root/radiance/ray/src/common/image.c
Revision: 2.36
Committed: Wed Mar 2 17:24:55 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.35: +8 -8 lines
Minor fix in conversion of negative image locations
2 static const char RCSid[] = "$Id: image.c,v 2.35 2008/12/12 22:05:38 greg Exp $";
5 * image.c - routines for image generation.
6 *
7 * External symbols declared in view.h
8 */
9
10 #include "copyright.h"
11
12 #include <ctype.h>
13 #include "rtio.h"
14 #include "rtmath.h"
15 #include "paths.h"
16 #include "view.h"
17
18
19 #define FEQ(x,y) (fabs((x)-(y)) <= FTINY)
20 #define VEQ(v,w) (FEQ((v)[0],(w)[0]) && FEQ((v)[1],(w)[1]) \
21 && FEQ((v)[2],(w)[2]))
22
23 VIEW stdview = STDVIEW; /* default view parameters */
24
25 static gethfunc gethview;
26
27
28 char *
29 setview( /* set hvec and vvec, return message on error */
30 VIEW *v
31 )
32 {
33 static char ill_horiz[] = "illegal horizontal view size";
34 static char ill_vert[] = "illegal vertical view size";
35
36 if (v->vaft < -FTINY || (v->vaft > FTINY && v->vaft <= v->vfore))
37 return("illegal fore/aft clipping plane");
38
39 if (v->vdist <= FTINY)
40 return("illegal view distance");
41 v->vdist *= normalize(v->vdir); /* normalize direction */
42 if (v->vdist == 0.0)
43 return("zero view direction");
44
45 if (normalize(v->vup) == 0.0) /* normalize view up */
46 return("zero view up vector");
47
48 fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */
49
50 if (normalize(v->hvec) == 0.0)
51 return("view up parallel to view direction");
52
53 fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */
54
55 if (v->horiz <= FTINY)
56 return(ill_horiz);
57 if (v->vert <= FTINY)
58 return(ill_vert);
59
60 switch (v->type) {
61 case VT_PAR: /* parallel view */
62 v->hn2 = v->horiz;
63 v->vn2 = v->vert;
64 break;
65 case VT_PER: /* perspective view */
66 if (v->horiz >= 180.0-FTINY)
67 return(ill_horiz);
68 if (v->vert >= 180.0-FTINY)
69 return(ill_vert);
70 v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0));
71 v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0));
72 break;
73 case VT_CYL: /* cylindrical panorama */
74 if (v->horiz > 360.0+FTINY)
75 return(ill_horiz);
76 if (v->vert >= 180.0-FTINY)
77 return(ill_vert);
78 v->hn2 = v->horiz * (PI/180.0);
79 v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0));
80 break;
81 case VT_ANG: /* angular fisheye */
82 if (v->horiz > 360.0+FTINY)
83 return(ill_horiz);
84 if (v->vert > 360.0+FTINY)
85 return(ill_vert);
86 v->hn2 = v->horiz * (PI/180.0);
87 v->vn2 = v->vert * (PI/180.0);
88 break;
89 case VT_HEM: /* hemispherical fisheye */
90 if (v->horiz > 180.0+FTINY)
91 return(ill_horiz);
92 if (v->vert > 180.0+FTINY)
93 return(ill_vert);
94 v->hn2 = 2.0 * sin(v->horiz*(PI/180.0/2.0));
95 v->vn2 = 2.0 * sin(v->vert*(PI/180.0/2.0));
96 break;
97 case VT_PLS: /* planispheric fisheye */
98 if (v->horiz >= 360.0-FTINY)
99 return(ill_horiz);
100 if (v->vert >= 360.0-FTINY)
101 return(ill_vert);
102 v->hn2 = 2.*sin(v->horiz*(PI/180.0/2.0)) /
103 (1.0 + cos(v->horiz*(PI/180.0/2.0)));
104 v->vn2 = 2.*sin(v->vert*(PI/180.0/2.0)) /
105 (1.0 + cos(v->vert*(PI/180.0/2.0)));
106 break;
107 default:
108 return("unknown view type");
109 }
110 if (v->type != VT_ANG && v->type != VT_PLS) {
111 if (v->type != VT_CYL) {
112 v->hvec[0] *= v->hn2;
113 v->hvec[1] *= v->hn2;
114 v->hvec[2] *= v->hn2;
115 }
116 v->vvec[0] *= v->vn2;
117 v->vvec[1] *= v->vn2;
118 v->vvec[2] *= v->vn2;
119 }
120 v->hn2 *= v->hn2;
121 v->vn2 *= v->vn2;
122
123 return(NULL);
124 }
125
126
127 void
128 normaspect( /* fix pixel aspect or resolution */
129 double va, /* view aspect ratio */
130 double *ap, /* pixel aspect in (or out if 0) */
131 int *xp,
132 int *yp /* x and y resolution in (or out if *ap!=0) */
133 )
134 {
135 if (*ap <= FTINY)
136 *ap = va * *xp / *yp; /* compute pixel aspect */
137 else if (va * *xp > *ap * *yp)
138 *xp = *yp / va * *ap + .5; /* reduce x resolution */
139 else
140 *yp = *xp * va / *ap + .5; /* reduce y resolution */
141 }
142
143
144 double
145 viewray( /* compute ray origin and direction */
146 FVECT orig,
147 FVECT direc,
148 VIEW *v,
149 double x,
150 double y
151 )
152 {
153 double d, z;
154
155 x += v->hoff - 0.5;
156 y += v->voff - 0.5;
157
158 switch(v->type) {
159 case VT_PAR: /* parallel view */
160 orig[0] = v->vp[0] + v->vfore*v->vdir[0]
161 + x*v->hvec[0] + y*v->vvec[0];
162 orig[1] = v->vp[1] + v->vfore*v->vdir[1]
163 + x*v->hvec[1] + y*v->vvec[1];
164 orig[2] = v->vp[2] + v->vfore*v->vdir[2]
165 + x*v->hvec[2] + y*v->vvec[2];
166 VCOPY(direc, v->vdir);
167 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
168 case VT_PER: /* perspective view */
169 direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
170 direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
171 direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
172 orig[0] = v->vp[0] + v->vfore*direc[0];
173 orig[1] = v->vp[1] + v->vfore*direc[1];
174 orig[2] = v->vp[2] + v->vfore*direc[2];
175 d = normalize(direc);
176 return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0);
177 case VT_HEM: /* hemispherical fisheye */
178 z = 1.0 - x*x*v->hn2 - y*y*v->vn2;
179 if (z < 0.0)
180 return(-1.0);
181 z = sqrt(z);
182 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
183 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
184 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
185 orig[0] = v->vp[0] + v->vfore*direc[0];
186 orig[1] = v->vp[1] + v->vfore*direc[1];
187 orig[2] = v->vp[2] + v->vfore*direc[2];
188 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
189 case VT_CYL: /* cylindrical panorama */
190 d = x * v->horiz * (PI/180.0);
191 z = cos(d);
192 x = sin(d);
193 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
194 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
195 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
196 orig[0] = v->vp[0] + v->vfore*direc[0];
197 orig[1] = v->vp[1] + v->vfore*direc[1];
198 orig[2] = v->vp[2] + v->vfore*direc[2];
199 d = normalize(direc);
200 return(v->vaft > FTINY ? (v->vaft - v->vfore)*d : 0.0);
201 case VT_ANG: /* angular fisheye */
202 x *= (1.0/180.0)*v->horiz;
203 y *= (1.0/180.0)*v->vert;
204 d = x*x + y*y;
205 if (d > 1.0)
206 return(-1.0);
207 d = sqrt(d);
208 z = cos(PI*d);
209 d = d <= FTINY ? PI : sqrt(1.0 - z*z)/d;
210 x *= d;
211 y *= d;
212 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
213 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
214 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
215 orig[0] = v->vp[0] + v->vfore*direc[0];
216 orig[1] = v->vp[1] + v->vfore*direc[1];
217 orig[2] = v->vp[2] + v->vfore*direc[2];
218 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
219 case VT_PLS: /* planispheric fisheye */
220 x *= sqrt(v->hn2);
221 y *= sqrt(v->vn2);
222 d = x*x + y*y;
223 z = (1. - d)/(1. + d);
224 d = d <= FTINY*FTINY ? PI : sqrt((1.0 - z*z)/d);
225 x *= d;
226 y *= d;
227 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
228 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
229 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
230 orig[0] = v->vp[0] + v->vfore*direc[0];
231 orig[1] = v->vp[1] + v->vfore*direc[1];
232 orig[2] = v->vp[2] + v->vfore*direc[2];
233 return(v->vaft > FTINY ? v->vaft - v->vfore : 0.0);
234 }
235 return(-1.0);
236 }
237
238
239 void
240 viewloc( /* find image location for point */
241 FVECT ip,
242 VIEW *v,
243 FVECT p
244 )
245 {
246 double d, d2;
247 FVECT disp;
248
249 VSUB(disp, p, v->vp);
250
251 switch (v->type) {
252 case VT_PAR: /* parallel view */
253 ip[2] = DOT(disp,v->vdir) - v->vfore;
254 break;
255 case VT_PER: /* perspective view */
256 d = DOT(disp,v->vdir);
257 ip[2] = VLEN(disp);
258 if (d < 0.0) { /* fold pyramid */
259 ip[2] = -ip[2];
260 d = -d;
261 }
262 if (d > FTINY) {
263 d = 1.0/d;
264 disp[0] *= d;
265 disp[1] *= d;
266 disp[2] *= d;
267 }
268 ip[2] *= (1.0 - v->vfore*d);
269 break;
270 case VT_HEM: /* hemispherical fisheye */
271 d = normalize(disp);
272 if (DOT(disp,v->vdir) < 0.0)
273 ip[2] = -d;
274 else
275 ip[2] = d;
276 ip[2] -= v->vfore;
277 break;
278 case VT_CYL: /* cylindrical panorama */
279 d = DOT(disp,v->hvec);
280 d2 = DOT(disp,v->vdir);
281 ip[0] = 180.0/PI * atan2(d,d2) / v->horiz + 0.5 - v->hoff;
282 d = 1.0/sqrt(d*d + d2*d2);
283 ip[1] = DOT(disp,v->vvec)*d/v->vn2 + 0.5 - v->voff;
284 ip[2] = VLEN(disp);
285 ip[2] *= (1.0 - v->vfore*d);
286 return;
287 case VT_ANG: /* angular fisheye */
288 ip[0] = 0.5 - v->hoff;
289 ip[1] = 0.5 - v->voff;
290 ip[2] = normalize(disp) - v->vfore;
291 d = DOT(disp,v->vdir);
292 if (d >= 1.0-FTINY)
293 return;
294 if (d <= -(1.0-FTINY)) {
295 ip[0] += 180.0/v->horiz;
296 return;
297 }
298 d = (180.0/PI)*acos(d) / sqrt(1.0 - d*d);
299 ip[0] += DOT(disp,v->hvec)*d/v->horiz;
300 ip[1] += DOT(disp,v->vvec)*d/v->vert;
301 return;
302 case VT_PLS: /* planispheric fisheye */
303 ip[0] = 0.5 - v->hoff;
304 ip[1] = 0.5 - v->voff;
305 ip[2] = normalize(disp) - v->vfore;
306 d = DOT(disp,v->vdir);
307 if (d >= 1.0-FTINY)
308 return;
309 if (d <= -(1.0-FTINY))
310 return; /* really an error */
311 d = sqrt(1.0 - d*d) / (1.0 + d);
312 ip[0] += DOT(disp,v->hvec)*d/sqrt(v->hn2);
313 ip[1] += DOT(disp,v->vvec)*d/sqrt(v->vn2);
314 return;
315 }
316 ip[0] = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff;
317 ip[1] = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff;
318 }
319
320
321 void
322 pix2loc( /* compute image location from pixel pos. */
323 RREAL loc[2],
324 RESOLU *rp,
325 int px,
326 int py
327 )
328 {
329 int x, y;
330
331 if (rp->rt & YMAJOR) {
332 x = px;
333 y = py;
334 } else {
335 x = py;
336 y = px;
337 }
338 if (rp->rt & XDECR)
339 x = rp->xr-1 - x;
340 if (rp->rt & YDECR)
341 y = rp->yr-1 - y;
342 loc[0] = (x+.5)/rp->xr;
343 loc[1] = (y+.5)/rp->yr;
344 }
345
346
347 void
348 loc2pix( /* compute pixel pos. from image location */
349 int pp[2],
350 RESOLU *rp,
351 double lx,
352 double ly
353 )
354 {
355 int x, y;
356
357 x = (lx >= 0.0) ? (int)(lx * rp->xr) : -(int)(-lx * rp->xr);
358 y = (ly >= 0.0) ? (int)(ly * rp->yr) : -(int)(-ly * rp->yr);
359 if (rp->rt & XDECR)
360 x = rp->xr-1 - x;
361 if (rp->rt & YDECR)
362 y = rp->yr-1 - y;
363 if (rp->rt & YMAJOR) {
364 pp[0] = x;
365 pp[1] = y;
366 } else {
367 pp[0] = y;
368 pp[1] = x;
369 }
370 }
371
372
373 int
374 getviewopt( /* process view argument */
375 VIEW *v,
376 int ac,
377 char *av[]
378 )
379 {
380 #define check(c,l) if ((av[0][c]&&av[0][c]!=' ') || \
381 badarg(ac-1,av+1,l)) return(-1)
382
383 if (ac <= 0 || av[0][0] != '-' || av[0][1] != 'v')
384 return(-1);
385 switch (av[0][2]) {
386 case 't': /* type */
387 if (!av[0][3] || av[0][3]==' ')
388 return(-1);
389 check(4,"");
390 v->type = av[0][3];
391 return(0);
392 case 'p': /* point */
393 check(3,"fff");
394 v->vp[0] = atof(av[1]);
395 v->vp[1] = atof(av[2]);
396 v->vp[2] = atof(av[3]);
397 return(3);
398 case 'd': /* direction */
399 check(3,"fff");
400 v->vdir[0] = atof(av[1]);
401 v->vdir[1] = atof(av[2]);
402 v->vdir[2] = atof(av[3]);
403 v->vdist = 1.;
404 return(3);
405 case 'u': /* up */
406 check(3,"fff");
407 v->vup[0] = atof(av[1]);
408 v->vup[1] = atof(av[2]);
409 v->vup[2] = atof(av[3]);
410 return(3);
411 case 'h': /* horizontal size */
412 check(3,"f");
413 v->horiz = atof(av[1]);
414 return(1);
415 case 'v': /* vertical size */
416 check(3,"f");
417 v->vert = atof(av[1]);
418 return(1);
419 case 'o': /* fore clipping plane */
420 check(3,"f");
421 v->vfore = atof(av[1]);
422 return(1);
423 case 'a': /* aft clipping plane */
424 check(3,"f");
425 v->vaft = atof(av[1]);
426 return(1);
427 case 's': /* shift */
428 check(3,"f");
429 v->hoff = atof(av[1]);
430 return(1);
431 case 'l': /* lift */
432 check(3,"f");
433 v->voff = atof(av[1]);
434 return(1);
435 default:
436 return(-1);
437 }
438 #undef check
439 }
440
441
442 int
443 sscanview( /* get view parameters from string */
444 VIEW *vp,
445 char *s
446 )
447 {
448 int ac;
449 char *av[4];
450 int na;
451 int nvopts = 0;
452
453 while (isspace(*s))
454 if (!*s++)
455 return(0);
456 while (*s) {
457 ac = 0;
458 do {
459 if (ac || *s == '-')
460 av[ac++] = s;
461 while (*s && !isspace(*s))
462 s++;
463 while (isspace(*s))
464 s++;
465 } while (*s && ac < 4);
466 if ((na = getviewopt(vp, ac, av)) >= 0) {
467 if (na+1 < ac)
468 s = av[na+1];
469 nvopts++;
470 } else if (ac > 1)
471 s = av[1];
472 }
473 return(nvopts);
474 }
475
476
477 void
478 fprintview( /* write out view parameters */
479 VIEW *vp,
480 FILE *fp
481 )
482 {
483 fprintf(fp, " -vt%c", vp->type);
484 fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]);
485 fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0]*vp->vdist,
486 vp->vdir[1]*vp->vdist,
487 vp->vdir[2]*vp->vdist);
488 fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]);
489 fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert);
490 fprintf(fp, " -vo %.6g -va %.6g", vp->vfore, vp->vaft);
491 fprintf(fp, " -vs %.6g -vl %.6g", vp->hoff, vp->voff);
492 }
493
494
495 char *
496 viewopt( /* translate to minimal view string */
497 VIEW *vp
498 )
499 {
500 static char vwstr[128];
501 char *cp = vwstr;
502
503 *cp = '\0';
504 if (vp->type != stdview.type) {
505 sprintf(cp, " -vt%c", vp->type);
506 cp += strlen(cp);
507 }
508 if (!VEQ(vp->vp,stdview.vp)) {
509 sprintf(cp, " -vp %.6g %.6g %.6g",
510 vp->vp[0], vp->vp[1], vp->vp[2]);
511 cp += strlen(cp);
512 }
513 if (!FEQ(vp->vdist,stdview.vdist) || !VEQ(vp->vdir,stdview.vdir)) {
514 sprintf(cp, " -vd %.6g %.6g %.6g",
515 vp->vdir[0]*vp->vdist,
516 vp->vdir[1]*vp->vdist,
517 vp->vdir[2]*vp->vdist);
518 cp += strlen(cp);
519 }
520 if (!VEQ(vp->vup,stdview.vup)) {
521 sprintf(cp, " -vu %.6g %.6g %.6g",
522 vp->vup[0], vp->vup[1], vp->vup[2]);
523 cp += strlen(cp);
524 }
525 if (!FEQ(vp->horiz,stdview.horiz)) {
526 sprintf(cp, " -vh %.6g", vp->horiz);
527 cp += strlen(cp);
528 }
529 if (!FEQ(vp->vert,stdview.vert)) {
530 sprintf(cp, " -vv %.6g", vp->vert);
531 cp += strlen(cp);
532 }
533 if (!FEQ(vp->vfore,stdview.vfore)) {
534 sprintf(cp, " -vo %.6g", vp->vfore);
535 cp += strlen(cp);
536 }
537 if (!FEQ(vp->vaft,stdview.vaft)) {
538 sprintf(cp, " -va %.6g", vp->vaft);
539 cp += strlen(cp);
540 }
541 if (!FEQ(vp->hoff,stdview.hoff)) {
542 sprintf(cp, " -vs %.6g", vp->hoff);
543 cp += strlen(cp);
544 }
545 if (!FEQ(vp->voff,stdview.voff)) {
546 sprintf(cp, " -vl %.6g", vp->voff);
547 cp += strlen(cp);
548 }
549 return(vwstr);
550 }
551
552
553 int
554 isview( /* is this a view string? */
555 char *s
556 )
557 {
558 static char *altname[]={NULL,VIEWSTR,"rpict","rview","rvu","rpiece","pinterp",NULL};
559 extern char *progname;
560 char *cp;
561 char **an;
562 /* add program name to list */
563 if (altname[0] == NULL) {
564 for (cp = progname; *cp; cp++)
565 ;
566 while (cp > progname && !ISDIRSEP(cp[-1]))
567 cp--;
568 altname[0] = cp;
569 }
570 /* skip leading path */
571 cp = s;
572 while (*cp && *cp != ' ')
573 cp++;
574 while (cp > s && !ISDIRSEP(cp[-1]))
575 cp--;
576 for (an = altname; *an != NULL; an++)
577 if (!strncmp(*an, cp, strlen(*an)))
578 return(1);
579 return(0);
580 }
581
582
583 struct myview {
584 VIEW *hv;
585 int ok;
586 };
587
588
589 static int
590 gethview( /* get view from header */
591 char *s,
592 void *v
593 )
594 {
595 if (isview(s) && sscanview(((struct myview*)v)->hv, s) > 0)
596 ((struct myview*)v)->ok++;
597 return(0);
598 }
599
600
601 int
602 viewfile( /* get view from file */
603 char *fname,
604 VIEW *vp,
605 RESOLU *rp
606 )
607 {
608 struct myview mvs;
609 FILE *fp;
610
611 if (fname == NULL || !strcmp(fname, "-"))
612 fp = stdin;
613 else if ((fp = fopen(fname, "r")) == NULL)
614 return(-1);
615
616 mvs.hv = vp;
617 mvs.ok = 0;
618
619 getheader(fp, gethview, &mvs);
620
621 if (rp != NULL && !fgetsresolu(rp, fp))
622 mvs.ok = 0;
623
624 fclose(fp);
625
626 return(mvs.ok);
627 }
