + VCOPY(orig, v->vp); + if (d <= FTINY) { + VCOPY(direc, v->vdir); + return(0); + } + d = sqrt(d); + z = cos(PI*d); + d = sqrt(1 - z*z)/d; + x *= d; + y *= d; + direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0]; + direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1]; + direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2]; + return(0); } + return(-1); } -viewpixel(xp, yp, zp, v, p) /* find image location for point */ -double *xp, *yp, *zp; +viewloc(ip, v, p) /* find image location for point */ +FVECT ip; register VIEW *v; FVECT p; { - extern double sqrt(); double d; FVECT disp; @@ -115,75 +176,149 @@ FVECT p; disp[1] = p[1] - v->vp[1]; disp[2] = p[2] - v->vp[2]; - if (v->type == VT_PAR) { /* parallel view */ - if (zp != NULL) - *zp = DOT(disp,v->vdir); - } else { /* perspective view */ - d = 1.0/DOT(disp,v->vdir); - if (zp != NULL) { - *zp = sqrt(DOT(disp,disp)); - if (d < 0.0) - *zp = -*zp; + switch (v->type) { + case VT_PAR: /* parallel view */ + ip[2] = DOT(disp,v->vdir); + break; + case VT_PER: /* perspective view */ + d = DOT(disp,v->vdir); + ip[2] = sqrt(DOT(disp,disp)); + if (d < 0.0) { /* fold pyramid */ + ip[2] = -ip[2]; + d = -d; + } else if (d > FTINY) { + d = 1.0/d; + disp[0] *= d; + disp[1] *= d; + disp[2] *= d; } - disp[0] *= d; - disp[1] *= d; - disp[2] *= d; + break; + case VT_HEM: /* hemispherical fisheye */ + d = normalize(disp); + if (DOT(disp,v->vdir) < 0.0) + ip[2] = -d; + else + ip[2] = d; + break; + case VT_ANG: /* angular fisheye */ + ip[0] = 0.5 - v->hoff; + ip[1] = 0.5 - v->voff; + ip[2] = normalize(disp); + d = DOT(disp,v->vdir); + if (d >= 1.0-FTINY) + return; + if (d <= -(1.0-FTINY)) { + ip[1] += 180.0/v->horiz; + ip[2] += 180.0/v->vert; + return; + } + d = acos(d)/PI / sqrt(1.0 - d*d); + ip[0] += DOT(disp,v->hvec)*d*180.0/v->horiz; + ip[1] += DOT(disp,v->vvec)*d*180.0/v->vert; + return; } - *xp = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff; - *yp = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff; + ip[0] = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff; + ip[1] = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff; } +pix2loc(loc, rp, px, py) /* compute image location from pixel pos. */ +FLOAT loc[2]; +register RESOLU *rp; +int px, py; +{ + register int x, y; + + if (rp->or & YMAJOR) { + x = px; + y = py; + } else { + x = py; + y = px; + } + if (rp->or & XDECR) + x = rp->xr-1 - x; + if (rp->or & YDECR) + y = rp->yr-1 - y; + loc[0] = (x+.5)/rp->xr; + loc[1] = (y+.5)/rp->yr; +} + + +loc2pix(pp, rp, lx, ly) /* compute pixel pos. from image location */ +int pp[2]; +register RESOLU *rp; +double lx, ly; +{ + register int x, y; + + x = lx * rp->xr; + y = ly * rp->yr; + if (rp->or & XDECR) + x = rp->xr-1 - x; + if (rp->or & YDECR) + y = rp->yr-1 - y; + if (rp->or & YMAJOR) { + pp[0] = x; + pp[1] = y; + } else { + pp[0] = y; + pp[1] = x; + } +} + + int getviewopt(v, ac, av) /* process view argument */ register VIEW *v; int ac; register char *av[]; { -#define check(c,n) if ((av[0][c]&&av[0][c]!=' ') || n>=ac) return(-1) +#define check(c,l) if ((av[0][c]&&av[0][c]!=' ') || \ + badarg(ac-1,av+1,l)) return(-1) extern double atof(); - if (av[0][0] != '-' || av[0][1] != 'v') + if (ac <= 0 || av[0][0] != '-' || av[0][1] != 'v') return(-1); switch (av[0][2]) { case 't': /* type */ if (!av[0][3] || av[0][3]==' ') return(-1); - check(4,0); + check(4,""); v->type = av[0][3]; return(0); case 'p': /* point */ - check(3,3); + check(3,"fff"); v->vp[0] = atof(av[1]); v->vp[1] = atof(av[2]); v->vp[2] = atof(av[3]); return(3); case 'd': /* direction */ - check(3,3); + check(3,"fff"); v->vdir[0] = atof(av[1]); v->vdir[1] = atof(av[2]); v->vdir[2] = atof(av[3]); return(3); case 'u': /* up */ - check(3,3); + check(3,"fff"); v->vup[0] = atof(av[1]); v->vup[1] = atof(av[2]); v->vup[2] = atof(av[3]); return(3); case 'h': /* horizontal size */ - check(3,1); + check(3,"f"); v->horiz = atof(av[1]); return(1); case 'v': /* vertical size */ - check(3,1); + check(3,"f"); v->vert = atof(av[1]); return(1); case 's': /* shift */ - check(3,1); + check(3,"f"); v->hoff = atof(av[1]); return(1); case 'l': /* lift */ - check(3,1); + check(3,"f"); v->voff = atof(av[1]); return(1); default: @@ -205,7 +340,7 @@ register char *s; while (*s == ' ') s++; - do { + while (*s) { ac = 0; do { av[ac++] = s; @@ -218,8 +353,9 @@ register char *s; if (na+1 < ac) s = av[na+1]; nvopts++; - } - } while (*s); + } else if (ac > 1) + s = av[1]; + } return(nvopts); } @@ -233,53 +369,57 @@ FILE *fp; fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]); fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]); fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert); - fprintf(fp, " -vs %d -vl %d", vp->hoff, vp->voff); + fprintf(fp, " -vs %.6g -vl %.6g", vp->hoff, vp->voff); } -static VIEW *hview; /* view from header */ -static int gothview; /* success indicator */ static char *altname[] = {NULL,"rpict","rview","pinterp",VIEWSTR,NULL}; +struct myview { + VIEW *hv; + int ok; +}; + static -gethview(s) /* get view from header */ +gethview(s, v) /* get view from header */ char *s; +register struct myview *v; { register char **an; for (an = altname; *an != NULL; an++) if (!strncmp(*an, s, strlen(*an))) { - if (sscanview(hview, s+strlen(*an)) > 0) - gothview++; + if (sscanview(v->hv, s+strlen(*an)) > 0) + v->ok++; return; } } int -viewfile(fname, vp, xp, yp) /* get view from file */ +viewfile(fname, vp, rp) /* get view from file */ char *fname; VIEW *vp; -int *xp, *yp; +RESOLU *rp; { extern char *progname; + struct myview mvs; FILE *fp; if ((fp = fopen(fname, "r")) == NULL) return(-1); altname[0] = progname; - hview = vp; - gothview = 0; + mvs.hv = vp; + mvs.ok = 0; - getheader(fp, gethview); + getheader(fp, gethview, &mvs); - if (xp != NULL && yp != NULL - && fgetresolu(xp, yp, fp) == -1) - gothview = 0; + if (rp != NULL && !fgetsresolu(rp, fp)) + mvs.ok = 0; fclose(fp); - return(gothview); + return(mvs.ok); }
