| 1 |
/* Copyright (c) 1994 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* header.c - routines for reading and writing information headers.
| 9 |
| 10 |
* 8/19/88
| 11 |
| 12 |
* newheader(t,fp) start new information header identified by string t
| 13 |
* isheadid(s) returns true if s is a header id line
| 14 |
* headidval(r,s) copy header identifier value in s to r
| 15 |
* printargs(ac,av,fp) print an argument list to fp, followed by '\n'
| 16 |
* isformat(s) returns true if s is of the form "FORMAT=*"
| 17 |
* formatval(r,s) copy the format value in s to r
| 18 |
* fputformat(s,fp) write "FORMAT=%s" to fp
| 19 |
* getheader(fp,f,p) read header from fp, calling f(s,p) on each line
| 20 |
* globmatch(pat, str) check for glob match of str against pat
| 21 |
* checkheader(i,p,o) check header format from i against p and copy to o
| 22 |
| 23 |
* To copy header from input to output, use getheader(fin, fputs, fout)
| 24 |
| 25 |
| 26 |
#include <stdio.h>
| 27 |
#include <ctype.h>
| 28 |
| 29 |
#define MAXLINE 512
| 30 |
| 31 |
#ifndef BSD
| 32 |
#define index strchr
| 33 |
#endif
| 34 |
| 35 |
extern char *index();
| 36 |
| 37 |
char HDRSTR[] = "#?"; /* information header magic number */
| 38 |
| 39 |
char FMTSTR[] = "FORMAT="; /* format identifier */
| 40 |
| 41 |
| 42 |
newheader(s, fp) /* identifying line of information header */
| 43 |
char *s;
| 44 |
register FILE *fp;
| 45 |
| 46 |
fputs(HDRSTR, fp);
| 47 |
fputs(s, fp);
| 48 |
putc('\n', fp);
| 49 |
| 50 |
| 51 |
| 52 |
int
| 53 |
headidval(r,s) /* get header id (return true if is id) */
| 54 |
register char *r, *s;
| 55 |
| 56 |
register char *cp = HDRSTR;
| 57 |
| 58 |
while (*cp) if (*cp++ != *s++) return(0);
| 59 |
if (r == NULL) return(1);
| 60 |
while (*s) *r++ = *s++;
| 61 |
*r = '\0';
| 62 |
return(1);
| 63 |
| 64 |
| 65 |
| 66 |
int
| 67 |
isheadid(s) /* check to see if line is header id */
| 68 |
char *s;
| 69 |
| 70 |
return(headidval(NULL, s));
| 71 |
| 72 |
| 73 |
| 74 |
printargs(ac, av, fp) /* print arguments to a file */
| 75 |
int ac;
| 76 |
char **av;
| 77 |
register FILE *fp;
| 78 |
| 79 |
int quote;
| 80 |
| 81 |
while (ac-- > 0) {
| 82 |
if (index(*av, ' ') != NULL) { /* quote it */
| 83 |
if (index(*av, '\'') != NULL)
| 84 |
quote = '"';
| 85 |
else
| 86 |
quote = '\'';
| 87 |
putc(quote, fp);
| 88 |
fputs(*av++, fp);
| 89 |
putc(quote, fp);
| 90 |
} else
| 91 |
fputs(*av++, fp);
| 92 |
putc(' ', fp);
| 93 |
| 94 |
putc('\n', fp);
| 95 |
| 96 |
| 97 |
| 98 |
int
| 99 |
formatval(r, s) /* get format value (return true if format) */
| 100 |
register char *r;
| 101 |
register char *s;
| 102 |
| 103 |
register char *cp = FMTSTR;
| 104 |
| 105 |
| 106 |
while (isspace(*s)) s++;
| 107 |
if (!*s) return(0);
| 108 |
| 109 |
do
| 110 |
*r++ = *s++;
| 111 |
while(*s && !isspace(*s));
| 112 |
*r = '\0';
| 113 |
return(1);
| 114 |
| 115 |
| 116 |
| 117 |
int
| 118 |
isformat(s) /* is line a format line? */
| 119 |
char *s;
| 120 |
| 121 |
return(formatval(NULL, s));
| 122 |
| 123 |
| 124 |
| 125 |
fputformat(s, fp) /* put out a format value */
| 126 |
char *s;
| 127 |
FILE *fp;
| 128 |
| 129 |
fputs(FMTSTR, fp);
| 130 |
fputs(s, fp);
| 131 |
putc('\n', fp);
| 132 |
| 133 |
| 134 |
| 135 |
int
| 136 |
getheader(fp, f, p) /* get header from file */
| 137 |
FILE *fp;
| 138 |
int (*f)();
| 139 |
char *p;
| 140 |
| 141 |
char buf[MAXLINE];
| 142 |
| 143 |
for ( ; ; ) {
| 144 |
buf[MAXLINE-2] = '\n';
| 145 |
if (fgets(buf, MAXLINE, fp) == NULL)
| 146 |
return(-1);
| 147 |
if (buf[0] == '\n')
| 148 |
return(0);
| 149 |
#ifdef MSDOS
| 150 |
if (buf[0] == '\r' && buf[1] == '\n')
| 151 |
return(0);
| 152 |
#endif
| 153 |
if (buf[MAXLINE-2] != '\n') {
| 154 |
ungetc(buf[MAXLINE-2], fp); /* prevent false end */
| 155 |
buf[MAXLINE-2] = '\0';
| 156 |
| 157 |
if (f != NULL)
| 158 |
(*f)(buf, p);
| 159 |
| 160 |
| 161 |
| 162 |
| 163 |
struct check {
| 164 |
FILE *fp;
| 165 |
char fs[64];
| 166 |
| 167 |
| 168 |
| 169 |
static
| 170 |
mycheck(s, cp) /* check a header line for format info. */
| 171 |
char *s;
| 172 |
register struct check *cp;
| 173 |
| 174 |
if (!formatval(cp->fs, s) && cp->fp != NULL)
| 175 |
fputs(s, cp->fp);
| 176 |
| 177 |
| 178 |
| 179 |
int
| 180 |
globmatch(pat, str) /* check for glob match of str against pat */
| 181 |
char *pat, *str;
| 182 |
| 183 |
register char *p = pat, *s = str;
| 184 |
| 185 |
do {
| 186 |
switch (*p) {
| 187 |
case '?': /* match any character */
| 188 |
if (!*s++)
| 189 |
return(0);
| 190 |
break;
| 191 |
case '*': /* match any string */
| 192 |
while (p[1] == '*') p++;
| 193 |
do
| 194 |
if ( (p[1]=='?' || p[1]==*s) &&
| 195 |
globmatch(p+1,s) )
| 196 |
return(1);
| 197 |
while (*s++);
| 198 |
return(0);
| 199 |
case '\\': /* literal next */
| 200 |
p++;
| 201 |
/* fall through */
| 202 |
default: /* normal character */
| 203 |
if (*p != *s)
| 204 |
return(0);
| 205 |
s++;
| 206 |
break;
| 207 |
| 208 |
} while (*p++);
| 209 |
return(1);
| 210 |
| 211 |
| 212 |
| 213 |
| 214 |
* Checkheader(fin,fmt,fout) returns a value of 1 if the input format
| 215 |
* matches the specification in fmt, 0 if no input format was found,
| 216 |
* and -1 if the input format does not match or there is an
| 217 |
* error reading the header. If fmt is empty, then -1 is returned
| 218 |
* if any input format is found (or there is an error), and 0 otherwise.
| 219 |
* If fmt contains any '*' or '?' characters, then checkheader
| 220 |
* does wildcard expansion and copies a matching result into fmt.
| 221 |
* Be sure that fmt is big enough to hold the match in such cases!
| 222 |
* The input header (minus any format lines) is copied to fout
| 223 |
* if fout is not NULL.
| 224 |
| 225 |
| 226 |
int
| 227 |
checkheader(fin, fmt, fout)
| 228 |
FILE *fin;
| 229 |
char *fmt;
| 230 |
FILE *fout;
| 231 |
| 232 |
struct check cdat;
| 233 |
| 234 |
cdat.fp = fout;
| 235 |
cdat.fs[0] = '\0';
| 236 |
if (getheader(fin, mycheck, &cdat) < 0)
| 237 |
return(-1);
| 238 |
if (!cdat.fs[0])
| 239 |
return(0);
| 240 |
if (globmatch(fmt, cdat.fs)) {
| 241 |
strcpy(fmt, cdat.fs);
| 242 |
return(1);
| 243 |
| 244 |
return(-1);
| 245 |
