root/radiance/ray/src/common/image.c
Revision: 1.6
Committed: Tue Jan 9 09:08:09 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.5: +16 -0 lines
added routine for computing image size and pixel aspect ratios
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * image.c - routines for image generation.
9 *
10 * 10/17/85
11 */
12
13 #include "standard.h"
14
15 #include "view.h"
16
17 VIEW stdview = STDVIEW; /* default view parameters */
18
19
20 char *
21 setview(v) /* set hvec and vvec, return message on error */
22 register VIEW *v;
23 {
24 extern double tan(), normalize();
25
26 if (normalize(v->vdir) == 0.0) /* normalize direction */
27 return("zero view direction");
28
29 fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */
30
31 if (normalize(v->hvec) == 0.0)
32 return("illegal view up vector");
33
34 fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */
35
36 if (v->type == VT_PAR)
37 v->hn2 = v->horiz;
38 else if (v->type == VT_PER)
39 v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0));
40 else
41 return("unknown view type");
42
43 if (v->hn2 <= FTINY || v->hn2 >= FHUGE)
44 return("illegal horizontal view size");
45
46 v->hvec[0] *= v->hn2;
47 v->hvec[1] *= v->hn2;
48 v->hvec[2] *= v->hn2;
49 v->hn2 *= v->hn2;
50
51 if (v->type == VT_PAR)
52 v->vn2 = v->vert;
53 else
54 v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0));
55
56 if (v->vn2 <= FTINY || v->vn2 >= FHUGE)
57 return("illegal vertical view size");
58
59 v->vvec[0] *= v->vn2;
60 v->vvec[1] *= v->vn2;
61 v->vvec[2] *= v->vn2;
62 v->vn2 *= v->vn2;
63
64 return(NULL);
65 }
66
67
68 normaspect(vp, ap, xp, yp) /* fix pixel aspect or resolution */
69 VIEW *vp;
70 double *ap;
71 int *xp, *yp;
72 {
73 double va = viewaspect(vp);
74
75 if (*ap <= FTINY)
76 *ap = (double)*yp / *xp / va; /* compute pixel aspect */
77 else if (va * *xp > *ap * *yp)
78 *xp = *yp / va * *ap; /* reduce x resolution */
79 else
80 *yp = *xp * va / *ap; /* reduce y resolution */
81 }
82
83
84 viewray(orig, direc, v, x, y) /* compute ray origin and direction */
85 FVECT orig, direc;
86 register VIEW *v;
87 double x, y;
88 {
89 x += v->hoff - 0.5;
90 y += v->voff - 0.5;
91
92 if (v->type == VT_PAR) { /* parallel view */
93 orig[0] = v->vp[0] + x*v->hvec[0] + y*v->vvec[0];
94 orig[1] = v->vp[1] + x*v->hvec[1] + y*v->vvec[1];
95 orig[2] = v->vp[2] + x*v->hvec[2] + y*v->vvec[2];
96 VCOPY(direc, v->vdir);
97 } else { /* perspective view */
98 VCOPY(orig, v->vp);
99 direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
100 direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
101 direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
102 normalize(direc);
103 }
104 }
105
106
107 viewpixel(xp, yp, zp, v, p) /* find image location for point */
108 double *xp, *yp, *zp;
109 register VIEW *v;
110 FVECT p;
111 {
112 extern double sqrt();
113 double d;
114 FVECT disp;
115
116 disp[0] = p[0] - v->vp[0];
117 disp[1] = p[1] - v->vp[1];
118 disp[2] = p[2] - v->vp[2];
119
120 if (v->type == VT_PAR) { /* parallel view */
121 if (zp != NULL)
122 *zp = DOT(disp,v->vdir);
123 } else { /* perspective view */
124 d = 1.0/DOT(disp,v->vdir);
125 if (zp != NULL) {
126 *zp = sqrt(DOT(disp,disp));
127 if (d < 0.0)
128 *zp = -*zp;
129 }
130 disp[0] *= d;
131 disp[1] *= d;
132 disp[2] *= d;
133 }
134 *xp = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff;
135 *yp = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff;
136 }
137
138
139 int
140 getviewopt(v, ac, av) /* process view argument */
141 register VIEW *v;
142 int ac;
143 register char *av[];
144 {
145 #define check(c,n) if ((av[0][c]&&av[0][c]!=' ') || n>=ac) return(-1)
146 extern double atof();
147
148 if (av[0][0] != '-' || av[0][1] != 'v')
149 return(-1);
150 switch (av[0][2]) {
151 case 't': /* type */
152 if (!av[0][3] || av[0][3]==' ')
153 return(-1);
154 check(4,0);
155 v->type = av[0][3];
156 return(0);
157 case 'p': /* point */
158 check(3,3);
159 v->vp[0] = atof(av[1]);
160 v->vp[1] = atof(av[2]);
161 v->vp[2] = atof(av[3]);
162 return(3);
163 case 'd': /* direction */
164 check(3,3);
165 v->vdir[0] = atof(av[1]);
166 v->vdir[1] = atof(av[2]);
167 v->vdir[2] = atof(av[3]);
168 return(3);
169 case 'u': /* up */
170 check(3,3);
171 v->vup[0] = atof(av[1]);
172 v->vup[1] = atof(av[2]);
173 v->vup[2] = atof(av[3]);
174 return(3);
175 case 'h': /* horizontal size */
176 check(3,1);
177 v->horiz = atof(av[1]);
178 return(1);
179 case 'v': /* vertical size */
180 check(3,1);
181 v->vert = atof(av[1]);
182 return(1);
183 case 's': /* shift */
184 check(3,1);
185 v->hoff = atof(av[1]);
186 return(1);
187 case 'l': /* lift */
188 check(3,1);
189 v->voff = atof(av[1]);
190 return(1);
191 default:
192 return(-1);
193 }
194 #undef check
195 }
196
197
198 int
199 sscanview(vp, s) /* get view parameters from string */
200 VIEW *vp;
201 register char *s;
202 {
203 int ac;
204 char *av[4];
205 int na;
206 int nvopts = 0;
207
208 while (*s == ' ')
209 s++;
210 do {
211 ac = 0;
212 do {
213 av[ac++] = s;
214 while (*s && *s != ' ')
215 s++;
216 while (*s == ' ')
217 s++;
218 } while (*s && ac < 4);
219 if ((na = getviewopt(vp, ac, av)) >= 0) {
220 if (na+1 < ac)
221 s = av[na+1];
222 nvopts++;
223 }
224 } while (*s);
225 return(nvopts);
226 }
227
228
229 fprintview(vp, fp) /* write out view parameters */
230 register VIEW *vp;
231 FILE *fp;
232 {
233 fprintf(fp, " -vt%c", vp->type);
234 fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]);
235 fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]);
236 fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]);
237 fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert);
238 fprintf(fp, " -vs %d -vl %d", vp->hoff, vp->voff);
239 }
240
241
242 static VIEW *hview; /* view from header */
243 static int gothview; /* success indicator */
244 static char *altname[] = {NULL,"rpict","rview","pinterp",VIEWSTR,NULL};
245
246
247 static
248 gethview(s) /* get view from header */
249 char *s;
250 {
251 register char **an;
252
253 for (an = altname; *an != NULL; an++)
254 if (!strncmp(*an, s, strlen(*an))) {
255 if (sscanview(hview, s+strlen(*an)) > 0)
256 gothview++;
257 return;
258 }
259 }
260
261
262 int
263 viewfile(fname, vp) /* get view from file */
264 char *fname;
265 VIEW *vp;
266 {
267 extern char *progname;
268 FILE *fp;
269
270 if ((fp = fopen(fname, "r")) == NULL)
271 return(-1);
272
273 altname[0] = progname;
274 hview = vp;
275 gothview = 0;
276
277 getheader(fp, gethview);
278
279 fclose(fp);
280
281 return(gothview);
282 }
