root/radiance/ray/src/common/header.c
Revision: 2.4
Committed: Sun Feb 27 10:16:45 1994 UTC (31 years, 3 months ago) by greg
Changes since 2.3: +52 -16 lines
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * header.c - routines for reading and writing information headers.
9 *
10 * 8/19/88
11 *
12 * newheader(t,fp) start new information header identified by string t
13 * isheadid(s) returns true if s is a header id line
14 * headidval(r,s) copy header identifier value in s to r
15 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
16 * isformat(s) returns true if s is of the form "FORMAT=*"
17 * formatval(r,s) copy the format value in s to r
18 * fputformat(s,fp) write "FORMAT=%s" to fp
19 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
20 * checkheader(i,p,o) check header format from i against p and copy to o
21 *
22 * To copy header from input to output, use getheader(fin, fputs, fout)
23 */
24
25 #include <stdio.h>
26 #include <ctype.h>
27
28 #define MAXLINE 512
29
30 #ifndef BSD
31 #define index strchr
32 #endif
33
34 extern char *index();
35
36 char HDRSTR[] = "#?"; /* information header magic number */
37
38 char FMTSTR[] = "FORMAT="; /* format identifier */
39
40
41 newheader(s, fp) /* identifying line of information header */
42 char *s;
43 register FILE *fp;
44 {
45 fputs(HDRSTR, fp);
46 fputs(s, fp);
47 putc('\n', fp);
48 }
49
50
51 headidval(r,s) /* get header id (return true if is id) */
52 register char *r, *s;
53 {
54 register char *cp = HDRSTR;
55
56 while (*cp) if (*cp++ != *s++) return(0);
57 if (r == NULL) return(1);
58 while (*s) *r++ = *s++;
59 *r = '\0';
60 return(1);
61 }
62
63
64 isheadid(s) /* check to see if line is header id */
65 char *s;
66 {
67 return(headidval(NULL, s));
68 }
69
70
71 printargs(ac, av, fp) /* print arguments to a file */
72 int ac;
73 char **av;
74 register FILE *fp;
75 {
76 int quote;
77
78 while (ac-- > 0) {
79 if (index(*av, ' ') != NULL) { /* quote it */
80 if (index(*av, '\'') != NULL)
81 quote = '"';
82 else
83 quote = '\'';
84 putc(quote, fp);
85 fputs(*av++, fp);
86 putc(quote, fp);
87 } else
88 fputs(*av++, fp);
89 putc(' ', fp);
90 }
91 putc('\n', fp);
92 }
93
94
95 formatval(r, s) /* get format value (return true if format) */
96 register char *r;
97 register char *s;
98 {
99 register char *cp = FMTSTR;
100
101 while (*cp) if (*cp++ != *s++) return(0);
102 while (isspace(*s)) s++;
103 if (!*s) return(0);
104 if (r == NULL) return(1);
105 while(*s) *r++ = *s++;
106 while (isspace(r[-1])) r--;
107 *r = '\0';
108 return(1);
109 }
110
111
112 isformat(s) /* is line a format line? */
113 char *s;
114 {
115 return(formatval(NULL, s));
116 }
117
118
119 fputformat(s, fp) /* put out a format value */
120 char *s;
121 FILE *fp;
122 {
123 fputs(FMTSTR, fp);
124 fputs(s, fp);
125 putc('\n', fp);
126 }
127
128
129 getheader(fp, f, p) /* get header from file */
130 FILE *fp;
131 int (*f)();
132 char *p;
133 {
134 char buf[MAXLINE];
135
136 for ( ; ; ) {
137 buf[MAXLINE-2] = '\n';
138 if (fgets(buf, MAXLINE, fp) == NULL)
139 return(-1);
140 if (buf[0] == '\n')
141 return(0);
142 #ifdef MSDOS
143 if (buf[0] == '\r' && buf[1] == '\n')
144 return(0);
145 #endif
146 if (buf[MAXLINE-2] != '\n') {
147 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
148 buf[MAXLINE-2] = '\0';
149 }
150 if (f != NULL)
151 (*f)(buf, p);
152 }
153 }
154
155
156 struct check {
157 FILE *fp;
158 char fs[64];
159 };
160
161
162 static
163 mycheck(s, cp) /* check a header line for format info. */
164 char *s;
165 register struct check *cp;
166 {
167 if (!formatval(cp->fs, s) && cp->fp != NULL)
168 fputs(s, cp->fp);
169 }
170
171
172 /*
173 * Copymatch(pat,str) checks pat for wildcards, and
174 * copies str into pat if there is a match (returning true).
175 */
176
177 #ifdef COPYMATCH
178 copymatch(pat, str)
179 char *pat, *str;
180 {
181 int docopy = 0;
182 register char *p = pat, *s = str;
183
184 do {
185 switch (*p) {
186 case '?': /* match any character */
187 if (!*s++)
188 return(0);
189 docopy++;
190 break;
191 case '*': /* match any string */
192 while (p[1] == '*') p++;
193 do
194 if ( (p[1]=='?' || p[1]==*s)
195 && copymatch(p+1,s) ) {
196 strcpy(pat, str);
197 return(1);
198 }
199 while (*s++);
200 return(0);
201 case '\\': /* literal next */
202 p++;
203 /* fall through */
204 default: /* normal character */
205 if (*p != *s)
206 return(0);
207 s++;
208 break;
209 }
210 } while (*p++);
211 if (docopy)
212 strcpy(pat, str);
213 return(1);
214 }
215 #else
216 #define copymatch(pat, s) (!strcmp(pat, s))
217 #endif
218
219
220 /*
221 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
222 * matches the specification in fmt, 0 if no input format was found,
223 * and -1 if the input format does not match or there is an
224 * error reading the header. If fmt is empty, then -1 is returned
225 * if any input format is found (or there is an error), and 0 otherwise.
226 * If fmt contains any '*' or '?' characters, then checkheader
227 * does wildcard expansion and copies a matching result into fmt.
228 * Be sure that fmt is big enough to hold the match in such cases!
229 * The input header (minus any format lines) is copied to fout
230 * if fout is not NULL.
231 */
232
233 checkheader(fin, fmt, fout)
234 FILE *fin;
235 char *fmt;
236 FILE *fout;
237 {
238 struct check cdat;
239
240 cdat.fp = fout;
241 cdat.fs[0] = '\0';
242 if (getheader(fin, mycheck, &cdat) < 0)
243 return(-1);
244 if (cdat.fs[0] != '\0')
245 return(copymatch(fmt, cdat.fs) ? 1 : -1);
246 return(0);
247 }
