| 1 |
/* RCSid $Id$ */
| 2 |
/* C header file for Hilbert curve functions */
| 3 |
#if !defined(_hilbert_h_)
| 4 |
#define _hilbert_h_
| 5 |
| 6 |
#ifdef __cplusplus
| 7 |
extern "C" {
| 8 |
#endif
| 9 |
| 10 |
/* define the bitmask_t type as an integer of sufficient size */
| 11 |
typedef unsigned long long bitmask_t;
| 12 |
/* define the halfmask_t type as an integer of 1/2 the size of bitmask_t */
| 13 |
typedef unsigned long halfmask_t;
| 14 |
| 15 |
| 16 |
* hilbert_i2c
| 17 |
| 18 |
* Convert an index into a Hilbert curve to a set of coordinates.
| 19 |
* Inputs:
| 20 |
* nDims: Number of coordinate axes.
| 21 |
* nBits: Number of bits per axis.
| 22 |
* index: The index, contains nDims*nBits bits (so nDims*nBits must be <= 8*sizeof(bitmask_t)).
| 23 |
* Outputs:
| 24 |
* coord: The list of nDims coordinates, each with nBits bits.
| 25 |
* Assumptions:
| 26 |
* nDims*nBits <= (sizeof index) * (bits_per_byte)
| 27 |
| 28 |
| 29 |
void hilbert_i2c(unsigned nDims, unsigned nBits, bitmask_t index, bitmask_t coord[]);
| 30 |
| 31 |
| 32 |
* hilbert_c2i
| 33 |
| 34 |
* Convert coordinates of a point on a Hilbert curve to its index.
| 35 |
* Inputs:
| 36 |
* nDims: Number of coordinates.
| 37 |
* nBits: Number of bits/coordinate.
| 38 |
* coord: Array of n nBits-bit coordinates.
| 39 |
* Outputs:
| 40 |
* index: Output index value. nDims*nBits bits.
| 41 |
* Assumptions:
| 42 |
* nDims*nBits <= (sizeof bitmask_t) * (bits_per_byte)
| 43 |
| 44 |
| 45 |
bitmask_t hilbert_c2i(unsigned nDims, unsigned nBits, bitmask_t const coord[]);
| 46 |
| 47 |
| 48 |
* hilbert_cmp, hilbert_ieee_cmp
| 49 |
| 50 |
* Determine which of two points lies further along the Hilbert curve
| 51 |
* Inputs:
| 52 |
| 53 |
* nBytes: Number of bytes of storage/coordinate (hilbert_cmp only)
| 54 |
* nBits: Number of bits/coordinate. (hilbert_cmp only)
| 55 |
* coord1: Array of nDims nBytes-byte coordinates (or doubles for ieee_cmp).
| 56 |
* coord2: Array of nDims nBytes-byte coordinates (or doubles for ieee_cmp).
| 57 |
* Return value:
| 58 |
* -1, 0, or 1 according to whether
| 59 |
coord1<coord2, coord1==coord2, coord1>coord2
| 60 |
* Assumptions:
| 61 |
* nBits <= (sizeof bitmask_t) * (bits_per_byte)
| 62 |
| 63 |
| 64 |
int hilbert_cmp(unsigned nDims, unsigned nBytes, unsigned nBits, void const* coord1, void const* coord2);
| 65 |
int hilbert_ieee_cmp(unsigned nDims, double const* coord1, double const* coord2);
| 66 |
| 67 |
| 68 |
* hilbert_box_vtx
| 69 |
| 70 |
* Determine the first or last vertex of a box to lie on a Hilbert curve
| 71 |
* Inputs:
| 72 |
| 73 |
* nBytes: Number of bytes/coordinate.
| 74 |
* nBits: Number of bits/coordinate. (hilbert_box_vtx only)
| 75 |
* findMin: Is it the least vertex sought?
| 76 |
* coord1: Array of nDims nBytes-byte coordinates - one corner of box
| 77 |
* coord2: Array of nDims nBytes-byte coordinates - opposite corner
| 78 |
* Output:
| 79 |
* c1 and c2 modified to refer to selected corner
| 80 |
* value returned is log2 of size of largest power-of-two-aligned box that
| 81 |
* contains the selected corner and no other corners
| 82 |
* Assumptions:
| 83 |
| 84 |
| 85 |
unsigned
| 86 |
hilbert_box_vtx(unsigned nDims, unsigned nBytes, unsigned nBits,
| 87 |
int findMin, void* c1, void* c2);
| 88 |
unsigned
| 89 |
hilbert_ieee_box_vtx(unsigned nDims,
| 90 |
int findMin, double* c1, double* c2);
| 91 |
| 92 |
| 93 |
* hilbert_box_pt
| 94 |
| 95 |
* Determine the first or last point of a box to lie on a Hilbert curve
| 96 |
* Inputs:
| 97 |
| 98 |
| 99 |
| 100 |
| 101 |
| 102 |
| 103 |
* Output:
| 104 |
* c1 and c2 modified to refer to least point
| 105 |
* Assumptions:
| 106 |
| 107 |
| 108 |
unsigned
| 109 |
hilbert_box_pt(unsigned nDims, unsigned nBytes, unsigned nBits,
| 110 |
int findMin, void* coord1, void* coord2);
| 111 |
unsigned
| 112 |
hilbert_ieee_box_pt(unsigned nDims,
| 113 |
| 114 |
| 115 |
| 116 |
* hilbert_nextinbox
| 117 |
| 118 |
* Determine the first point of a box after a given point to lie on a Hilbert curve
| 119 |
* Inputs:
| 120 |
| 121 |
| 122 |
| 123 |
* findPrev: Is the previous point sought?
| 124 |
| 125 |
| 126 |
* point: Array of nDims nBytes-byte coordinates - lower bound on point returned
| 127 |
| 128 |
* Output:
| 129 |
if returns 1:
| 130 |
* c1 and c2 modified to refer to least point after "point" in box
| 131 |
else returns 0:
| 132 |
arguments unchanged; "point" is beyond the last point of the box
| 133 |
* Assumptions:
| 134 |
| 135 |
| 136 |
int
| 137 |
hilbert_nextinbox(unsigned nDims, unsigned nBytes, unsigned nBits,
| 138 |
int findPrev, void* coord1, void* coord2,
| 139 |
void const* point);
| 140 |
| 141 |
| 142 |
* hilbert_incr
| 143 |
| 144 |
* Advance from one point to its successor on a Hilbert curve
| 145 |
* Inputs:
| 146 |
| 147 |
| 148 |
* coord: Array of nDims nBits-bit coordinates.
| 149 |
* Output:
| 150 |
* coord: Next point on Hilbert curve
| 151 |
* Assumptions:
| 152 |
| 153 |
| 154 |
| 155 |
void
| 156 |
hilbert_incr(unsigned nDims, unsigned nBits, bitmask_t coord[]);
| 157 |
| 158 |
#ifdef __cplusplus
| 159 |
| 160 |
#endif
| 161 |
| 162 |
#endif /* _hilbert_h_ */
