root/radiance/ray/src/common/hilbert.h
Revision: 3.2
Committed: Fri Feb 18 18:41:04 2011 UTC (14 years, 5 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R1, rad4R2P1, rad4R2P2, HEAD
Changes since 3.1: +1 -0 lines
Added missing RCS tags
1 /* RCSid $Id$ */
2 /* C header file for Hilbert curve functions */
3 #if !defined(_hilbert_h_)
4 #define _hilbert_h_
5
6 #ifdef __cplusplus
7 extern "C" {
8 #endif
9
10 /* define the bitmask_t type as an integer of sufficient size */
11 typedef unsigned long long bitmask_t;
12 /* define the halfmask_t type as an integer of 1/2 the size of bitmask_t */
13 typedef unsigned long halfmask_t;
14
15 /*****************************************************************
16 * hilbert_i2c
17 *
18 * Convert an index into a Hilbert curve to a set of coordinates.
19 * Inputs:
20 * nDims: Number of coordinate axes.
21 * nBits: Number of bits per axis.
22 * index: The index, contains nDims*nBits bits (so nDims*nBits must be <= 8*sizeof(bitmask_t)).
23 * Outputs:
24 * coord: The list of nDims coordinates, each with nBits bits.
25 * Assumptions:
26 * nDims*nBits <= (sizeof index) * (bits_per_byte)
27 */
28
29 void hilbert_i2c(unsigned nDims, unsigned nBits, bitmask_t index, bitmask_t coord[]);
30
31 /*****************************************************************
32 * hilbert_c2i
33 *
34 * Convert coordinates of a point on a Hilbert curve to its index.
35 * Inputs:
36 * nDims: Number of coordinates.
37 * nBits: Number of bits/coordinate.
38 * coord: Array of n nBits-bit coordinates.
39 * Outputs:
40 * index: Output index value. nDims*nBits bits.
41 * Assumptions:
42 * nDims*nBits <= (sizeof bitmask_t) * (bits_per_byte)
43 */
44
45 bitmask_t hilbert_c2i(unsigned nDims, unsigned nBits, bitmask_t const coord[]);
46
47 /*****************************************************************
48 * hilbert_cmp, hilbert_ieee_cmp
49 *
50 * Determine which of two points lies further along the Hilbert curve
51 * Inputs:
52 * nDims: Number of coordinates.
53 * nBytes: Number of bytes of storage/coordinate (hilbert_cmp only)
54 * nBits: Number of bits/coordinate. (hilbert_cmp only)
55 * coord1: Array of nDims nBytes-byte coordinates (or doubles for ieee_cmp).
56 * coord2: Array of nDims nBytes-byte coordinates (or doubles for ieee_cmp).
57 * Return value:
58 * -1, 0, or 1 according to whether
59 coord1<coord2, coord1==coord2, coord1>coord2
60 * Assumptions:
61 * nBits <= (sizeof bitmask_t) * (bits_per_byte)
62 */
63
64 int hilbert_cmp(unsigned nDims, unsigned nBytes, unsigned nBits, void const* coord1, void const* coord2);
65 int hilbert_ieee_cmp(unsigned nDims, double const* coord1, double const* coord2);
66
67 /*****************************************************************
68 * hilbert_box_vtx
69 *
70 * Determine the first or last vertex of a box to lie on a Hilbert curve
71 * Inputs:
72 * nDims: Number of coordinates.
73 * nBytes: Number of bytes/coordinate.
74 * nBits: Number of bits/coordinate. (hilbert_box_vtx only)
75 * findMin: Is it the least vertex sought?
76 * coord1: Array of nDims nBytes-byte coordinates - one corner of box
77 * coord2: Array of nDims nBytes-byte coordinates - opposite corner
78 * Output:
79 * c1 and c2 modified to refer to selected corner
80 * value returned is log2 of size of largest power-of-two-aligned box that
81 * contains the selected corner and no other corners
82 * Assumptions:
83 * nBits <= (sizeof bitmask_t) * (bits_per_byte)
84 */
85 unsigned
86 hilbert_box_vtx(unsigned nDims, unsigned nBytes, unsigned nBits,
87 int findMin, void* c1, void* c2);
88 unsigned
89 hilbert_ieee_box_vtx(unsigned nDims,
90 int findMin, double* c1, double* c2);
91
92 /*****************************************************************
93 * hilbert_box_pt
94 *
95 * Determine the first or last point of a box to lie on a Hilbert curve
96 * Inputs:
97 * nDims: Number of coordinates.
98 * nBytes: Number of bytes/coordinate.
99 * nBits: Number of bits/coordinate.
100 * findMin: Is it the least vertex sought?
101 * coord1: Array of nDims nBytes-byte coordinates - one corner of box
102 * coord2: Array of nDims nBytes-byte coordinates - opposite corner
103 * Output:
104 * c1 and c2 modified to refer to least point
105 * Assumptions:
106 * nBits <= (sizeof bitmask_t) * (bits_per_byte)
107 */
108 unsigned
109 hilbert_box_pt(unsigned nDims, unsigned nBytes, unsigned nBits,
110 int findMin, void* coord1, void* coord2);
111 unsigned
112 hilbert_ieee_box_pt(unsigned nDims,
113 int findMin, double* c1, double* c2);
114
115 /*****************************************************************
116 * hilbert_nextinbox
117 *
118 * Determine the first point of a box after a given point to lie on a Hilbert curve
119 * Inputs:
120 * nDims: Number of coordinates.
121 * nBytes: Number of bytes/coordinate.
122 * nBits: Number of bits/coordinate.
123 * findPrev: Is the previous point sought?
124 * coord1: Array of nDims nBytes-byte coordinates - one corner of box
125 * coord2: Array of nDims nBytes-byte coordinates - opposite corner
126 * point: Array of nDims nBytes-byte coordinates - lower bound on point returned
127 *
128 * Output:
129 if returns 1:
130 * c1 and c2 modified to refer to least point after "point" in box
131 else returns 0:
132 arguments unchanged; "point" is beyond the last point of the box
133 * Assumptions:
134 * nBits <= (sizeof bitmask_t) * (bits_per_byte)
135 */
136 int
137 hilbert_nextinbox(unsigned nDims, unsigned nBytes, unsigned nBits,
138 int findPrev, void* coord1, void* coord2,
139 void const* point);
140
141 /*****************************************************************
142 * hilbert_incr
143 *
144 * Advance from one point to its successor on a Hilbert curve
145 * Inputs:
146 * nDims: Number of coordinates.
147 * nBits: Number of bits/coordinate.
148 * coord: Array of nDims nBits-bit coordinates.
149 * Output:
150 * coord: Next point on Hilbert curve
151 * Assumptions:
152 * nBits <= (sizeof bitmask_t) * (bits_per_byte)
153 */
154
155 void
156 hilbert_incr(unsigned nDims, unsigned nBits, bitmask_t coord[]);
157
158 #ifdef __cplusplus
159 }
160 #endif
161
162 #endif /* _hilbert_h_ */
