| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: header.c,v 2.50 2025/06/06 19:11:21 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* header.c - routines for reading and writing information headers.
| 6 |
| 7 |
* Externals declared in rtio.h
| 8 |
| 9 |
* newheader(t,fp) start new information header identified by string t
| 10 |
* headidval(r,s) copy header identifier value in s to r
| 11 |
* dateval(t,s) get capture date value as UTC
| 12 |
* gmtval(t,s) get GMT as UTC
| 13 |
* fputdate(t,fp) put out the given UTC
| 14 |
* fputnow(fp) put out the current date and time
| 15 |
* formatval(r,s) copy the format value in s to r
| 16 |
* fputformat(s,fp) write "FORMAT=%s" to fp
| 17 |
* nativebigendian() are we native on big-endian machine?
| 18 |
* isbigendian(s) header line matches "BigEndian=1" (-1 if irrelevant)
| 19 |
* fputendian(fp) write native endianness in BigEndian= line
| 20 |
* getheader(fp,f,p) read header from fp, calling f(s,p) on each line
| 21 |
* globmatch(pat, str) check for glob match of str against pat
| 22 |
* checkheader(i,p,o) check header format from i against p and copy to o
| 23 |
| 24 |
* To copy header from input to output, use getheader(fin, fputs, fout)
| 25 |
| 26 |
| 27 |
#include "copyright.h"
| 28 |
| 29 |
#include <ctype.h>
| 30 |
| 31 |
#include "tiff.h" /* for int32 */
| 32 |
#include "rtio.h"
| 33 |
#include "color.h"
| 34 |
#include "resolu.h"
| 35 |
| 36 |
#define MAXLINE 2048
| 37 |
| 38 |
extern time_t timegm(struct tm *tm);
| 39 |
| 40 |
const char HDRSTR[] = "#?"; /* information header magic number */
| 41 |
| 42 |
const char FMTSTR[] = "FORMAT="; /* format identifier */
| 43 |
| 44 |
const char TMSTR[] = "CAPDATE="; /* capture date identifier */
| 45 |
const char GMTSTR[] = "GMT="; /* GMT identifier */
| 46 |
| 47 |
const char BIGEND[] = "BigEndian="; /* big-endian variable */
| 48 |
| 49 |
static gethfunc mycheck;
| 50 |
| 51 |
| 52 |
void
| 53 |
newheader( /* identifying line of information header */
| 54 |
const char *s,
| 55 |
FILE *fp
| 56 |
| 57 |
| 58 |
fputs(HDRSTR, fp);
| 59 |
fputs(s, fp);
| 60 |
fputc('\n', fp);
| 61 |
| 62 |
| 63 |
| 64 |
int
| 65 |
headidval( /* get header id (return true if is id) */
| 66 |
char *r,
| 67 |
const char *s
| 68 |
| 69 |
| 70 |
const char *cp = HDRSTR;
| 71 |
| 72 |
while (*cp) if (*cp++ != *s++) return(0);
| 73 |
if (r == NULL) return(1);
| 74 |
while (*s && !isspace(*s)) *r++ = *s++;
| 75 |
*r = '\0';
| 76 |
return(1);
| 77 |
| 78 |
| 79 |
| 80 |
int
| 81 |
dateval( /* convert capture date line to UTC */
| 82 |
time_t *tloc,
| 83 |
const char *s
| 84 |
| 85 |
| 86 |
struct tm tms;
| 87 |
const char *cp = TMSTR;
| 88 |
| 89 |
| 90 |
while (isspace(*s)) s++;
| 91 |
if (!*s) return(0);
| 92 |
if (sscanf(s, "%d:%d:%d %d:%d:%d",
| 93 |
&tms.tm_year, &tms.tm_mon, &tms.tm_mday,
| 94 |
&tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
| 95 |
return(0);
| 96 |
if (tloc == NULL)
| 97 |
return(1);
| 98 |
tms.tm_mon--;
| 99 |
tms.tm_year -= 1900;
| 100 |
tms.tm_isdst = -1; /* ask mktime() to figure out DST */
| 101 |
*tloc = mktime(&tms);
| 102 |
return(1);
| 103 |
| 104 |
| 105 |
| 106 |
int
| 107 |
gmtval( /* convert GMT date line to UTC */
| 108 |
time_t *tloc,
| 109 |
const char *s
| 110 |
| 111 |
| 112 |
struct tm tms;
| 113 |
const char *cp = GMTSTR;
| 114 |
| 115 |
| 116 |
| 117 |
if (!*s) return(0);
| 118 |
| 119 |
| 120 |
| 121 |
return(0);
| 122 |
if (tloc == NULL)
| 123 |
return(1);
| 124 |
tms.tm_mon--;
| 125 |
| 126 |
*tloc = timegm(&tms);
| 127 |
return(1);
| 128 |
| 129 |
| 130 |
| 131 |
void
| 132 |
fputdate( /* write out the given time value (local & GMT) */
| 133 |
time_t tv,
| 134 |
FILE *fp
| 135 |
| 136 |
| 137 |
struct tm *tms;
| 138 |
| 139 |
tms = localtime(&tv);
| 140 |
if (tms != NULL)
| 141 |
fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
| 142 |
tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
| 143 |
tms->tm_hour, tms->tm_min, tms->tm_sec);
| 144 |
tms = gmtime(&tv);
| 145 |
if (tms != NULL)
| 146 |
fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", GMTSTR,
| 147 |
| 148 |
| 149 |
| 150 |
| 151 |
| 152 |
void
| 153 |
fputnow( /* write out the current time */
| 154 |
FILE *fp
| 155 |
| 156 |
| 157 |
time_t tv;
| 158 |
time(&tv);
| 159 |
fputdate(tv, fp);
| 160 |
| 161 |
| 162 |
| 163 |
int
| 164 |
formatval( /* get format value (return true if format) */
| 165 |
char fmt[MAXFMTLEN],
| 166 |
const char *s
| 167 |
| 168 |
| 169 |
const char *cp = FMTSTR;
| 170 |
char *r = fmt;
| 171 |
/* check against format string */
| 172 |
| 173 |
| 174 |
if (!*s) return(0);
| 175 |
if (r == NULL) /* just checking if format? */
| 176 |
return(1);
| 177 |
do /* copy format ID */
| 178 |
*r++ = *s++;
| 179 |
while (*s && r-fmt < MAXFMTLEN-1);
| 180 |
| 181 |
do /* remove trailing white space */
| 182 |
*r-- = '\0';
| 183 |
while (r > fmt && isspace(*r));
| 184 |
| 185 |
return(1);
| 186 |
| 187 |
| 188 |
| 189 |
void
| 190 |
fputformat( /* put out a format value */
| 191 |
const char *s,
| 192 |
FILE *fp
| 193 |
| 194 |
| 195 |
int align = 0;
| 196 |
| 197 |
fputs(FMTSTR, fp);
| 198 |
fputs(s, fp);
| 199 |
/* pad to align binary type for mmap() */
| 200 |
if (globmatch(PICFMT, s))
| 201 |
align = 0; /* not needed for picture data */
| 202 |
else if (!strncmp("float", s, 5))
| 203 |
align = sizeof(float);
| 204 |
else if (!strncmp("double", s, 6))
| 205 |
align = sizeof(double);
| 206 |
else if (!strncmp("16-bit", s, 6))
| 207 |
align = 2;
| 208 |
else if (!strncmp("32-bit", s, 6))
| 209 |
align = 4;
| 210 |
else if (!strncmp("64-bit", s, 6))
| 211 |
align = 8;
| 212 |
if (align) {
| 213 |
long pos = ftell(fp);
| 214 |
if (pos >= 0) {
| 215 |
pos = (pos + 2) % align;
| 216 |
if (pos) align -= pos;
| 217 |
else align = 0;
| 218 |
} else
| 219 |
align = 0;
| 220 |
| 221 |
while (align-- > 0)
| 222 |
putc(' ', fp);
| 223 |
fputc('\n', fp);
| 224 |
| 225 |
| 226 |
| 227 |
int
| 228 |
nativebigendian() /* are we native on a big-endian machine? */
| 229 |
| 230 |
union { int32 i; char c[4]; } u;
| 231 |
| 232 |
u.i = 1;
| 233 |
| 234 |
return(u.c[0] == 0);
| 235 |
| 236 |
| 237 |
| 238 |
int
| 239 |
isbigendian( /* header line says "BigEndian=1" (-1 if irrelevant) */
| 240 |
const char *s
| 241 |
| 242 |
| 243 |
const char *be = BIGEND;
| 244 |
| 245 |
while ((*s != '\0') & (*be != '=') && *s++ == *be)
| 246 |
++be;
| 247 |
if (*be != '=')
| 248 |
return(-1); /* irrelevant */
| 249 |
while (isspace(*s))
| 250 |
s++;
| 251 |
if (*s++ != '=')
| 252 |
return(-1);
| 253 |
while (isspace(*s))
| 254 |
s++;
| 255 |
return(*s == '1');
| 256 |
| 257 |
| 258 |
| 259 |
void
| 260 |
fputendian( /* write native endianness in BigEndian= line */
| 261 |
FILE *fp
| 262 |
| 263 |
| 264 |
fputs(BIGEND, fp);
| 265 |
if (nativebigendian())
| 266 |
fputs("1\n", fp);
| 267 |
else
| 268 |
fputs("0\n", fp);
| 269 |
| 270 |
| 271 |
| 272 |
int
| 273 |
getheader( /* get header from file */
| 274 |
FILE *fp,
| 275 |
gethfunc *f,
| 276 |
void *p
| 277 |
| 278 |
| 279 |
int rtotal = 0;
| 280 |
char buf[MAXLINE];
| 281 |
int firstc = fgetc(fp);
| 282 |
| 283 |
if (!isprint(firstc))
| 284 |
return(-1); /* messed up */
| 285 |
ungetc(firstc, fp);
| 286 |
for ( ; ; ) {
| 287 |
int rval = 0;
| 288 |
buf[MAXLINE-2] = '\n';
| 289 |
if (fgets(buf, MAXLINE, fp) == NULL)
| 290 |
return(-1);
| 291 |
if (buf[buf[0]=='\r'] == '\n') /* end of header? */
| 292 |
return(rtotal);
| 293 |
if (buf[MAXLINE-2] != '\n') {
| 294 |
ungetc(buf[MAXLINE-2], fp); /* prevent false end */
| 295 |
buf[MAXLINE-2] = '\0';
| 296 |
| 297 |
if (f != NULL && (rval = (*f)(buf, p)) < 0)
| 298 |
return(-1);
| 299 |
rtotal += rval;
| 300 |
| 301 |
| 302 |
| 303 |
| 304 |
struct check {
| 305 |
FILE *fp;
| 306 |
char fs[MAXFMTLEN];
| 307 |
| 308 |
| 309 |
| 310 |
static int
| 311 |
mycheck( /* check a header line for format info. */
| 312 |
char *s,
| 313 |
void *cp
| 314 |
| 315 |
| 316 |
struct check *scp = (struct check *)cp;
| 317 |
| 318 |
if (!formatval(scp->fs, s) && scp->fp != NULL)
| 319 |
return(fputs(s, scp->fp));
| 320 |
| 321 |
return(0);
| 322 |
| 323 |
| 324 |
| 325 |
int
| 326 |
globmatch( /* check for match of s against pattern p */
| 327 |
const char *p,
| 328 |
const char *s
| 329 |
| 330 |
| 331 |
int setmatch;
| 332 |
| 333 |
do {
| 334 |
switch (*p) {
| 335 |
case '?': /* match any character */
| 336 |
if (!*s++)
| 337 |
return(0);
| 338 |
break;
| 339 |
case '*': /* match any string */
| 340 |
while (p[1] == '*') p++;
| 341 |
do
| 342 |
if ( (p[1]=='?') | (p[1]==*s) &&
| 343 |
globmatch(p+1,s) )
| 344 |
return(1);
| 345 |
while (*s++);
| 346 |
return(0);
| 347 |
case '[': /* character set */
| 348 |
setmatch = (*s == *++p);
| 349 |
if (!*p)
| 350 |
return(0);
| 351 |
while (*++p != ']') {
| 352 |
if (!*p)
| 353 |
return(0);
| 354 |
if (*p == '-') {
| 355 |
setmatch += (p[-1] <= *s) & (*s <= p[1]);
| 356 |
if (!*++p)
| 357 |
break;
| 358 |
} else
| 359 |
setmatch += (*p == *s);
| 360 |
| 361 |
if (!setmatch)
| 362 |
return(0);
| 363 |
s++;
| 364 |
break;
| 365 |
case '\\': /* literal next */
| 366 |
if (!*++p)
| 367 |
return(0);
| 368 |
/* fall through */
| 369 |
default: /* normal character */
| 370 |
if (*p != *s)
| 371 |
return(0);
| 372 |
s++;
| 373 |
break;
| 374 |
| 375 |
} while (*p++);
| 376 |
return(1);
| 377 |
| 378 |
| 379 |
| 380 |
| 381 |
* Checkheader(fin,fmt,fout) returns a value of 1 if the input format
| 382 |
* matches the specification in fmt, 0 if no input format was found,
| 383 |
* and -1 if the input format does not match or there is an
| 384 |
* error reading the header. If fmt is empty, then -1 is returned
| 385 |
* if any input format is found (or there is an error), and 0 otherwise.
| 386 |
* If fmt contains any '*' or '?' characters, then checkheader
| 387 |
* does wildcard expansion and copies a matching result into fmt.
| 388 |
* Be sure that fmt is big enough to hold the match in such cases,
| 389 |
* and that it is not a static, read-only string!
| 390 |
* The input header (minus any format lines) is copied to fout
| 391 |
* if fout is not NULL.
| 392 |
| 393 |
| 394 |
int
| 395 |
checkheader(
| 396 |
FILE *fin,
| 397 |
| 398 |
FILE *fout
| 399 |
| 400 |
| 401 |
struct check cdat;
| 402 |
char *cp;
| 403 |
| 404 |
cdat.fp = fout;
| 405 |
cdat.fs[0] = '\0';
| 406 |
if (getheader(fin, mycheck, &cdat) < 0)
| 407 |
return(-1);
| 408 |
if (!cdat.fs[0])
| 409 |
return(0);
| 410 |
for (cp = fmt; *cp; cp++) /* check for globbing */
| 411 |
if ((*cp == '?') | (*cp == '*')) {
| 412 |
if (globmatch(fmt, cdat.fs)) {
| 413 |
strcpy(fmt, cdat.fs);
| 414 |
return(1);
| 415 |
} else
| 416 |
return(-1);
| 417 |
| 418 |
return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
| 419 |
