root/radiance/ray/src/common/hilbert.c
Revision: 3.2
Committed: Fri Feb 18 18:41:04 2011 UTC (14 years, 5 months ago) by greg
Changes since 3.1: +3 -0 lines
Added missing RCS tags
4 /* See LICENSE below for information on rights to use, modify and distribute
5 this code. */
6
7 /*
8 * hilbert.c - Computes Hilbert space-filling curve coordinates, without
9 * recursion, from integer index, and vice versa, and other Hilbert-related
10 * calculations. Also known as Pi-order or Peano scan.
11 *
12 * Author: Doug Moore
13 * Dept. of Computational and Applied Math
14 * Rice University
15 * http://www.caam.rice.edu/~dougm
16 * Date: Sun Feb 20 2000
17 * Copyright (c) 1998-2000, Rice University
18 *
19 * Acknowledgement:
20 * This implementation is based on the work of A. R. Butz ("Alternative
21 * Algorithm for Hilbert's Space-Filling Curve", IEEE Trans. Comp., April,
22 * 1971, pp 424-426) and its interpretation by Spencer W. Thomas, University
23 * of Michigan (http://www-personal.umich.edu/~spencer/Home.html) in his widely
24 * available C software. While the implementation here differs considerably
25 * from his, the first two interfaces and the style of some comments are very
26 * much derived from his work. */
27
28
29 #include "hilbert.h"
30
31 /* implementation of the hilbert functions */
32
33 #define adjust_rotation(rotation,nDims,bits) \
34 do { \
35 /* rotation = (rotation + 1 + ffs(bits)) % nDims; */ \
36 bits &= -bits & nd1Ones; \
37 while (bits) \
38 bits >>= 1, ++rotation; \
39 if ( ++rotation >= nDims ) \
40 rotation -= nDims; \
41 } while (0)
42
43 #define ones(T,k) ((((T)2) << (k-1)) - 1)
44
45 #define rdbit(w,k) (((w) >> (k)) & 1)
46
47 #define rotateRight(arg, nRots, nDims) \
48 ((((arg) >> (nRots)) | ((arg) << ((nDims)-(nRots)))) & ones(bitmask_t,nDims))
49
50 #define rotateLeft(arg, nRots, nDims) \
51 ((((arg) << (nRots)) | ((arg) >> ((nDims)-(nRots)))) & ones(bitmask_t,nDims))
52
53 #define DLOGB_BIT_TRANSPOSE
54 static bitmask_t
55 bitTranspose(unsigned nDims, unsigned nBits, bitmask_t inCoords)
56 #if defined(DLOGB_BIT_TRANSPOSE)
57 {
58 unsigned const nDims1 = nDims-1;
59 unsigned inB = nBits;
60 unsigned utB;
61 bitmask_t inFieldEnds = 1;
62 bitmask_t inMask = ones(bitmask_t,inB);
63 bitmask_t coords = 0;
64
65 while ((utB = inB >> 1))
66 {
67 unsigned const shiftAmt = nDims1 * utB;
68 bitmask_t const utFieldEnds =
69 inFieldEnds | (inFieldEnds << (shiftAmt+utB));
70 bitmask_t const utMask =
71 (utFieldEnds << utB) - utFieldEnds;
72 bitmask_t utCoords = 0;
73 unsigned d;
74 if (inB & 1)
75 {
76 bitmask_t const inFieldStarts = inFieldEnds << (inB-1);
77 unsigned oddShift = 2*shiftAmt;
78 for (d = 0; d < nDims; ++d)
79 {
80 bitmask_t in = inCoords & inMask;
81 inCoords >>= inB;
82 coords |= (in & inFieldStarts) << oddShift++;
83 in &= ~inFieldStarts;
84 in = (in | (in << shiftAmt)) & utMask;
85 utCoords |= in << (d*utB);
86 }
87 }
88 else
89 {
90 for (d = 0; d < nDims; ++d)
91 {
92 bitmask_t in = inCoords & inMask;
93 inCoords >>= inB;
94 in = (in | (in << shiftAmt)) & utMask;
95 utCoords |= in << (d*utB);
96 }
97 }
98 inCoords = utCoords;
99 inB = utB;
100 inFieldEnds = utFieldEnds;
101 inMask = utMask;
102 }
103 coords |= inCoords;
104 return coords;
105 }
106 #else
107 {
108 bitmask_t coords = 0;
109 unsigned d;
110 for (d = 0; d < nDims; ++d)
111 {
112 unsigned b;
113 bitmask_t in = inCoords & ones(bitmask_t,nBits);
114 bitmask_t out = 0;
115 inCoords >>= nBits;
116 for (b = nBits; b--;)
117 {
118 out <<= nDims;
119 out |= rdbit(in, b);
120 }
121 coords |= out << d;
122 }
123 return coords;
124 }
125 #endif
126
127 /*****************************************************************
128 * hilbert_i2c
129 *
130 * Convert an index into a Hilbert curve to a set of coordinates.
131 * Inputs:
132 * nDims: Number of coordinate axes.
133 * nBits: Number of bits per axis.
134 * index: The index, contains nDims*nBits bits
135 * (so nDims*nBits must be <= 8*sizeof(bitmask_t)).
136 * Outputs:
137 * coord: The list of nDims coordinates, each with nBits bits.
138 * Assumptions:
139 * nDims*nBits <= (sizeof index) * (bits_per_byte)
140 */
141 void
142 hilbert_i2c(unsigned nDims, unsigned nBits, bitmask_t index, bitmask_t coord[])
143 {
144 if (nDims > 1)
145 {
146 bitmask_t coords;
147 halfmask_t const nbOnes = ones(halfmask_t,nBits);
148 unsigned d;
149
150 if (nBits > 1)
151 {
152 unsigned const nDimsBits = nDims*nBits;
153 halfmask_t const ndOnes = ones(halfmask_t,nDims);
154 halfmask_t const nd1Ones= ndOnes >> 1; /* for adjust_rotation */
155 unsigned b = nDimsBits;
156 unsigned rotation = 0;
157 halfmask_t flipBit = 0;
158 bitmask_t const nthbits = ones(bitmask_t,nDimsBits) / ndOnes;
159 index ^= (index ^ nthbits) >> 1;
160 coords = 0;
161 do
162 {
163 halfmask_t bits = (index >> (b-=nDims)) & ndOnes;
164 coords <<= nDims;
165 coords |= rotateLeft(bits, rotation, nDims) ^ flipBit;
166 flipBit = (halfmask_t)1 << rotation;
167 adjust_rotation(rotation,nDims,bits);
168 } while (b);
169 for (b = nDims; b < nDimsBits; b *= 2)
170 coords ^= coords >> b;
171 coords = bitTranspose(nBits, nDims, coords);
172 }
173 else
174 coords = index ^ (index >> 1);
175
176 for (d = 0; d < nDims; ++d)
177 {
178 coord[d] = coords & nbOnes;
179 coords >>= nBits;
180 }
181 }
182 else
183 coord[0] = index;
184 }
185
186 /*****************************************************************
187 * hilbert_c2i
188 *
189 * Convert coordinates of a point on a Hilbert curve to its index.
190 * Inputs:
191 * nDims: Number of coordinates.
192 * nBits: Number of bits/coordinate.
193 * coord: Array of n nBits-bit coordinates.
194 * Outputs:
195 * index: Output index value. nDims*nBits bits.
196 * Assumptions:
197 * nDims*nBits <= (sizeof bitmask_t) * (bits_per_byte)
198 */
199 bitmask_t
200 hilbert_c2i(unsigned nDims, unsigned nBits, bitmask_t const coord[])
201 {
202 if (nDims > 1)
203 {
204 unsigned const nDimsBits = nDims*nBits;
205 bitmask_t index;
206 unsigned d;
207 bitmask_t coords = 0;
208 for (d = nDims; d--; )
209 {
210 coords <<= nBits;
211 coords |= coord[d];
212 }
213
214 if (nBits > 1)
215 {
216 halfmask_t const ndOnes = ones(halfmask_t,nDims);
217 halfmask_t const nd1Ones= ndOnes >> 1; /* for adjust_rotation */
218 unsigned b = nDimsBits;
219 unsigned rotation = 0;
220 halfmask_t flipBit = 0;
221 bitmask_t const nthbits = ones(bitmask_t,nDimsBits) / ndOnes;
222 coords = bitTranspose(nDims, nBits, coords);
223 coords ^= coords >> nDims;
224 index = 0;
225 do
226 {
227 halfmask_t bits = (coords >> (b-=nDims)) & ndOnes;
228 bits = rotateRight(flipBit ^ bits, rotation, nDims);
229 index <<= nDims;
230 index |= bits;
231 flipBit = (halfmask_t)1 << rotation;
232 adjust_rotation(rotation,nDims,bits);
233 } while (b);
234 index ^= nthbits >> 1;
235 }
236 else
237 index = coords;
238 for (d = 1; d < nDimsBits; d *= 2)
239 index ^= index >> d;
240 return index;
241 }
242 else
243 return coord[0];
244 }
245
246 /*****************************************************************
247 * Readers and writers of bits
248 */
249
250 typedef bitmask_t (*BitReader) (unsigned nDims, unsigned nBytes,
251 char const* c, unsigned y);
252 typedef void (*BitWriter) (unsigned d, unsigned nBytes,
253 char* c, unsigned y, int fold);
254
255
256 #if defined(sparc)
257 #define __BIG_ENDIAN__
258 #endif
259
260 #if defined(__BIG_ENDIAN__)
261 #define whichByte(nBytes,y) (nBytes-1-y/8)
262 #define setBytes(dst,pos,nBytes,val) \
263 memset(&dst[pos+1],val,nBytes-pos-1)
264 #else
265 #define whichByte(nBytes,y) (y/8)
266 #define setBytes(dst,pos,nBytes,val) \
267 memset(&dst[0],val,pos)
268 #endif
269
270 static bitmask_t
271 getIntBits(unsigned nDims, unsigned nBytes, char const* c, unsigned y)
272 {
273 unsigned const bit = y%8;
274 unsigned const offs = whichByte(nBytes,y);
275 unsigned d;
276 bitmask_t bits = 0;
277 c += offs;
278 for (d = 0; d < nDims; ++d)
279 {
280 bits |= rdbit(*c, bit) << d;
281 c += nBytes;
282 }
283 return bits;
284 }
285
286 #include <string.h>
287 static void
288 propogateIntBits(unsigned d, unsigned nBytes,
289 char* c, unsigned y, int fold)
290 {
291 unsigned const byteId = whichByte(nBytes,y);
292 unsigned const b = y%8;
293 char const bthbit = 1 << b;
294 char* const target = &c[d*nBytes];
295 target[byteId] ^= bthbit;
296 if (!fold)
297 {
298 char notbit = ((target[byteId] >> b) & 1) - 1;
299 if (notbit)
300 target[byteId] |= bthbit-1;
301 else
302 target[byteId] &= -bthbit;
303 setBytes(target,byteId,nBytes,notbit);
304 }
305 }
306
307 /* An IEEE double is treated as a 2100 bit number. In particular, 0 is treated
308 as a 1 followed by 2099 zeroes, and negative 0 as a 0 followed by 2099 ones.
309 Only 53 bits differ between a number and a zero of the same sign, with the
310 position of the 53 determined by the exponent, and the values of the 53 by
311 the significand (with implicit leading 1 bit). Although IEEE 754 uses the
312 maximum exponent for NaN's and infinities, this implementation ignores that
313 decision, so that infinities and NaN's are treated as very large numbers.
314 Note that we do not explicitly construct a 2100 bit bitmask in the IEEE
315 routines below. */
316
317 enum { IEEEexpBits = 11 };
318 enum { IEEEsigBits = 52 };
319 enum { IEEErepBits = (1 << IEEEexpBits) + IEEEsigBits };
320
321 typedef union ieee754_double
322 {
323 double d;
324
325 /* This is the IEEE 754 double-precision format. */
326 struct
327 {
328 #if defined(__BIG_ENDIAN__)
329 unsigned int negative:1;
330 unsigned int exponent:11;
331 /* Together these comprise the mantissa. */
332 unsigned int mantissa0:20;
333 unsigned int mantissa1:32;
334 #else /* Big endian. */
335 /* Together these comprise the mantissa. */
336 unsigned int mantissa1:32;
337 unsigned int mantissa0:20;
338 unsigned int exponent:11;
339 unsigned int negative:1;
340 #endif /* Little endian. */
341 } ieee;
342 } ieee754_double;
343
344 static bitmask_t
345 getIEEESignBits(unsigned nDims, double const* c)
346 {
347 unsigned d;
348 ieee754_double x;
349 bitmask_t bits = 0;
350 for (d = 0; d < nDims; ++d)
351 {
352 x.d = c[d];
353 bits |= x.ieee.negative << d;
354 }
355 return bits;
356 }
357
358 static bitmask_t
359 getIEEEBits(unsigned nDims,
360 unsigned ignoreMe, /* ignored */
361 char const* cP,
362 unsigned y)
363 /* retrieve bits y of elements of double array c, where an expanded IEEE
364 double has 2100 bits. */
365 {
366 unsigned d;
367 double const* c = (double const*) cP;
368 ieee754_double x;
369 bitmask_t bits = 0;
370 for (x.d = c[d=0]; d < nDims; x.d = c[++d])
371 {
372 bitmask_t bit = x.ieee.negative;
373 unsigned normalized = (x.ieee.exponent != 0);
374 unsigned diff = y - (x.ieee.exponent - normalized);
375 if (diff <= 52)
376 bit ^= 1 & ((diff < 32)? x.ieee.mantissa1 >> diff:
377 (diff < 52)? x.ieee.mantissa0 >> (diff - 32):
378 /* else */ normalized);
379 else
380 bit ^= (y == IEEErepBits-1);
381
382 bits |= bit << d;
383 }
384 return bits;
385 }
386
387 static void
388 propogateIEEEBits(unsigned d, unsigned nBytes,
389 char* cP, unsigned y, int fold)
390 {
391 ieee754_double* x = d + (ieee754_double*) cP;
392 unsigned normalized = (x->ieee.exponent != 0);
393 unsigned diff = y - (x->ieee.exponent - normalized);
394 if (diff < 32)
395 {
396 unsigned b = 1 << diff;
397 unsigned bit = x->ieee.mantissa1 & b;
398 x->ieee.mantissa1 &= ~(b-1);
399 x->ieee.mantissa1 |= b;
400 if (bit)
401 --x->ieee.mantissa1;
402 }
403 else if (diff < 52)
404 {
405 unsigned b = 1 << (diff - 32);
406 unsigned bit = x->ieee.mantissa0 & b;
407 x->ieee.mantissa0 &= ~(b-1);
408 x->ieee.mantissa0 |= b;
409 if (bit)
410 --x->ieee.mantissa0;
411 x->ieee.mantissa1 = bit?-1: 0;
412 }
413 else if (diff == 52) /* "flip" the implicit 1 bit */
414 {
415 if (normalized)
416 --x->ieee.exponent;
417 else
418 x->ieee.exponent = 1;
419 x->ieee.mantissa0 = -normalized;
420 x->ieee.mantissa1 = -normalized;
421 }
422 else if (diff < IEEErepBits)
423 {
424 if (y == IEEErepBits-1)
425 {
426 x->ieee.negative ^= 1;
427 x->ieee.exponent = 0;
428 }
429 else
430 x->ieee.exponent = y - 51;
431 x->ieee.mantissa0 = 0;
432 x->ieee.mantissa1 = 0;
433 }
434 }
435
436 static unsigned
437 getIEEEexptMax(unsigned nDims, double const* c)
438 {
439 unsigned max = 0;
440 unsigned d;
441 for (d = 0; d < nDims; ++d)
442 {
443 ieee754_double x;
444 x.d = c[d];
445 if (max < x.ieee.exponent)
446 max = x.ieee.exponent;
447 }
448 if (max) --max;
449 return max;
450 }
451
452 static void
453 getIEEEinitValues(double const* c1,
454 unsigned y,
455 unsigned nDims,
456 unsigned* rotation,
457 bitmask_t* bits,
458 bitmask_t* index)
459 {
460 bitmask_t const one = 1;
461 unsigned d;
462 bitmask_t signBits = getIEEESignBits(nDims, c1);
463 unsigned signParity, leastZeroBit, strayBit;
464
465 /* compute the odd/evenness of the number of sign bits */
466 {
467 bitmask_t signPar = signBits;
468 for (d = 1; d < nDims; d *= 2)
469 signPar ^= signPar >> d;
470 signParity = signPar & 1;
471 }
472
473 /* find the position of the least-order 0 bit in among signBits and adjust it
474 if necessary */
475 for (leastZeroBit = 0; leastZeroBit < nDims; ++leastZeroBit)
476 if (rdbit(signBits, leastZeroBit) == 0)
477 break;
478 strayBit = 0;
479 if (leastZeroBit == nDims-2)
480 strayBit = 1;
481 else if (leastZeroBit == nDims)
482 leastZeroBit = nDims-1;
483
484 if (y % 2 == 1)
485 {
486 *rotation = (IEEErepBits - y + 1 + leastZeroBit) % nDims;
487 if (y < IEEErepBits-1)
488 {
489 *bits = signBits ^ (one << ((*rotation + strayBit) % nDims));
490 *index = signParity;
491 }
492 else /* y == IEEErepBits-1 */
493 {
494 *bits = signBits ^ (ones(bitmask_t,nDims) &~ 1);
495 *index = signParity ^ (nDims&1);
496 }
497 }
498 else /* y % 2 == 0 */
499 if (y < IEEErepBits)
500 {
501 unsigned shift_amt = (IEEErepBits - y + leastZeroBit) % nDims;
502 *rotation = (shift_amt + 2 + strayBit) % nDims;
503 *bits = signBits ^ (one << shift_amt);
504 *index = signParity ^ 1;
505 }
506 else /* y == IEEErepBits */
507 {
508 *rotation = 0;
509 *bits = one << (nDims-1);
510 *index = 1;
511 }
512 }
513
514 /*****************************************************************
515 * hilbert_cmp, hilbert_ieee_cmp
516 *
517 * Determine which of two points lies further along the Hilbert curve
518 * Inputs:
519 * nDims: Number of coordinates.
520 * nBytes: Number of bytes of storage/coordinate (hilbert_cmp only)
521 * nBits: Number of bits/coordinate. (hilbert_cmp only)
522 * coord1: Array of nDims nBytes-byte coordinates (or doubles for ieee_cmp).
523 * coord2: Array of nDims nBytes-byte coordinates (or doubles for ieee_cmp).
524 * Return value:
525 * -1, 0, or 1 according to whether
526 coord1<coord2, coord1==coord2, coord1>coord2
527 * Assumptions:
528 * nBits <= (sizeof bitmask_t) * (bits_per_byte)
529 */
530
531 static int
532 hilbert_cmp_work(unsigned nDims, unsigned nBytes, unsigned nBits,
533 unsigned max, unsigned y,
534 char const* c1, char const* c2,
535 unsigned rotation,
536 bitmask_t bits,
537 bitmask_t index,
538 BitReader getBits)
539 {
540 bitmask_t const one = 1;
541 bitmask_t const nd1Ones = ones(bitmask_t,nDims) >> 1; /* used in adjust_rotation macro */
542 while (y-- > max)
543 {
544 bitmask_t reflection = getBits(nDims, nBytes, c1, y);
545 bitmask_t diff = reflection ^ getBits(nDims, nBytes, c2, y);
546 bits ^= reflection;
547 bits = rotateRight(bits, rotation, nDims);
548 if (diff)
549 {
550 unsigned d;
551 diff = rotateRight(diff, rotation, nDims);
552 for (d = 1; d < nDims; d *= 2)
553 {
554 index ^= index >> d;
555 bits ^= bits >> d;
556 diff ^= diff >> d;
557 }
558 return (((index ^ y ^ nBits) & 1) == (bits < (bits^diff)))? -1: 1;
559 }
560 index ^= bits;
561 reflection ^= one << rotation;
562 adjust_rotation(rotation,nDims,bits);
563 bits = reflection;
564 }
565 return 0;
566 }
567
568 int
569 hilbert_cmp(unsigned nDims, unsigned nBytes, unsigned nBits,
570 void const* c1, void const* c2)
571 {
572 bitmask_t const one = 1;
573 bitmask_t bits = one << (nDims-1);
574 return hilbert_cmp_work(nDims, nBytes, nBits, 0, nBits,
575 (char const*)c1, (char const*)c2,
576 0, bits, bits, getIntBits);
577 }
578
579 int
580 hilbert_ieee_cmp(unsigned nDims, double const* c1, double const* c2)
581 {
582 unsigned rotation, max;
583 bitmask_t bits, index;
584 if (getIEEESignBits(nDims, c1) != getIEEESignBits(nDims, c2))
585 max = 2047;
586 else
587 {
588 unsigned max1 = getIEEEexptMax(nDims, c1);
589 unsigned max2 = getIEEEexptMax(nDims, c2);
590 max = (max1 > max2)? max1: max2;
591 }
592
593 getIEEEinitValues(c1, max+53, nDims, &rotation, &bits, &index);
594 return hilbert_cmp_work(nDims, 8, 64, max, max+53,
595 (char const*)c1, (char const*)c2,
596 rotation, bits, index, getIEEEBits);
597 }
598
599 /*****************************************************************
600 * hilbert_box_vtx
601 *
602 * Determine the first or last vertex of a box to lie on a Hilbert curve
603 * Inputs:
604 * nDims: Number of coordinates.
605 * nBytes: Number of bytes/coordinate.
606 * nBits: Number of bits/coordinate.
607 * findMin: Is it the least vertex sought?
608 * coord1: Array of nDims nBytes-byte coordinates - one corner of box
609 * coord2: Array of nDims nBytes-byte coordinates - opposite corner
610 * Output:
611 * c1 and c2 modified to refer to selected corner
612 * value returned is log2 of size of largest power-of-two-aligned box that
613 * contains the selected corner and no other corners
614 * Assumptions:
615 * nBits <= (sizeof bitmask_t) * (bits_per_byte)
616 */
617
618
619 static unsigned
620 hilbert_box_vtx_work(unsigned nDims, unsigned nBytes, unsigned nBits,
621 int findMin,
622 unsigned max, unsigned y,
623 char* c1, char* c2,
624 unsigned rotation,
625 bitmask_t bits,
626 bitmask_t index,
627 BitReader getBits)
628 {
629 bitmask_t const one = 1;
630 bitmask_t const ndOnes = ones(bitmask_t,nDims);
631 bitmask_t const nd1Ones= ndOnes >> 1;
632 bitmask_t bitsFolded = 0;
633
634 while (y--)
635 {
636 bitmask_t reflection = getBits(nDims, nBytes, c1, y);
637 bitmask_t diff = reflection ^ getBits(nDims, nBytes, c2, y);
638 if (diff)
639 {
640 unsigned d;
641 bitmask_t smear = rotateRight(diff, rotation, nDims) >> 1;
642 bitmask_t digit = rotateRight(bits ^ reflection, rotation, nDims);
643 for (d = 1; d < nDims; d *= 2)
644 {
645 index ^= index >> d;
646 digit ^= (digit >> d) &~ smear;
647 smear |= smear >> d;
648 }
649 index &= 1;
650 if ((index ^ y ^ findMin) & 1)
651 digit ^= smear+1;
652 digit = rotateLeft(digit, rotation, nDims) & diff;
653 reflection ^= digit;
654
655 for (d = 0; d < nDims; ++d)
656 if (rdbit(diff, d))
657 {
658 int way = rdbit(digit, d);
659 char* target = d*nBytes + (way? c1: c2);
660 char* const source = 2*d*nBytes + c1 - target + c2;
661 memcpy(target, source, nBytes);
662 }
663
664 bitsFolded |= diff;
665 if (bitsFolded == ndOnes)
666 return y;
667 }
668
669 bits ^= reflection;
670 bits = rotateRight(bits, rotation, nDims);
671 index ^= bits;
672 reflection ^= one << rotation;
673 adjust_rotation(rotation,nDims,bits);
674 bits = reflection;
675 }
676 return y;
677 }
678
679 unsigned
680 hilbert_box_vtx(unsigned nDims, unsigned nBytes, unsigned nBits,
681 int findMin, void* c1, void* c2)
682 {
683 bitmask_t const one = 1;
684 bitmask_t bits = one << (nDims-1);
685 return hilbert_box_vtx_work(nDims, nBytes, nBits, findMin,
686 0, nBits, (char*)c1, (char*)c2,
687 0, bits, bits, getIntBits);
688 }
689
690 unsigned
691 hilbert_ieee_box_vtx(unsigned nDims,
692 int findMin, double* c1, double* c2)
693 {
694 unsigned rotation, max;
695 bitmask_t bits, index;
696 if (getIEEESignBits(nDims, c1) != getIEEESignBits(nDims, c2))
697 max = 2047;
698 else
699 {
700 unsigned max1 = getIEEEexptMax(nDims, c1);
701 unsigned max2 = getIEEEexptMax(nDims, c2);
702 max = (max1 > max2)? max1: max2;
703 }
704
705 getIEEEinitValues(c1, max+53, nDims, &rotation, &bits, &index);
706
707 return hilbert_box_vtx_work(nDims, 8, 64, findMin,
708 max, max+53, (char *)c1, (char *)c2,
709 rotation, bits, index, getIEEEBits);
710 }
711
712 /*****************************************************************
713 * hilbert_box_pt
714 *
715 * Determine the first or last point of a box to lie on a Hilbert curve
716 * Inputs:
717 * nDims: Number of coordinates.
718 * nBytes: Number of bytes/coordinate.
719 * nBits: Number of bits/coordinate.
720 * findMin: Is it the least vertex sought?
721 * coord1: Array of nDims nBytes-byte coordinates - one corner of box
722 * coord2: Array of nDims nBytes-byte coordinates - opposite corner
723 * Output:
724 * c1 and c2 modified to refer to least point
725 * Assumptions:
726 * nBits <= (sizeof bitmask_t) * (bits_per_byte)
727 */
728 unsigned
729 hilbert_box_pt_work(unsigned nDims, unsigned nBytes, unsigned nBits,
730 int findMin,
731 unsigned max, unsigned y,
732 char* c1, char* c2,
733 unsigned rotation,
734 bitmask_t bits,
735 bitmask_t index,
736 BitReader getBits,
737 BitWriter propogateBits)
738 {
739 bitmask_t const one = 1;
740 bitmask_t const nd1Ones = ones(bitmask_t,nDims) >> 1;
741 bitmask_t fold1 = 0, fold2 = 0;
742 unsigned smearSum = 0;
743
744 while (y-- > max)
745 {
746 bitmask_t reflection = getBits(nDims, nBytes, c1, y);
747 bitmask_t diff = reflection ^ getBits(nDims, nBytes, c2, y);
748 if (diff)
749 {
750 bitmask_t smear = rotateRight(diff, rotation, nDims) >> 1;
751 bitmask_t digit = rotateRight(bits ^ reflection, rotation, nDims);
752 unsigned d;
753 for (d = 1; d < nDims; d *= 2)
754 {
755 index ^= index >> d;
756 digit ^= (digit >> d) &~ smear;
757 smear |= smear >> d;
758 }
759 smearSum += smear;
760 index &= 1;
761 if ((index ^ y ^ findMin) & 1)
762 digit ^= smear+1;
763 digit = rotateLeft(digit, rotation, nDims) & diff;
764 reflection ^= digit;
765
766 for (d = 0; d < nDims; ++d)
767 if (rdbit(diff, d))
768 {
769 int way = rdbit(digit, d);
770 char* c = way? c1: c2;
771 bitmask_t fold = way? fold1: fold2;
772 propogateBits(d, nBytes, c, y, rdbit(fold, d));
773 }
774 diff ^= digit;
775 fold1 |= digit;
776 fold2 |= diff;
777 }
778
779 bits ^= reflection;
780 bits = rotateRight(bits, rotation, nDims);
781 index ^= bits;
782 reflection ^= one << rotation;
783 adjust_rotation(rotation,nDims,bits);
784 bits = reflection;
785 }
786 return smearSum;
787 }
788
789 unsigned
790 hilbert_box_pt(unsigned nDims, unsigned nBytes, unsigned nBits,
791 int findMin, void* c1, void* c2)
792 {
793 bitmask_t const one = 1;
794 bitmask_t bits = one << (nDims-1);
795 return hilbert_box_pt_work(nDims, nBytes, nBits, findMin,
796 0, nBits, (char*)c1, (char*)c2,
797 0, bits, bits,
798 getIntBits, propogateIntBits);
799 }
800
801 unsigned
802 hilbert_ieee_box_pt(unsigned nDims,
803 int findMin, double* c1, double* c2)
804 {
805 unsigned rotation, max;
806 bitmask_t bits, index;
807 bitmask_t c1Signs = getIEEESignBits(nDims, c1);
808 bitmask_t c2Signs = getIEEESignBits(nDims, c2);
809 if (c1Signs != c2Signs)
810 {
811 rotation = 0;
812 bits = (bitmask_t)1 << (nDims-1);
813 index = 1;
814 hilbert_box_pt_work(nDims, 8, 64, findMin,
815 IEEErepBits-1, IEEErepBits, (char *)c1, (char *)c2,
816 rotation, bits, index,
817 getIEEEBits, propogateIEEEBits);
818 }
819
820 /* having put everything in the same orthant, start */
821 {
822 unsigned max1 = getIEEEexptMax(nDims, c1);
823 unsigned max2 = getIEEEexptMax(nDims, c2);
824 max = (max1 > max2)? max1: max2;
825 }
826
827 getIEEEinitValues(c1, max+53, nDims, &rotation, &bits, &index);
828
829 return hilbert_box_pt_work(nDims, 8, 64, findMin,
830 max, max+53, (char *)c1, (char *)c2,
831 rotation, bits, index,
832 getIEEEBits, propogateIEEEBits);
833 }
834
835 /*****************************************************************
836 * hilbert_nextinbox
837 *
838 * Determine the first point of a box after or before a given point to lie on
839 * a Hilbert curve
840 * Inputs:
841 * nDims: Number of coordinates.
842 * nBytes: Number of bytes/coordinate.
843 * nBits: Number of bits/coordinate.
844 * findPrev: Is it a previous point that you want?
845 * coord1: Array of nDims nBytes-byte coordinates - one corner of box
846 * coord2: Array of nDims nBytes-byte coordinates - opposite corner
847 * point: Array of nDims nBytes-byte coordinates - lower bound on point returned
848 *
849 * Output:
850 if returns 1:
851 * c1 and c2 modified to refer to least point after "point" in box
852 else returns 0:
853 arguments unchanged; "point" is beyond the last point of the box
854 * Assumptions:
855 * nBits <= (sizeof bitmask_t) * (bits_per_byte)
856 */
857 int
858 hilbert_nextinbox(unsigned nDims, unsigned nBytes, unsigned nBits,
859 int findPrev, void* c1V, void* c2V, void const* ptV)
860 {
861 bitmask_t const one = 1;
862 unsigned y = nBits;
863 bitmask_t const ndOnes = ones(bitmask_t,nDims);
864 bitmask_t const nd1Ones = ndOnes >> 1;
865 unsigned rotation = 0;
866 bitmask_t bits = 0;
867 bitmask_t index = 0;
868 bitmask_t fold1 = 0, fold2 = 0;
869 bitmask_t valu1 = 0, valu2 = 0;
870 unsigned p_y;
871 bitmask_t p_separator = 0, p_firstSeparator;
872 bitmask_t p_cornerdiff, p_reflection;
873 bitmask_t p_fold1, p_fold2, p_valu1, p_valu2;
874
875 char* c1 = (char*)c1V;
876 char* c2 = (char*)c2V;
877 char const* pt = (const char*)ptV;
878
879 while (y-- > 0)
880 {
881 bitmask_t reflection = getIntBits(nDims, nBytes, pt, y);
882 bitmask_t diff = reflection ^ /* planes that separate box and point */
883 ((getIntBits(nDims, nBytes, c1, y) &~ fold1) | valu1);
884
885 if (diff)
886 /* some coordinate planes separate point from box or
887 dividing box or both; smear the bits of diff to reflect that
888 after the first diff dimension, they might as well all be
889 diffing; adjust the diff to reflect the fact that diffed
890 dimensions don't matter. */
891 {
892 /* compute (the complement of) a "digit" in the integer index of this
893 point */
894 bitmask_t cornerdiff = (diff ^ reflection) ^ /* separate box crnrs */
895 ((getIntBits(nDims, nBytes, c2, y) &~ fold2) | valu2);
896 bitmask_t separator = diff & ~cornerdiff;
897 /* eventually, the most significant separating cutting plane */
898 bitmask_t firstSeparator;
899 /* bits less significant than the msb of separator are irrelevant;
900 for convenience, call them all separators too */
901 bitmask_t rotSep = rotateRight(separator, rotation, nDims);
902 /* compute the (complement of the) digit of the hilbert code
903 assoc with point */
904 bitmask_t digit = rotateRight(bits ^ reflection, rotation, nDims);
905 unsigned d;
906 for (d = 1; d < nDims; d *= 2)
907 {
908 index ^= index >> d;
909 digit ^= digit >> d;
910 rotSep |= rotSep >> d;
911 }
912 index &= 1;
913 digit &= rotSep;
914 if ((index ^ y ^ findPrev) & 1)
915 digit ^= rotSep;
916
917 separator = rotateLeft(rotSep, rotation, nDims);
918 rotSep -= rotSep >> 1;
919 firstSeparator = rotateLeft(rotSep, rotation, nDims);
920 /* forget about all the planes that split the box, except those that
921 are more significant than the most significant separator. */
922 cornerdiff &= ~separator;
923
924 if (cornerdiff && digit)
925 /* some coordinate planes divide the box. Call the part of the
926 box in the same orthant as the point "here" and the part of
927 the box in the next (or previous) orthant "there". Remember
928 what the "there" orthant of the box looks like in case it
929 turns out that the curve doesn't reenter the box "here" after
930 (before) passing thru point. Continue working with the
931 "here" part. If there is no "there" there, skip it */
932 {
933 p_firstSeparator = digit & -digit;
934 p_separator = 2*p_firstSeparator-1;
935 p_separator = rotateLeft(p_separator, rotation, nDims);
936 p_firstSeparator = rotateLeft(p_firstSeparator, rotation, nDims);
937 p_cornerdiff = cornerdiff &~ (p_separator ^ p_firstSeparator);
938 p_y = y;
939 p_reflection = reflection ^ p_firstSeparator;
940 p_fold1 = fold1;
941 p_fold2 = fold2;
942 p_valu1 = valu1;
943 p_valu2 = valu2;
944 }
945
946 if (digit < rotSep)
947
948 /* use next box */
949 {
950 if (!p_separator) return 0; /* no next point */
951 separator = p_separator;
952 firstSeparator = p_firstSeparator;
953 y = p_y;
954 cornerdiff = p_cornerdiff;
955 reflection = p_reflection;
956 fold1 = p_fold1;
957 fold2 = p_fold2;
958 valu1 = p_valu1;
959 valu2 = p_valu2;
960 }
961
962 if (cornerdiff)
963 {
964 /* reduce currbox */
965 bitmask_t corner = diff & cornerdiff;
966 cornerdiff ^= corner;
967 fold1 |= corner;
968 fold2 |= cornerdiff;
969 valu1 |= ~reflection & corner;
970 valu2 |= ~reflection & cornerdiff;
971 }
972
973 separator ^= firstSeparator;
974 if (firstSeparator)
975 /* we have completely separated the point from a part of the box
976 ahead of it on the curve; almost done */
977 {
978 unsigned byteId = whichByte(nBytes,y);
979 bitmask_t bthbit = one << y%8;
980 for (d = 0; d < nDims; ++d)
981 {
982 char lo1, lo2;
983 char* cc1 = &c1[d*nBytes];
984 char* cc2 = &c2[d*nBytes];
985 char const* pnt = &pt[d*nBytes];
986 char hibits = -bthbit;
987 char hipart = pnt[byteId] & hibits;
988 memcpy(cc1, pnt, byteId);
989 memcpy(cc2, pnt, byteId);
990
991 if (rdbit(separator, d))
992 hibits ^= bthbit;
993 if (rdbit(firstSeparator, d))
994 hipart ^= bthbit;
995
996 if (rdbit(fold1, d))
997 {
998 lo1 = -rdbit(valu1, d);
999 setBytes(cc1,byteId,nBytes,lo1);
1000 }
1001 else lo1 = cc1[byteId];
1002 cc1[byteId] = hipart | (lo1 &~ hibits);
1003
1004 if (rdbit(fold2, d))
1005 {
1006 lo2 = -rdbit(valu2, d);
1007 setBytes(cc2,byteId,nBytes,lo2);
1008 }
1009 else lo2 = cc2[byteId];
1010 cc2[byteId] = hipart | (lo2 &~ hibits);
1011 }
1012
1013 hilbert_box_pt(nDims, nBytes, nBits, !findPrev, c1V, c2V);
1014 return 1;
1015 }
1016 }
1017
1018 bits ^= reflection;
1019 bits = rotateRight(bits, rotation, nDims);
1020 index ^= bits;
1021 reflection ^= one << rotation;
1022 adjust_rotation(rotation,nDims,bits);
1023 bits = reflection;
1024 }
1025
1026 /* point is in box */
1027 {
1028 unsigned d;
1029 for (d = 0; d < nDims; ++d)
1030 ((char*)c1)[d] = ((char*)c2)[d] = ((char*)pt)[d];
1031 }
1032 return 1;
1033 }
1034
1035
1036
1037 /*****************************************************************
1038 * hilbert_incr
1039 *
1040 * Advance from one point to its successor on a Hilbert curve
1041 * Inputs:
1042 * nDims: Number of coordinates.
1043 * nBits: Number of bits/coordinate.
1044 * coord: Array of nDims nBits-bit coordinates.
1045 * Output:
1046 * coord: Next point on Hilbert curve
1047 * Assumptions:
1048 * nBits <= (sizeof bitmask_t) * (bits_per_byte)
1049 */
1050
1051 void
1052 hilbert_incr(unsigned nDims, unsigned nBits, bitmask_t coord[])
1053 {
1054 bitmask_t const one = 1;
1055 bitmask_t const ndOnes = ones(bitmask_t,nDims);
1056 bitmask_t const nd1Ones= ndOnes >> 1;
1057 unsigned b, d;
1058 unsigned rotation = 0;
1059 bitmask_t reflection = 0;
1060 bitmask_t index = 0;
1061 unsigned rb = nBits-1;
1062 bitmask_t rd = ndOnes;
1063
1064 for (b = nBits; b--;)
1065 {
1066 bitmask_t bits = reflection;
1067 reflection = 0;
1068 for (d = 0; d < nDims; ++d)
1069 reflection |= rdbit(coord[d], b) << d;
1070 bits ^= reflection;
1071 bits = rotateRight(bits, rotation, nDims);
1072 index ^= bits;
1073 for (d = 1; d < nDims; d *= 2)
1074 index ^= index >> d;
1075 if (index++ != ndOnes)
1076 {
1077 rb = b;
1078 rd = index & -index;
1079 rd = rotateLeft(rd, rotation, nDims);
1080
1081 }
1082 index &= 1;
1083 index <<= nDims-1;
1084
1085 reflection ^= one << rotation;
1086 adjust_rotation(rotation,nDims,bits);
1087 }
1088 for (d = 0; !rdbit(rd, d); ++d) {}
1089 coord[d] ^= (2 << rb) - 1;
1090 }
1091
1092
1093 /* LICENSE
1094 *
1095 * This software is copyrighted by Rice University. It may be freely copied,
1096 * modified, and redistributed, provided that the copyright notice is
1097 * preserved on all copies.
1098 *
1099 * There is no warranty or other guarantee of fitness for this software,
1100 * it is provided solely "as is". Bug reports or fixes may be sent
1101 * to the author, who may or may not act on them as he desires.
1102 *
1103 * You may include this software in a program or other software product,
1104 * but must display the notice:
1105 *
1106 * Hilbert Curve implementation copyright 1998, Rice University
1107 *
1108 * in any place where the end-user would see your own copyright.
1109 *
1110 * If you modify this software, you should include a notice giving the
1111 * name of the person performing the modification, the date of modification,
1112 * and the reason for such modification.
1113 */
1114
1115
1116
1117 /* Revision history:
1118
1119 July 1998: Initial release
1120
1121 Sept 1998: Second release
1122
1123 Dec 1998: Fixed bug in hilbert_c2i that allowed a shift by number of bits in
1124 bitmask to vaporize index, in last bit of the function. Implemented
1125 hilbert_incr.
1126
1127 August 1999: Added argument to hilbert_nextinbox so that you can, optionally,
1128 find the previous point along the curve to intersect the box, rather than the
1129 next point.
1130
1131 Nov 1999: Defined fast bit-transpose function (fast, at least, if the number
1132 of bits is large), and reimplemented i2c and c2i in terms of it. Collapsed
1133 loops in hilbert_cmp, with the intention of reusing the cmp code to compare
1134 more general bitstreams.
1135
1136 Feb 2000: Implemented almost all the floating point versions of cmp, etc, so
1137 that coordinates expressed in terms of double-precision IEEE floating point
1138 can be ordered. Still have to do next-in-box, though.
1139
1140 Oct 2001: Learned that some arbitrary coding choices caused some routines
1141 to fail in one dimension, and changed those choices.
1142
1143 version 2001-10-20-05:34
1144
1145 */
1146
1147 /* What remains is test code that won't be compiled unless you define the
1148 TEST_HILBERT preprocessor symbol */
1149
1150 #ifdef TEST_HILBERT
1151 #include <stdio.h>
1152 #define abs(x) (((x)>=0)?(x):(-(x)))
1153
1154 int main()
1155 {
1156 #define maxDim (8*sizeof(bitmask_t))
1157 bitmask_t coord[maxDim], coordPrev[maxDim];
1158 unsigned nDims, nBits, nPrints, orderCheck, i;
1159 bitmask_t r, r1;
1160
1161 for (;;)
1162 {
1163 printf( "Enter nDims, nBits, nPrints, orderCheck: " );
1164 scanf( "%d", &nDims);
1165 if ( nDims == 0 )
1166 break;
1167 scanf( "%d%d%d", &nBits, &nPrints, &orderCheck);
1168 while ( (i = getchar()) != '\n' && i != EOF )
1169 ;
1170 if ( i == EOF )
1171 break;
1172
1173 if (nDims*nBits > 8*sizeof(r))
1174 {
1175 printf("Product of nDims and nBits not exceed %d.\n", 8*sizeof(r));
1176 break;
1177 }
1178
1179 if (nBits == 0)
1180 {
1181 printf("nBits must be positive.\n");
1182 break;
1183 }
1184
1185 if (nPrints > (1ULL << (nDims*nBits)))
1186 nPrints = 1ULL << (nDims*nBits);
1187
1188 for (r = 0; r < nPrints; ++r)
1189 {
1190 bitmask_t coord1[maxDim];
1191 int miscount = 0;
1192 hilbert_i2c( nDims, nBits, r, coord );
1193 printf("%d: ", (unsigned)r);
1194 for (i = 0; i < nDims; ++i)
1195 {
1196 int diff = (int)(coord[i] - coordPrev[i]);
1197 miscount += abs(diff);
1198 coordPrev[i] = coord[i];
1199 printf(" %d", (unsigned)coord[i]);
1200 }
1201 if (r > 0 && miscount != 1)
1202 printf(".....error");
1203 printf("\n");
1204 r1 = hilbert_c2i( nDims, nBits, coord );
1205 if ( r != r1 )
1206 printf( "r = 0x%x; r1 = 0x%x\n", (unsigned)r, (unsigned)r1);
1207 for (i = 0; i < nDims; ++i)
1208 coord[i] = coordPrev[i];
1209
1210 if (! orderCheck)
1211 continue;
1212
1213 for (r1 = 0; r1 < r; ++r1 )
1214 {
1215 unsigned ans;
1216 hilbert_i2c( nDims, nBits, r1, coord1 );
1217 ans = hilbert_cmp( nDims, sizeof(coord[0]), nBits, coord, coord1);
1218 if (ans != 1)
1219 {
1220 int width = (nDims*nBits + 3) / 4;
1221 printf( "cmp r = 0x%0*x; r1 = 0x%0*x, ans = %2d\n",
1222 width, (unsigned)r,
1223 width, (unsigned)r1, ans );
1224 }
1225 }
1226 hilbert_i2c( nDims, nBits, r1, coord1 );
1227 if (hilbert_cmp( nDims, sizeof(coord[0]), nBits, coord, coord1) != 0)
1228 printf( "cmp r = 0x%0*x; r1 = 0x%0*x\n", (nDims*nBits+3)/4, (unsigned)r,
1229 (nDims*nBits+3)/4, (unsigned)r1 );
1230
1231 }
1232 }
1233 return 0;
1234 }
1235
1236 #endif
1237
1238 #ifdef TEST_IEEE
1239 #include <stdio.h>
1240 #include <stdlib.h>
1241 #include <math.h>
1242
1243 int cmp(const void* xv, const void* yv)
1244 {
1245 double const* x = xv;
1246 double const* y = yv;
1247 /* return hilbert_cmp(2, 8, 64, x, y); */
1248 return hilbert_ieee_cmp(2, x, y);
1249 }
1250
1251 int main()
1252 {
1253 double *a;
1254 unsigned i;
1255 unsigned n;
1256 printf("How many points? ");
1257 scanf("%d", &n);
1258 a = (double*) malloc(2*n*sizeof(double));
1259 for (i = 0; i < n; ++i)
1260 a[2*i] = drand48()-0.5, a[2*i+1] = drand48()-0.5;
1261
1262 qsort(a, n, 2*sizeof(double), cmp);
1263
1264 for (i = 0; i < n; ++i)
1265 printf("%8g %8g\n", a[2*i], a[2*i+1]);
1266 free(a);
1267 return 0;
1268 }
1269
1270 #endif
1271
1272 #ifdef TEST_CMP
1273 #include <stdio.h>
1274
1275 #define maxDim (8*sizeof(bitmask_t))
1276 int main()
1277 {
1278 double coord[maxDim];
1279 unsigned nDims, i, k;
1280
1281 printf( "Enter nDims: " );
1282 scanf( "%d", &nDims);
1283 if ( nDims == 0 )
1284 return 0;
1285 while ( (i = getchar()) != '\n' && i != EOF )
1286 ;
1287 if ( i == EOF )
1288 return 0;
1289
1290 for (k = 0; k < (1<<nDims); ++k)
1291 {
1292 printf("Orth %2d\n", k);
1293 for (i = 0; i < nDims; ++i)
1294 coord[i] = ((k>>i)&1)? -1.: 1.;
1295
1296
1297 hilbert_ieee_cmp( nDims, coord, coord);
1298 }
1299 return 0;
1300 }
1301
1302 #endif
1303
1304 #ifdef TEST_VTX
1305 #include <stdio.h>
1306 #include <stdlib.h>
1307
1308 #define maxDim (8*sizeof(bitmask_t))
1309
1310 unsigned g_nDims;
1311
1312 int cmp(void const* c1p, void const* c2p)
1313 {
1314 return hilbert_cmp(g_nDims, sizeof(unsigned), 8*sizeof(unsigned), c1p, c2p);
1315 }
1316
1317 int main()
1318 {
1319 unsigned corner0[maxDim], corner1[maxDim];
1320 unsigned cornerlo[maxDim], cornerhi[maxDim], work[maxDim];
1321 typedef unsigned array_t[maxDim];
1322 array_t* array;
1323
1324 unsigned nDims, i, k;
1325
1326 printf( "Enter nDims: " );
1327 scanf( "%d", &nDims);
1328 if ( nDims == 0 )
1329 return 0;
1330 while ( (i = getchar()) != '\n' && i != EOF )
1331 ;
1332 if ( i == EOF )
1333 return 0;
1334
1335 printf("Enter one corner (%d coordinates): ", nDims);
1336 for (k = 0; k < nDims; ++k)
1337 scanf("%d", &corner0[k]);
1338
1339 printf("Enter other corner (%d coordinates): ", nDims);
1340 for (k = 0; k < nDims; ++k)
1341 scanf("%d", &corner1[k]);
1342
1343
1344 /* find first corner */
1345 for (k = 0; k < nDims; ++k)
1346 {
1347 cornerlo[k] = corner0[k];
1348 work[k] = corner1[k];
1349 }
1350
1351 hilbert_box_vtx(nDims, sizeof(unsigned), 8*sizeof(unsigned),
1352 1, cornerlo, work);
1353 printf("Predicted lo corner: ");
1354 for (k = 0; k < nDims; ++k)
1355 printf("%4u", cornerlo[k]);
1356 printf("\n");
1357
1358
1359 /* find last corner */
1360 for (k = 0; k < nDims; ++k)
1361 {
1362 work[k] = corner0[k];
1363 cornerhi[k] = corner1[k];
1364 }
1365
1366 hilbert_box_vtx(nDims, sizeof(unsigned), 8*sizeof(unsigned),
1367 0, work, cornerhi);
1368 printf("Predicted hi corner: ");
1369 for (k = 0; k < nDims; ++k)
1370 printf("%4u", cornerhi[k]);
1371 printf("\n");
1372
1373 array = (array_t*) malloc(maxDim*sizeof(unsigned) << nDims);
1374 for (k = 0; k < (1<<nDims); ++k)
1375 {
1376 unsigned j;
1377 unsigned* eltk = &array[k][0];
1378 for (j = 0; j < nDims; ++j)
1379 {
1380 unsigned* src = ((k>>j)&1)? corner1: corner0;
1381 eltk[j] = src[j];
1382 }
1383 }
1384
1385 g_nDims = nDims;
1386 qsort(array, (1<<nDims), maxDim*sizeof(unsigned), cmp);
1387
1388 printf("Result of sort\n");
1389 for (k = 0; k < (1<<nDims); k += (1 << nDims) - 1)
1390 {
1391 unsigned j;
1392 unsigned* eltk = &array[k][0];
1393 for (j = 0; j < nDims; ++j)
1394 printf("%4u", eltk[j]);
1395 printf("\n");
1396 }
1397 free((char*)array);
1398 return 0;
1399 }
1400
1401 #endif
1402
1403 #ifdef TEST_IEEE_VTX
1404 #include <stdio.h>
1405 #include <stdlib.h>
1406 #include <assert.h>
1407
1408 #define maxDim (8*sizeof(bitmask_t))
1409 typedef double key_t;
1410
1411 unsigned g_nDims;
1412
1413 int cmp(void const* c1p, void const* c2p)
1414 {
1415 return hilbert_ieee_cmp(g_nDims, c1p, c2p);
1416 }
1417
1418 int main()
1419 {
1420 key_t corner0[maxDim], corner1[maxDim];
1421 key_t cornerlo[maxDim], cornerhi[maxDim], work[maxDim];
1422 typedef key_t array_t[maxDim];
1423 array_t* array;
1424
1425 unsigned nDims, i, k;
1426
1427 printf( "Enter nDims: " );
1428 scanf( "%d", &nDims);
1429 if ( nDims == 0 )
1430 return 0;
1431
1432 for (i = 0; i < 10000; ++i)
1433 {
1434 for (k = 0; k < nDims; ++k)
1435 {
1436 corner0[k] = 2.*drand48() - 1.;
1437 corner1[k] = 2.*drand48() - 1.;
1438 }
1439
1440 /* find first corner */
1441 for (k = 0; k < nDims; ++k)
1442 {
1443 cornerlo[k] = corner0[k];
1444 work[k] = corner1[k];
1445 }
1446
1447 hilbert_ieee_box_vtx(nDims, 1, cornerlo, work);
1448
1449 /* find last corner */
1450 for (k = 0; k < nDims; ++k)
1451 {
1452 work[k] = corner0[k];
1453 cornerhi[k] = corner1[k];
1454 }
1455
1456 hilbert_ieee_box_vtx(nDims, 0, work, cornerhi);
1457
1458 array = (array_t*) malloc(maxDim*sizeof(key_t) << nDims);
1459 for (k = 0; k < (1<<nDims); ++k)
1460 {
1461 unsigned j;
1462 key_t* eltk = &array[k][0];
1463 for (j = 0; j < nDims; ++j)
1464 {
1465 key_t* src = ((k>>j)&1)? corner1: corner0;
1466 eltk[j] = src[j];
1467 }
1468 }
1469
1470 g_nDims = nDims;
1471 qsort(array, (1<<nDims), maxDim*sizeof(key_t), cmp);
1472
1473 for (k = 0; k < (1<<nDims); k += (1 << nDims) - 1)
1474 {
1475 unsigned j;
1476 int mismatch = 0;
1477 key_t* eltk = &array[k][0];
1478 for (j = 0; j < nDims & !mismatch; ++j)
1479 {
1480 mismatch = (eltk[j] != ((k==0)? cornerlo: cornerhi)[j]);
1481 }
1482 assert (!mismatch);
1483 }
1484 free((char*)array);
1485 }
1486 return 0;
1487 }
1488
1489 #endif
1490
1491 #ifdef TEST_PT
1492 #include <stdio.h>
1493 #include <stdlib.h>
1494
1495 #define maxDim (8*sizeof(bitmask_t))
1496
1497 unsigned g_nDims;
1498
1499 int cmp(void const* c1p, void const* c2p)
1500 {
1501 return hilbert_cmp(g_nDims, sizeof(unsigned), 8*sizeof(unsigned), c1p, c2p);
1502 }
1503
1504 int main()
1505 {
1506 unsigned point0[maxDim], point1[maxDim];
1507 unsigned pointlo[maxDim], pointhi[maxDim], work[maxDim];
1508 typedef unsigned array_t[maxDim];
1509 array_t* array;
1510
1511 unsigned nDims, i, k, outvolume = 1, involume = 1;
1512 unsigned nextItem;
1513
1514 printf( "Enter nDims: " );
1515 scanf( "%d", &nDims);
1516 if ( nDims == 0 )
1517 return 0;
1518 while ( (i = getchar()) != '\n' && i != EOF )
1519 ;
1520 if ( i == EOF )
1521 return 0;
1522
1523 printf("Enter one point (%d coordinates): ", nDims);
1524 for (k = 0; k < nDims; ++k)
1525 scanf("%d", &point0[k]);
1526
1527 printf("Enter other point (%d coordinates, strictly greater): ", nDims);
1528 for (k = 0; k < nDims; ++k)
1529 {
1530 unsigned diff;
1531 scanf("%d", &point1[k]);
1532 diff = point1[k] - point0[k];
1533 outvolume *= diff + 1;
1534 involume *= diff - 1;
1535 }
1536
1537
1538 /* find first point */
1539 for (k = 0; k < nDims; ++k)
1540 {
1541 pointlo[k] = point0[k];
1542 work[k] = point1[k];
1543 }
1544
1545 hilbert_box_pt(nDims, sizeof(unsigned), 8*sizeof(unsigned),
1546 1, pointlo, work);
1547 printf("Predicted lo point: ");
1548 for (k = 0; k < nDims; ++k)
1549 printf("%4u", pointlo[k]);
1550 printf("\n");
1551
1552
1553 /* find last point */
1554 for (k = 0; k < nDims; ++k)
1555 {
1556 work[k] = point0[k];
1557 pointhi[k] = point1[k];
1558 }
1559
1560 hilbert_box_pt(nDims, sizeof(unsigned), 8*sizeof(unsigned),
1561 0, work, pointhi);
1562 printf("Predicted hi point: ");
1563 for (k = 0; k < nDims; ++k)
1564 printf("%4u", pointhi[k]);
1565 printf("\n");
1566
1567
1568
1569 array = (array_t*) malloc(maxDim*sizeof(unsigned) * (outvolume-involume));
1570 if (array == 0)
1571 {
1572 fprintf(stderr, "Out of memory.\n");
1573 exit(-1);
1574 }
1575 nextItem = 0;
1576 for (k = 0; k < outvolume; ++k)
1577 {
1578 unsigned kk = k;
1579 unsigned j;
1580 unsigned* eltk = &array[nextItem][0];
1581 int boundary = 0;
1582
1583 for (j = 0; j < nDims; ++j)
1584 {
1585 unsigned diff1 = point1[j] - point0[j] + 1;
1586 unsigned pos = point0[j] + (kk % diff1);
1587 boundary |= (point0[j] == pos || pos == point1[j]);
1588 eltk[j] = pos;
1589 kk /= diff1;
1590 }
1591 if (boundary)
1592 ++nextItem;
1593 }
1594
1595 g_nDims = nDims;
1596 qsort(array, outvolume-involume, maxDim*sizeof(unsigned), cmp);
1597
1598 printf("Result of sort\n");
1599 for (k = 0; k < outvolume-involume; k += outvolume-involume-1)
1600 {
1601 unsigned j;
1602 unsigned* eltk = &array[k][0];
1603 for (j = 0; j < nDims; ++j)
1604 printf("%4u", eltk[j]);
1605 printf("\n");
1606 }
1607 free((char*)array);
1608 return 0;
1609 }
1610
1611 #endif
1612
1613 #ifdef TEST_IEEE_PT
1614 #include <stdio.h>
1615 #include <stdlib.h>
1616
1617 #define maxDim (8*sizeof(bitmask_t))
1618
1619 int main()
1620 {
1621 double point0[maxDim], point1[maxDim];
1622 double pointlo[maxDim], pointhi[maxDim], work[maxDim];
1623
1624 unsigned nDims, k, i;
1625
1626 printf( "Enter nDims: " );
1627 scanf( "%d", &nDims);
1628 if ( nDims == 0 )
1629 return 0;
1630 while ( (i = getchar()) != '\n' && i != EOF )
1631 ;
1632 if ( i == EOF )
1633 return 0;
1634
1635 printf("Enter one point (%d coordinates): ", nDims);
1636 for (k = 0; k < nDims; ++k)
1637 scanf("%lf", &point0[k]);
1638
1639 printf("Enter other point (%d coordinates, strictly greater): ", nDims);
1640 for (k = 0; k < nDims; ++k)
1641 scanf("%lf", &point1[k]);
1642
1643 /* find last point */
1644 for (k = 0; k < nDims; ++k)
1645 {
1646 work[k] = point0[k];
1647 pointhi[k] = point1[k];
1648 }
1649
1650 hilbert_ieee_box_pt(nDims, 0, work, pointhi);
1651 printf("Predicted hi point: ");
1652 for (k = 0; k < nDims; ++k)
1653 printf("%10lg", pointhi[k]);
1654 printf("\n");
1655
1656 /* find first point */
1657 for (k = 0; k < nDims; ++k)
1658 {
1659 pointlo[k] = point0[k];
1660 work[k] = point1[k];
1661 }
1662
1663 hilbert_ieee_box_pt(nDims, 1, pointlo, work);
1664 printf("Predicted lo point: ");
1665 for (k = 0; k < nDims; ++k)
1666 printf("%10lg", pointlo[k]);
1667 printf("\n");
1668
1669 /* validate by sorting random boundary points */
1670 #define nPts 1000000
1671 assert(hilbert_ieee_cmp(nDims, pointlo, pointhi) < 0);
1672 for (i = 0; i < nPts; ++i)
1673 {
1674 double pt1[maxDim], pt2[maxDim];
1675 for (k = 0; k < nDims; ++k)
1676 {
1677 if (i % nDims == k)
1678 pt1[k] = point0[k];
1679 else
1680 pt1[k] = point0[k] + drand48()*(point1[k]-point0[k]);
1681 }
1682 for (k = 0; k < nDims; ++k)
1683 {
1684 if (i % nDims == k)
1685 pt2[k] = point1[k];
1686 else
1687 pt2[k] = point0[k] + drand48()*(point1[k]-point0[k]);
1688 }
1689 if (hilbert_ieee_cmp(nDims, pt1, pt2) < 0)
1690 {
1691 if (hilbert_ieee_cmp(nDims, pt1, pointlo) < 0)
1692 memcpy(pointlo, pt1, maxDim*sizeof(double));
1693 if (hilbert_ieee_cmp(nDims, pointhi, pt2) < 0)
1694 memcpy(pointhi, pt2, maxDim*sizeof(double));
1695 }
1696 else
1697 {
1698 if (hilbert_ieee_cmp(nDims, pt2, pointlo) < 0)
1699 memcpy(pointlo, pt2, maxDim*sizeof(double));
1700 if (hilbert_ieee_cmp(nDims, pointhi, pt1) < 0)
1701 memcpy(pointhi, pt1, maxDim*sizeof(double));
1702 }
1703 }
1704
1705 printf("Sorted hi and lo:\n");
1706 for (k = 0; k < nDims; ++k)
1707 printf("%10lg", pointhi[k]);
1708 printf("\n");
1709 for (k = 0; k < nDims; ++k)
1710 printf("%10lg", pointlo[k]);
1711 printf("\n");
1712
1713 return 0;
1714 }
1715
1716 #endif
1717
1718 #ifdef TEST_NEXT
1719 #include <stdio.h>
1720
1721 int main()
1722 {
1723 unsigned i;
1724 unsigned c1[100], c2[100], pt[100];
1725 unsigned nDims, nBytes = 4;
1726 int stat, findPrev;
1727 printf("Enter nDims: " );
1728 scanf("%u", &nDims);
1729
1730 printf("Enter 1st box corner: ");
1731 for (i = 0; i < nDims; ++i)
1732 scanf("%u", &c1[i]);
1733 printf("Enter 2nd box corner: ");
1734 for (i = 0; i < nDims; ++i)
1735 scanf("%u", &c2[i]);
1736 printf("Enter point: ");
1737 for (i = 0; i < nDims; ++i)
1738 scanf("%u", &pt[i]);
1739 printf("Find prev?: ");
1740 scanf("%d", &findPrev);
1741
1742 stat = hilbert_nextinbox(nDims, nBytes, 8*nBytes, findPrev, c1, c2, pt);
1743
1744 if (stat)
1745 for (i = 0; i < nDims; ++i)
1746 printf("%u ", c1[i]);
1747 else
1748 printf("No such point");
1749
1750 printf("\n");
1751 return 0;
1752 }
1753 #endif
