root/radiance/ray/src/common/image.c
Revision: 2.58
Committed: Wed Jun 25 15:28:56 2025 UTC (5 days, 16 hours ago) by greg
Changes since 2.57: +7 -7 lines
Error occurred while calculating annotation data.
perf: Adjusted significant digits in view parameter output
2 static const char RCSid[] = "$Id: image.c,v 2.57 2025/06/20 16:29:02 greg Exp $";
5 * image.c - routines for image generation.
6 *
7 * External symbols declared in view.h
8 */
9
10 #include "copyright.h"
11
12 #include <ctype.h>
13 #include "rtio.h"
14 #include "rtmath.h"
15 #include "paths.h"
16 #include "view.h"
17
18 VIEW stdview = STDVIEW; /* default view parameters */
19
20 static gethfunc gethview;
21
22
23 char *
24 setview( /* set hvec and vvec, return message on error */
25 VIEW *v
26 )
27 {
28 static char ill_horiz[] = "illegal horizontal view size";
29 static char ill_vert[] = "illegal vertical view size";
30
31 if ((v->vfore < -FTINY) | (v->vaft < -FTINY) ||
32 (v->vaft > FTINY) & (v->vaft <= v->vfore))
33 return("illegal fore/aft clipping plane");
34
35 if (v->vdist <= FTINY)
36 return("illegal view distance");
37 v->vdist *= normalize(v->vdir); /* normalize direction */
38 if (v->vdist == 0.0)
39 return("zero view direction");
40
41 if (normalize(v->vup) == 0.0) /* normalize view up */
42 return("zero view up vector");
43
44 fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */
45
46 if (normalize(v->hvec) == 0.0)
47 return("view up parallel to view direction");
48
49 fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */
50
51 if (v->horiz <= FTINY)
52 return(ill_horiz);
53 if (v->vert <= FTINY)
54 return(ill_vert);
55
56 switch (v->type) {
57 case VT_PAR: /* parallel view */
58 v->hn2 = v->horiz;
59 v->vn2 = v->vert;
60 break;
61 case VT_PER: /* perspective view */
62 if (v->horiz >= 180.0-FTINY)
63 return(ill_horiz);
64 if (v->vert >= 180.0-FTINY)
65 return(ill_vert);
66 v->hn2 = 2.0 * tan(v->horiz*(PI/360.));
67 v->vn2 = 2.0 * tan(v->vert*(PI/360.));
68 break;
69 case VT_CYL: /* cylindrical panorama */
70 if (v->horiz > 360.0+FTINY)
71 return(ill_horiz);
72 if (v->vert >= 180.0-FTINY)
73 return(ill_vert);
74 v->hn2 = v->horiz * (PI/180.0);
75 v->vn2 = 2.0 * tan(v->vert*(PI/360.));
76 break;
77 case VT_ANG: /* angular fisheye */
78 if (v->horiz > 360.0+FTINY)
79 return(ill_horiz);
80 if (v->vert > 360.0+FTINY)
81 return(ill_vert);
82 v->hn2 = v->horiz * (PI/180.0);
83 v->vn2 = v->vert * (PI/180.0);
84 break;
85 case VT_HEM: /* hemispherical fisheye */
86 if (v->horiz > 180.0+FTINY)
87 return(ill_horiz);
88 if (v->vert > 180.0+FTINY)
89 return(ill_vert);
90 v->hn2 = 2.0 * sin(v->horiz*(PI/360.));
91 v->vn2 = 2.0 * sin(v->vert*(PI/360.));
92 break;
93 case VT_PLS: /* planispheric fisheye */
94 if (v->horiz >= 360.0-FTINY)
95 return(ill_horiz);
96 if (v->vert >= 360.0-FTINY)
97 return(ill_vert);
98 v->hn2 = 2.*sin(v->horiz*(PI/360.)) /
99 (1.0 + cos(v->horiz*(PI/360.)));
100 v->vn2 = 2.*sin(v->vert*(PI/360.)) /
101 (1.0 + cos(v->vert*(PI/360.)));
102 break;
103 default:
104 return("unknown view type");
105 }
106 if (v->type != VT_ANG && v->type != VT_PLS) {
107 if (v->type != VT_CYL) {
108 v->hvec[0] *= v->hn2;
109 v->hvec[1] *= v->hn2;
110 v->hvec[2] *= v->hn2;
111 }
112 v->vvec[0] *= v->vn2;
113 v->vvec[1] *= v->vn2;
114 v->vvec[2] *= v->vn2;
115 }
116 v->hn2 *= v->hn2;
117 v->vn2 *= v->vn2;
118
119 return(NULL);
120 }
121
122
123 char *
124 cropview( /* crop a view to the indicated bounds */
125 VIEW *v,
126 double x0,
127 double y0,
128 double x1,
129 double y1
130 )
131 {
132 static char ill_hemi[] = "illegal crop for hemispherical view";
133 double d;
134 /* order crop extrema */
135 if (x0 > x1) { d=x0; x0=x1; x1=d; }
136 if (y0 > y1) { d=y0; y0=y1; y1=d; }
137
138 if ((x1-x0 <= FTINY) | (y1-y0 <= FTINY))
139 return("zero crop area");
140
141 d = x1 - x0; /* adjust horizontal size? */
142 if (!FABSEQ(d, 1.))
143 switch (v->type) {
144 case VT_PER:
145 v->horiz = 360./PI*atan( d*tan(PI/360.*v->horiz) );
146 break;
147 case VT_PAR:
148 case VT_ANG:
149 case VT_CYL:
150 v->horiz *= d;
151 break;
152 case VT_HEM:
153 d *= sin(PI/360.*v->horiz);
154 if (d > 1.)
155 return(ill_hemi);
156 v->horiz = 360./PI*asin( d );
157 break;
158 case VT_PLS:
159 d *= sin(PI/360.*v->horiz) /
160 (1. + cos(PI/360.*v->horiz));
161 v->horiz = 360./PI*acos( (1. - d*d) / (1. + d*d) );
162 break;
163 }
164
165 d = y1 - y0; /* adjust vertical size? */
166 if (!FABSEQ(d, 1.))
167 switch (v->type) {
168 case VT_PER:
169 case VT_CYL:
170 v->vert = 360./PI*atan( d*tan(PI/360.*v->vert) );
171 break;
172 case VT_PAR:
173 case VT_ANG:
174 v->vert *= d;
175 break;
176 case VT_HEM:
177 d *= sin(PI/360.*v->vert);
178 if (d > 1.)
179 return(ill_hemi);
180 v->vert = 360./PI*asin( d );
181 break;
182 case VT_PLS:
183 d *= sin(PI/360.*v->vert) /
184 (1. + cos(PI/360.*v->vert));
185 v->vert = 360./PI*acos( (1. - d*d) / (1. + d*d) );
186 break;
187 }
188 /* adjust offsets */
189 v->hoff = ((x0 + x1)*.5 - .5 + v->hoff) / (x1 - x0);
190 v->voff = ((y0 + y1)*.5 - .5 + v->voff) / (y1 - y0);
191
192 return(setview(v)); /* final error checks & set-up */
193 }
194
195
196 void
197 normaspect( /* fix pixel aspect or resolution */
198 double va, /* view aspect ratio */
199 double *ap, /* pixel aspect in (or out if 0) */
200 int *xp,
201 int *yp /* x and y resolution in (or out if *ap!=0) */
202 )
203 {
204 if (*ap <= FTINY)
205 *ap = va * *xp / *yp; /* compute pixel aspect */
206 else if (va * *xp > *ap * *yp)
207 *xp = *yp / va * *ap + .5; /* reduce x resolution */
208 else
209 *yp = *xp * va / *ap + .5; /* reduce y resolution */
210 }
211
212
213 double
214 viewray( /* compute ray origin and direction */
215 FVECT orig,
216 FVECT direc,
217 VIEW *v,
218 double x,
219 double y
220 )
221 {
222 double d, z;
223
224 x += v->hoff - 0.5;
225 y += v->voff - 0.5;
226
227 switch(v->type) {
228 case VT_PAR: /* parallel view */
229 orig[0] = v->vp[0] + v->vfore*v->vdir[0]
230 + x*v->hvec[0] + y*v->vvec[0];
231 orig[1] = v->vp[1] + v->vfore*v->vdir[1]
232 + x*v->hvec[1] + y*v->vvec[1];
233 orig[2] = v->vp[2] + v->vfore*v->vdir[2]
234 + x*v->hvec[2] + y*v->vvec[2];
235 VCOPY(direc, v->vdir);
236 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
237 case VT_PER: /* perspective view */
238 direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
239 direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
240 direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
241 VSUM(orig, v->vp, direc, v->vfore);
242 d = normalize(direc);
243 return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0);
244 case VT_HEM: /* hemispherical fisheye */
245 z = 1.0 - x*x*v->hn2 - y*y*v->vn2;
246 if (z < 0.0)
247 return(-1.0);
248 z = sqrt(z);
249 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
250 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
251 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
252 VSUM(orig, v->vp, direc, v->vfore);
253 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
254 case VT_CYL: /* cylindrical panorama */
255 d = x * v->horiz * (PI/180.0);
256 z = cos(d);
257 x = sin(d);
258 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
259 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
260 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
261 VSUM(orig, v->vp, direc, v->vfore);
262 d = normalize(direc);
263 return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0);
264 case VT_ANG: /* angular fisheye */
265 x *= (1.0/180.0)*v->horiz;
266 y *= (1.0/180.0)*v->vert;
267 d = x*x + y*y;
268 if (d > 1.0)
269 return(-1.0);
270 d = sqrt(d);
271 z = cos(PI*d);
272 d = d <= FTINY ? PI : sqrt(1.0 - z*z)/d;
273 x *= d;
274 y *= d;
275 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
276 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
277 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
278 VSUM(orig, v->vp, direc, v->vfore);
279 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
280 case VT_PLS: /* planispheric fisheye */
281 x *= sqrt(v->hn2);
282 y *= sqrt(v->vn2);
283 d = x*x + y*y;
284 z = (1. - d)/(1. + d);
285 x *= (1. + z);
286 y *= (1. + z);
287 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
288 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
289 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
290 VSUM(orig, v->vp, direc, v->vfore);
291 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
292 }
293 return(-1.0);
294 }
295
296
297 int
298 viewloc( /* find image location for point */
299 FVECT ip,
300 VIEW *v,
301 FVECT p
302 ) /* Use VL_* flags to interpret return value */
303 {
304 int rflags = VL_GOOD;
305 double d, d2;
306 FVECT disp;
307
308 VSUB(disp, p, v->vp);
309
310 switch (v->type) {
311 case VT_PAR: /* parallel view */
312 ip[2] = DOT(disp,v->vdir) - v->vfore;
313 break;
314 case VT_PER: /* perspective view */
315 d = DOT(disp,v->vdir);
316 rflags |= VL_BEYOND*((v->vaft > FTINY) &
317 (d >= v->vaft));
318 ip[2] = VLEN(disp);
319 if (d < -FTINY) { /* fold pyramid */
320 ip[2] = -ip[2];
321 d = -d;
322 } else if (d <= FTINY)
323 return(VL_BAD); /* at infinite edge */
324 d = 1.0/d;
325 disp[0] *= d;
326 disp[1] *= d;
327 disp[2] *= d;
328 if (ip[2] < 0.0) d = -d;
329 ip[2] *= (1.0 - v->vfore*d);
330 break;
331 case VT_HEM: /* hemispherical fisheye */
332 d = normalize(disp);
333 if (DOT(disp,v->vdir) < 0.0)
334 ip[2] = -d;
335 else
336 ip[2] = d;
337 ip[2] -= v->vfore;
338 break;
339 case VT_CYL: /* cylindrical panorama */
340 d = DOT(disp,v->hvec);
341 d2 = DOT(disp,v->vdir);
342 ip[0] = 180.0/PI * atan2(d,d2) / v->horiz + 0.5 - v->hoff;
343 d2 = d*d + d2*d2;
344 if (d2 <= FTINY*FTINY)
345 return(VL_BAD); /* at pole */
346 rflags |= VL_BEYOND*((v->vaft > FTINY) &
347 (d2 >= v->vaft*v->vaft));
348 d = 1.0/sqrt(d2);
349 ip[1] = DOT(disp,v->vvec)*d/v->vn2 + 0.5 - v->voff;
350 ip[2] = VLEN(disp);
351 ip[2] *= (1.0 - v->vfore*d);
352 goto gotall;
353 case VT_ANG: /* angular fisheye */
354 ip[0] = 0.5 - v->hoff;
355 ip[1] = 0.5 - v->voff;
356 ip[2] = normalize(disp) - v->vfore;
357 d = DOT(disp,v->vdir);
358 if (d >= 1.0-FTINY)
359 goto gotall;
360 if (d <= -(1.0-FTINY)) {
361 ip[0] += 180.0/v->horiz;
362 goto gotall;
363 }
364 d = (180.0/PI)*acos(d) / sqrt(1.0 - d*d);
365 ip[0] += DOT(disp,v->hvec)*d/v->horiz;
366 ip[1] += DOT(disp,v->vvec)*d/v->vert;
367 goto gotall;
368 case VT_PLS: /* planispheric fisheye */
369 ip[0] = 0.5 - v->hoff;
370 ip[1] = 0.5 - v->voff;
371 ip[2] = normalize(disp) - v->vfore;
372 d = DOT(disp,v->vdir);
373 if (d >= 1.0-FTINY)
374 goto gotall;
375 if (d <= -(1.0-FTINY))
376 return(VL_BAD);
377 ip[0] += DOT(disp,v->hvec)/((1. + d)*sqrt(v->hn2));
378 ip[1] += DOT(disp,v->vvec)/((1. + d)*sqrt(v->vn2));
379 goto gotall;
380 default:
381 return(VL_BAD);
382 }
383 ip[0] = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff;
384 ip[1] = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff;
385 gotall: /* add appropriate return flags */
386 if (ip[2] <= 0.0)
387 rflags |= VL_BEHIND;
388 else if ((v->type != VT_PER) & (v->type != VT_CYL))
389 rflags |= VL_BEYOND*((v->vaft > FTINY) &
390 (ip[2] >= v->vaft - v->vfore));
391 rflags |= VL_OUTSIDE*((0.0 >= ip[0]) | (ip[0] >= 1.0) |
392 (0.0 >= ip[1]) | (ip[1] >= 1.0));
393 return(rflags);
394 }
395
396
397 void
398 pix2loc( /* compute image location from pixel pos. */
399 RREAL loc[2],
400 RESOLU *rp,
401 int px,
402 int py
403 )
404 {
405 int x, y;
406
407 if (rp->rt & YMAJOR) {
408 x = px;
409 y = py;
410 } else {
411 x = py;
412 y = px;
413 }
414 if (rp->rt & XDECR)
415 x = rp->xr-1 - x;
416 if (rp->rt & YDECR)
417 y = rp->yr-1 - y;
418 loc[0] = (x+.5)/rp->xr;
419 loc[1] = (y+.5)/rp->yr;
420 }
421
422
423 void
424 loc2pix( /* compute pixel pos. from image location */
425 int pp[2],
426 RESOLU *rp,
427 double lx,
428 double ly
429 )
430 {
431 int x, y;
432
433 x = (int)(lx*rp->xr + .5 - (lx < 0.0));
434 y = (int)(ly*rp->yr + .5 - (ly < 0.0));
435
436 if (rp->rt & XDECR)
437 x = rp->xr-1 - x;
438 if (rp->rt & YDECR)
439 y = rp->yr-1 - y;
440 if (rp->rt & YMAJOR) {
441 pp[0] = x;
442 pp[1] = y;
443 } else {
444 pp[0] = y;
445 pp[1] = x;
446 }
447 }
448
449
450 int
451 getviewopt( /* process view argument */
452 VIEW *v,
453 int ac,
454 char *av[]
455 )
456 {
457 #define check(c,l) if ((av[0][c]&&!isspace(av[0][c])) || \
458 badarg(ac-1,av+1,l)) return(-1)
459
460 if (ac <= 0 || av[0][0] != '-' || av[0][1] != 'v')
461 return(-1);
462 switch (av[0][2]) {
463 case 't': /* type */
464 if (!av[0][3] || isspace(av[0][3]))
465 return(-1);
466 check(4,"");
467 v->type = av[0][3];
468 return(0);
469 case 'p': /* point */
470 check(3,"fff");
471 v->vp[0] = atof(av[1]);
472 v->vp[1] = atof(av[2]);
473 v->vp[2] = atof(av[3]);
474 return(3);
475 case 'd': /* direction */
476 check(3,"fff");
477 v->vdir[0] = atof(av[1]);
478 v->vdir[1] = atof(av[2]);
479 v->vdir[2] = atof(av[3]);
480 v->vdist = 1.;
481 return(3);
482 case 'u': /* up */
483 check(3,"fff");
484 v->vup[0] = atof(av[1]);
485 v->vup[1] = atof(av[2]);
486 v->vup[2] = atof(av[3]);
487 return(3);
488 case 'h': /* horizontal size */
489 check(3,"f");
490 v->horiz = atof(av[1]);
491 return(1);
492 case 'v': /* vertical size */
493 check(3,"f");
494 v->vert = atof(av[1]);
495 return(1);
496 case 'o': /* fore clipping plane */
497 check(3,"f");
498 v->vfore = atof(av[1]);
499 return(1);
500 case 'a': /* aft clipping plane */
501 check(3,"f");
502 v->vaft = atof(av[1]);
503 return(1);
504 case 's': /* shift */
505 check(3,"f");
506 v->hoff = atof(av[1]);
507 return(1);
508 case 'l': /* lift */
509 check(3,"f");
510 v->voff = atof(av[1]);
511 return(1);
512 default:
513 return(-1);
514 }
515 #undef check
516 }
517
518
519 int
520 sscanview( /* get view parameters from string */
521 VIEW *vp,
522 char *s
523 )
524 {
525 int ac;
526 char *av[4];
527 int na;
528 int nvopts = 0;
529
530 while (isspace(*s))
531 if (!*s++)
532 return(0);
533 while (*s) {
534 ac = 0;
535 do {
536 if (ac || *s == '-')
537 av[ac++] = s;
538 while (*s && !isspace(*s))
539 s++;
540 while (isspace(*s))
541 s++;
542 } while (*s && ac < 4);
543 if ((na = getviewopt(vp, ac, av)) >= 0) {
544 if (na+1 < ac)
545 s = av[na+1];
546 nvopts++;
547 } else if (ac > 1)
548 s = av[1];
549 }
550 return(nvopts);
551 }
552
553
554 void
555 fprintview( /* write out view parameters */
556 VIEW *vp,
557 FILE *fp
558 )
559 {
560 fprintf(fp, " -vt%c", vp->type);
561 fprintf(fp, " -vp %.7g %.7g %.7g", vp->vp[0], vp->vp[1], vp->vp[2]);
562 fprintf(fp, " -vd %.7g %.7g %.7g", vp->vdir[0]*vp->vdist,
563 vp->vdir[1]*vp->vdist,
564 vp->vdir[2]*vp->vdist);
565 fprintf(fp, " -vu %.5g %.5g %.5g", vp->vup[0], vp->vup[1], vp->vup[2]);
566 fprintf(fp, " -vh %.5g -vv %.5g", vp->horiz, vp->vert);
567 fprintf(fp, " -vo %.5g -va %.5g", vp->vfore, vp->vaft);
568 fprintf(fp, " -vs %.5g -vl %.5g", vp->hoff, vp->voff);
569 }
570
571
572 char *
573 viewopt( /* translate to minimal view string */
574 VIEW *vp
575 )
576 {
577 static char vwstr[128];
578 char *cp = vwstr;
579
580 *cp = '\0';
581 if (vp->type != stdview.type) {
582 sprintf(cp, " -vt%c", vp->type);
583 cp += strlen(cp);
584 }
585 if (!VABSEQ(vp->vp,stdview.vp)) {
586 sprintf(cp, " -vp %.6g %.6g %.6g",
587 vp->vp[0], vp->vp[1], vp->vp[2]);
588 cp += strlen(cp);
589 }
590 if (!FABSEQ(vp->vdist,stdview.vdist) || !VABSEQ(vp->vdir,stdview.vdir)) {
591 sprintf(cp, " -vd %.6g %.6g %.6g",
592 vp->vdir[0]*vp->vdist,
593 vp->vdir[1]*vp->vdist,
594 vp->vdir[2]*vp->vdist);
595 cp += strlen(cp);
596 }
597 if (!VABSEQ(vp->vup,stdview.vup)) {
598 sprintf(cp, " -vu %.6g %.6g %.6g",
599 vp->vup[0], vp->vup[1], vp->vup[2]);
600 cp += strlen(cp);
601 }
602 if (!FABSEQ(vp->horiz,stdview.horiz)) {
603 sprintf(cp, " -vh %.6g", vp->horiz);
604 cp += strlen(cp);
605 }
606 if (!FABSEQ(vp->vert,stdview.vert)) {
607 sprintf(cp, " -vv %.6g", vp->vert);
608 cp += strlen(cp);
609 }
610 if (!FABSEQ(vp->vfore,stdview.vfore)) {
611 sprintf(cp, " -vo %.6g", vp->vfore);
612 cp += strlen(cp);
613 }
614 if (!FABSEQ(vp->vaft,stdview.vaft)) {
615 sprintf(cp, " -va %.6g", vp->vaft);
616 cp += strlen(cp);
617 }
618 if (!FABSEQ(vp->hoff,stdview.hoff)) {
619 sprintf(cp, " -vs %.6g", vp->hoff);
620 cp += strlen(cp);
621 }
622 if (!FABSEQ(vp->voff,stdview.voff)) {
623 sprintf(cp, " -vl %.6g", vp->voff);
624 cp += strlen(cp);
625 }
626 return(vwstr);
627 }
628
629
630 int
631 isview( /* is this a view string? */
632 char *s
633 )
634 {
635 static char *altname[]={NULL,VIEWSTR,"rpict","rvu","rpiece","rxpiece","pinterp","rview",NULL};
636 char *cp;
637 char **an;
638 /* add program name to list */
639 if (altname[0] == NULL) {
640 for (cp = progname; *cp; cp++)
641 ;
642 while (cp > progname && !ISDIRSEP(cp[-1]))
643 cp--;
644 altname[0] = cp;
645 }
646 /* skip leading path */
647 cp = s;
648 while (*cp && !isspace(*cp))
649 cp++;
650 while (cp > s && !ISDIRSEP(cp[-1]))
651 cp--;
652 for (an = altname; *an != NULL; an++)
653 if (!strncmp(*an, cp, strlen(*an)))
654 return(1);
655 return(0);
656 }
657
658
659 struct myview {
660 VIEW *hv;
661 int ok;
662 };
663
664
665 static int
666 gethview( /* get view from header */
667 char *s,
668 void *v
669 )
670 {
671 if (isview(s) && sscanview(((struct myview*)v)->hv, s) > 0)
672 ((struct myview*)v)->ok++;
673 return(0);
674 }
675
676
677 int
678 viewfile( /* get view from file */
679 char *fname,
680 VIEW *vp,
681 RESOLU *rp
682 )
683 {
684 struct myview mvs;
685 FILE *fp;
686
687 if (fname == NULL || !strcmp(fname, "-"))
688 fp = stdin;
689 else if ((fp = fopen(fname, "r")) == NULL)
690 return(-1);
691
692 mvs.hv = vp;
693 mvs.ok = 0;
694
695 getheader(fp, gethview, &mvs);
696
697 if (rp != NULL && !fgetsresolu(rp, fp))
698 mvs.ok = 0;
699
700 if (fp != stdin)
701 fclose(fp);
702
703 return(mvs.ok);
704 }
