root/radiance/ray/src/common/image.c
Revision: 2.51
Committed: Thu May 14 20:49:57 2020 UTC (5 years, 2 months ago) by greg
Changes since 2.50: +5 -5 lines
Minor aesthetic fixes
2 static const char RCSid[] = "$Id: image.c,v 2.50 2019/05/04 00:36:58 greg Exp $";
5 * image.c - routines for image generation.
6 *
7 * External symbols declared in view.h
8 */
9
10 #include "copyright.h"
11
12 #include <ctype.h>
13 #include "rtio.h"
14 #include "rtmath.h"
15 #include "paths.h"
16 #include "view.h"
17
18
19 #define FEQ(x,y) (fabs((x)-(y)) <= FTINY)
20 #define VEQ(v,w) (FEQ((v)[0],(w)[0]) && FEQ((v)[1],(w)[1]) \
21 && FEQ((v)[2],(w)[2]))
22
23 VIEW stdview = STDVIEW; /* default view parameters */
24
25 static gethfunc gethview;
26
27
28 char *
29 setview( /* set hvec and vvec, return message on error */
30 VIEW *v
31 )
32 {
33 static char ill_horiz[] = "illegal horizontal view size";
34 static char ill_vert[] = "illegal vertical view size";
35
36 if ((v->vfore < -FTINY) | (v->vaft < -FTINY) ||
37 (v->vaft > FTINY) & (v->vaft <= v->vfore))
38 return("illegal fore/aft clipping plane");
39
40 if (v->vdist <= FTINY)
41 return("illegal view distance");
42 v->vdist *= normalize(v->vdir); /* normalize direction */
43 if (v->vdist == 0.0)
44 return("zero view direction");
45
46 if (normalize(v->vup) == 0.0) /* normalize view up */
47 return("zero view up vector");
48
49 fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */
50
51 if (normalize(v->hvec) == 0.0)
52 return("view up parallel to view direction");
53
54 fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */
55
56 if (v->horiz <= FTINY)
57 return(ill_horiz);
58 if (v->vert <= FTINY)
59 return(ill_vert);
60
61 switch (v->type) {
62 case VT_PAR: /* parallel view */
63 v->hn2 = v->horiz;
64 v->vn2 = v->vert;
65 break;
66 case VT_PER: /* perspective view */
67 if (v->horiz >= 180.0-FTINY)
68 return(ill_horiz);
69 if (v->vert >= 180.0-FTINY)
70 return(ill_vert);
71 v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0));
72 v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0));
73 break;
74 case VT_CYL: /* cylindrical panorama */
75 if (v->horiz > 360.0+FTINY)
76 return(ill_horiz);
77 if (v->vert >= 180.0-FTINY)
78 return(ill_vert);
79 v->hn2 = v->horiz * (PI/180.0);
80 v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0));
81 break;
82 case VT_ANG: /* angular fisheye */
83 if (v->horiz > 360.0+FTINY)
84 return(ill_horiz);
85 if (v->vert > 360.0+FTINY)
86 return(ill_vert);
87 v->hn2 = v->horiz * (PI/180.0);
88 v->vn2 = v->vert * (PI/180.0);
89 break;
90 case VT_HEM: /* hemispherical fisheye */
91 if (v->horiz > 180.0+FTINY)
92 return(ill_horiz);
93 if (v->vert > 180.0+FTINY)
94 return(ill_vert);
95 v->hn2 = 2.0 * sin(v->horiz*(PI/180.0/2.0));
96 v->vn2 = 2.0 * sin(v->vert*(PI/180.0/2.0));
97 break;
98 case VT_PLS: /* planispheric fisheye */
99 if (v->horiz >= 360.0-FTINY)
100 return(ill_horiz);
101 if (v->vert >= 360.0-FTINY)
102 return(ill_vert);
103 v->hn2 = 2.*sin(v->horiz*(PI/180.0/2.0)) /
104 (1.0 + cos(v->horiz*(PI/180.0/2.0)));
105 v->vn2 = 2.*sin(v->vert*(PI/180.0/2.0)) /
106 (1.0 + cos(v->vert*(PI/180.0/2.0)));
107 break;
108 default:
109 return("unknown view type");
110 }
111 if (v->type != VT_ANG && v->type != VT_PLS) {
112 if (v->type != VT_CYL) {
113 v->hvec[0] *= v->hn2;
114 v->hvec[1] *= v->hn2;
115 v->hvec[2] *= v->hn2;
116 }
117 v->vvec[0] *= v->vn2;
118 v->vvec[1] *= v->vn2;
119 v->vvec[2] *= v->vn2;
120 }
121 v->hn2 *= v->hn2;
122 v->vn2 *= v->vn2;
123
124 return(NULL);
125 }
126
127
128 void
129 normaspect( /* fix pixel aspect or resolution */
130 double va, /* view aspect ratio */
131 double *ap, /* pixel aspect in (or out if 0) */
132 int *xp,
133 int *yp /* x and y resolution in (or out if *ap!=0) */
134 )
135 {
136 if (*ap <= FTINY)
137 *ap = va * *xp / *yp; /* compute pixel aspect */
138 else if (va * *xp > *ap * *yp)
139 *xp = *yp / va * *ap + .5; /* reduce x resolution */
140 else
141 *yp = *xp * va / *ap + .5; /* reduce y resolution */
142 }
143
144
145 double
146 viewray( /* compute ray origin and direction */
147 FVECT orig,
148 FVECT direc,
149 VIEW *v,
150 double x,
151 double y
152 )
153 {
154 double d, z;
155
156 x += v->hoff - 0.5;
157 y += v->voff - 0.5;
158
159 switch(v->type) {
160 case VT_PAR: /* parallel view */
161 orig[0] = v->vp[0] + v->vfore*v->vdir[0]
162 + x*v->hvec[0] + y*v->vvec[0];
163 orig[1] = v->vp[1] + v->vfore*v->vdir[1]
164 + x*v->hvec[1] + y*v->vvec[1];
165 orig[2] = v->vp[2] + v->vfore*v->vdir[2]
166 + x*v->hvec[2] + y*v->vvec[2];
167 VCOPY(direc, v->vdir);
168 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
169 case VT_PER: /* perspective view */
170 direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
171 direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
172 direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
173 VSUM(orig, v->vp, direc, v->vfore);
174 d = normalize(direc);
175 return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0);
176 case VT_HEM: /* hemispherical fisheye */
177 z = 1.0 - x*x*v->hn2 - y*y*v->vn2;
178 if (z < 0.0)
179 return(-1.0);
180 z = sqrt(z);
181 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
182 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
183 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
184 VSUM(orig, v->vp, direc, v->vfore);
185 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
186 case VT_CYL: /* cylindrical panorama */
187 d = x * v->horiz * (PI/180.0);
188 z = cos(d);
189 x = sin(d);
190 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
191 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
192 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
193 VSUM(orig, v->vp, direc, v->vfore);
194 d = normalize(direc);
195 return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0);
196 case VT_ANG: /* angular fisheye */
197 x *= (1.0/180.0)*v->horiz;
198 y *= (1.0/180.0)*v->vert;
199 d = x*x + y*y;
200 if (d > 1.0)
201 return(-1.0);
202 d = sqrt(d);
203 z = cos(PI*d);
204 d = d <= FTINY ? PI : sqrt(1.0 - z*z)/d;
205 x *= d;
206 y *= d;
207 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
208 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
209 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
210 VSUM(orig, v->vp, direc, v->vfore);
211 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
212 case VT_PLS: /* planispheric fisheye */
213 x *= sqrt(v->hn2);
214 y *= sqrt(v->vn2);
215 d = x*x + y*y;
216 z = (1. - d)/(1. + d);
217 x *= (1. + z);
218 y *= (1. + z);
219 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
220 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
221 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
222 VSUM(orig, v->vp, direc, v->vfore);
223 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
224 }
225 return(-1.0);
226 }
227
228
229 int
230 viewloc( /* find image location for point */
231 FVECT ip,
232 VIEW *v,
233 FVECT p
234 ) /* Use VL_* flags to interpret return value */
235 {
236 int rflags = VL_GOOD;
237 double d, d2;
238 FVECT disp;
239
240 VSUB(disp, p, v->vp);
241
242 switch (v->type) {
243 case VT_PAR: /* parallel view */
244 ip[2] = DOT(disp,v->vdir) - v->vfore;
245 break;
246 case VT_PER: /* perspective view */
247 d = DOT(disp,v->vdir);
248 if ((v->vaft > FTINY) & (d >= v->vaft))
249 rflags |= VL_BEYOND;
250 ip[2] = VLEN(disp);
251 if (d < -FTINY) { /* fold pyramid */
252 ip[2] = -ip[2];
253 d = -d;
254 } else if (d <= FTINY)
255 return(VL_BAD); /* at infinite edge */
256 d = 1.0/d;
257 disp[0] *= d;
258 disp[1] *= d;
259 disp[2] *= d;
260 if (ip[2] < 0.0) d = -d;
261 ip[2] *= (1.0 - v->vfore*d);
262 break;
263 case VT_HEM: /* hemispherical fisheye */
264 d = normalize(disp);
265 if (DOT(disp,v->vdir) < 0.0)
266 ip[2] = -d;
267 else
268 ip[2] = d;
269 ip[2] -= v->vfore;
270 break;
271 case VT_CYL: /* cylindrical panorama */
272 d = DOT(disp,v->hvec);
273 d2 = DOT(disp,v->vdir);
274 ip[0] = 180.0/PI * atan2(d,d2) / v->horiz + 0.5 - v->hoff;
275 d2 = d*d + d2*d2;
276 if (d2 <= FTINY*FTINY)
277 return(VL_BAD); /* at pole */
278 if ((v->vaft > FTINY) & (d2 >= v->vaft*v->vaft))
279 rflags |= VL_BEYOND;
280 d = 1.0/sqrt(d2);
281 ip[1] = DOT(disp,v->vvec)*d/v->vn2 + 0.5 - v->voff;
282 ip[2] = VLEN(disp);
283 ip[2] *= (1.0 - v->vfore*d);
284 goto gotall;
285 case VT_ANG: /* angular fisheye */
286 ip[0] = 0.5 - v->hoff;
287 ip[1] = 0.5 - v->voff;
288 ip[2] = normalize(disp) - v->vfore;
289 d = DOT(disp,v->vdir);
290 if (d >= 1.0-FTINY)
291 goto gotall;
292 if (d <= -(1.0-FTINY)) {
293 ip[0] += 180.0/v->horiz;
294 goto gotall;
295 }
296 d = (180.0/PI)*acos(d) / sqrt(1.0 - d*d);
297 ip[0] += DOT(disp,v->hvec)*d/v->horiz;
298 ip[1] += DOT(disp,v->vvec)*d/v->vert;
299 goto gotall;
300 case VT_PLS: /* planispheric fisheye */
301 ip[0] = 0.5 - v->hoff;
302 ip[1] = 0.5 - v->voff;
303 ip[2] = normalize(disp) - v->vfore;
304 d = DOT(disp,v->vdir);
305 if (d >= 1.0-FTINY)
306 goto gotall;
307 if (d <= -(1.0-FTINY))
308 return(VL_BAD);
309 ip[0] += DOT(disp,v->hvec)/((1. + d)*sqrt(v->hn2));
310 ip[1] += DOT(disp,v->vvec)/((1. + d)*sqrt(v->vn2));
311 goto gotall;
312 default:
313 return(VL_BAD);
314 }
315 ip[0] = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff;
316 ip[1] = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff;
317 gotall: /* add appropriate return flags */
318 if (ip[2] <= 0.0)
319 rflags |= VL_BEHIND;
320 else if ((v->type != VT_PER) & (v->type != VT_CYL))
321 rflags |= VL_BEYOND*((v->vaft > FTINY) &
322 (ip[2] >= v->vaft - v->vfore));
323 rflags |= VL_OUTSIDE*((0.0 >= ip[0]) | (ip[0] >= 1.0) |
324 (0.0 >= ip[1]) | (ip[1] >= 1.0));
325 return(rflags);
326 }
327
328
329 void
330 pix2loc( /* compute image location from pixel pos. */
331 RREAL loc[2],
332 RESOLU *rp,
333 int px,
334 int py
335 )
336 {
337 int x, y;
338
339 if (rp->rt & YMAJOR) {
340 x = px;
341 y = py;
342 } else {
343 x = py;
344 y = px;
345 }
346 if (rp->rt & XDECR)
347 x = rp->xr-1 - x;
348 if (rp->rt & YDECR)
349 y = rp->yr-1 - y;
350 loc[0] = (x+.5)/rp->xr;
351 loc[1] = (y+.5)/rp->yr;
352 }
353
354
355 void
356 loc2pix( /* compute pixel pos. from image location */
357 int pp[2],
358 RESOLU *rp,
359 double lx,
360 double ly
361 )
362 {
363 int x, y;
364
365 x = (int)(lx*rp->xr + .5 - (lx < 0.0));
366 y = (int)(ly*rp->yr + .5 - (ly < 0.0));
367
368 if (rp->rt & XDECR)
369 x = rp->xr-1 - x;
370 if (rp->rt & YDECR)
371 y = rp->yr-1 - y;
372 if (rp->rt & YMAJOR) {
373 pp[0] = x;
374 pp[1] = y;
375 } else {
376 pp[0] = y;
377 pp[1] = x;
378 }
379 }
380
381
382 int
383 getviewopt( /* process view argument */
384 VIEW *v,
385 int ac,
386 char *av[]
387 )
388 {
389 #define check(c,l) if ((av[0][c]&&!isspace(av[0][c])) || \
390 badarg(ac-1,av+1,l)) return(-1)
391
392 if (ac <= 0 || av[0][0] != '-' || av[0][1] != 'v')
393 return(-1);
394 switch (av[0][2]) {
395 case 't': /* type */
396 if (!av[0][3] || isspace(av[0][3]))
397 return(-1);
398 check(4,"");
399 v->type = av[0][3];
400 return(0);
401 case 'p': /* point */
402 check(3,"fff");
403 v->vp[0] = atof(av[1]);
404 v->vp[1] = atof(av[2]);
405 v->vp[2] = atof(av[3]);
406 return(3);
407 case 'd': /* direction */
408 check(3,"fff");
409 v->vdir[0] = atof(av[1]);
410 v->vdir[1] = atof(av[2]);
411 v->vdir[2] = atof(av[3]);
412 v->vdist = 1.;
413 return(3);
414 case 'u': /* up */
415 check(3,"fff");
416 v->vup[0] = atof(av[1]);
417 v->vup[1] = atof(av[2]);
418 v->vup[2] = atof(av[3]);
419 return(3);
420 case 'h': /* horizontal size */
421 check(3,"f");
422 v->horiz = atof(av[1]);
423 return(1);
424 case 'v': /* vertical size */
425 check(3,"f");
426 v->vert = atof(av[1]);
427 return(1);
428 case 'o': /* fore clipping plane */
429 check(3,"f");
430 v->vfore = atof(av[1]);
431 return(1);
432 case 'a': /* aft clipping plane */
433 check(3,"f");
434 v->vaft = atof(av[1]);
435 return(1);
436 case 's': /* shift */
437 check(3,"f");
438 v->hoff = atof(av[1]);
439 return(1);
440 case 'l': /* lift */
441 check(3,"f");
442 v->voff = atof(av[1]);
443 return(1);
444 default:
445 return(-1);
446 }
447 #undef check
448 }
449
450
451 int
452 sscanview( /* get view parameters from string */
453 VIEW *vp,
454 char *s
455 )
456 {
457 int ac;
458 char *av[4];
459 int na;
460 int nvopts = 0;
461
462 while (isspace(*s))
463 if (!*s++)
464 return(0);
465 while (*s) {
466 ac = 0;
467 do {
468 if (ac || *s == '-')
469 av[ac++] = s;
470 while (*s && !isspace(*s))
471 s++;
472 while (isspace(*s))
473 s++;
474 } while (*s && ac < 4);
475 if ((na = getviewopt(vp, ac, av)) >= 0) {
476 if (na+1 < ac)
477 s = av[na+1];
478 nvopts++;
479 } else if (ac > 1)
480 s = av[1];
481 }
482 return(nvopts);
483 }
484
485
486 void
487 fprintview( /* write out view parameters */
488 VIEW *vp,
489 FILE *fp
490 )
491 {
492 fprintf(fp, " -vt%c", vp->type);
493 fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]);
494 fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0]*vp->vdist,
495 vp->vdir[1]*vp->vdist,
496 vp->vdir[2]*vp->vdist);
497 fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]);
498 fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert);
499 fprintf(fp, " -vo %.6g -va %.6g", vp->vfore, vp->vaft);
500 fprintf(fp, " -vs %.6g -vl %.6g", vp->hoff, vp->voff);
501 }
502
503
504 char *
505 viewopt( /* translate to minimal view string */
506 VIEW *vp
507 )
508 {
509 static char vwstr[128];
510 char *cp = vwstr;
511
512 *cp = '\0';
513 if (vp->type != stdview.type) {
514 sprintf(cp, " -vt%c", vp->type);
515 cp += strlen(cp);
516 }
517 if (!VEQ(vp->vp,stdview.vp)) {
518 sprintf(cp, " -vp %.6g %.6g %.6g",
519 vp->vp[0], vp->vp[1], vp->vp[2]);
520 cp += strlen(cp);
521 }
522 if (!FEQ(vp->vdist,stdview.vdist) || !VEQ(vp->vdir,stdview.vdir)) {
523 sprintf(cp, " -vd %.6g %.6g %.6g",
524 vp->vdir[0]*vp->vdist,
525 vp->vdir[1]*vp->vdist,
526 vp->vdir[2]*vp->vdist);
527 cp += strlen(cp);
528 }
529 if (!VEQ(vp->vup,stdview.vup)) {
530 sprintf(cp, " -vu %.6g %.6g %.6g",
531 vp->vup[0], vp->vup[1], vp->vup[2]);
532 cp += strlen(cp);
533 }
534 if (!FEQ(vp->horiz,stdview.horiz)) {
535 sprintf(cp, " -vh %.6g", vp->horiz);
536 cp += strlen(cp);
537 }
538 if (!FEQ(vp->vert,stdview.vert)) {
539 sprintf(cp, " -vv %.6g", vp->vert);
540 cp += strlen(cp);
541 }
542 if (!FEQ(vp->vfore,stdview.vfore)) {
543 sprintf(cp, " -vo %.6g", vp->vfore);
544 cp += strlen(cp);
545 }
546 if (!FEQ(vp->vaft,stdview.vaft)) {
547 sprintf(cp, " -va %.6g", vp->vaft);
548 cp += strlen(cp);
549 }
550 if (!FEQ(vp->hoff,stdview.hoff)) {
551 sprintf(cp, " -vs %.6g", vp->hoff);
552 cp += strlen(cp);
553 }
554 if (!FEQ(vp->voff,stdview.voff)) {
555 sprintf(cp, " -vl %.6g", vp->voff);
556 cp += strlen(cp);
557 }
558 return(vwstr);
559 }
560
561
562 int
563 isview( /* is this a view string? */
564 char *s
565 )
566 {
567 static char *altname[]={NULL,VIEWSTR,"rpict","rview","rvu","rpiece","pinterp",NULL};
568 extern char *progname;
569 char *cp;
570 char **an;
571 /* add program name to list */
572 if (altname[0] == NULL) {
573 for (cp = progname; *cp; cp++)
574 ;
575 while (cp > progname && !ISDIRSEP(cp[-1]))
576 cp--;
577 altname[0] = cp;
578 }
579 /* skip leading path */
580 cp = s;
581 while (*cp && !isspace(*cp))
582 cp++;
583 while (cp > s && !ISDIRSEP(cp[-1]))
584 cp--;
585 for (an = altname; *an != NULL; an++)
586 if (!strncmp(*an, cp, strlen(*an)))
587 return(1);
588 return(0);
589 }
590
591
592 struct myview {
593 VIEW *hv;
594 int ok;
595 };
596
597
598 static int
599 gethview( /* get view from header */
600 char *s,
601 void *v
602 )
603 {
604 if (isview(s) && sscanview(((struct myview*)v)->hv, s) > 0)
605 ((struct myview*)v)->ok++;
606 return(0);
607 }
608
609
610 int
611 viewfile( /* get view from file */
612 char *fname,
613 VIEW *vp,
614 RESOLU *rp
615 )
616 {
617 struct myview mvs;
618 FILE *fp;
619
620 if (fname == NULL || !strcmp(fname, "-"))
621 fp = stdin;
622 else if ((fp = fopen(fname, "r")) == NULL)
623 return(-1);
624
625 mvs.hv = vp;
626 mvs.ok = 0;
627
628 getheader(fp, gethview, &mvs);
629
630 if (rp != NULL && !fgetsresolu(rp, fp))
631 mvs.ok = 0;
632
633 if (fp != stdin)
634 fclose(fp);
635
636 return(mvs.ok);
637 }
