1 |
/* Copyright (c) 1994 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* header.c - routines for reading and writing information headers. |
9 |
10 |
* 8/19/88 |
11 |
12 |
* newheader(t,fp) start new information header identified by string t |
13 |
* isheadid(s) returns true if s is a header id line |
14 |
* headidval(r,s) copy header identifier value in s to r |
15 |
* printargs(ac,av,fp) print an argument list to fp, followed by '\n' |
16 |
* isformat(s) returns true if s is of the form "FORMAT=*" |
17 |
* formatval(r,s) copy the format value in s to r |
18 |
* fputformat(s,fp) write "FORMAT=%s" to fp |
19 |
* getheader(fp,f,p) read header from fp, calling f(s,p) on each line |
20 |
* globmatch(pat, str) check for glob match of str against pat |
21 |
* checkheader(i,p,o) check header format from i against p and copy to o |
22 |
23 |
* To copy header from input to output, use getheader(fin, fputs, fout) |
24 |
25 |
26 |
#include <stdio.h> |
27 |
#include <ctype.h> |
28 |
29 |
#define MAXLINE 512 |
30 |
31 |
#ifndef BSD |
32 |
#define index strchr |
33 |
#endif |
34 |
35 |
extern char *index(); |
36 |
37 |
char HDRSTR[] = "#?"; /* information header magic number */ |
38 |
39 |
char FMTSTR[] = "FORMAT="; /* format identifier */ |
40 |
41 |
42 |
newheader(s, fp) /* identifying line of information header */ |
43 |
char *s; |
44 |
register FILE *fp; |
45 |
46 |
fputs(HDRSTR, fp); |
47 |
fputs(s, fp); |
48 |
putc('\n', fp); |
49 |
50 |
51 |
52 |
int |
53 |
headidval(r,s) /* get header id (return true if is id) */ |
54 |
register char *r, *s; |
55 |
56 |
register char *cp = HDRSTR; |
57 |
58 |
while (*cp) if (*cp++ != *s++) return(0); |
59 |
if (r == NULL) return(1); |
60 |
while (*s) *r++ = *s++; |
61 |
*r = '\0'; |
62 |
return(1); |
63 |
64 |
65 |
66 |
int |
67 |
isheadid(s) /* check to see if line is header id */ |
68 |
char *s; |
69 |
70 |
return(headidval(NULL, s)); |
71 |
72 |
73 |
74 |
printargs(ac, av, fp) /* print arguments to a file */ |
75 |
int ac; |
76 |
char **av; |
77 |
78 |
79 |
int quote; |
80 |
81 |
while (ac-- > 0) { |
82 |
if (index(*av, ' ') != NULL) { /* quote it */ |
83 |
if (index(*av, '\'') != NULL) |
84 |
quote = '"'; |
85 |
else |
86 |
quote = '\''; |
87 |
putc(quote, fp); |
88 |
fputs(*av++, fp); |
89 |
putc(quote, fp); |
90 |
} else |
91 |
fputs(*av++, fp); |
92 |
putc(' ', fp); |
93 |
94 |
putc('\n', fp); |
95 |
96 |
97 |
98 |
int |
99 |
formatval(r, s) /* get format value (return true if format) */ |
100 |
register char *r; |
101 |
register char *s; |
102 |
103 |
register char *cp = FMTSTR; |
104 |
105 |
106 |
while (isspace(*s)) s++; |
107 |
if (!*s) return(0); |
108 |
109 |
do |
110 |
*r++ = *s++; |
111 |
while(*s && !isspace(*s)); |
112 |
*r = '\0'; |
113 |
return(1); |
114 |
115 |
116 |
117 |
int |
118 |
isformat(s) /* is line a format line? */ |
119 |
char *s; |
120 |
121 |
return(formatval(NULL, s)); |
122 |
123 |
124 |
125 |
fputformat(s, fp) /* put out a format value */ |
126 |
char *s; |
127 |
FILE *fp; |
128 |
129 |
fputs(FMTSTR, fp); |
130 |
fputs(s, fp); |
131 |
putc('\n', fp); |
132 |
133 |
134 |
135 |
int |
136 |
getheader(fp, f, p) /* get header from file */ |
137 |
FILE *fp; |
138 |
int (*f)(); |
139 |
char *p; |
140 |
141 |
char buf[MAXLINE]; |
142 |
143 |
for ( ; ; ) { |
144 |
buf[MAXLINE-2] = '\n'; |
145 |
if (fgets(buf, MAXLINE, fp) == NULL) |
146 |
return(-1); |
147 |
if (buf[0] == '\n') |
148 |
return(0); |
149 |
#ifdef MSDOS |
150 |
if (buf[0] == '\r' && buf[1] == '\n') |
151 |
return(0); |
152 |
#endif |
153 |
if (buf[MAXLINE-2] != '\n') { |
154 |
ungetc(buf[MAXLINE-2], fp); /* prevent false end */ |
155 |
buf[MAXLINE-2] = '\0'; |
156 |
157 |
if (f != NULL) |
158 |
(*f)(buf, p); |
159 |
160 |
161 |
162 |
163 |
struct check { |
164 |
FILE *fp; |
165 |
char fs[64]; |
166 |
167 |
168 |
169 |
static |
170 |
mycheck(s, cp) /* check a header line for format info. */ |
171 |
char *s; |
172 |
register struct check *cp; |
173 |
174 |
if (!formatval(cp->fs, s) && cp->fp != NULL) |
175 |
fputs(s, cp->fp); |
176 |
177 |
178 |
179 |
int |
180 |
globmatch(pat, str) /* check for glob match of str against pat */ |
181 |
char *pat, *str; |
182 |
183 |
register char *p = pat, *s = str; |
184 |
185 |
do { |
186 |
switch (*p) { |
187 |
case '?': /* match any character */ |
188 |
if (!*s++) |
189 |
return(0); |
190 |
break; |
191 |
case '*': /* match any string */ |
192 |
while (p[1] == '*') p++; |
193 |
do |
194 |
if ( (p[1]=='?' || p[1]==*s) && |
195 |
globmatch(p+1,s) ) |
196 |
return(1); |
197 |
while (*s++); |
198 |
return(0); |
199 |
case '\\': /* literal next */ |
200 |
p++; |
201 |
/* fall through */ |
202 |
default: /* normal character */ |
203 |
if (*p != *s) |
204 |
return(0); |
205 |
s++; |
206 |
break; |
207 |
208 |
} while (*p++); |
209 |
return(1); |
210 |
211 |
212 |
213 |
214 |
* Checkheader(fin,fmt,fout) returns a value of 1 if the input format |
215 |
* matches the specification in fmt, 0 if no input format was found, |
216 |
* and -1 if the input format does not match or there is an |
217 |
* error reading the header. If fmt is empty, then -1 is returned |
218 |
* if any input format is found (or there is an error), and 0 otherwise. |
219 |
* If fmt contains any '*' or '?' characters, then checkheader |
220 |
* does wildcard expansion and copies a matching result into fmt. |
221 |
* Be sure that fmt is big enough to hold the match in such cases! |
222 |
* The input header (minus any format lines) is copied to fout |
223 |
* if fout is not NULL. |
224 |
225 |
226 |
int |
227 |
checkheader(fin, fmt, fout) |
228 |
FILE *fin; |
229 |
char *fmt; |
230 |
FILE *fout; |
231 |
232 |
struct check cdat; |
233 |
234 |
cdat.fp = fout; |
235 |
cdat.fs[0] = '\0'; |
236 |
if (getheader(fin, mycheck, &cdat) < 0) |
237 |
return(-1); |
238 |
if (!cdat.fs[0]) |
239 |
return(0); |
240 |
if (globmatch(fmt, cdat.fs)) { |
241 |
strcpy(fmt, cdat.fs); |
242 |
return(1); |
243 |
244 |
return(-1); |
245 |
