1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: hilbert.c,v 3.2 2011/02/18 18:41:04 greg Exp $"; |
3 |
#endif |
4 |
/* See LICENSE below for information on rights to use, modify and distribute |
5 |
this code. */ |
6 |
7 |
8 |
* hilbert.c - Computes Hilbert space-filling curve coordinates, without |
9 |
* recursion, from integer index, and vice versa, and other Hilbert-related |
10 |
* calculations. Also known as Pi-order or Peano scan. |
11 |
12 |
* Author: Doug Moore |
13 |
* Dept. of Computational and Applied Math |
14 |
* Rice University |
15 |
* http://www.caam.rice.edu/~dougm |
16 |
* Date: Sun Feb 20 2000 |
17 |
* Copyright (c) 1998-2000, Rice University |
18 |
19 |
* Acknowledgement: |
20 |
* This implementation is based on the work of A. R. Butz ("Alternative |
21 |
* Algorithm for Hilbert's Space-Filling Curve", IEEE Trans. Comp., April, |
22 |
* 1971, pp 424-426) and its interpretation by Spencer W. Thomas, University |
23 |
* of Michigan (http://www-personal.umich.edu/~spencer/Home.html) in his widely |
24 |
* available C software. While the implementation here differs considerably |
25 |
* from his, the first two interfaces and the style of some comments are very |
26 |
* much derived from his work. */ |
27 |
28 |
#include <stdlib.h> |
29 |
#include "hilbert.h" |
30 |
31 |
/* implementation of the hilbert functions */ |
32 |
33 |
#define adjust_rotation(rotation,nDims,bits) \ |
34 |
do { \ |
35 |
/* rotation = (rotation + 1 + ffs(bits)) % nDims; */ \ |
36 |
bits &= -bits & nd1Ones; \ |
37 |
while (bits) \ |
38 |
bits >>= 1, ++rotation; \ |
39 |
if ( ++rotation >= nDims ) \ |
40 |
rotation -= nDims; \ |
41 |
} while (0) |
42 |
43 |
#define ones(T,k) ((((T)2) << (k-1)) - 1) |
44 |
45 |
#define rdbit(w,k) (((w) >> (k)) & 1) |
46 |
47 |
#define rotateRight(arg, nRots, nDims) \ |
48 |
((((arg) >> (nRots)) | ((arg) << ((nDims)-(nRots)))) & ones(bitmask_t,nDims)) |
49 |
50 |
#define rotateLeft(arg, nRots, nDims) \ |
51 |
((((arg) << (nRots)) | ((arg) >> ((nDims)-(nRots)))) & ones(bitmask_t,nDims)) |
52 |
53 |
#define DLOGB_BIT_TRANSPOSE |
54 |
static bitmask_t |
55 |
bitTranspose(unsigned nDims, unsigned nBits, bitmask_t inCoords) |
56 |
#if defined(DLOGB_BIT_TRANSPOSE) |
57 |
58 |
unsigned const nDims1 = nDims-1; |
59 |
unsigned inB = nBits; |
60 |
unsigned utB; |
61 |
bitmask_t inFieldEnds = 1; |
62 |
bitmask_t inMask = ones(bitmask_t,inB); |
63 |
bitmask_t coords = 0; |
64 |
65 |
while ((utB = inB >> 1)) |
66 |
67 |
unsigned const shiftAmt = nDims1 * utB; |
68 |
bitmask_t const utFieldEnds = |
69 |
inFieldEnds | (inFieldEnds << (shiftAmt+utB)); |
70 |
bitmask_t const utMask = |
71 |
(utFieldEnds << utB) - utFieldEnds; |
72 |
bitmask_t utCoords = 0; |
73 |
unsigned d; |
74 |
if (inB & 1) |
75 |
76 |
bitmask_t const inFieldStarts = inFieldEnds << (inB-1); |
77 |
unsigned oddShift = 2*shiftAmt; |
78 |
for (d = 0; d < nDims; ++d) |
79 |
80 |
bitmask_t in = inCoords & inMask; |
81 |
inCoords >>= inB; |
82 |
coords |= (in & inFieldStarts) << oddShift++; |
83 |
in &= ~inFieldStarts; |
84 |
in = (in | (in << shiftAmt)) & utMask; |
85 |
utCoords |= in << (d*utB); |
86 |
87 |
88 |
else |
89 |
90 |
91 |
92 |
93 |
inCoords >>= inB; |
94 |
95 |
96 |
97 |
98 |
inCoords = utCoords; |
99 |
inB = utB; |
100 |
inFieldEnds = utFieldEnds; |
101 |
inMask = utMask; |
102 |
103 |
coords |= inCoords; |
104 |
return coords; |
105 |
106 |
#else |
107 |
108 |
109 |
unsigned d; |
110 |
111 |
112 |
unsigned b; |
113 |
bitmask_t in = inCoords & ones(bitmask_t,nBits); |
114 |
bitmask_t out = 0; |
115 |
inCoords >>= nBits; |
116 |
for (b = nBits; b--;) |
117 |
118 |
out <<= nDims; |
119 |
out |= rdbit(in, b); |
120 |
121 |
coords |= out << d; |
122 |
123 |
return coords; |
124 |
125 |
#endif |
126 |
127 |
128 |
* hilbert_i2c |
129 |
130 |
* Convert an index into a Hilbert curve to a set of coordinates. |
131 |
* Inputs: |
132 |
* nDims: Number of coordinate axes. |
133 |
* nBits: Number of bits per axis. |
134 |
* index: The index, contains nDims*nBits bits |
135 |
* (so nDims*nBits must be <= 8*sizeof(bitmask_t)). |
136 |
* Outputs: |
137 |
* coord: The list of nDims coordinates, each with nBits bits. |
138 |
* Assumptions: |
139 |
* nDims*nBits <= (sizeof index) * (bits_per_byte) |
140 |
141 |
void |
142 |
hilbert_i2c(unsigned nDims, unsigned nBits, bitmask_t index, bitmask_t coord[]) |
143 |
144 |
if (nDims > 1) |
145 |
146 |
bitmask_t coords; |
147 |
halfmask_t const nbOnes = ones(halfmask_t,nBits); |
148 |
unsigned d; |
149 |
150 |
if (nBits > 1) |
151 |
152 |
unsigned const nDimsBits = nDims*nBits; |
153 |
halfmask_t const ndOnes = ones(halfmask_t,nDims); |
154 |
halfmask_t const nd1Ones= ndOnes >> 1; /* for adjust_rotation */ |
155 |
unsigned b = nDimsBits; |
156 |
unsigned rotation = 0; |
157 |
halfmask_t flipBit = 0; |
158 |
bitmask_t const nthbits = ones(bitmask_t,nDimsBits) / ndOnes; |
159 |
index ^= (index ^ nthbits) >> 1; |
160 |
coords = 0; |
161 |
do |
162 |
163 |
halfmask_t bits = (index >> (b-=nDims)) & ndOnes; |
164 |
coords <<= nDims; |
165 |
coords |= rotateLeft(bits, rotation, nDims) ^ flipBit; |
166 |
flipBit = (halfmask_t)1 << rotation; |
167 |
adjust_rotation(rotation,nDims,bits); |
168 |
} while (b); |
169 |
for (b = nDims; b < nDimsBits; b *= 2) |
170 |
coords ^= coords >> b; |
171 |
coords = bitTranspose(nBits, nDims, coords); |
172 |
173 |
else |
174 |
coords = index ^ (index >> 1); |
175 |
176 |
177 |
178 |
coord[d] = coords & nbOnes; |
179 |
coords >>= nBits; |
180 |
181 |
182 |
else |
183 |
coord[0] = index; |
184 |
185 |
186 |
187 |
* hilbert_c2i |
188 |
189 |
* Convert coordinates of a point on a Hilbert curve to its index. |
190 |
* Inputs: |
191 |
* nDims: Number of coordinates. |
192 |
* nBits: Number of bits/coordinate. |
193 |
* coord: Array of n nBits-bit coordinates. |
194 |
* Outputs: |
195 |
* index: Output index value. nDims*nBits bits. |
196 |
* Assumptions: |
197 |
* nDims*nBits <= (sizeof bitmask_t) * (bits_per_byte) |
198 |
199 |
bitmask_t |
200 |
hilbert_c2i(unsigned nDims, unsigned nBits, bitmask_t const coord[]) |
201 |
202 |
if (nDims > 1) |
203 |
204 |
205 |
bitmask_t index; |
206 |
unsigned d; |
207 |
208 |
for (d = nDims; d--; ) |
209 |
210 |
coords <<= nBits; |
211 |
coords |= coord[d]; |
212 |
213 |
214 |
if (nBits > 1) |
215 |
216 |
217 |
218 |
219 |
220 |
221 |
222 |
coords = bitTranspose(nDims, nBits, coords); |
223 |
coords ^= coords >> nDims; |
224 |
index = 0; |
225 |
do |
226 |
227 |
halfmask_t bits = (coords >> (b-=nDims)) & ndOnes; |
228 |
bits = rotateRight(flipBit ^ bits, rotation, nDims); |
229 |
index <<= nDims; |
230 |
index |= bits; |
231 |
232 |
233 |
} while (b); |
234 |
index ^= nthbits >> 1; |
235 |
236 |
else |
237 |
index = coords; |
238 |
for (d = 1; d < nDimsBits; d *= 2) |
239 |
index ^= index >> d; |
240 |
return index; |
241 |
242 |
else |
243 |
return coord[0]; |
244 |
245 |
246 |
247 |
* Readers and writers of bits |
248 |
249 |
250 |
typedef bitmask_t (*BitReader) (unsigned nDims, unsigned nBytes, |
251 |
char const* c, unsigned y); |
252 |
typedef void (*BitWriter) (unsigned d, unsigned nBytes, |
253 |
char* c, unsigned y, int fold); |
254 |
255 |
256 |
#if defined(sparc) |
257 |
#define __BIG_ENDIAN__ |
258 |
#endif |
259 |
260 |
#if defined(__BIG_ENDIAN__) |
261 |
#define whichByte(nBytes,y) (nBytes-1-y/8) |
262 |
#define setBytes(dst,pos,nBytes,val) \ |
263 |
memset(&dst[pos+1],val,nBytes-pos-1) |
264 |
#else |
265 |
#define whichByte(nBytes,y) (y/8) |
266 |
267 |
memset(&dst[0],val,pos) |
268 |
#endif |
269 |
270 |
static bitmask_t |
271 |
getIntBits(unsigned nDims, unsigned nBytes, char const* c, unsigned y) |
272 |
273 |
unsigned const bit = y%8; |
274 |
unsigned const offs = whichByte(nBytes,y); |
275 |
unsigned d; |
276 |
bitmask_t bits = 0; |
277 |
c += offs; |
278 |
279 |
280 |
bits |= rdbit(*c, bit) << d; |
281 |
c += nBytes; |
282 |
283 |
return bits; |
284 |
285 |
286 |
#include <string.h> |
287 |
static void |
288 |
propogateIntBits(unsigned d, unsigned nBytes, |
289 |
char* c, unsigned y, int fold) |
290 |
291 |
unsigned const byteId = whichByte(nBytes,y); |
292 |
unsigned const b = y%8; |
293 |
char const bthbit = 1 << b; |
294 |
char* const target = &c[d*nBytes]; |
295 |
target[byteId] ^= bthbit; |
296 |
if (!fold) |
297 |
298 |
char notbit = ((target[byteId] >> b) & 1) - 1; |
299 |
if (notbit) |
300 |
target[byteId] |= bthbit-1; |
301 |
else |
302 |
target[byteId] &= -bthbit; |
303 |
setBytes(target,byteId,nBytes,notbit); |
304 |
305 |
306 |
307 |
/* An IEEE double is treated as a 2100 bit number. In particular, 0 is treated |
308 |
as a 1 followed by 2099 zeroes, and negative 0 as a 0 followed by 2099 ones. |
309 |
Only 53 bits differ between a number and a zero of the same sign, with the |
310 |
position of the 53 determined by the exponent, and the values of the 53 by |
311 |
the significand (with implicit leading 1 bit). Although IEEE 754 uses the |
312 |
maximum exponent for NaN's and infinities, this implementation ignores that |
313 |
decision, so that infinities and NaN's are treated as very large numbers. |
314 |
Note that we do not explicitly construct a 2100 bit bitmask in the IEEE |
315 |
routines below. */ |
316 |
317 |
enum { IEEEexpBits = 11 }; |
318 |
enum { IEEEsigBits = 52 }; |
319 |
enum { IEEErepBits = (1 << IEEEexpBits) + IEEEsigBits }; |
320 |
321 |
typedef union ieee754_double |
322 |
323 |
double d; |
324 |
325 |
/* This is the IEEE 754 double-precision format. */ |
326 |
struct |
327 |
328 |
329 |
unsigned int negative:1; |
330 |
unsigned int exponent:11; |
331 |
/* Together these comprise the mantissa. */ |
332 |
unsigned int mantissa0:20; |
333 |
unsigned int mantissa1:32; |
334 |
#else /* Big endian. */ |
335 |
336 |
337 |
338 |
339 |
340 |
#endif /* Little endian. */ |
341 |
} ieee; |
342 |
} ieee754_double; |
343 |
344 |
static bitmask_t |
345 |
getIEEESignBits(unsigned nDims, double const* c) |
346 |
347 |
unsigned d; |
348 |
ieee754_double x; |
349 |
350 |
351 |
352 |
x.d = c[d]; |
353 |
bits |= x.ieee.negative << d; |
354 |
355 |
return bits; |
356 |
357 |
358 |
static bitmask_t |
359 |
getIEEEBits(unsigned nDims, |
360 |
unsigned ignoreMe, /* ignored */ |
361 |
char const* cP, |
362 |
unsigned y) |
363 |
/* retrieve bits y of elements of double array c, where an expanded IEEE |
364 |
double has 2100 bits. */ |
365 |
366 |
unsigned d; |
367 |
double const* c = (double const*) cP; |
368 |
ieee754_double x; |
369 |
370 |
for (x.d = c[d=0]; d < nDims; x.d = c[++d]) |
371 |
372 |
bitmask_t bit = x.ieee.negative; |
373 |
unsigned normalized = (x.ieee.exponent != 0); |
374 |
unsigned diff = y - (x.ieee.exponent - normalized); |
375 |
if (diff <= 52) |
376 |
bit ^= 1 & ((diff < 32)? x.ieee.mantissa1 >> diff: |
377 |
(diff < 52)? x.ieee.mantissa0 >> (diff - 32): |
378 |
/* else */ normalized); |
379 |
else |
380 |
bit ^= (y == IEEErepBits-1); |
381 |
382 |
bits |= bit << d; |
383 |
384 |
return bits; |
385 |
386 |
387 |
static void |
388 |
propogateIEEEBits(unsigned d, unsigned nBytes, |
389 |
char* cP, unsigned y, int fold) |
390 |
391 |
ieee754_double* x = d + (ieee754_double*) cP; |
392 |
unsigned normalized = (x->ieee.exponent != 0); |
393 |
unsigned diff = y - (x->ieee.exponent - normalized); |
394 |
if (diff < 32) |
395 |
396 |
unsigned b = 1 << diff; |
397 |
unsigned bit = x->ieee.mantissa1 & b; |
398 |
x->ieee.mantissa1 &= ~(b-1); |
399 |
x->ieee.mantissa1 |= b; |
400 |
if (bit) |
401 |
--x->ieee.mantissa1; |
402 |
403 |
else if (diff < 52) |
404 |
405 |
unsigned b = 1 << (diff - 32); |
406 |
unsigned bit = x->ieee.mantissa0 & b; |
407 |
x->ieee.mantissa0 &= ~(b-1); |
408 |
x->ieee.mantissa0 |= b; |
409 |
if (bit) |
410 |
--x->ieee.mantissa0; |
411 |
x->ieee.mantissa1 = bit?-1: 0; |
412 |
413 |
else if (diff == 52) /* "flip" the implicit 1 bit */ |
414 |
415 |
if (normalized) |
416 |
--x->ieee.exponent; |
417 |
else |
418 |
x->ieee.exponent = 1; |
419 |
x->ieee.mantissa0 = -normalized; |
420 |
x->ieee.mantissa1 = -normalized; |
421 |
422 |
else if (diff < IEEErepBits) |
423 |
424 |
if (y == IEEErepBits-1) |
425 |
426 |
x->ieee.negative ^= 1; |
427 |
x->ieee.exponent = 0; |
428 |
429 |
else |
430 |
x->ieee.exponent = y - 51; |
431 |
x->ieee.mantissa0 = 0; |
432 |
x->ieee.mantissa1 = 0; |
433 |
434 |
435 |
436 |
static unsigned |
437 |
getIEEEexptMax(unsigned nDims, double const* c) |
438 |
439 |
unsigned max = 0; |
440 |
unsigned d; |
441 |
442 |
443 |
ieee754_double x; |
444 |
x.d = c[d]; |
445 |
if (max < x.ieee.exponent) |
446 |
max = x.ieee.exponent; |
447 |
448 |
if (max) --max; |
449 |
return max; |
450 |
451 |
452 |
static void |
453 |
getIEEEinitValues(double const* c1, |
454 |
unsigned y, |
455 |
unsigned nDims, |
456 |
unsigned* rotation, |
457 |
bitmask_t* bits, |
458 |
bitmask_t* index) |
459 |
460 |
bitmask_t const one = 1; |
461 |
unsigned d; |
462 |
bitmask_t signBits = getIEEESignBits(nDims, c1); |
463 |
unsigned signParity, leastZeroBit, strayBit; |
464 |
465 |
/* compute the odd/evenness of the number of sign bits */ |
466 |
467 |
bitmask_t signPar = signBits; |
468 |
for (d = 1; d < nDims; d *= 2) |
469 |
signPar ^= signPar >> d; |
470 |
signParity = signPar & 1; |
471 |
472 |
473 |
/* find the position of the least-order 0 bit in among signBits and adjust it |
474 |
if necessary */ |
475 |
for (leastZeroBit = 0; leastZeroBit < nDims; ++leastZeroBit) |
476 |
if (rdbit(signBits, leastZeroBit) == 0) |
477 |
break; |
478 |
strayBit = 0; |
479 |
if (leastZeroBit == nDims-2) |
480 |
strayBit = 1; |
481 |
else if (leastZeroBit == nDims) |
482 |
leastZeroBit = nDims-1; |
483 |
484 |
if (y % 2 == 1) |
485 |
486 |
*rotation = (IEEErepBits - y + 1 + leastZeroBit) % nDims; |
487 |
if (y < IEEErepBits-1) |
488 |
489 |
*bits = signBits ^ (one << ((*rotation + strayBit) % nDims)); |
490 |
*index = signParity; |
491 |
492 |
else /* y == IEEErepBits-1 */ |
493 |
494 |
*bits = signBits ^ (ones(bitmask_t,nDims) &~ 1); |
495 |
*index = signParity ^ (nDims&1); |
496 |
497 |
498 |
else /* y % 2 == 0 */ |
499 |
if (y < IEEErepBits) |
500 |
501 |
unsigned shift_amt = (IEEErepBits - y + leastZeroBit) % nDims; |
502 |
*rotation = (shift_amt + 2 + strayBit) % nDims; |
503 |
*bits = signBits ^ (one << shift_amt); |
504 |
*index = signParity ^ 1; |
505 |
506 |
else /* y == IEEErepBits */ |
507 |
508 |
*rotation = 0; |
509 |
*bits = one << (nDims-1); |
510 |
*index = 1; |
511 |
512 |
513 |
514 |
515 |
* hilbert_cmp, hilbert_ieee_cmp |
516 |
517 |
* Determine which of two points lies further along the Hilbert curve |
518 |
* Inputs: |
519 |
520 |
* nBytes: Number of bytes of storage/coordinate (hilbert_cmp only) |
521 |
* nBits: Number of bits/coordinate. (hilbert_cmp only) |
522 |
* coord1: Array of nDims nBytes-byte coordinates (or doubles for ieee_cmp). |
523 |
* coord2: Array of nDims nBytes-byte coordinates (or doubles for ieee_cmp). |
524 |
* Return value: |
525 |
* -1, 0, or 1 according to whether |
526 |
coord1<coord2, coord1==coord2, coord1>coord2 |
527 |
* Assumptions: |
528 |
* nBits <= (sizeof bitmask_t) * (bits_per_byte) |
529 |
530 |
531 |
static int |
532 |
hilbert_cmp_work(unsigned nDims, unsigned nBytes, unsigned nBits, |
533 |
unsigned max, unsigned y, |
534 |
char const* c1, char const* c2, |
535 |
unsigned rotation, |
536 |
bitmask_t bits, |
537 |
bitmask_t index, |
538 |
BitReader getBits) |
539 |
540 |
541 |
bitmask_t const nd1Ones = ones(bitmask_t,nDims) >> 1; /* used in adjust_rotation macro */ |
542 |
while (y-- > max) |
543 |
544 |
bitmask_t reflection = getBits(nDims, nBytes, c1, y); |
545 |
bitmask_t diff = reflection ^ getBits(nDims, nBytes, c2, y); |
546 |
bits ^= reflection; |
547 |
bits = rotateRight(bits, rotation, nDims); |
548 |
if (diff) |
549 |
550 |
unsigned d; |
551 |
diff = rotateRight(diff, rotation, nDims); |
552 |
553 |
554 |
555 |
bits ^= bits >> d; |
556 |
diff ^= diff >> d; |
557 |
558 |
return (((index ^ y ^ nBits) & 1) == (bits < (bits^diff)))? -1: 1; |
559 |
560 |
index ^= bits; |
561 |
reflection ^= one << rotation; |
562 |
563 |
bits = reflection; |
564 |
565 |
return 0; |
566 |
567 |
568 |
int |
569 |
hilbert_cmp(unsigned nDims, unsigned nBytes, unsigned nBits, |
570 |
void const* c1, void const* c2) |
571 |
572 |
573 |
bitmask_t bits = one << (nDims-1); |
574 |
return hilbert_cmp_work(nDims, nBytes, nBits, 0, nBits, |
575 |
(char const*)c1, (char const*)c2, |
576 |
0, bits, bits, getIntBits); |
577 |
578 |
579 |
int |
580 |
hilbert_ieee_cmp(unsigned nDims, double const* c1, double const* c2) |
581 |
582 |
unsigned rotation, max; |
583 |
bitmask_t bits, index; |
584 |
if (getIEEESignBits(nDims, c1) != getIEEESignBits(nDims, c2)) |
585 |
max = 2047; |
586 |
else |
587 |
588 |
unsigned max1 = getIEEEexptMax(nDims, c1); |
589 |
unsigned max2 = getIEEEexptMax(nDims, c2); |
590 |
max = (max1 > max2)? max1: max2; |
591 |
592 |
593 |
getIEEEinitValues(c1, max+53, nDims, &rotation, &bits, &index); |
594 |
return hilbert_cmp_work(nDims, 8, 64, max, max+53, |
595 |
596 |
rotation, bits, index, getIEEEBits); |
597 |
598 |
599 |
600 |
* hilbert_box_vtx |
601 |
602 |
* Determine the first or last vertex of a box to lie on a Hilbert curve |
603 |
* Inputs: |
604 |
605 |
* nBytes: Number of bytes/coordinate. |
606 |
607 |
* findMin: Is it the least vertex sought? |
608 |
* coord1: Array of nDims nBytes-byte coordinates - one corner of box |
609 |
* coord2: Array of nDims nBytes-byte coordinates - opposite corner |
610 |
* Output: |
611 |
* c1 and c2 modified to refer to selected corner |
612 |
* value returned is log2 of size of largest power-of-two-aligned box that |
613 |
* contains the selected corner and no other corners |
614 |
* Assumptions: |
615 |
616 |
617 |
618 |
619 |
static unsigned |
620 |
hilbert_box_vtx_work(unsigned nDims, unsigned nBytes, unsigned nBits, |
621 |
int findMin, |
622 |
623 |
char* c1, char* c2, |
624 |
625 |
bitmask_t bits, |
626 |
bitmask_t index, |
627 |
628 |
629 |
630 |
bitmask_t const ndOnes = ones(bitmask_t,nDims); |
631 |
bitmask_t const nd1Ones= ndOnes >> 1; |
632 |
bitmask_t bitsFolded = 0; |
633 |
634 |
while (y--) |
635 |
636 |
637 |
638 |
if (diff) |
639 |
640 |
unsigned d; |
641 |
bitmask_t smear = rotateRight(diff, rotation, nDims) >> 1; |
642 |
bitmask_t digit = rotateRight(bits ^ reflection, rotation, nDims); |
643 |
644 |
645 |
646 |
digit ^= (digit >> d) &~ smear; |
647 |
smear |= smear >> d; |
648 |
649 |
index &= 1; |
650 |
if ((index ^ y ^ findMin) & 1) |
651 |
digit ^= smear+1; |
652 |
digit = rotateLeft(digit, rotation, nDims) & diff; |
653 |
reflection ^= digit; |
654 |
655 |
656 |
if (rdbit(diff, d)) |
657 |
658 |
int way = rdbit(digit, d); |
659 |
char* target = d*nBytes + (way? c1: c2); |
660 |
char* const source = 2*d*nBytes + c1 - target + c2; |
661 |
memcpy(target, source, nBytes); |
662 |
663 |
664 |
bitsFolded |= diff; |
665 |
if (bitsFolded == ndOnes) |
666 |
return y; |
667 |
668 |
669 |
670 |
671 |
index ^= bits; |
672 |
673 |
674 |
675 |
676 |
return y; |
677 |
678 |
679 |
unsigned |
680 |
hilbert_box_vtx(unsigned nDims, unsigned nBytes, unsigned nBits, |
681 |
int findMin, void* c1, void* c2) |
682 |
683 |
684 |
685 |
return hilbert_box_vtx_work(nDims, nBytes, nBits, findMin, |
686 |
0, nBits, (char*)c1, (char*)c2, |
687 |
688 |
689 |
690 |
unsigned |
691 |
hilbert_ieee_box_vtx(unsigned nDims, |
692 |
int findMin, double* c1, double* c2) |
693 |
694 |
695 |
696 |
697 |
max = 2047; |
698 |
else |
699 |
700 |
701 |
702 |
703 |
704 |
705 |
706 |
707 |
return hilbert_box_vtx_work(nDims, 8, 64, findMin, |
708 |
max, max+53, (char *)c1, (char *)c2, |
709 |
710 |
711 |
712 |
713 |
* hilbert_box_pt |
714 |
715 |
* Determine the first or last point of a box to lie on a Hilbert curve |
716 |
* Inputs: |
717 |
718 |
719 |
720 |
721 |
722 |
723 |
* Output: |
724 |
* c1 and c2 modified to refer to least point |
725 |
* Assumptions: |
726 |
727 |
728 |
unsigned |
729 |
hilbert_box_pt_work(unsigned nDims, unsigned nBytes, unsigned nBits, |
730 |
int findMin, |
731 |
732 |
733 |
734 |
bitmask_t bits, |
735 |
bitmask_t index, |
736 |
BitReader getBits, |
737 |
BitWriter propogateBits) |
738 |
739 |
740 |
bitmask_t const nd1Ones = ones(bitmask_t,nDims) >> 1; |
741 |
bitmask_t fold1 = 0, fold2 = 0; |
742 |
unsigned smearSum = 0; |
743 |
744 |
while (y-- > max) |
745 |
746 |
747 |
748 |
if (diff) |
749 |
750 |
751 |
752 |
unsigned d; |
753 |
754 |
755 |
756 |
757 |
758 |
759 |
smearSum += smear; |
760 |
index &= 1; |
761 |
762 |
digit ^= smear+1; |
763 |
764 |
765 |
766 |
767 |
768 |
769 |
770 |
char* c = way? c1: c2; |
771 |
bitmask_t fold = way? fold1: fold2; |
772 |
propogateBits(d, nBytes, c, y, rdbit(fold, d)); |
773 |
774 |
diff ^= digit; |
775 |
fold1 |= digit; |
776 |
fold2 |= diff; |
777 |
778 |
779 |
780 |
781 |
index ^= bits; |
782 |
783 |
784 |
785 |
786 |
return smearSum; |
787 |
788 |
789 |
unsigned |
790 |
hilbert_box_pt(unsigned nDims, unsigned nBytes, unsigned nBits, |
791 |
792 |
793 |
794 |
795 |
return hilbert_box_pt_work(nDims, nBytes, nBits, findMin, |
796 |
797 |
0, bits, bits, |
798 |
getIntBits, propogateIntBits); |
799 |
800 |
801 |
unsigned |
802 |
hilbert_ieee_box_pt(unsigned nDims, |
803 |
804 |
805 |
806 |
807 |
bitmask_t c1Signs = getIEEESignBits(nDims, c1); |
808 |
bitmask_t c2Signs = getIEEESignBits(nDims, c2); |
809 |
if (c1Signs != c2Signs) |
810 |
811 |
rotation = 0; |
812 |
bits = (bitmask_t)1 << (nDims-1); |
813 |
index = 1; |
814 |
hilbert_box_pt_work(nDims, 8, 64, findMin, |
815 |
IEEErepBits-1, IEEErepBits, (char *)c1, (char *)c2, |
816 |
rotation, bits, index, |
817 |
getIEEEBits, propogateIEEEBits); |
818 |
819 |
820 |
/* having put everything in the same orthant, start */ |
821 |
822 |
823 |
824 |
825 |
826 |
827 |
828 |
829 |
return hilbert_box_pt_work(nDims, 8, 64, findMin, |
830 |
831 |
832 |
833 |
834 |
835 |
836 |
* hilbert_nextinbox |
837 |
838 |
* Determine the first point of a box after or before a given point to lie on |
839 |
* a Hilbert curve |
840 |
* Inputs: |
841 |
842 |
843 |
844 |
* findPrev: Is it a previous point that you want? |
845 |
846 |
847 |
* point: Array of nDims nBytes-byte coordinates - lower bound on point returned |
848 |
849 |
* Output: |
850 |
if returns 1: |
851 |
* c1 and c2 modified to refer to least point after "point" in box |
852 |
else returns 0: |
853 |
arguments unchanged; "point" is beyond the last point of the box |
854 |
* Assumptions: |
855 |
856 |
857 |
int |
858 |
hilbert_nextinbox(unsigned nDims, unsigned nBytes, unsigned nBits, |
859 |
int findPrev, void* c1V, void* c2V, void const* ptV) |
860 |
861 |
862 |
unsigned y = nBits; |
863 |
864 |
bitmask_t const nd1Ones = ndOnes >> 1; |
865 |
866 |
867 |
bitmask_t index = 0; |
868 |
869 |
bitmask_t valu1 = 0, valu2 = 0; |
870 |
unsigned p_y; |
871 |
bitmask_t p_separator = 0, p_firstSeparator; |
872 |
bitmask_t p_cornerdiff, p_reflection; |
873 |
bitmask_t p_fold1, p_fold2, p_valu1, p_valu2; |
874 |
875 |
char* c1 = (char*)c1V; |
876 |
char* c2 = (char*)c2V; |
877 |
char const* pt = (const char*)ptV; |
878 |
879 |
while (y-- > 0) |
880 |
881 |
bitmask_t reflection = getIntBits(nDims, nBytes, pt, y); |
882 |
bitmask_t diff = reflection ^ /* planes that separate box and point */ |
883 |
((getIntBits(nDims, nBytes, c1, y) &~ fold1) | valu1); |
884 |
885 |
if (diff) |
886 |
/* some coordinate planes separate point from box or |
887 |
dividing box or both; smear the bits of diff to reflect that |
888 |
after the first diff dimension, they might as well all be |
889 |
diffing; adjust the diff to reflect the fact that diffed |
890 |
dimensions don't matter. */ |
891 |
892 |
/* compute (the complement of) a "digit" in the integer index of this |
893 |
point */ |
894 |
bitmask_t cornerdiff = (diff ^ reflection) ^ /* separate box crnrs */ |
895 |
((getIntBits(nDims, nBytes, c2, y) &~ fold2) | valu2); |
896 |
bitmask_t separator = diff & ~cornerdiff; |
897 |
/* eventually, the most significant separating cutting plane */ |
898 |
bitmask_t firstSeparator; |
899 |
/* bits less significant than the msb of separator are irrelevant; |
900 |
for convenience, call them all separators too */ |
901 |
bitmask_t rotSep = rotateRight(separator, rotation, nDims); |
902 |
/* compute the (complement of the) digit of the hilbert code |
903 |
assoc with point */ |
904 |
905 |
unsigned d; |
906 |
907 |
908 |
909 |
digit ^= digit >> d; |
910 |
rotSep |= rotSep >> d; |
911 |
912 |
index &= 1; |
913 |
digit &= rotSep; |
914 |
if ((index ^ y ^ findPrev) & 1) |
915 |
digit ^= rotSep; |
916 |
917 |
separator = rotateLeft(rotSep, rotation, nDims); |
918 |
rotSep -= rotSep >> 1; |
919 |
firstSeparator = rotateLeft(rotSep, rotation, nDims); |
920 |
/* forget about all the planes that split the box, except those that |
921 |
are more significant than the most significant separator. */ |
922 |
cornerdiff &= ~separator; |
923 |
924 |
if (cornerdiff && digit) |
925 |
/* some coordinate planes divide the box. Call the part of the |
926 |
box in the same orthant as the point "here" and the part of |
927 |
the box in the next (or previous) orthant "there". Remember |
928 |
what the "there" orthant of the box looks like in case it |
929 |
turns out that the curve doesn't reenter the box "here" after |
930 |
(before) passing thru point. Continue working with the |
931 |
"here" part. If there is no "there" there, skip it */ |
932 |
933 |
p_firstSeparator = digit & -digit; |
934 |
p_separator = 2*p_firstSeparator-1; |
935 |
p_separator = rotateLeft(p_separator, rotation, nDims); |
936 |
p_firstSeparator = rotateLeft(p_firstSeparator, rotation, nDims); |
937 |
p_cornerdiff = cornerdiff &~ (p_separator ^ p_firstSeparator); |
938 |
p_y = y; |
939 |
p_reflection = reflection ^ p_firstSeparator; |
940 |
p_fold1 = fold1; |
941 |
p_fold2 = fold2; |
942 |
p_valu1 = valu1; |
943 |
p_valu2 = valu2; |
944 |
945 |
946 |
if (digit < rotSep) |
947 |
948 |
/* use next box */ |
949 |
950 |
if (!p_separator) return 0; /* no next point */ |
951 |
separator = p_separator; |
952 |
firstSeparator = p_firstSeparator; |
953 |
y = p_y; |
954 |
cornerdiff = p_cornerdiff; |
955 |
reflection = p_reflection; |
956 |
fold1 = p_fold1; |
957 |
fold2 = p_fold2; |
958 |
valu1 = p_valu1; |
959 |
valu2 = p_valu2; |
960 |
961 |
962 |
if (cornerdiff) |
963 |
964 |
/* reduce currbox */ |
965 |
bitmask_t corner = diff & cornerdiff; |
966 |
cornerdiff ^= corner; |
967 |
fold1 |= corner; |
968 |
fold2 |= cornerdiff; |
969 |
valu1 |= ~reflection & corner; |
970 |
valu2 |= ~reflection & cornerdiff; |
971 |
972 |
973 |
separator ^= firstSeparator; |
974 |
if (firstSeparator) |
975 |
/* we have completely separated the point from a part of the box |
976 |
ahead of it on the curve; almost done */ |
977 |
978 |
unsigned byteId = whichByte(nBytes,y); |
979 |
bitmask_t bthbit = one << y%8; |
980 |
981 |
982 |
char lo1, lo2; |
983 |
char* cc1 = &c1[d*nBytes]; |
984 |
char* cc2 = &c2[d*nBytes]; |
985 |
char const* pnt = &pt[d*nBytes]; |
986 |
char hibits = -bthbit; |
987 |
char hipart = pnt[byteId] & hibits; |
988 |
memcpy(cc1, pnt, byteId); |
989 |
memcpy(cc2, pnt, byteId); |
990 |
991 |
if (rdbit(separator, d)) |
992 |
hibits ^= bthbit; |
993 |
if (rdbit(firstSeparator, d)) |
994 |
hipart ^= bthbit; |
995 |
996 |
if (rdbit(fold1, d)) |
997 |
998 |
lo1 = -rdbit(valu1, d); |
999 |
setBytes(cc1,byteId,nBytes,lo1); |
1000 |
1001 |
else lo1 = cc1[byteId]; |
1002 |
cc1[byteId] = hipart | (lo1 &~ hibits); |
1003 |
1004 |
if (rdbit(fold2, d)) |
1005 |
1006 |
lo2 = -rdbit(valu2, d); |
1007 |
setBytes(cc2,byteId,nBytes,lo2); |
1008 |
1009 |
else lo2 = cc2[byteId]; |
1010 |
cc2[byteId] = hipart | (lo2 &~ hibits); |
1011 |
1012 |
1013 |
hilbert_box_pt(nDims, nBytes, nBits, !findPrev, c1V, c2V); |
1014 |
return 1; |
1015 |
1016 |
1017 |
1018 |
1019 |
1020 |
index ^= bits; |
1021 |
1022 |
1023 |
1024 |
1025 |
1026 |
/* point is in box */ |
1027 |
1028 |
unsigned d; |
1029 |
1030 |
((char*)c1)[d] = ((char*)c2)[d] = ((char*)pt)[d]; |
1031 |
1032 |
return 1; |
1033 |
1034 |
1035 |
1036 |
1037 |
1038 |
* hilbert_incr |
1039 |
1040 |
* Advance from one point to its successor on a Hilbert curve |
1041 |
* Inputs: |
1042 |
1043 |
1044 |
* coord: Array of nDims nBits-bit coordinates. |
1045 |
* Output: |
1046 |
* coord: Next point on Hilbert curve |
1047 |
* Assumptions: |
1048 |
1049 |
1050 |
1051 |
void |
1052 |
hilbert_incr(unsigned nDims, unsigned nBits, bitmask_t coord[]) |
1053 |
1054 |
1055 |
1056 |
1057 |
unsigned b, d; |
1058 |
1059 |
bitmask_t reflection = 0; |
1060 |
1061 |
unsigned rb = nBits-1; |
1062 |
bitmask_t rd = ndOnes; |
1063 |
1064 |
1065 |
1066 |
bitmask_t bits = reflection; |
1067 |
reflection = 0; |
1068 |
1069 |
reflection |= rdbit(coord[d], b) << d; |
1070 |
1071 |
1072 |
index ^= bits; |
1073 |
1074 |
1075 |
if (index++ != ndOnes) |
1076 |
1077 |
rb = b; |
1078 |
rd = index & -index; |
1079 |
rd = rotateLeft(rd, rotation, nDims); |
1080 |
1081 |
1082 |
index &= 1; |
1083 |
index <<= nDims-1; |
1084 |
1085 |
1086 |
1087 |
1088 |
for (d = 0; !rdbit(rd, d); ++d) {} |
1089 |
coord[d] ^= (2 << rb) - 1; |
1090 |
1091 |
1092 |
1093 |
/* LICENSE |
1094 |
1095 |
* This software is copyrighted by Rice University. It may be freely copied, |
1096 |
* modified, and redistributed, provided that the copyright notice is |
1097 |
* preserved on all copies. |
1098 |
1099 |
* There is no warranty or other guarantee of fitness for this software, |
1100 |
* it is provided solely "as is". Bug reports or fixes may be sent |
1101 |
* to the author, who may or may not act on them as he desires. |
1102 |
1103 |
* You may include this software in a program or other software product, |
1104 |
* but must display the notice: |
1105 |
1106 |
* Hilbert Curve implementation copyright 1998, Rice University |
1107 |
1108 |
* in any place where the end-user would see your own copyright. |
1109 |
1110 |
* If you modify this software, you should include a notice giving the |
1111 |
* name of the person performing the modification, the date of modification, |
1112 |
* and the reason for such modification. |
1113 |
1114 |
1115 |
1116 |
1117 |
/* Revision history: |
1118 |
1119 |
July 1998: Initial release |
1120 |
1121 |
Sept 1998: Second release |
1122 |
1123 |
Dec 1998: Fixed bug in hilbert_c2i that allowed a shift by number of bits in |
1124 |
bitmask to vaporize index, in last bit of the function. Implemented |
1125 |
hilbert_incr. |
1126 |
1127 |
August 1999: Added argument to hilbert_nextinbox so that you can, optionally, |
1128 |
find the previous point along the curve to intersect the box, rather than the |
1129 |
next point. |
1130 |
1131 |
Nov 1999: Defined fast bit-transpose function (fast, at least, if the number |
1132 |
of bits is large), and reimplemented i2c and c2i in terms of it. Collapsed |
1133 |
loops in hilbert_cmp, with the intention of reusing the cmp code to compare |
1134 |
more general bitstreams. |
1135 |
1136 |
Feb 2000: Implemented almost all the floating point versions of cmp, etc, so |
1137 |
that coordinates expressed in terms of double-precision IEEE floating point |
1138 |
can be ordered. Still have to do next-in-box, though. |
1139 |
1140 |
Oct 2001: Learned that some arbitrary coding choices caused some routines |
1141 |
to fail in one dimension, and changed those choices. |
1142 |
1143 |
version 2001-10-20-05:34 |
1144 |
1145 |
1146 |
1147 |
/* What remains is test code that won't be compiled unless you define the |
1148 |
TEST_HILBERT preprocessor symbol */ |
1149 |
1150 |
#ifdef TEST_HILBERT |
1151 |
#include <stdio.h> |
1152 |
#define abs(x) (((x)>=0)?(x):(-(x))) |
1153 |
1154 |
int main() |
1155 |
1156 |
#define maxDim (8*sizeof(bitmask_t)) |
1157 |
bitmask_t coord[maxDim], coordPrev[maxDim]; |
1158 |
unsigned nDims, nBits, nPrints, orderCheck, i; |
1159 |
bitmask_t r, r1; |
1160 |
1161 |
for (;;) |
1162 |
1163 |
printf( "Enter nDims, nBits, nPrints, orderCheck: " ); |
1164 |
scanf( "%d", &nDims); |
1165 |
if ( nDims == 0 ) |
1166 |
break; |
1167 |
scanf( "%d%d%d", &nBits, &nPrints, &orderCheck); |
1168 |
while ( (i = getchar()) != '\n' && i != EOF ) |
1169 |
1170 |
if ( i == EOF ) |
1171 |
break; |
1172 |
1173 |
if (nDims*nBits > 8*sizeof(r)) |
1174 |
1175 |
printf("Product of nDims and nBits not exceed %d.\n", 8*sizeof(r)); |
1176 |
break; |
1177 |
1178 |
1179 |
if (nBits == 0) |
1180 |
1181 |
printf("nBits must be positive.\n"); |
1182 |
break; |
1183 |
1184 |
1185 |
if (nPrints > (1ULL << (nDims*nBits))) |
1186 |
nPrints = 1ULL << (nDims*nBits); |
1187 |
1188 |
for (r = 0; r < nPrints; ++r) |
1189 |
1190 |
bitmask_t coord1[maxDim]; |
1191 |
int miscount = 0; |
1192 |
hilbert_i2c( nDims, nBits, r, coord ); |
1193 |
printf("%d: ", (unsigned)r); |
1194 |
for (i = 0; i < nDims; ++i) |
1195 |
1196 |
int diff = (int)(coord[i] - coordPrev[i]); |
1197 |
miscount += abs(diff); |
1198 |
coordPrev[i] = coord[i]; |
1199 |
printf(" %d", (unsigned)coord[i]); |
1200 |
1201 |
if (r > 0 && miscount != 1) |
1202 |
printf(".....error"); |
1203 |
printf("\n"); |
1204 |
r1 = hilbert_c2i( nDims, nBits, coord ); |
1205 |
if ( r != r1 ) |
1206 |
printf( "r = 0x%x; r1 = 0x%x\n", (unsigned)r, (unsigned)r1); |
1207 |
1208 |
coord[i] = coordPrev[i]; |
1209 |
1210 |
if (! orderCheck) |
1211 |
continue; |
1212 |
1213 |
for (r1 = 0; r1 < r; ++r1 ) |
1214 |
1215 |
unsigned ans; |
1216 |
hilbert_i2c( nDims, nBits, r1, coord1 ); |
1217 |
ans = hilbert_cmp( nDims, sizeof(coord[0]), nBits, coord, coord1); |
1218 |
if (ans != 1) |
1219 |
1220 |
int width = (nDims*nBits + 3) / 4; |
1221 |
printf( "cmp r = 0x%0*x; r1 = 0x%0*x, ans = %2d\n", |
1222 |
width, (unsigned)r, |
1223 |
width, (unsigned)r1, ans ); |
1224 |
1225 |
1226 |
1227 |
if (hilbert_cmp( nDims, sizeof(coord[0]), nBits, coord, coord1) != 0) |
1228 |
printf( "cmp r = 0x%0*x; r1 = 0x%0*x\n", (nDims*nBits+3)/4, (unsigned)r, |
1229 |
(nDims*nBits+3)/4, (unsigned)r1 ); |
1230 |
1231 |
1232 |
1233 |
return 0; |
1234 |
1235 |
1236 |
#endif |
1237 |
1238 |
#ifdef TEST_IEEE |
1239 |
1240 |
1241 |
#include <math.h> |
1242 |
1243 |
int cmp(const void* xv, const void* yv) |
1244 |
1245 |
double const* x = xv; |
1246 |
double const* y = yv; |
1247 |
/* return hilbert_cmp(2, 8, 64, x, y); */ |
1248 |
return hilbert_ieee_cmp(2, x, y); |
1249 |
1250 |
1251 |
int main() |
1252 |
1253 |
double *a; |
1254 |
unsigned i; |
1255 |
unsigned n; |
1256 |
printf("How many points? "); |
1257 |
scanf("%d", &n); |
1258 |
a = (double*) malloc(2*n*sizeof(double)); |
1259 |
for (i = 0; i < n; ++i) { |
1260 |
a[2*i] = rand()*(1./RAND_MAX) - 0.5; |
1261 |
a[2*i+1] = rand()*(1./RAND_MAX) - 0.5; |
1262 |
1263 |
qsort(a, n, 2*sizeof(double), cmp); |
1264 |
1265 |
for (i = 0; i < n; ++i) |
1266 |
printf("%8g %8g\n", a[2*i], a[2*i+1]); |
1267 |
free(a); |
1268 |
return 0; |
1269 |
1270 |
1271 |
#endif |
1272 |
1273 |
#ifdef TEST_CMP |
1274 |
1275 |
1276 |
1277 |
int main() |
1278 |
1279 |
double coord[maxDim]; |
1280 |
unsigned nDims, i, k; |
1281 |
1282 |
printf( "Enter nDims: " ); |
1283 |
1284 |
if ( nDims == 0 ) |
1285 |
return 0; |
1286 |
1287 |
1288 |
if ( i == EOF ) |
1289 |
return 0; |
1290 |
1291 |
for (k = 0; k < (1<<nDims); ++k) |
1292 |
1293 |
printf("Orth %2d\n", k); |
1294 |
1295 |
coord[i] = ((k>>i)&1)? -1.: 1.; |
1296 |
1297 |
1298 |
hilbert_ieee_cmp( nDims, coord, coord); |
1299 |
1300 |
return 0; |
1301 |
1302 |
1303 |
#endif |
1304 |
1305 |
#ifdef TEST_VTX |
1306 |
1307 |
1308 |
1309 |
1310 |
1311 |
unsigned g_nDims; |
1312 |
1313 |
int cmp(void const* c1p, void const* c2p) |
1314 |
1315 |
return hilbert_cmp(g_nDims, sizeof(unsigned), 8*sizeof(unsigned), c1p, c2p); |
1316 |
1317 |
1318 |
int main() |
1319 |
1320 |
unsigned corner0[maxDim], corner1[maxDim]; |
1321 |
unsigned cornerlo[maxDim], cornerhi[maxDim], work[maxDim]; |
1322 |
typedef unsigned array_t[maxDim]; |
1323 |
array_t* array; |
1324 |
1325 |
1326 |
1327 |
1328 |
1329 |
if ( nDims == 0 ) |
1330 |
return 0; |
1331 |
1332 |
1333 |
if ( i == EOF ) |
1334 |
return 0; |
1335 |
1336 |
printf("Enter one corner (%d coordinates): ", nDims); |
1337 |
for (k = 0; k < nDims; ++k) |
1338 |
scanf("%d", &corner0[k]); |
1339 |
1340 |
printf("Enter other corner (%d coordinates): ", nDims); |
1341 |
1342 |
scanf("%d", &corner1[k]); |
1343 |
1344 |
1345 |
/* find first corner */ |
1346 |
1347 |
1348 |
cornerlo[k] = corner0[k]; |
1349 |
work[k] = corner1[k]; |
1350 |
1351 |
1352 |
hilbert_box_vtx(nDims, sizeof(unsigned), 8*sizeof(unsigned), |
1353 |
1, cornerlo, work); |
1354 |
printf("Predicted lo corner: "); |
1355 |
1356 |
printf("%4u", cornerlo[k]); |
1357 |
printf("\n"); |
1358 |
1359 |
1360 |
/* find last corner */ |
1361 |
1362 |
1363 |
work[k] = corner0[k]; |
1364 |
cornerhi[k] = corner1[k]; |
1365 |
1366 |
1367 |
1368 |
0, work, cornerhi); |
1369 |
printf("Predicted hi corner: "); |
1370 |
1371 |
printf("%4u", cornerhi[k]); |
1372 |
printf("\n"); |
1373 |
1374 |
array = (array_t*) malloc(maxDim*sizeof(unsigned) << nDims); |
1375 |
1376 |
1377 |
unsigned j; |
1378 |
unsigned* eltk = &array[k][0]; |
1379 |
for (j = 0; j < nDims; ++j) |
1380 |
1381 |
unsigned* src = ((k>>j)&1)? corner1: corner0; |
1382 |
eltk[j] = src[j]; |
1383 |
1384 |
1385 |
1386 |
g_nDims = nDims; |
1387 |
qsort(array, (1<<nDims), maxDim*sizeof(unsigned), cmp); |
1388 |
1389 |
printf("Result of sort\n"); |
1390 |
for (k = 0; k < (1<<nDims); k += (1 << nDims) - 1) |
1391 |
1392 |
unsigned j; |
1393 |
1394 |
1395 |
printf("%4u", eltk[j]); |
1396 |
printf("\n"); |
1397 |
1398 |
free((char*)array); |
1399 |
return 0; |
1400 |
1401 |
1402 |
#endif |
1403 |
1404 |
#ifdef TEST_IEEE_VTX |
1405 |
1406 |
1407 |
#include <assert.h> |
1408 |
1409 |
1410 |
typedef double key_t; |
1411 |
1412 |
unsigned g_nDims; |
1413 |
1414 |
1415 |
1416 |
return hilbert_ieee_cmp(g_nDims, c1p, c2p); |
1417 |
1418 |
1419 |
int main() |
1420 |
1421 |
key_t corner0[maxDim], corner1[maxDim]; |
1422 |
key_t cornerlo[maxDim], cornerhi[maxDim], work[maxDim]; |
1423 |
typedef key_t array_t[maxDim]; |
1424 |
array_t* array; |
1425 |
1426 |
1427 |
1428 |
1429 |
1430 |
if ( nDims == 0 ) |
1431 |
return 0; |
1432 |
1433 |
for (i = 0; i < 10000; ++i) |
1434 |
1435 |
1436 |
1437 |
corner0[k] = 2.*drand48() - 1.; |
1438 |
corner1[k] = 2.*drand48() - 1.; |
1439 |
1440 |
1441 |
1442 |
1443 |
1444 |
1445 |
1446 |
1447 |
1448 |
hilbert_ieee_box_vtx(nDims, 1, cornerlo, work); |
1449 |
1450 |
1451 |
1452 |
1453 |
1454 |
1455 |
1456 |
1457 |
hilbert_ieee_box_vtx(nDims, 0, work, cornerhi); |
1458 |
1459 |
array = (array_t*) malloc(maxDim*sizeof(key_t) << nDims); |
1460 |
1461 |
1462 |
unsigned j; |
1463 |
key_t* eltk = &array[k][0]; |
1464 |
1465 |
1466 |
key_t* src = ((k>>j)&1)? corner1: corner0; |
1467 |
eltk[j] = src[j]; |
1468 |
1469 |
1470 |
1471 |
g_nDims = nDims; |
1472 |
qsort(array, (1<<nDims), maxDim*sizeof(key_t), cmp); |
1473 |
1474 |
1475 |
1476 |
unsigned j; |
1477 |
int mismatch = 0; |
1478 |
1479 |
for (j = 0; j < nDims & !mismatch; ++j) |
1480 |
1481 |
mismatch = (eltk[j] != ((k==0)? cornerlo: cornerhi)[j]); |
1482 |
1483 |
assert (!mismatch); |
1484 |
1485 |
1486 |
1487 |
return 0; |
1488 |
1489 |
1490 |
#endif |
1491 |
1492 |
#ifdef TEST_PT |
1493 |
1494 |
1495 |
1496 |
1497 |
1498 |
unsigned g_nDims; |
1499 |
1500 |
1501 |
1502 |
1503 |
1504 |
1505 |
int main() |
1506 |
1507 |
unsigned point0[maxDim], point1[maxDim]; |
1508 |
unsigned pointlo[maxDim], pointhi[maxDim], work[maxDim]; |
1509 |
1510 |
array_t* array; |
1511 |
1512 |
unsigned nDims, i, k, outvolume = 1, involume = 1; |
1513 |
unsigned nextItem; |
1514 |
1515 |
1516 |
1517 |
if ( nDims == 0 ) |
1518 |
return 0; |
1519 |
1520 |
1521 |
if ( i == EOF ) |
1522 |
return 0; |
1523 |
1524 |
printf("Enter one point (%d coordinates): ", nDims); |
1525 |
1526 |
scanf("%d", &point0[k]); |
1527 |
1528 |
printf("Enter other point (%d coordinates, strictly greater): ", nDims); |
1529 |
1530 |
1531 |
unsigned diff; |
1532 |
scanf("%d", &point1[k]); |
1533 |
diff = point1[k] - point0[k]; |
1534 |
outvolume *= diff + 1; |
1535 |
involume *= diff - 1; |
1536 |
1537 |
1538 |
1539 |
/* find first point */ |
1540 |
1541 |
1542 |
pointlo[k] = point0[k]; |
1543 |
work[k] = point1[k]; |
1544 |
1545 |
1546 |
hilbert_box_pt(nDims, sizeof(unsigned), 8*sizeof(unsigned), |
1547 |
1, pointlo, work); |
1548 |
printf("Predicted lo point: "); |
1549 |
1550 |
printf("%4u", pointlo[k]); |
1551 |
printf("\n"); |
1552 |
1553 |
1554 |
/* find last point */ |
1555 |
1556 |
1557 |
work[k] = point0[k]; |
1558 |
pointhi[k] = point1[k]; |
1559 |
1560 |
1561 |
1562 |
0, work, pointhi); |
1563 |
printf("Predicted hi point: "); |
1564 |
1565 |
printf("%4u", pointhi[k]); |
1566 |
printf("\n"); |
1567 |
1568 |
1569 |
1570 |
array = (array_t*) malloc(maxDim*sizeof(unsigned) * (outvolume-involume)); |
1571 |
if (array == 0) |
1572 |
1573 |
fprintf(stderr, "Out of memory.\n"); |
1574 |
exit(-1); |
1575 |
1576 |
nextItem = 0; |
1577 |
for (k = 0; k < outvolume; ++k) |
1578 |
1579 |
unsigned kk = k; |
1580 |
unsigned j; |
1581 |
unsigned* eltk = &array[nextItem][0]; |
1582 |
int boundary = 0; |
1583 |
1584 |
1585 |
1586 |
unsigned diff1 = point1[j] - point0[j] + 1; |
1587 |
unsigned pos = point0[j] + (kk % diff1); |
1588 |
boundary |= (point0[j] == pos || pos == point1[j]); |
1589 |
eltk[j] = pos; |
1590 |
kk /= diff1; |
1591 |
1592 |
if (boundary) |
1593 |
++nextItem; |
1594 |
1595 |
1596 |
g_nDims = nDims; |
1597 |
qsort(array, outvolume-involume, maxDim*sizeof(unsigned), cmp); |
1598 |
1599 |
1600 |
for (k = 0; k < outvolume-involume; k += outvolume-involume-1) |
1601 |
1602 |
unsigned j; |
1603 |
1604 |
1605 |
1606 |
printf("\n"); |
1607 |
1608 |
1609 |
return 0; |
1610 |
1611 |
1612 |
#endif |
1613 |
1614 |
#ifdef TEST_IEEE_PT |
1615 |
1616 |
1617 |
1618 |
1619 |
1620 |
int main() |
1621 |
1622 |
double point0[maxDim], point1[maxDim]; |
1623 |
double pointlo[maxDim], pointhi[maxDim], work[maxDim]; |
1624 |
1625 |
unsigned nDims, k, i; |
1626 |
1627 |
1628 |
1629 |
if ( nDims == 0 ) |
1630 |
return 0; |
1631 |
1632 |
1633 |
if ( i == EOF ) |
1634 |
return 0; |
1635 |
1636 |
1637 |
1638 |
scanf("%lf", &point0[k]); |
1639 |
1640 |
1641 |
1642 |
scanf("%lf", &point1[k]); |
1643 |
1644 |
1645 |
1646 |
1647 |
1648 |
1649 |
1650 |
1651 |
hilbert_ieee_box_pt(nDims, 0, work, pointhi); |
1652 |
1653 |
1654 |
printf("%10lg", pointhi[k]); |
1655 |
printf("\n"); |
1656 |
1657 |
1658 |
1659 |
1660 |
1661 |
1662 |
1663 |
1664 |
hilbert_ieee_box_pt(nDims, 1, pointlo, work); |
1665 |
1666 |
1667 |
printf("%10lg", pointlo[k]); |
1668 |
printf("\n"); |
1669 |
1670 |
/* validate by sorting random boundary points */ |
1671 |
#define nPts 1000000 |
1672 |
assert(hilbert_ieee_cmp(nDims, pointlo, pointhi) < 0); |
1673 |
for (i = 0; i < nPts; ++i) |
1674 |
1675 |
double pt1[maxDim], pt2[maxDim]; |
1676 |
1677 |
1678 |
if (i % nDims == k) |
1679 |
pt1[k] = point0[k]; |
1680 |
else |
1681 |
pt1[k] = point0[k] + drand48()*(point1[k]-point0[k]); |
1682 |
1683 |
1684 |
1685 |
1686 |
pt2[k] = point1[k]; |
1687 |
else |
1688 |
pt2[k] = point0[k] + drand48()*(point1[k]-point0[k]); |
1689 |
1690 |
if (hilbert_ieee_cmp(nDims, pt1, pt2) < 0) |
1691 |
1692 |
if (hilbert_ieee_cmp(nDims, pt1, pointlo) < 0) |
1693 |
memcpy(pointlo, pt1, maxDim*sizeof(double)); |
1694 |
if (hilbert_ieee_cmp(nDims, pointhi, pt2) < 0) |
1695 |
memcpy(pointhi, pt2, maxDim*sizeof(double)); |
1696 |
1697 |
else |
1698 |
1699 |
if (hilbert_ieee_cmp(nDims, pt2, pointlo) < 0) |
1700 |
memcpy(pointlo, pt2, maxDim*sizeof(double)); |
1701 |
if (hilbert_ieee_cmp(nDims, pointhi, pt1) < 0) |
1702 |
memcpy(pointhi, pt1, maxDim*sizeof(double)); |
1703 |
1704 |
1705 |
1706 |
printf("Sorted hi and lo:\n"); |
1707 |
1708 |
1709 |
printf("\n"); |
1710 |
1711 |
1712 |
printf("\n"); |
1713 |
1714 |
return 0; |
1715 |
1716 |
1717 |
#endif |
1718 |
1719 |
#ifdef TEST_NEXT |
1720 |
1721 |
1722 |
int main() |
1723 |
1724 |
unsigned i; |
1725 |
unsigned c1[100], c2[100], pt[100]; |
1726 |
unsigned nDims, nBytes = 4; |
1727 |
int stat, findPrev; |
1728 |
printf("Enter nDims: " ); |
1729 |
scanf("%u", &nDims); |
1730 |
1731 |
printf("Enter 1st box corner: "); |
1732 |
1733 |
scanf("%u", &c1[i]); |
1734 |
printf("Enter 2nd box corner: "); |
1735 |
1736 |
scanf("%u", &c2[i]); |
1737 |
printf("Enter point: "); |
1738 |
1739 |
scanf("%u", &pt[i]); |
1740 |
printf("Find prev?: "); |
1741 |
scanf("%d", &findPrev); |
1742 |
1743 |
stat = hilbert_nextinbox(nDims, nBytes, 8*nBytes, findPrev, c1, c2, pt); |
1744 |
1745 |
if (stat) |
1746 |
1747 |
printf("%u ", c1[i]); |
1748 |
else |
1749 |
printf("No such point"); |
1750 |
1751 |
printf("\n"); |
1752 |
return 0; |
1753 |
1754 |
#endif |
