1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: header.c,v 2.28 2012/08/09 23:15:38 greg Exp $"; |
3 |
#endif |
4 |
5 |
* header.c - routines for reading and writing information headers. |
6 |
7 |
* Externals declared in resolu.h |
8 |
9 |
* newheader(t,fp) start new information header identified by string t |
10 |
* headidval(r,s) copy header identifier value in s to r |
11 |
* dateval(t,s) get capture date value as UTC |
12 |
* gmtval(t,s) get GMT as UTC |
13 |
* fputdate(t,fp) put out the given UTC |
14 |
* fputnow(fp) put out the current date and time |
15 |
* printargs(ac,av,fp) print an argument list to fp, followed by '\n' |
16 |
* formatval(r,s) copy the format value in s to r |
17 |
* fputformat(s,fp) write "FORMAT=%s" to fp |
18 |
* getheader(fp,f,p) read header from fp, calling f(s,p) on each line |
19 |
* globmatch(pat, str) check for glob match of str against pat |
20 |
* checkheader(i,p,o) check header format from i against p and copy to o |
21 |
22 |
* To copy header from input to output, use getheader(fin, fputs, fout) |
23 |
24 |
25 |
#include "copyright.h" |
26 |
27 |
#include <ctype.h> |
28 |
29 |
#include "rtio.h" |
30 |
#include "resolu.h" |
31 |
32 |
#define MAXLINE 2048 |
33 |
34 |
extern time_t timegm(struct tm *tm); |
35 |
36 |
const char HDRSTR[] = "#?"; /* information header magic number */ |
37 |
38 |
const char FMTSTR[] = "FORMAT="; /* format identifier */ |
39 |
40 |
const char TMSTR[] = "CAPDATE="; /* capture date identifier */ |
41 |
const char GMTSTR[] = "GMT="; /* GMT identifier */ |
42 |
43 |
static gethfunc mycheck; |
44 |
45 |
46 |
void |
47 |
newheader( /* identifying line of information header */ |
48 |
char *s, |
49 |
FILE *fp |
50 |
51 |
52 |
fputs(HDRSTR, fp); |
53 |
fputs(s, fp); |
54 |
putc('\n', fp); |
55 |
56 |
57 |
58 |
int |
59 |
headidval( /* get header id (return true if is id) */ |
60 |
char *r, |
61 |
char *s |
62 |
63 |
64 |
const char *cp = HDRSTR; |
65 |
66 |
while (*cp) if (*cp++ != *s++) return(0); |
67 |
if (r == NULL) return(1); |
68 |
while (*s && !isspace(*s)) *r++ = *s++; |
69 |
*r = '\0'; |
70 |
return(1); |
71 |
72 |
73 |
74 |
int |
75 |
dateval( /* convert capture date line to UTC */ |
76 |
time_t *tloc, |
77 |
char *s |
78 |
79 |
80 |
struct tm tms; |
81 |
const char *cp = TMSTR; |
82 |
83 |
84 |
while (isspace(*s)) s++; |
85 |
if (!*s) return(0); |
86 |
if (sscanf(s, "%d:%d:%d %d:%d:%d", |
87 |
&tms.tm_year, &tms.tm_mon, &tms.tm_mday, |
88 |
&tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6) |
89 |
return(0); |
90 |
if (tloc == NULL) |
91 |
return(1); |
92 |
tms.tm_mon--; |
93 |
tms.tm_year -= 1900; |
94 |
tms.tm_isdst = -1; /* ask mktime() to figure out DST */ |
95 |
*tloc = mktime(&tms); |
96 |
return(1); |
97 |
98 |
99 |
100 |
int |
101 |
gmtval( /* convert GMT date line to UTC */ |
102 |
time_t *tloc, |
103 |
char *s |
104 |
105 |
106 |
struct tm tms; |
107 |
const char *cp = GMTSTR; |
108 |
109 |
110 |
111 |
112 |
113 |
114 |
115 |
return(0); |
116 |
if (tloc == NULL) |
117 |
return(1); |
118 |
tms.tm_mon--; |
119 |
120 |
*tloc = timegm(&tms); |
121 |
return(1); |
122 |
123 |
124 |
125 |
void |
126 |
fputdate( /* write out the given time value (local & GMT) */ |
127 |
time_t tv, |
128 |
FILE *fp |
129 |
130 |
131 |
struct tm *tms; |
132 |
133 |
tms = localtime(&tv); |
134 |
if (tms != NULL) |
135 |
fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR, |
136 |
tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday, |
137 |
tms->tm_hour, tms->tm_min, tms->tm_sec); |
138 |
tms = gmtime(&tv); |
139 |
if (tms != NULL) |
140 |
fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", GMTSTR, |
141 |
142 |
143 |
144 |
145 |
146 |
void |
147 |
fputnow( /* write out the current time */ |
148 |
FILE *fp |
149 |
150 |
151 |
time_t tv; |
152 |
time(&tv); |
153 |
fputdate(tv, fp); |
154 |
155 |
156 |
157 |
void |
158 |
printargs( /* print arguments to a file */ |
159 |
int ac, |
160 |
char **av, |
161 |
FILE *fp |
162 |
163 |
164 |
while (ac-- > 0) { |
165 |
fputword(*av++, fp); |
166 |
fputc(ac ? ' ' : '\n', fp); |
167 |
168 |
169 |
170 |
171 |
int |
172 |
formatval( /* get format value (return true if format) */ |
173 |
char *r, |
174 |
char *s |
175 |
176 |
177 |
const char *cp = FMTSTR; |
178 |
179 |
180 |
181 |
182 |
183 |
do |
184 |
*r++ = *s++; |
185 |
while (*s && !isspace(*s)); |
186 |
*r = '\0'; |
187 |
return(1); |
188 |
189 |
190 |
191 |
void |
192 |
fputformat( /* put out a format value */ |
193 |
char *s, |
194 |
FILE *fp |
195 |
196 |
197 |
fputs(FMTSTR, fp); |
198 |
fputs(s, fp); |
199 |
putc('\n', fp); |
200 |
201 |
202 |
203 |
int |
204 |
getheader( /* get header from file */ |
205 |
FILE *fp, |
206 |
gethfunc *f, |
207 |
void *p |
208 |
209 |
210 |
char buf[MAXLINE]; |
211 |
212 |
for ( ; ; ) { |
213 |
buf[MAXLINE-2] = '\n'; |
214 |
if (fgets(buf, MAXLINE, fp) == NULL) |
215 |
return(-1); |
216 |
if (buf[buf[0]=='\r'] == '\n') |
217 |
return(0); |
218 |
if (buf[MAXLINE-2] != '\n') { |
219 |
ungetc(buf[MAXLINE-2], fp); /* prevent false end */ |
220 |
buf[MAXLINE-2] = '\0'; |
221 |
222 |
if (f != NULL && (*f)(buf, p) < 0) |
223 |
return(-1); |
224 |
225 |
226 |
227 |
228 |
struct check { |
229 |
FILE *fp; |
230 |
char fs[64]; |
231 |
232 |
233 |
234 |
static int |
235 |
mycheck( /* check a header line for format info. */ |
236 |
char *s, |
237 |
void *cp |
238 |
239 |
240 |
if (!formatval(((struct check*)cp)->fs, s) |
241 |
&& ((struct check*)cp)->fp != NULL) { |
242 |
fputs(s, ((struct check*)cp)->fp); |
243 |
244 |
return(0); |
245 |
246 |
247 |
248 |
int |
249 |
globmatch( /* check for match of s against pattern p */ |
250 |
char *p, |
251 |
char *s |
252 |
253 |
254 |
int setmatch; |
255 |
256 |
do { |
257 |
switch (*p) { |
258 |
case '?': /* match any character */ |
259 |
if (!*s++) |
260 |
return(0); |
261 |
break; |
262 |
case '*': /* match any string */ |
263 |
while (p[1] == '*') p++; |
264 |
do |
265 |
if ( (p[1]=='?') | (p[1]==*s) && |
266 |
globmatch(p+1,s) ) |
267 |
return(1); |
268 |
while (*s++); |
269 |
return(0); |
270 |
case '[': /* character set */ |
271 |
setmatch = *s == *++p; |
272 |
if (!*p) |
273 |
return(0); |
274 |
while (*++p != ']') { |
275 |
if (!*p) |
276 |
return(0); |
277 |
if (*p == '-') { |
278 |
setmatch += (p[-1] <= *s && *s <= p[1]); |
279 |
if (!*++p) |
280 |
break; |
281 |
} else |
282 |
setmatch += (*p == *s); |
283 |
284 |
if (!setmatch) |
285 |
return(0); |
286 |
s++; |
287 |
break; |
288 |
case '\\': /* literal next */ |
289 |
p++; |
290 |
/* fall through */ |
291 |
default: /* normal character */ |
292 |
if (*p != *s) |
293 |
return(0); |
294 |
s++; |
295 |
break; |
296 |
297 |
} while (*p++); |
298 |
return(1); |
299 |
300 |
301 |
302 |
303 |
* Checkheader(fin,fmt,fout) returns a value of 1 if the input format |
304 |
* matches the specification in fmt, 0 if no input format was found, |
305 |
* and -1 if the input format does not match or there is an |
306 |
* error reading the header. If fmt is empty, then -1 is returned |
307 |
* if any input format is found (or there is an error), and 0 otherwise. |
308 |
* If fmt contains any '*' or '?' characters, then checkheader |
309 |
* does wildcard expansion and copies a matching result into fmt. |
310 |
* Be sure that fmt is big enough to hold the match in such cases, |
311 |
* and that it is not a static, read-only string! |
312 |
* The input header (minus any format lines) is copied to fout |
313 |
* if fout is not NULL. |
314 |
315 |
316 |
int |
317 |
checkheader( |
318 |
FILE *fin, |
319 |
char *fmt, |
320 |
FILE *fout |
321 |
322 |
323 |
struct check cdat; |
324 |
char *cp; |
325 |
326 |
cdat.fp = fout; |
327 |
cdat.fs[0] = '\0'; |
328 |
if (getheader(fin, mycheck, &cdat) < 0) |
329 |
return(-1); |
330 |
if (!cdat.fs[0]) |
331 |
return(0); |
332 |
for (cp = fmt; *cp; cp++) /* check for globbing */ |
333 |
if ((*cp == '?') | (*cp == '*')) { |
334 |
if (globmatch(fmt, cdat.fs)) { |
335 |
strcpy(fmt, cdat.fs); |
336 |
return(1); |
337 |
} else |
338 |
return(-1); |
339 |
340 |
return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */ |
341 |
