root/radiance/ray/src/common/image.c
Revision: 1.12
Committed: Sat Oct 13 20:56:01 1990 UTC (34 years, 10 months ago) by greg
Changes since 1.11: +123 -31 lines
added fisheye view types
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * image.c - routines for image generation.
9 *
10 * 10/17/85
11 */
12
13 #include "standard.h"
14
15 #include "view.h"
16
17 VIEW stdview = STDVIEW; /* default view parameters */
18
19
20 char *
21 setview(v) /* set hvec and vvec, return message on error */
22 register VIEW *v;
23 {
24 static char ill_horiz[] = "illegal horizontal view size";
25 static char ill_vert[] = "illegal vertical view size";
26
27 if (normalize(v->vdir) == 0.0) /* normalize direction */
28 return("zero view direction");
29
30 fcross(v->hvec, v->vdir, v->vup); /* compute horiz dir */
31
32 if (normalize(v->hvec) == 0.0)
33 return("illegal view up vector");
34
35 fcross(v->vvec, v->hvec, v->vdir); /* compute vert dir */
36
37 if (v->horiz <= FTINY)
38 return(ill_horiz);
39 if (v->vert <= FTINY)
40 return(ill_vert);
41
42 switch (v->type) {
43 case VT_PAR: /* parallel view */
44 v->hn2 = v->horiz;
45 v->vn2 = v->vert;
46 break;
47 case VT_PER: /* perspective view */
48 if (v->horiz >= 180.0-FTINY)
49 return(ill_horiz);
50 if (v->vert >= 180.0-FTINY)
51 return(ill_vert);
52 v->hn2 = 2.0 * tan(v->horiz*(PI/180.0/2.0));
53 v->vn2 = 2.0 * tan(v->vert*(PI/180.0/2.0));
54 break;
55 case VT_ANG: /* angular fisheye */
56 if (v->horiz > 360.0+FTINY)
57 return(ill_horiz);
58 if (v->vert > 360.0+FTINY)
59 return(ill_vert);
60 v->hn2 = v->horiz / 90.0;
61 v->vn2 = v->vert / 90.0;
62 break;
63 case VT_HEM: /* hemispherical fisheye */
64 if (v->horiz > 180.0+FTINY)
65 return(ill_horiz);
66 if (v->vert > 180.0+FTINY)
67 return(ill_vert);
68 v->hn2 = 2.0 * sin(v->horiz*(PI/180.0/2.0));
69 v->vn2 = 2.0 * sin(v->vert*(PI/180.0/2.0));
70 break;
71 default:
72 return("unknown view type");
73 }
74 if (v->type == VT_PAR || v->type == VT_PER) {
75 v->hvec[0] *= v->hn2;
76 v->hvec[1] *= v->hn2;
77 v->hvec[2] *= v->hn2;
78 v->vvec[0] *= v->vn2;
79 v->vvec[1] *= v->vn2;
80 v->vvec[2] *= v->vn2;
81 }
82 v->hn2 *= v->hn2;
83 v->vn2 *= v->vn2;
84
85 return(NULL);
86 }
87
88
89 normaspect(va, ap, xp, yp) /* fix pixel aspect or resolution */
90 double va; /* view aspect ratio */
91 double *ap; /* pixel aspect in (or out if 0) */
92 int *xp, *yp; /* x and y resolution in (or out if *ap!=0) */
93 {
94 if (*ap <= FTINY)
95 *ap = va * *xp / *yp; /* compute pixel aspect */
96 else if (va * *xp > *ap * *yp)
97 *xp = *yp / va * *ap + .5; /* reduce x resolution */
98 else
99 *yp = *xp * va / *ap + .5; /* reduce y resolution */
100 }
101
102
103 viewray(orig, direc, v, x, y) /* compute ray origin and direction */
104 FVECT orig, direc;
105 register VIEW *v;
106 double x, y;
107 {
108 double d, z;
109
110 x += v->hoff - 0.5;
111 y += v->voff - 0.5;
112
113 switch(v->type) {
114 case VT_PAR: /* parallel view */
115 orig[0] = v->vp[0] + x*v->hvec[0] + y*v->vvec[0];
116 orig[1] = v->vp[1] + x*v->hvec[1] + y*v->vvec[1];
117 orig[2] = v->vp[2] + x*v->hvec[2] + y*v->vvec[2];
118 VCOPY(direc, v->vdir);
119 return(0);
120 case VT_PER: /* perspective view */
121 VCOPY(orig, v->vp);
122 direc[0] = v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
123 direc[1] = v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
124 direc[2] = v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
125 normalize(direc);
126 return(0);
127 case VT_HEM: /* hemispherical fisheye */
128 x *= v->horiz/90.0;
129 y *= v->vert/90.0;
130 z = 1.0 - x*x - y*y;
131 if (z < 0.0)
132 return(-1);
133 z = sqrt(z);
134 VCOPY(orig, v->vp);
135 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
136 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
137 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
138 return(0);
139 case VT_ANG: /* angular fisheye */
140 x *= v->horiz/180.0;
141 y *= v->vert/180.0;
142 d = x*x + y*y;
143 if (d > 1.0)
144 return(-1);
145 VCOPY(orig, v->vp);
146 if (d <= FTINY) {
147 VCOPY(direc, v->vdir);
148 return(0);
149 }
150 d = sqrt(d);
151 z = cos(PI*d);
152 d = sqrt(1 - z*z)/d;
153 x *= d;
154 y *= d;
155 direc[0] = z*v->vdir[0] + x*v->hvec[0] + y*v->vvec[0];
156 direc[1] = z*v->vdir[1] + x*v->hvec[1] + y*v->vvec[1];
157 direc[2] = z*v->vdir[2] + x*v->hvec[2] + y*v->vvec[2];
158 return(0);
159 }
160 return(-1);
161 }
162
163
164 viewpixel(xp, yp, zp, v, p) /* find image location for point */
165 double *xp, *yp, *zp;
166 register VIEW *v;
167 FVECT p;
168 {
169 double d;
170 FVECT disp;
171
172 disp[0] = p[0] - v->vp[0];
173 disp[1] = p[1] - v->vp[1];
174 disp[2] = p[2] - v->vp[2];
175
176 switch (v->type) {
177 case VT_PAR: /* parallel view */
178 if (zp != NULL)
179 *zp = DOT(disp,v->vdir);
180 *xp = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff;
181 *yp = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff;
182 return;
183 case VT_PER: /* perspective view */
184 d = DOT(disp,v->vdir);
185 if (zp != NULL) {
186 *zp = sqrt(DOT(disp,disp));
187 if (d < 0.0)
188 *zp = -*zp;
189 }
190 if (d < 0.0) /* fold pyramid */
191 d = -d;
192 if (d > FTINY) {
193 d = 1.0/d;
194 disp[0] *= d;
195 disp[1] *= d;
196 disp[2] *= d;
197 }
198 *xp = DOT(disp,v->hvec)/v->hn2 + 0.5 - v->hoff;
199 *yp = DOT(disp,v->vvec)/v->vn2 + 0.5 - v->voff;
200 return;
201 case VT_HEM: /* hemispherical fisheye */
202 d = normalize(disp);
203 if (zp != NULL) {
204 if (DOT(disp,v->vdir) < 0.0)
205 *zp = -d;
206 else
207 *zp = d;
208 }
209 *xp = DOT(disp,v->hvec)*90.0/v->horiz + 0.5 - v->hoff;
210 *yp = DOT(disp,v->vvec)*90.0/v->vert + 0.5 - v->voff;
211 return;
212 case VT_ANG: /* angular fisheye */
213 d = normalize(disp);
214 if (zp != NULL)
215 *zp = d;
216 *xp = 0.5 - v->hoff;
217 *yp = 0.5 - v->voff;
218 d = DOT(disp,v->vdir);
219 if (d >= 1.0-FTINY)
220 return;
221 if (d <= -(1.0-FTINY)) {
222 *xp += 180.0/v->horiz;
223 *yp += 180.0/v->vert;
224 return;
225 }
226 d = acos(d)/PI / sqrt(1.0 - d*d);
227 *xp += DOT(disp,v->hvec)*d*180.0/v->horiz;
228 *yp += DOT(disp,v->vvec)*d*180.0/v->vert;
229 return;
230 }
231 }
232
233
234 int
235 getviewopt(v, ac, av) /* process view argument */
236 register VIEW *v;
237 int ac;
238 register char *av[];
239 {
240 #define check(c,n) if ((av[0][c]&&av[0][c]!=' ') || n>=ac) return(-1)
241 extern double atof();
242
243 if (ac <= 0 || av[0][0] != '-' || av[0][1] != 'v')
244 return(-1);
245 switch (av[0][2]) {
246 case 't': /* type */
247 if (!av[0][3] || av[0][3]==' ')
248 return(-1);
249 check(4,0);
250 v->type = av[0][3];
251 return(0);
252 case 'p': /* point */
253 check(3,3);
254 v->vp[0] = atof(av[1]);
255 v->vp[1] = atof(av[2]);
256 v->vp[2] = atof(av[3]);
257 return(3);
258 case 'd': /* direction */
259 check(3,3);
260 v->vdir[0] = atof(av[1]);
261 v->vdir[1] = atof(av[2]);
262 v->vdir[2] = atof(av[3]);
263 return(3);
264 case 'u': /* up */
265 check(3,3);
266 v->vup[0] = atof(av[1]);
267 v->vup[1] = atof(av[2]);
268 v->vup[2] = atof(av[3]);
269 return(3);
270 case 'h': /* horizontal size */
271 check(3,1);
272 v->horiz = atof(av[1]);
273 return(1);
274 case 'v': /* vertical size */
275 check(3,1);
276 v->vert = atof(av[1]);
277 return(1);
278 case 's': /* shift */
279 check(3,1);
280 v->hoff = atof(av[1]);
281 return(1);
282 case 'l': /* lift */
283 check(3,1);
284 v->voff = atof(av[1]);
285 return(1);
286 default:
287 return(-1);
288 }
289 #undef check
290 }
291
292
293 int
294 sscanview(vp, s) /* get view parameters from string */
295 VIEW *vp;
296 register char *s;
297 {
298 int ac;
299 char *av[4];
300 int na;
301 int nvopts = 0;
302
303 while (*s == ' ')
304 s++;
305 while (*s) {
306 ac = 0;
307 do {
308 av[ac++] = s;
309 while (*s && *s != ' ')
310 s++;
311 while (*s == ' ')
312 s++;
313 } while (*s && ac < 4);
314 if ((na = getviewopt(vp, ac, av)) >= 0) {
315 if (na+1 < ac)
316 s = av[na+1];
317 nvopts++;
318 } else if (ac > 1)
319 s = av[1];
320 }
321 return(nvopts);
322 }
323
324
325 fprintview(vp, fp) /* write out view parameters */
326 register VIEW *vp;
327 FILE *fp;
328 {
329 fprintf(fp, " -vt%c", vp->type);
330 fprintf(fp, " -vp %.6g %.6g %.6g", vp->vp[0], vp->vp[1], vp->vp[2]);
331 fprintf(fp, " -vd %.6g %.6g %.6g", vp->vdir[0], vp->vdir[1], vp->vdir[2]);
332 fprintf(fp, " -vu %.6g %.6g %.6g", vp->vup[0], vp->vup[1], vp->vup[2]);
333 fprintf(fp, " -vh %.6g -vv %.6g", vp->horiz, vp->vert);
334 fprintf(fp, " -vs %.6g -vl %.6g", vp->hoff, vp->voff);
335 }
336
337
338 static VIEW *hview; /* view from header */
339 static int gothview; /* success indicator */
340 static char *altname[] = {NULL,"rpict","rview","pinterp",VIEWSTR,NULL};
341
342
343 static
344 gethview(s) /* get view from header */
345 char *s;
346 {
347 register char **an;
348
349 for (an = altname; *an != NULL; an++)
350 if (!strncmp(*an, s, strlen(*an))) {
351 if (sscanview(hview, s+strlen(*an)) > 0)
352 gothview++;
353 return;
354 }
355 }
356
357
358 int
359 viewfile(fname, vp, xp, yp) /* get view from file */
360 char *fname;
361 VIEW *vp;
362 int *xp, *yp;
363 {
364 extern char *progname;
365 FILE *fp;
366
367 if ((fp = fopen(fname, "r")) == NULL)
368 return(-1);
369
370 altname[0] = progname;
371 hview = vp;
372 gothview = 0;
373
374 getheader(fp, gethview);
375
376 if (xp != NULL && yp != NULL
377 && fgetresolu(xp, yp, fp) == -1)
378 gothview = 0;
379
380 fclose(fp);
381
382 return(gothview);
383 }
